PDA
View Full Version : Brushed/Brushless motors, speed controls, gear drives
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Brushless motor help
  2. What is a BEC and do I need one for the below combo?
  3. the out runner motor blues
  4. Brushless pulling out
  5. Hitec Energy Sport ESC's
  6. Reversing the shaft on a turnigy 2836-1200
  7. 20" props OK with 50cc Rotomax, a Suppo 7035/8 or a 50c rimfire?
  8. How do I replace
  9. How to set up an electric motor kill switch using a Futaba 14SG
  10. Need new esc advice
  11. Need Electric Replacement for 50cc Gas Engine
  12. Hot Hot Motor!
  13. Turnigy ESC Can't hear tone
  14. turnigy 2211-1700 motor
  15. Dr Mas Thrust 3682 1700 kV ?
  16. Need help identifying ESC
  17. Bridi Aero commander airfoil?
  18. question about Blue wonder motor
  19. Need 35-40 amp brushless ESC + BEC recommendation
  20. scorpion tribunus 14-200a telemetry
  21. Help
  22. un- marked out runner motors
  23. what amp esc for this motor? pls help
  24. what amp esc for this motor? pls help
  25. Would this esc work for my rc plane
  26. Is this esc bad?
  27. Promodeler ESC HV 200A-12S
  28. Push button throttle
  29. Homemade brushless motor only making a high-pitched noise and not turning. Help!
  30. 2814 vs 2836 Electric Motor
  31. How do I connect my servo and dc brushed motor to my reciver
  32. esc compatability
  33. Wires of my brushless motor have different resistances, what can I do?
  34. eFlight Power 160 / 3-Blade Prop
  35. Phoenix Edge ESC Initial Programming
  36. Old Phoenix 125 BEC question
  37. motor vibrating uncontrollably at high throttle
  38. Looking for ESC manual
  39. Motor compatibility AR636A
  40. What brushless motors should I use for these old kits
  41. Is there motor damage with ESC short?
  42. Reversed motor???
  43. Anyone have luck with the Red Brick 125 programming?
  44. Neu 2230 p62 vario prop help
  45. ESC Wire Extension
  46. s battery and ESC
  47. Exceed RC ESC OPTO BEC
  48. Motor wires thinner than ESC wires, please HELP
  49. EFLM1315 Brushless Outrunner Motor
  50. RCM Crusader 2 electric conversion
  51. Gws Formosa help please motor
  52. FlyFIy ASW 28 2530mm/100" Fiber Glass/Balsa Electric Glider Motor & ESC?
  53. Motor source ?
  54. ESC set up question
  55. TekSumo needs more speed
  56. Skyartec brushless problem
  57. Where do I find brushless motor parts ???
  58. Hobbyking 40A ESC not responding (URGENT)
  59. Question for the Universal Mind
  60. Which one you think the better for the job; Castle 90 ESC or Cobra 100 ESC ??
  61. Here anyone use iFLY F390 20A Mini 3-4s Quadcopter ESC Speed Controller BLHeli?
  62. Which is the heat sink?
  63. Prop adapter size
  64. Prop and engines
  65. FMS 5060 300kv outrunner low watts output
  66. 50 or 60 watt ESC
  67. Questions about ESC... LVC, programing ect...
  68. which brushless motor will fit my r/c plane?
  69. HobbyKing X-Car 45a sensored ESC. What program card?
  70. Emax RS2205 are awesome!
  71. Turnigy Plush 18amp version
  72. 10c vs 20c battery for electric skateboard build
  73. decent replacement ESC
  74. Turnigy sk3 3548 reverse 700kv
  75. *CC Phoenix Edge 80HV Wrong Cell Count*
  76. What Battery for this ESC & Motor?
  77. HK Bushmaster motor substitute
  78. ZTW Beatlkes 40 AMP ESC goes to full power on loss of signal
  79. ESC Problem
  80. safe receivers
  81. HKing Bushmaster motor
  82. replacment for Hacker A-40
  83. Need Help finding High Voltage BEC options. Quality preferred
  84. prop size
  85. Motor size for 60 size spitfire
  86. Tomcat G60 Brushless
  87. rimfire 200
  88. Cobra 4120/14 710kv motor good choice for a 10Lb Kadet??
  89. electric motor resistance
  90. Turnigy SK4250-650
  91. hot motor
  92. burning up motors and esc's
  93. Looking for specs: Xtra 2826/12 outrunner motor
  94. Small brushless motors - lots out of stock??
  95. Motor beeping
  96. Brushless Motor sinusoidal voltage input
  97. CC 10Amp BEC Brownout
  98. Setup for longest flight time
  99. EDF ESC for prop plane?
  100. Hacker A50 16s V3
  101. 65cc rimfire electric motor
  102. Electric twin PBY problem
  103. Turnigy 120a hv dlux problems
  104. Rimfire 300 - Number of Windings?
  105. Brushed motor selection help
  106. ESC Arming tones sometimes faint.
  107. Wire disconnected
  108. Kv vs.Synchronous RPM
  109. Neewer ESC emitted smoke with no motor attached.
  110. New grayson hobbies megajet motor sounds like rocks in it, shuts down.
  111. which motor
  112. wondering about a drop in replacement for the Eflight 160 brushless out runner motor
  113. DYS mini esc XM20A
  114. Anybody had good luck with the larger Suppo 60 sized motors? Check out this video.
  115. brushless motor problem
  116. brushed motor diodes...
  117. Apollo 12 ESC programming ???
  118. Himax hc3516-1130 prop shaft replacement
  119. looking for 24V-48V motor with high cogging torque
  120. Converting an old kit to brushless, ESC advice please
  121. 150cc electric can u run it at full on the ground
  122. Turnigy Multistar ESC throttle curve programming issue
  123. EFLM221 Replacement?
  124. motor watt vs watt?Help
  125. esc help
  126. G Force G46 Prop adapter
  127. Side thrust of OMA-5025-375 electric motor shaft.
  128. Parkzone P51 Mustang BNF Upgrades....
  129. RotoStar ESCs any good?
  130. RC Smart 80 and 100 amp opto ESC (aircraft) - Good or Bad and who makes it?
  131. ESC's with simon k firmware questions
  132. Speed controller identification needed.
  133. fluttering servo's
  134. 480 outrunner problems???
  135. new shaft needed 3.175 X 50 mm
  136. Flyzone ESC and Futaba
  137. Reliable source for electric motor parts?
  138. Suppo 7035-8 Bearing Configuration
  139. Motor issues
  140. How to inscrease my airspeed ?
  141. 2212-6 Motor. Extra parts?
  142. Painting a brushless motor
  143. E-Flite 440 helicopter motor for use in RC plane?
  144. Which esc is best for a mini fpv quad copter
  145. Turnigy Aerodrive SK3 6374-149 questions
  146. Bad ESC or motor
  147. What SBEC does everyone like to use?
  148. Which motor?
  149. Beginner question on brushed motors
  150. Possible ESC or Motor Problems
  151. What causes brushless motors to die?
  152. Spin 99 Optra Speed control program issue
  153. Redcat Volcano EPX Pro Brushless.
  154. Brushless motor
  155. help for choosing right motor for my custom project
  156. looking for brushless motor info. please help
  157. e-f lite park 250
  158. CF 2822 PWM Throttle control
  159. Guillows Spirit Of St Louis strt motor or gearbox?
  160. Will this motor fly my plane well ?
  161. Instructions for an FMS 85 amp ESC
  162. TomCat Motors
  163. Using a nano quadcopter to build a larger scale quadcopter
  164. Brushless Outrunner Recomendation
  165. ESC problem
  166. ESC Hookup
  167. Can this ESC be used on Planes?
  168. Why would the end bell pop out?
  169. Red Bird Hummer Plane - which is the best engine to use - That I already have
  170. Turnigy CA80-80-10 Dimensions
  171. why is there a stiff spot as motor cools down
  172. Motor Stutter. ESC problem
  173. Need bearings for Cermark CEM 2814-1030
  174. NTM 35-42 1250kv prop size
  175. Brushless ESC Failsafe?
  176. E-flite carbon-z splendor-maiden flight attempt issues
  177. problem programming ESC
  178. Don Lein 190
  179. Hyperion Micro Data Logger
  180. Shaft Sizes
  181. Motor sizing
  182. Kontronik Jazz 63v Program card
  183. Atlas brush less motor looses power
  184. Tm pro esc programming
  185. Castle Talon 90 spool up settings
  186. super tiger .10 with super tiger 30A speed controller 2200 Mah battery?
  187. Propeller, number of blades, another aspect
  188. Sensei motor shaft repair and motor shaft replacement. NEED HELP AND INFO!
  189. Hacker X-70-SB -Pro and Futaba SB rx
  190. I need bullet connectors . . . please help
  191. Electric Warbird: Help with ESC Selection
  192. brushed to brushless conversion
  193. dumb question - 100A ESC with HK Vampire
  194. Help-ESC Problem
  195. quick question about lipo + brushed motor
  196. airplane motor vs rc car motor
  197. ESC Soft Start?
  198. motor shaft
  199. What is the power equivalent?
  200. eflite bl50 magnets came loose
  201. 2 blade Pusher prop for SkySurfer2000?
  202. Which 3536 Motor to Run ?
  203. Cobri gearboxs....where to buy online?
  204. Eflite Power 15 Mystery
  205. Turnigy T285A ESC Trouble
  206. Soldering Electrifly ESC and Rimfire bullet connectors, need help
  207. Timing Questions
  208. Electrifly Rimfire .32 and 13"/14" props
  209. Esc help!!!!!!!
  210. turnigy park250 brushless outrunner
  211. 540 tamiya, what ESC?
  212. Hobby People ESC problems
  213. Smoked ESC
  214. robarts retract binding
  215. What is Optical Coupling?
  216. ID help needed
  217. Bent shaft on Dr Mad thrust 90mm EDF
  218. Hurc 40 and Hurc 18 problems getting full throttle from motor
  219. First ARF build questions
  220. .46 convertion
  221. hacker
  222. Changing out motors
  223. Mystery cloud 20A ESC programming???
  224. Wanted: WattAge 370 Power Set
  225. Old Phoenix 25 esc problems
  226. Wattage ultimate biplane brushless conversion
  227. Slipping Prop Adapter
  228. Size of Motor for a Gillows Balsa model
  229. Question in regards motor and battery
  230. first ARF build, could use some advice
  231. Are These motors basically the same?
  232. Using two different AMP brushless speed controls
  233. Identify my motors?
  234. Electric motor recommendation for hob warbirds
  235. Yet another Prop Size Question
  236. Need help with choosing a brushless speed controller
  237. FMS 60amp ESC programming?
  238. what voltage to use??
  239. motor to esc extension
  240. Extending prop drive, some thoughts and maybe your ideas
  241. How do i get more clearance
  242. help identify motor
  243. What to look for to replace .15 Glow
  244. Electric Motor Performance Data
  245. ESC problem with new plane
  246. AXi 2820/18 DroidWorx motors in Fixed Wing Aircraft...
  247. Aeroworks EXTRA 260EP-3D/Park400 (A little help, please!)
  248. Throttle delay Flyzone DH Beaver
  249. inrunner motor for .25 size airplane
  250. Any info on 4 blade prop for limited ground clearence issues?
