- Servo extension cords & receiver aerial
- 42" servo extension cords & ferrite beads
- How do I set up flaps to move downwards only?
- S9151 resonating on rudder
- 14 MZ MANUAL DOWNLOAD
- change reciever channel 14 to 51/55
- 3PK Megatech... with 75mhz?
- 14 mz can not find g3 rxs
- Heli and airplane radio.
- Transmitter left on
- 3pk with spektrum
- 9253 compatibility
- Futaba 6VA Srping Question?
- FUTABA DENY TO REPLY
- 14mz and throttle hold
- 14MZ receiver sensitivity
- 9C - change from 72MHz to 36 MHz
- ooops! the timer mixing question is on a 9CAP
- Timer mixing
- Futaba Switch ML-1AFSP - Dress Nuts Supplied ?
- Crystal compatibility question
- Will 7CAP trainer function work with Hitec Focus 4?
- 14 mz Back-light Help
- dual flaps & ailerons
- do i or dont i
- Futaba 3PK antenna
- 14 MZ, Question on menu options
- FP-T5LK questions
- gyro/14mz problems
- 9C Super and Ultra Stick Quad set up
- Has Futaba 6 EXAS been discontinued and replaced?
- dumb radio question
- 6YG For Training
- Futaba 9451 digital servo humming
- 9C Trim settings problem
- Torque rating for S9304?
- Running two receivers in a tri engine plane
- Replacement 1st gear ''only'' for s3305
- 9C and swash set up on micro heli
- 14 MZ
- 9c & simulator
- 14mz airbrake
- 9z wc2 expo and DR set up!!!!
- 14MZ in trainer mode
- futaba receiver aerial length
- futaba 9c questions
- 9C sound volume adjustable?
- 7-channel receiver
- Shift used on FP-7UAF 6Meter
- Futaba site no listing for crystal SET for 9C which one?
- Pecking order
- FP-R128DF Receiver
- Module questions...
- JR channel expander for a Futaba Radio??
- changing stick mode on futaba 6exa
- 14mz servo compatibility
- 7CAP -Trainor TRTXFM
- 14mz Rudder to Aileron function
- T14 Throttle to Rudder mix
- 6XE Super Dual Elavator Mixing.
- ...I need a part for my older PCM1024 radio...will buy broken radio for casing...
- 8UAFM radio and a gas engine range check.
- Ratchet Throttle conversion
- Dual Rates won't x-fer to Buddy Box?
- 14mz throttle hold delay
- Futaba 14MZ timer question
- futaba/hitec/JR compatibility
- Futaba 3PK (DISP/RF)
- Futaba T7CAP Vs 7CAP?
- Futaba Conquest FP-T4NBF Documentation
- FUTABA 3PM
- 7cap trim on throttle wont adjust down
- S9206 on 6v?
- 14 mz radio ?
- Mixing elevator servos with a 9CAPS
- 1024 rx crystal
- 9Z Hi idle switching?
- 9CAP intermittent fault - rudder offset
- GY401 Gyro w/ the 9Z
- Hi and Lo Band Rx
- FF7CP and FP HB problem
- Buddy box
- Testing receiver of new Fut 14mz
- Warranty question
- Antenna replacement
- MOVED: Safety concerns with 14MZ.
- WC2 TCV question
- Futaba T9CAP Chrome Plating Blisters
- Latest on R5014 DPS Receiver
- 14MZ ATV / End Point question
- Servo current draw & flight time
- I need a gimbal for an 8UAF
- 14mz and audio files and pics
- how to change neutral position gy601 gyro.
- 9c firmware upgrade?
- PCM problem
- Futaba 149DP & S9206: 6V safe?
- Futaba S3150 Slim Servo
- 9z wc2 electric govenor setup
- MOVED: Gp 2500 battery ff9?
- FF9 T9CHP Super PCM 1024 Hélicoptères system !
- GV-1 problems Please help!
- 9CHP switches position
- Futaba 4VWD - Seek Info
- 75mhz Module?
- MOVED: PC Joystick-To-R/C Trx Integration
- HRS vs. ESC,,,,HRS is winning
- 9C Mixing Throttle to Smoke question
- Futaba 8U**S Elevators
- 14 MZ Manual/New Version
- 7cap PMix-Rudder (master) to Aileron (slave)
- Safety concerns with 14MZ.
- Futaba S131S servo
- R5014 Current Handeling
- 7C timer problem
- Range Testing
- New Case
- 3151 servo squeals
- Upgrade
- Futaba 9C / Determine firmware version
- Campac and how to save question
- receiver / battery question
- Compatibility betweew Futaba T14MZ and Powerbox 40/24
- 9chp
- dual elevator servos on 7cap
- 14 channel receiver
- 14MZ Forum Access-Register?
- futaba radio questions
- 14MZ D/R AFR Question
- futaba 6exas
- 7 CAP display problem
- Futaba 6EXA Super product availability in Australia
- 3pk vs 3pk black question
- 3PK ?
- FP-R129DP
- Futaba 6XA dual elevator setup
- 8UAFM transmitter memory battery power.
- S 148 throttle servo jiggles.
- 0H00 on 7c display
- Need help with R114F
- Futaba FP-7FG TX still legal and battery question.
- 14MZ mixing
- FF8s Moving the gear from switch G to A???
- 9C ( not super) trim problems
- 9ZWC2 Airbrake Feature.....I'm Lost
- 9C Aileron channel dilemma...
- ch 6 or ch 7 for the second aileron servo?
- 7CAP using flap
- futaba
- Futaba Scan-Select Synth' Rx???
- Which quartz?
- Futaba 4EXA - High/Low rates?
- 7CAP using flaps
- 8UAF vs 8UAF
- 8U Radio Glitches
- Battery Replacement for Futaba Conquest FP-T4NBF transmitter
- T6XHs
- 8UHPS to 9CHPS
- I need a Gimbal for a 9Z WC 2!
- MOVED: radio interferance
- Unanswered Question: What is charging amp limit on 7CAP TX charge plug?
- 7UAF SUPER
- Waiting for a response??? 7CAP Dual Alierons,dual elevator & flaps
- What Radio??
- 9z WC2 Question
- Futaba Digital Servo chatter/glitching
- 9CAP Problem?
- Futaba transmitter-receiver compatability
- MOVED: Using both JR Servos and Futaba Servos on the Same Receiver
- Futaba BR-2000 Battery Checker Question
- Futaba FP-R127DF RX
- Futaba 6exa 72Mhz to 35Mhz
- R319DPS for heli use?
- 9Z Case foam
- 9Z problem
- Futaba FP-T6NFK - windows doesn't detect
- SERVO GEAR LUBE
- Reciever compatability w/ 9ZAP
- 7CAP Dual Alierons,dual elevator & flaps
- elevator to flap mix
- 9C +3-position Switch Updates
- Futaba HF-Module Question
- 9VAP Module
- 7C - Servo neutral points shift at different throw settings.
- Wrong Name & email Bouncing
- PCM Radio won't rangecheck...
- 9Z WCII battery holder
- Futaba 9C 3-Position Switch Locations
- 3101 servo?
- FP-113iP
- What G2 Interface cable do I need?
- GYA350 Gyro Recommended Servo?
- Digital Servo power needs
- 14MZ Elevon setup
- Futaba GY401
- Retracts on Ch4 with 7C
- General question re:Futaba airborn
- Futaba 9 Cap
- modules
- Need a little info
- slight problem
- General Futaba Flight Pack Question
- R146iP on 75MHz needed
- MOVED: 9C vs. 9Z
- Servo Bench Check
- 9z and 16k campac
- Checking Battery condition Conquest FM
- Dual aileron setup for Futaba 8UAFS
- Using 4 servos Ail and flaps with 9Z
- Stalled servo?
- r156f receiver not working
- Servo reverser
- Buy a Futaba 3PK???
- S3050 slop...
- Ground and transmitter don't mix
- Flaps and flaperons?
- R319DPS Receiver and dual batteries problem
- Any way to get variable airbrake/crow in Acro mode?
- 9C Flap / Spoiler mix help
- **** POSTING IN THIS FORUM ****
- Throttle Conversion?
- Futaba 9CAF ? on Spoilerons & Flaperons
- MOVED: Voltage regulator
- 14MZ: Flying wing 2 aileron programming question
- 9Z not talking to FMA M5
- programing 9C for nose wheel steering
- How to set a dial to Throttle EPA with 3PK?
- 6EXA Mixing question
- Futaba 9CAP and Pmix
- 6EXAS voltage reading incorrect
- 7c throttle spring
- I'm concerned about my receiver
- Krysta, are you there?
- 3pk display problem
- 14mz won't recognize my R149DP
- jr and futaba
- More Indepth Manual for 14MZ
- Switching rx. from low to high band?
- 7 Cap flap/elevator mix on G switch
- Programming Help - 9C
- can 9C synthsized module install on 9Z
- Can 9Z use FP-TP-FM Tx module?
- ff9 spoilerons & flaperons
- 7C crow and servo position
- Futaba 9CAP simulator use
- 9C Flaperons
- Futaba FP-T6NFK trainer switch
- Specs for a S9201
- 14MZ software update and new manual ... WHEN?
- MOVED: Glitch problem, need help
