- Help moving to Li-Po power?
- servo problems
- Jeti JES 110 Programing Help me
- Go Brushless.com
- AXI to Jeti Phasor motor comparision
- Jeti Advance Controlers - good for Lipo?
- Phonenix 45 Settings
- Estimating Output Power??
- different lipo cuttoff with different pixie's...why?
- which will be better?
- standard servos on the C-10
- himaxx HOW HOt!!
- motor for wattage extra 330l
- electric motor info
- 1 quick question
- cheap can motors
- Brushless Motor Prop Recommendation - its a long story
- Matching motors for a twin...
- Really need help on brushless setup
- Nontraditional EP motors
- sky scooter gearbox ?
- PJS 550E???
- What are the benefits of a brushless motor?
- Help windy crash caused problems
- A few good brushless questions
- 14x4 L and R hand drive props??
- Motor Mania
- How many guys on here are winding your own motors???
- Adding series batteries and flight time?
- How many amp will this draw
- Brushless for Formosa
- Epoxy on car
- Brushless v Brushes
- CC Phoenix 45 stops after Full Throttle
- GWS speed control question
- Installing a pinion on Himaxx motor shaft
- Still having big problems with brushless setup
- Order of connectors on Cirrus receiver
- CC25 and Aveox 27/13/4 help
- 50 AMP SHUNT, 50MV=50A. Can I use this?
- Are there any ESC with BEC for Lipos
- GWS vs. APC??
- BV-208
- Jeti 30/3 max Watts
- Controler Problem
- Multimotored brushless issues
- Brushless motor confusion
- New Gearbox spins prop Backwards!
- Throttle cut off at 50%
- Lost strut on e-starter
- Performance Evaluation Wanted
- GWS Tiger Moth motor uograde?
- IPS to EPS
- Need Himark / Cermark 480 (400 long can) motor information
- Brushless Motor Recommendation for Sig Rascal 49"
- AXI 4120-18 Real World RPMS
- Need help to take off gear
- HiMaxx 4 GWS
- ESC advise needed....
- Aveox motor question????
- EQUIVALENT MOTOR
- Max Safe RPM For GWS EDF Fans
- Improving the Great Planes DC-3
- Please help an elcetric newbie
- GWS A OR D on a mini ifo?
- speed controlers
- OLD receiver with new ESC??
- motor breakin
- PHX-Link Interface - The good and the bad
- GWS 350 question
- Mid wing engine mount on flying wing
- electric engines for UAV
- less power from 400 motor, 30 esc, 10 cell combo
- Anyone know anything about the Watt-Age Super 400 Cobalt Motor?
- using higher amp esc? problem or not?
- Prop for AXI 2212-26
- Internal Motor Support for Electric Motors
- cutoff voltage?
- What does 27 turn, single wind motor mean and will two of them get me off the ground
- ESC and receiver combo
- PROBLEM WITH GEAR DRIVE!
- Aveox A-15 with 3s Lipos?
- Watt Prop is Best
- What motor is this
- AXI2820 help
- Question about dean's Micro connectors
- Power loss or gain with supplied wire (Newbie Question)
- ESC for Li Pol batteries??
- Wattage Extra 330L Crash
- Hot Climate, Brushless Motors, & LiPo Batteries
- Expert Advice Required
- cells for speed 400 6v 5x4 prop
- Electric motor brush question
- Help, reading amps with clampmeter
- A Halfmoon129 Premire
- advice on motor
- Sparking motor
- GWS 350D parts
- Replacement motor for EPS-350c
- Hearing loss.
- Zagi 20 Speed Control Receiver Hookup Soldering Order
- Atomic force motor
- Himax 2015-4100/5400 or 2025-????
- # of poles on a motor???
- Himax 2015-4100
- Kalt Whisper Heli Drive Gear
- Can a C-10 support 2 standard servos?
- Wattage Extra 330L What Motor?
- GWS 350C-DS with Aveox A-15?
- Brushless Speed Controllers
- Inner Gear Drive Cearboxes?
- advice please
- electric motor help
- Help-unlabeled motor leads
- ESC question
- Slow Stick Motor mount
- GWS flight packs
- What ratio gearbox?
- 020 Astro prop?
- Brushless Recommendation
- Choice of Speed Controller - cut out?
- AeroCruiser Speed Control Problem
- Hacker B50-13S +6.7:1 versus AXI 2820/10
- GWS EDP 50XC Life Span?
- ESC Set up
- What do I need......
- Proper ESC for LI-POLYs
- can anyone tell me ....
- What's up with the BERG4 DSP for JR
- Phoenix 25 settings for Himax 2015
- Prop Question
- Checking amp draw help
- Question for NMPhi767
- 3D slow stick power system?
- Crazy 8 Wattage UK Help
- How hot is safe for brushless motor question
- c-20 question
- Razor 2500 motor questions
- Castle Service
- Cheap Brushless Motors
- E-Starter & its power system,ahhh!
- What motor system should I choose
- motor setup
- 3 cell Lipoly+Pheneox 25=what motor?????
- mega 22/20/2 geared 2:1
- Help calculating remaining flight time with LiPo's
- How do You guys calculate Watts ratio to weight
- Motor replacement
- Brushless Motor questions.
- big 6 electric motored bomber
- 18 lb. twin EDF, what motors???????
- Electric Motor ?'s
- Wire Gauge on AXI 2212 series?
- Lubrication for brushed motors?
- What Connectors for Cobalt 400?
- Hi-current connector choice
- Pheonix 25 set up problem
- a little help on selecting the optimal motor
- J250/DM189????
- Jeti 70-3p brushless controller
- Low motor speed
- thrust!?
- Anyone see this site?
- CD motor links
- setup question
- Brushless motors at radio shack
- What are these???
- ESC/BEC switch leaks power?
- Speed 400 Needs Help....!
- Radioshack brushless fan
- Best AXI for a Dandy Sport?
- gws 350 cs replacement motor!?
- Mega Motor Help
- Beneifits/detriments of additional winds on AXI
- Looks like good deals.
- gearbox
- Looking for forward/ reverse timed speed 400's
- Explain gear ratios please
- Analyzing the failure of GWS 350
- What gear for a 3-4 pound plane?
- brushless battery question
- What motor do I need?
- More power without going brushless... Possible?
- prop for 280 gear box
- phenoix 10A Issue
- Prop pros / cons help needed.
- How does a brushless motor work?
- GWS BB-B
- Phoenix 25 Problems
- What is wrong with my new Himax Brushless????
- Squeaky 400
- GWS "A" Motor (but what type?)
- 5-100x variable fast forward 5-100x variable fast forward dvd player
- pheonix 10 esc problem
- Anyone tried GWS Moth with the EPS350c?
- Motor running time
- Cutoff voltage for Lithium ESC
- Kyosho Spree: Seeking recommendation for brushless/gearless motor
- contra-rotating twin elect. 1-spd.control
- mega 16/15/2 mini 480 fan???
- gws esp 100c recomendations?
- 3DX, wanting to go brushless out runner?
- Brushless motor from a CD drive
- Using larger motor and run time is longer??
- What battery?
- battery seires question???
- esc ?'s, specifically gws
- What are gear Drives (gear Boxes) for?
- EP Expectation Questions
- himax 2015-2800
- I need Mr. Kirsch's help!!!!!!
- Contra-Rotating Props
- Hobby-Lobby Motor specifications
- Himax Motor Question
- New Projetti
- Need help with E-Starter power stuff!!!!!!!
- GARY WRIGHTS ENDOPLASMA SET UP
- Himax + Phoenix 10 ???
- Gas to electric converson HELP!
- Hacker C-40/Phoenix 35 difficult to throttle UP
- GWS ME 109 brushless Recomendation
- "speed" of motors and prop sizes
- Astro 05 2T
- GWS corsair 350 to 400 change??
- I have a JR8301 that will not develop full power
- CD rom motor comparision
- 9.6V on an Electrifly S280BB motor?
- GWS gearbox parts (where to buy)
- HiMax HA2015-4100
- How to Gear.....
- thrust question
- JST 1000 and Pigi
- Folding Prop - Parts selection
- AXI That Chatters
- Too many choices--need advice.
- Slow Stick Radio Equipment
- smoked 3 gws 350 ds?
- ESC and Lipos
- Motor sputters?
- using two brushless motors
- Herr 48"Piper w/ floats
- Jeti 18 -3 cutting off at 9.5 volts
- Another AXI question for the gurus
- Brushless Motors for GWS Drive A Gearbox?
- BRUSHED MOTORS
- Question about CASTLE CREATIONS ESC/BEC
- Prop Expert?
- AXI Motors PROS AND CONS?
- Jeti 45/3
- Down-right thrust mod on Slow Stick
