- DRAW??
- brushless setup for Gillows Spitfire
- motors for greatplanes DC-3 ????
- CD ROM MOTORS-WHERE $$
- FMA Super 20 ESC cutting motor too early?
- PLANE FOR AXI 2212/26
- 380 Vs 400 motors
- Spinner for elec ???
- E-Flite Park 370 & GWS Corsair - what prop?
- Setup Question??
- Where can I find these connectors?
- Kokam 1500 3S for park 400 geared?
- AXI 2212/34 ok with Jeti 8?
- need motor picture help hole location
- AILERON / RECEIVER ISSUES
- Feigao motors
- E-Flite 400 Brushless
- Caused my own prob this time. Broken crank shaft.
- Motor Windings?
- power curve
- CORRECT SET UP..?
- Park flyer pusher props. Is there such an animal?
- Electric newbie need help badly.
- battery for Slowstick
- Typhoon 15-12 brushless motor
- HACKER E3-37..!
- HACKER E3-37..!
- GWS dual IPS drive
- ESC cut-off
- ESC and Lipolys
- Current Draw In Flight?
- brushless motor question about torque
- Efficiency ratings
- Governor mode on CC-10 - a myth?
- stuka conversion
- Slow Stick help!?!?
- Himaxx 2812-1080 brushless motor..
- Great Planes (Chilipepper) 4300
- Really ticked with CC 10 ESC
- Water breakin-retiming 400 motors...
- graupner folding props...
- Kyosho Endoplasma and Gearboxes
- Twinstar electric help me please
- 9x5 hd prop/...
- NEED HELP ON HOOKING UP BRUSHLESS????
- Kontronic Motors and ECU
- slow stick Wire Gauges!!!PLEASE HELP!
- JST CONNECTOR
- E-Flite - AXI MOUNTING
- AXI 2212/26..!
- GWS Pico Stick engine upgrade?
- E-Starter video can't post Help PLS
- Cobalt or Brushless For Global Cub?
- Axi 2808 question
- axi glitching problems!
- speed 300 motor
- GWS Slow Stick Prop Question
- Axi 2204/54 Current Draw / Battery End State?
- help a newbie with ESC/safety switch?
- school science project help
- Scratch built twin
- Electric 1/7th scale p38, need your expertise
- What prop to use on Gee Bee electric
- need connectors for himax motors
- BRUSHLESS MOTORS-Whats good-Whats pure junk
- [ESC] Pixie failure.
- which axi for ultrafly pc9
- Speed controller for My smoke pump?
- Himaxx brushless spare parts
- Twin Electric Planes Help!!
- brushless motor/esc setup..please help..
- Fried ESC ?
- Eflite controllers lipo capable?
- HiMax Outrunner ?
- Prop OK?
- PKZ J-3 Cub Prop ?
- e-flight 1360 outrunner what prop
- what is a good motor for a tensor?
- PUSHER PROP? REVERSING A MOTOR?
- speed 400 Can motors..please help..
- Please enlighten me.
- Need help, Speed control and motor problems
- propsaver for AXI ?
- speed control problem?
- how many oz of thrust does a geared hacker B 20 15L make?
- ep yak 55 3d controller
- Jinxed TigerMoth 400 ??
- tech details re: prop size vs. gearing
- MOTOR ANGLE ISSUES
- Prop question
- Larger Hacker!
- New brushless setup and interference????
- brushless external rotor HELP!
- axi 2208/34 4 cell ok?
- What is a good direct drive motor for GWS planes?
- Newbie Motor Question
- Lil'Roughneck - what motor/prop?
- Brushless for 15 oz AUW?
- E-Flite 400-4200kv VS Himax 2025-4200
- twins
- Web cams and cameras
- HELP - Will motor work on conversion?
- How Hot is Hot?
- Crystal's
- Brushless motor jumps at startup
- Which Outrunner Motor??
- wHICH aXI
- programming cc25 esc for "current limiting"
- MP Jet motor soldering config
- EFlite Motor Questions
- What prop on Himaxx brushless
- under water motor break in....
- Park 370 1360kv outrunner variables for Motocalc
- brushless motor equivilencies
- Question: Speed controller for Aerobird Extreme motor.
- Good brushless motor for the Ultrafly Hawk?
- New and in the dark
- slow stick set up
- Speed controller for Aerobird Extreme motor.
- hacjer 30m or 28m
- Razor Motor Question
- Hacker B20 parts?
- Any Experience with Lehner 1515 Motor??
- Capacitors on brushless motors?
- Typhoon foamie
- Strong brushless for KADET ARF?
- axi motors or twister motors?
- Great planes 10 amp esc
- Electrifly c-50 esc and suprestar ep esc Questions
- Charging Lipos and How long does it take?
- axi or himax?
- fiberglass lipos
- CC 35 amp ESC programing
- stryker brushless with combat module
- Ikarus Brushless Motor/Speedcontrol
- thermal cut out on Jeti controller?
- Mini Funtana / Brushless
- motor kv verses no load rpm
- Hobbico Aerocruiser replacement motor
- programming cc25 exc for himax2812-0850
- Phoenix 25 won't go into programming mode
- Wattage Electronic Speed Control
- HELP Finding a Thread on GWS FORWARD running with gearbox
- Hard drive brushless motor
- Plettenberg motor?
- Zagi Power plant
- Castle Creations Tech Support, Excellent!!!
- GWS 300 Motors
- mini funtana ep
- Brushless Speed Controls
- Cheap-good-brushless for GWS corsair
- power recommendations for ultimate
- easy way to get off gears on motor shaft...
- brushless hook up
- Hardware for camera turret
- motor choice: himax 2812-0850 or 2015-4100
- AXI motor for Playboy?
- Need help with Phoenix 45 speed controller
- Typhoon Micro6 & CC Phx10 problem
- I would like to know the best esc for the slow stick with the bb 400 motor and a 7.4v battery lithBa
- Best ESC For Slow Stick with the BB 400 motor and 7.4v lithium battery (Hurry!!! Christmas!!!)
- Futaba reciever with JR crystal?
- How do I find free running rpm
- CAUGHT ON FIRE!!!!!
- axi bearing noise
- ESC Pixie-20B and helico Corona
- PJS 1200
- Tiger Moth on/off switch
- Upgraded Firebird Commander
- Will Loctite hold a slip fit pinion gear?
- Hacker B20-18L Phoenix 10 in Tribute?
- Question on LiPo vs. NiMh applications
- ???Jeti speed controller
- Using a Whattmeter
- What´s the best prop for an Axi 2208/34
- Astro Cobalt Geared 40
- MOTOR CAN ROTATING PROBLEM...
- question on electric motor physics
- MOTOR FAILURE HELP
- HiMax Motor Surging - Help!
- Himax 2025 w/gear drive on a ALFA warbird!
- Whats the ratio?
- Strange project, need some help
- doing a conversion
- Question about GWS speed control
- Park 370 Outrunner
- how to choose gearing
- Is a Schottky diode needed
- Speed Controller
- Prop Test - 2208/34 CCPhoenix10
- Motor Need to Be Replaced??
- How many amps????????????
- Best, Price/Performance setup for GWS zero? want to go brushless + lipo
- Himax HC2808-1160 wont start??
- Speed controller and motor timing.
- Motor Suggestions for Goldberg Shock 3D
- E-Flite 400 question for a GWS Warbird
- New Horizon Hobby stuff!!!
- Speed controller for Robbe EF 76-II motor
- PROP ADAPTER HELP ?
- Kyosho Spree / Motor / Diodes and Caps
- PJS 1500 performance ?
- Bench Testing Electrics / Tools and Questions
- Question Re: Motor Testing / Tools
- Bench Testing Electric Motors - Questions and Tools
- Help with motor
- choosing motors, theory vs practice
- Snap ring?
- Hacker motor question
- AXI TROUBLES!!
- Hard timing, Soft timing, Break on/off
- ESC & brushless motor don't spin
- Brushless set up problems
- stator rings on can motors
- "Align" Brushless motors
- Going Brushless..Need help
- heatsink for 480 gws esc
- superstar ep general electric motor questions
- My first plane setup---see any problems?
- astro 15 time
- CL 415
- Dumas Bearcat motor
- Himax 2025 vs 2015 motors
- Nemesis Blue brushless motors.
- Prop/gearbox setup for eflite 4200kv motor
- TWISTER BRUSHLESS motors
- MotoCalc
- Setup for new plane design???
- Which electric motor for BB Playboy?
- 2 speed 400 motors brushed
- Reading Amps
- Brushed Motor Suggestions
- General question
- Best brushless motors for GWS A-10 warthog?
- E-flight 30 amp with lipo?
- Johnson DCM-189 Motor question
- Motor very "jerky" on startup
- duration mutiplex cargo plane
- brushless motor for 18 oz plane
- Getting a pinion gear on a Himaxx motor
- Plettenberg Motors
- Stator Theory 101
- Kavan Albatros D.V.
- What ESC to use for 3C Lipo and Speed 400?
- Hacker B40 11S?
- 9 Hours
- Motor Theory 101
