- ESC ratings for Dummies!
- Help on "High Torque" Motor Identification
- axi5330 jeti 77 batt wiring question pics added!
- Motor Equivalent
- Rimfire 42-50-800 substitute?
- Scorpio 12amp lipo controller manual help
- Super Tigre Electric Power Systems
- Wiring turnigy plush esc with hitec receiver - UPDATE: fixed
- Puffy Lipo
- Cyclone Brushless motor
- funky servos
- Cheap ESC replacement for Typhoon 2 3D
- ESC related
- Jetti ESC for Lipo
- programming
- Whats wrong with my ESC!!!????
- 45mm heat sink for KB45-17XL 700kv motor
- Turnigy Plush 80 ESC
- Motor suggestion needed Mini Ultra Stick
- HL/Starmax Panther ESC Problem?
- castle creation bec and greatplanes parallel connector
- esc/ motor
- Rimfire vs AXI for Great Planes Reactor
- Dualsky XM4250-CA6
- pz 480 park motor
- Receiver glitch at 9 amps
- Motor/ESC/Battery/Prop - I need a tutorial !
- motor chatters when throttle is advanced
- two motors with two esc's question
- Motor angle question?
- Magnet glue??
- E-Flite Power 110 w/ Phoenix 85HV
- trouble shooting bec
- novak hv maxx propblem
- PZ FW repower questions??
- e-flite 370 brushless motor problems
- snap rings for 1/8 dia shaft AXI motors
- Cleaning mud from an outrunner
- Need snap ring for 22 series AXI motor
- 6s lipos on Astro model 210 brushed speed controller.
- lipo v-level
- running a 3 wire brushless motor in a 12v system
- Whats bigger than the E-Flight 450 besides the 480?
- New F16 Engine
- Folding prop vs. normal prop
- Help with Turnigy "Sentry" ESC
- Is there any advantage to going with a higher amp ESC than you need
- what size prop
- emax 2215/20 peeping
- esc help motor trying to turn both ways
- Lost TMM A12 manual
- Brushed motor upgrade for aerobird challenger
- What size?
- 750-1000W brushless suppliers
- testing the outputs to the motor
- Breaking of Radian Prop Blades
- Raiden Motor Question - please help
- Direct drive vs geared prop
- Older ESC's with 2.4 ghz
- can a brushed moter/esc use lipo
- Brand New-PULSO X series Brushless Motor
- Brushless connectors?
- cROSS REFERENCE OF ELECTRIC MTRS
- Electric ducted fan
- What does KV rating mean on brushless motors?
- What electric motor to use on scratch build?
- Brushed S-90 ESC HELP
- burnt out motor
- TSUNAMI 72A ESC PROBLEM
- CC ESCs, can they truly handle the # of LiPos they say they can?
- possible
- disable the Bec. for big twins ep?
- Help please.
- High Voltage ESC's
- ESC Forward/Reverse
- Eflite extra 260 power problem?
- Odd Motor/ESC Issue
- ESC... doesnt have a manual how to program
- Nippy 0808-98 on graupner hydro boat/plane
- ESC/Motor interference with 401 Gyro
- Castle treated me very well!
- NEED YOUR ADVISE
- robbe ro power Lipo batteries !!
- het f-20 ducted fan setup
- help choosing motor
- Best price on a 40amp esc?
- What is the problem here!!
- E-flite park 480 problem
- how much pressure around a standard 280 brushed motor?
- HZ Super Cub burned out ESC????
- Replace the Leads on a Brushless Motor
- Slow stick bent prop shaft?
- Hooking up 2 motors
- Ikarus Bleriot III gearbox problem
- Brushed car motors for airplane use?
- Aeolianmotor 2825- KV5200 Brushless Motor Question
- brushed esc and LiPo odd result
- HELP replacing esc on art tech typhoon heli
- reattaching reciever lead to mystery 60 amp esc
- Guillows 28" Wing Span Sopwith Camel....
- Hobbywing/Turnigy ESC glitching
- e-starter from gws
- Problems with TP2409-12T
- Brushless Motor Help
- more speed!
- Which to use? 370 or 400???
- ESC just sputters...
- GP Rimfire motors?
- twin motor help
- Ewatt brushless motor advice
- Troubleshooting T-34 "pulsing" sound at full throttle
- Choose the right EDF system
- Elf hobby outrunner with strange alarm.
- Motor, Speed control and other questions
- motor mounts for flying wings
- Ultrafly F/18/10 substitute
- ESC power losses.
- motor makes grinding sound w/heavy load
- Which B/L motor for Sig Kadet EP
- help! brushless motor
- What propeller should I use???
- how to test electric plane components?
- Possible to re-program ESC?
- KV question... i just dont get it.
- HELP!! AXI prop shaft reversal question
- scorpion S-3014-22 comp series.
- EDF Question (Kyosho FV1000) Conversion
- motor combo re: 30 oz. airplane
- Brushless Motor Durability
- Motor/prop combo for 1.5 oz AEA Silver Dart?
- No "power" new e Heli
- can this brushless be direct drive?
- PJS 3D 550 Prop Shaft Reversal
- need help with controller program card
- eflight beaver
- calibration help!
- KV Rating??
- Will receiver have power after motor stops?
- Brushless Motor Question
- LV setting on esc?
- Jeti-Hacker speed control
- brushless hangs
- Speed 480 To Brushless Inrunner
- EMAX BL2826-850KV Any info?
- cleaning a b-less outrunner?
- copterx 430L or XL
- Does LIPOs Batteries needs to Be Broken In?
- Reverse a Brushless???
- Damaged motor...is this normal ???
- Prop size?
- Mud Drown Scorpion Motor!!
- Li Po tests
- BEC vs REC pack??
- motor replacement comparison
- LI Po Voltage cut off
- Hacker to ESC connections
- have an old outrunner engine. It is a MT-W28
- Which is more efficient?
- AXI 2820/10 needs a new home, or else...
- CL-415 Canadair 80'' Electric
- Rimfire Motor and ESC Question
- Modern equivalent
- dumb question
- electric equvalent of 50cc Gas engine
- receiver too close to esc?
- GWS Gearbox, how to mount ?
- IS IT SUPPOSED TO BE MAKING THAT SOUND?
- Motor thrust estimation
- Reversing motor shafts
- inrunner or out runner
- Kv and prop size relationship help
- Wire Gauge Question?
- Mega 16/15/4 Turnigy Equivalent
- X-Era motors
- LiPo's and ESC's for brushed motors?
- is it possible for a receiver to have 1broken channel?
- CM PRO DISCUS CS HELP
- Do you use securing collar with axi
- QUESTIONS!
- Please take a look!
- Need help with ESC?
- What plane for an RC Smart RC1050 brushless motor?
- Max Voltage for a Neu Motor
- Kv question
- Hyperion E-Meter Cord
- hobby-wing pentium 30A esc
- KMS 30A esc question
- Pressing out shaft for changing ends
- Hot new item
- AXI 4120/18 - Power capability
- Speed Controllers
- how to install 2 brushless esc with one battery?
- Astro Flite Status??!!!
- Electric motors for Don Smith B-24 Liberator
- Electric Conversion Question
- outrunner noise at full stick
- Motor - speed controller - battery - reciever
- Rimfire Efficiency
- Phoenix Ice - What's going on with Castle?
- Is this a .46 electric motor..power wise?
- Is 3amp BEC enough power
- Battery and ESC compatable with a FP-R114H Receiver?
- ESC question
- J POWER ESC'S
- E-Flite 30 A speed control questions
- Dymond 100A Esc
- how to determine prop size
- Trying to find servos for cheap
- AXI motor
- e flite 60 shaft extension
- what is wrong with my esc?
- ParkZone 480 and E-Flite 30A Pro esc questions
- Cheap high power edf setup questions
- How to wire a brushless speed control?
- E Flight 250
- BP Hobbies 4120 vx Axi 4120
- suitable esc
- Brushless motor chart
- Converion from brushed to brushless?
- best prop & motor for 2s 910 lipo
- Unidentified speed control
- Hacker B50 6S gearbox bearings
- Speed controler question
- brushless set up for b 17
- fly 11.1 v 2100Mhg
- Brushless motor
- Need help going brushless on a PZ FW-190
- Axi 2208/34 problem, or esc???
- park 480 brushless outrunner
- Orion Pilot ESC help
- Half stick no more power
- What is the best setup for my spitfire?
- 11.1V OR 14.8V?
- Jeti 40 amp controller or other?
- I found out electrics are very expensive!
- CASTLE PHOENIX-80
- Conversion Question
- ESC connection to receiver??
- Help TURNIGY 80A beeping question
- PLEASE HELP MOTOR/SPEED CONTROL PROBLEM
- What does my motor "failure" tell me?
- Help programming ESC?
- damaged Park 480 motor
- electric motor as generator?
- motor advice plz :)
- Question on brushless outrunner motors.
- Endoplasma help
- Where buy AVEOX motor?
- How do speed controllers work?
- Cooked Motors repair Post
