- What are modes 3 and 4?
- Triple rates on 12Z?
- MOVED: Sullivan SkyWriter smoke system set up on a 9CAPS
- 9C Four aileron set up MIX questiion
- futaba 2pl
- 7CAP flaperons/air brakes
- 8UAF flap programming?
- Range Check Question
- New HI/LO receivers from Futaba?
- 9z saving freq and ppm-pcm settings
- Futaba 12Z gimbal modification
- servo arm selection
- T6XA Ch1 Rachet Spring Holder Broke
- G3?
- Futaba Buddy box problem
- 148DF vs. 168DF
- 9C Manual - Is there not something better?
- Hlep!! R149DP receiver
- 7CHP gyro settings
- How long to reply?
- Lithium Ion
- Rubber grip on Futaba 9ZAP transmitter
- MOVED: 12Z internals?
- GV-1 Governor set up problem
- 3050 servo
- R138DP Operation with FMA Co-Pilot
- Futaba FP-T6NFK crystals
- Rotary dial reversal ?
- 12z range problem
- Servo Quit
- 9C Super Aux questions
- 8UAF Mixes for Sport Plane 4-Servo Wing
- Futaba 9cap programing help!!! p47-d 1/5 scale plane
- FP5148
- Synth module issue?
- Cap 7
- Broken Gimbal on my 7CAP
- Futaba reciever/JR and Hitech servo compatibility
- 8UAF problem?
- Ham TX models?
- 9z: ATV vs AFR
- R 168RF FM DC
- 14mz as trainer to a 9z
- Three Position Choke?
- 9CAPSuper Transmitter Switch F
- 9Z Low Throttle to Elevator Mix
- MOVED: batteries
- FF9 changes from PPM to PCM by itself
- 3PK LCD display problem
- R146iP xtal !!!
- 75MHz Synth module for 9CAP
- First radio system purchase.
- TX batteries for the 9C-Super
- Twin servos in the same
- 6XAs transmitter failure
- T7CAP - Flaperon Endpoints
- 12Z Flaperon Programming
- delete
- 12Z and Mode 3
- 12Z Firmware Updates
- 9CAP Super Doesn't Transmit Signal
- 9CAP mixing question
- Glider reflex and camber on 9C
- 12Z aileron differential
- Q&A
- I bought four of these servos from Tower and none seem to come with any
- Gear sets and Tx stick springs
- why does futaba keep making "super" series
- 14MZ as a buddy box slave
- gv1 question
- Futaba S9550 gear sets
- 9252 Servo chatter
- Is this possible?
- FP-R127DF glitches
- changing transmitter crystals
- 9z wc2 throttle prob
- R127DF discontinued?
- 9CAP Super question
- 12z Help
- T9CAP Radio Manual
- Futaba 6EXAP Antenna trouble
- FP-R127DF high or low???
- Throttle stick
- WEATRONIC and 14MZ radio
- 12Z Band change from 72 to 35mhz
- Using a Pmix to implement throttle cut -9C
- r319dps pcm
- Slider as throttle trim in 12Z
- Super 7UAP Question!!
- FP-T3PG Antenna
- 9Z Stick is Broken
- 7CAP trim
- Futaba S9152 - 6v or 4.8v?
- Tower Hobbies Receiver Repair
- Futaba radio,receiver
- 8U Super problem
- 7CAF or 6EXA : How to Configure Dual Throttle Servos on Seperate Channels?
- 9V buddy box connector
- Dual rate trim change
- buddy box ?
- G3 RX and PowerBox??
- 9CAP-ELEVATOR PROBLEMS
- 9Cs trainer cord with older Tx
- 9C with 2 recievers
- Servo Specs
- 7 CAP Trainer Function
- 6EXAS Elevator Pmix Question
- Synthesized transmitter module
- 9Z V-tail two independent servos
- Jason Kraus - XFC Blaim G3 for CRASH
- Aileron differential on 14mz
- Futaba 9C/9CS Synth Trans Module 72MHz Antenna
- 3305 crash me a plane please help me
- 14mz and 12mz model question
- Jittery throttle
- specs for current draw on servos
- 14MZ at the XFC?
- Whip antenna on Futaba 12MZ/14MZ
- 9cap voltage?
- Older Module Question
- selecting rx for 6exap
- Trim set up?
- Channel eleven question/problem/feature
- FP-R129DP receiver 6Volt Battery
- Transmitter diode
- 9 zap
- Which Radio??
- R133f range problem
- Need some help setting up dual aileron servos and flaps on my 7C.
- Elevator->flap trim capability.
- New 9Cap Super won't change to PCM
- 9Z expert Questions
- Futaba 7CAP tx??
- Conflicting reports about programming capabilities
- 7CHP dual rates.
- FF9 butterfly mix - flap servo travel
- Flaps and trainer box
- Problems With 9CHPS and G3 Sim
- 12Z programing for Slimline smoke pump
- 9 CAP & 3 position flaps
- 14MZ Question
- old futaba radio
- Transmitters and modules
- 6EXAP Flaperons
- problem with 9C super glider programming
- 12z mode 1 to mode 2??
- 9Z Antenna came off
- 8SGA-P Heli Compatable???????
- FF9C Super??
- Does it really matter 9CAPS or 9CHPS
- Starter Needing Help
- TP-FSM Module
- Futaba receivers dying
- High Band - Low Band Question
- Transmitter doesn't work after battery change
- R146iP receiver question
- Range Check Issue
- DIN plug installatin on old AM TX?
- Repair progress
- Futaba receiver R114-F
- 6 meters and the 12Z
- Futaba Flyers club registration
- WC2 issue
- 7C programming - VR at 0% when moving Channel 2
- exhaust oil soaked servo.
- 9ZHP WCII power light blinks
- Latest on R5014 DPS Receiver
- Futaba T2PH Problem
- Crystal change on 7C
- Frequency Change
- Crystal for R114F explanation
- 9153 current draw
- Mode change on a Futaba 12 Z
- 12MZ Question
- 6EXAS Intermittent Loss of Control
- FM/PPM vs FM/PCM
- 6EXAPs cross interfering
- Trainer 14MZ / Student FF9-super: channels different, can this be solved?
- Glider 2 Flap and ability to use throttle?
- Crow and saving Trims
- Skysport 4YF-FM>Trainer funct. work with JR & Hitec?
- I messed up my transmitter, oops!
- 14MZ Problem
- Smoking servo, popping reciever
- 4 aileron servos
- Split elevators
- 12z
- Futaba 7CAP Timer
- Quick 14MZ Sounds question
- FM Failsafe
- mulitple model
- MOVED: 9c and hyperion hp-dsp*6-fs compatability
- 9C Super Swash settings
- 6exh cannot on
- Futaba PCM Receiver question
- 9Z programming, ATV vs. AFR
- 8U LCD Display Board
- 12z and 149dp RX
- FUTL14 27mhz conversion module
- Servo problems 9153
- Futaba gear set lubricant for S3003
- IS THERE A 12Z PROGRAMMING GUIDE FOR DUMMIES AVAILABLE??
- Help with 9C Trainer function & helicopters
- 14MZ Headphones/Voice prompt question
- 9c Dual rates and Expo
- T6XHs..trim problem
- Any news on spread spectrum?
- 12Z Pitch Programming
- Cross linking trims
- 8U air to Surface module change
- dropped my transmitter
- Can the 14 MZ work with Airtronics
- Micro receiver interference ?
- 6EXAP Flaperon
- Minor problem with long file names on 14MZ
- 7C ultra stick 40 Programming
- 14MZ Model Date Wierd
- 6EXAS and Electron 6 Reciever
- futaba t9zhp issues
- At what point HD wires & switch?
- Futaba 9C Super
- 512 or 1024
- Elevator Servo Travel
- ignition interference on ailevator function during range check?
- R136F Rx problems
- Gear set for S9256 servo
- JR PCM rx and Futaba 601 Failsafe issue
- Slow servo movement?
- 14MZ / 12Z .mdl file format
- RXs converted to 10 Channels?
- sailplane receiver
- 14MZ update for Australia?
- Receiver For Futaba 6EXA FM Transmitter
- 14MZ Throttle Curve
- replace rx wire
- 7CAP timer?
- Conversion Question
- Messing with MDL files
- Which radio for two elevator servos
- Ooops! the question for matching servo speed was for a 9CAP
- Matching servo throws
- High - Low band ?
- Futaba 6EX Tx with Simulator Software
- eclipse tx and futaba rx
- Li-Po Rx batteries
- Two elevator servos with 6ex
- 12M radio Flyers club or specific forum for owners
- R5014DPS reciever and Whip antenas
