- T6EX 2.4 linking
- About to drive me crazy!!
- FG 8 charging question
- futaba ff9 Led Mod ?
- RC Receiver/Transmitter Crystal
- 7C Tx battery alternatives?
- Hitec servos work with Futaba 7C Tx/Rx?
- Rudder to elevator coupling for knife edge flight
- FASST Receiver compatability
- Looking for charger for FP-T4L 4 Channel Remote
- Replacement battery for 9Z
- Futaba Receivers Rumors
- 9C-10C Helo Copy rudder non linear
- reciver?
- 10CAG compatible receivers
- How to Update Firmware on a Mac??
- Futaba 7CHP 72mhz glitch problem
- servo jitters
- 9C with TM-8 Fasst module
- request for next update on 12z
- 9Z
- 14mz pos offset in AFR?
- JM912 module
- Question re: R6203SB
- R6008HS Troubles
- servo setting
- Color to Color??
- 14mz w tm14 problem
- R608FS voltage?
- 12Z Battery Failsafe
- t7c 2.4 rudder help
- 8FG or 10CA
- 8FG Throttle cut
- 14MZ and Phoenix Flight Sim
- 6014 Receiver and Optic kill switch
- Change 14MZ Heli Tx from Heli operation to Plane.
- 8FG digital channels
- 12 FGA SD Card
- Any rumor about 18 MZ
- receivers and high speed servos
- S.Bus newbie, couple questions
- 8FG with an Ultra Stick
- Rotorworkz Tx Bling Sticks
- Touch screen question
- 7C display blanks out
- Futaba TM-14 Loose
- Timers
- display screen going dark
- 12FG Flaperon/Spoileron Setup
- help, need owners' manual!!!
- Futaba 8UAF CCPM Mixing Fixed!!!
- Futaba GY-240 gyro in a plane ?
- I put the music in my 14mz but when it plays everything is slow and seems froze
- 4EXA Throttle level Problem
- Intergrated 14MZ?
- 10C Channels 9 and 10
- H switch on 8U transmitter
- Mode 4 instructor, Mode 2 student
- 12z help.
- 10C Question
- R6014FS receiver and temperature
- 8FG LCD panel freaked out
- 6 volt vs 4.8 volt receiver supply
- R6108SB s.bus with esc
- 12fg display?
- Futaba 12fg and 14 channel tx
- RS6108sb RX
- Futaba radio & Hitec receivers
- Futaba 8UAF Broke Switchs
- Servo AMP draw while in motion
- Flap Switch
- Frequency ?
- Futaba 9c what recivers can i use
- T14MZ display.
- Rudder pot
- Dual Elevator servo mixes
- Futaba 14MZ Flyers Club account activation
- 2 Batteries 1 Receiver
- elevator programing
- 12z update files.
- Tx/Rx?
- Futaba FASST will not operate speed control
- R149 DP Rx/Tx compatibility
- 8fg or 10c
- 8fg or 10c
- I was doing a thrust run without
- Subtrim and differential
- Futaba 14MZ Flyers Club - account activation
- 8fg Smoke Pump Programing
- Fix a receiver?
- 7 channel FASST throttle to elevator mix? And rudder to aileron?
- Futaba Serial Bus and Powerbox
- Retract switch alarm on power on.
- 3 position switch for 14mz
- 14MZH / 14MZ differences
- ANYONE here in the USA that owns 14mz
- 14MZ RF Module not connected
- Futaba Flyers Club BB locked?
- 6 and 7 Channel RX's compatible with 12FG 2.4?
- Channel assignments
- 12FG having issues again
- 12z Tx with two 6014FS Rxs
- Futaba 2.4 Rx antenna positioning
- why does changing the tail type on a 12fg erase all model setup data.?
- v2.1 12FG locks up if System Timer used
- rcvr/servo compat.
- Futaba T9CAP programing help
- FUTABA 10CG FLAP PROGRAMMING
- Need help with T7C
- Software update affect on saved models
- 12fg Throttle Hold
- Post removed by author
- T8FG LiPo battery
- 14 mz Flap control
- Futaba 12Z and plug and play question
- 8fg
- what servo to use with my 9C on my my Edge 540 60
- 14mz Can not create process
- futaba 6008 and 6108
- R603FF vs R603FS
- 12Z momentary switch
- OFFSET??
- Battery backer question
- Limit vs Travel
- 40% plane setup
- 12FG Timer Setup Problem
- T10C updates?
- Futaba 4PKS
- 14MZ Software Update
- 7c 2.4 flaps
- 9CHP Super converted to 9capSuper
- 9CHP Futaba programming change
- 12FG update 2.1
- R6014HS
- R603FF 2.4GHz FASST
- Software Update 12z
- Futaba 12Z 2.4GHz Battery...
- 12Z Programmable Mix Questions
- S3101 Servo voltage
- Deleting conditions on 9ZWC2
- Futaba 10 cag
- using two receivers okay?
- R6106HF
- Flying Heli's with a 10 CAG - throttle question
- Single Vs Group Thanks
- 12FG: How to disable steering with gear up?
- Futaba t7 cap ,fm, part broken,lost plane
- MOVED: 12FGA or the 12Z?
- More Single Vs Group
- Disabling nosegear steering chanel once in flight with a 10C?
- Single vs Group
- help w/setup of the GY401 gyro
- 6Ex Throttle stick pot
- Failsafe and DG1/DG2 using a 12Z
- Campac reliability
- 12z (72 MHz) antenna with base?
- MOVED: 12FG Module pins
- Futaba 14MZ with 36Mhz bandwith?.
- 12Z Tx Modules
- 3PM 2.4Ghz Transmitter binding
- Elevator Servos out of sync
- Erratic Transmission Problems
- 14MZ from ASIA
- Futaba standard chargers
- Program 10CG
- Printing program set up
- R617FS quit then fixed itself??
- 8FG Trainer cord options
- Help with BNF heli
- servo wire grommets
- T 10 CAG servo rate
- Gyros with S Bus
- 8FGA RTN button
- Futaba equivalent to HiTec 82mg
- Futaba FP-T8JN
- Futaba 12FG with Spektrum module and receiver
- Futaba S9351 vs S9155
- Delta setup with the 10c
- FUTABA, please make the calibration menu accessible.
- Futaba Flyers Club Question
- S9551 and S9452 use
- Calibration of Futaba Production
- tm 7 , tm8 for t10
- 8FGA RF Off
- Should I send my 10C to Futaba for checkup & updates?
- Futaba 6 EX ..Servo direction problem????
- Governer setting on 12Z
- 10 Channel Choices
- GY520 w BLS251 or bls 254?
- futaba 10C and two servo for each ail...
- 8FG - Mixing 2 ESC's
- Lost Link with Receivers
- channel question
- Charging batt. TX:7C and 8FG
- 6014 Receiver Problem
- FUTM5549 Transmitter Extension Hook
- Mode 1 & Mode 2
- T8FGA / T8FGH / T8FG - what's the difference?
- european radio
- Transferring Airplane data from 8FG to memory card
- Odd mixing issue
- Batt connection
- Gyro recommendation
- Very strange Futaba 10C problem
- T8FG Airbrake/Flaperon setting
- Telemetry
- 14MZ update not installing
- 10c trim switch circuit board
- Can I use this setup without issues?
- receiver
- 8FG Condition renaming
- File System Error
- GY 401 Gyro
- Futaba 27 mhz module compatible with Futaba 3VC
- Need some Help Programming a Delta
- A Book 14Z for dummies
- Problem with Futaba R617FS Receiver
- Flyers Club
- Question on FPT8SGA=P
- Servo connections
- Futaba MG servo for nose wheel
- R6014HS 14-Channel Receiver
- How to set a T10CAP for 4 ailerons biplane?
- Futaba Gyro
- trainer cord 12fg to 8fg
- 8FG throttle cut problem
- sub trim
- Flap setting ?
- 7C 2.4 Display
- 7C : down trim with flaps
- 10CHG Mode Change?
- Futaba S3151 6V compatible?
- Futaba Fliers club
- Futaba 8U glitching
- 12FG Springs
- Whats the difference between the Futaba 12FG and the 12FGA?
- 8fg elevons
- 12FG dual rudder servo, high rate link issue
- 8UHP age?
- 10 Cap Failsafe
- DISCONTINUED SERVO GEARS?
- MOVED: 12z - Simple Question
- 12Z update, 1.6.0 or 1.6.1 ?
- Damaged R603FS receiver
- T8FG from Europe
- 14Mzh 4 position flaps
- 12Z Switch Replacement
- Model Data Convertor
- 14MZ AIL Differential
