- matching receiver with radios
- GYA430 Gyro
- Old 8ch Futaba with 2.4 module
- Radio stopped working....again.
- Re-assign proportional knobs on 10CG
- Multiply voltage readings on Futaba 18MZ
- Futaba R617FS receiver problem. Need Help
- 617rx compatible withnew 8channel 2.4 Fasst?
- Sbus servo question
- MOVED: FASST, FHSS Ranges
- Timer Contol
- progressive elevator/flap mix
- Futaba t7c - How to reverse control sticks??
- 8FGS & OPTICAL KILL SWITCH
- MOVED: 8FG & Naza set-up concern
- FASST installation in ALUMINUM fuselage
- Range of Futaba R2106GF receiver?
- Total Timer on &C-2.4
- FG Series 2.4 ghz Mod
- MOVED: Bullet proof!!!!
- 12FG model memory
- Futaba receiver compatibility
- 18MZ Telemetry log
- R6008HS ch 8 operation
- Futaba 12Z & Electric Retracts
- IBEC into S.bus network
- 617FS receiver 7th channel
- MOVED: What radio do I buy?
- TRIPLE RATES WITH A 14Mz
- Antenna Position for 2.4 Receivers
- Throttle cut function
- dual battery set up on R617FS fasst receiver
- 12FG Tx radio problem
- Are FF9Ch and r129dp incompatible?
- TX Question
- Futaba T8FG setup for flying wing
- Obscure TX parts - 4NBF
- 9C Super Flap set up
- Futaba 8fgs and 6014 help
- Setting flaps on a 9cap
- Trainer cord - 18MZ to 12FGA?
- 9252 digital
- T6XA TX
- RX futaba R168DF use with ESC
- Steering Stop with GearUP
- 18MZ Soft Sticks
- 18mz has a backup battery?
- 100% Trim
- Trying to set a function for a 3 position switch
- 8FGS Dual Rates
- Futaba servos and LIFe Battery
- Can someone show how to program gear door sequencing on 18mz?
- 18Mz Music + Timer bip
- 12FG broken case
- No receiver voltage detected with F1666 Telemetry box
- futaba R6008HS receiver
- Service Turn Around
- TM7 and 72 MHz Antenna
- Futaba S9072SB replacement gear set
- T6XA TX
- FUTABA 7C 2.4 RADIO QUESTION!!!!!!!!!!!!
- Futaba 12FG & WTR-7 compatibility
- 18 MZ Charging
- 12Z "SA" switch is not working correctly
- Antenna Position as Far as the Planes of Said Antennas
- 7cap
- 14MZ Mixing setup- HELP
- MOVED: Futaba 6EZ-2.4 Question
- 8FG / 7C trainer setup
- FASST MODULE UPGRADEABLE RADIOS & TP-FSM 72mhz use
- FUTABA 12Z strange stick behaviour
- Dual Receiver for the 18MZ
- Futaba Receiver Check NO disassembly
- Whats the difference between these to other than the extra Sbus
- Help to configure Futaba T8J
- Futaba servo mixer question.
- Switch for smoke just on & off
- 18MZ Bezel replacement
- 18 MZ T2 trim reversed
- 6J programing Issues
- cgy750 - 4 point CCPM -> servo jitter in AVCS mode ..
- How do I set up crow with 18mz?
- Futaba SBE-1 S.Bus PWM Adapter question
- Help Will my Campac from 9c super Work in a 10c
- 18mz and external third party module
- 8FG Super master to 9C trainer cord
- 8FG programming issue
- 18MZ and Sbus
- Copy data from t9chp super to t9chp non super
- Copy Function???
- FF9 screen turning dark
- Mode 2 to mode 1 on buddy box
- Futaba 6 EX 2.4 Systems Upgrades
- Throttle Cut on 9ZAP WCII
- 10C End Points Ch 9 & 10
- Dual aileron servo wiggle to center.
- Idle up Airplane
- Futaba 14mz 2.4mhz binding new receiver question
- Thrust Vectoring Setup With Futaba 7C
- Trusty old Futaba 9ZHP's LCD screen is a bit dark.
- 4 Servo Wing Radian Pro
- Replacement LCD display for my 8UAF
- 14MZ decals
- 14mz crow
- R617FSrx & Servo issues
- Ultra Stick program for 10C
- Futaba 6J Trainer Switch Issue and Buddy Box
- MOVED: Super T8FG and R2008SB
- R6308SBT receiver
- Training
- T8FG Issue
- Futaba 8FG Super recommended switch assignments?
- 12Z and r617fs
- 12FG heli setup
- Calling futaba TX EXPERTS
- Futaba 12FG Question
- newbie help
- S3003 GEARS
- 8j 2 Elev. +2AIL+2 FLAP servos
- Tp 50cc mustang flaps question. 10cap
- heat with a 2009 R6014FS
- T12fga question
- Receiver
- 10cg Expo programming question
- T7C low battery warning while in "student mode"
- Help ! 10C - parameter function
- Biplane with separate channels Futaba 12Z
- Futaba S.Bus programming with T18MZ
- Lipo in a 9c?
- Buddy Box Question
- 12FG Gyro Tx programming
- Futaba 7C Lost binding
- 10CG programming question
- Differential aileron 9CAP
- 7C 2.4mhz flap set up on switch G question
- S.Bus power info needed
- Long FASST RX antennas
- 10C Program high Throttle Idle with Gear Up
- Update for 12Z
- 9C Super and using VR(D)
- 8FG Super Servo Slow?
- Can I update the Firmware for Futaba 8fg with Linux?
- T6J aileron & elevator mixing issue
- Servos for SFHSS
- 12FG Butterfly
- 12FG flap setting
- Futaba 10 chg replacment antenna
- Memory from 12fg to 8fg
- Is it possible to turn the 18MZ off
- Fasst receiver location
- How to program a Futuba T7C for a 4 servo wing
- Fatuba and Tamiya help please
- 10CG Trainer / buddy box question
- 10 CAP mode 1 to 2 change
- 8u upgrade
- 6208 SB Receiver-No Data Log ?
- 8FGS to 4EXA trainer cord
- 12FG FHSS? S-FHSS? S-BUS?
- MOVED: Futaba and Model Airplane News
- 12 FG ch assignment
- Futaba Skysport 6VA Question
- Vector thrust problem
- Futaba 10CG binding question in model memory
- 12FG stick calibration problem
- 12z lost model memory
- Futaba GY401 Gyro and the Futaba servo can't lock
- 12FG, 14MZ and 18MZ
- 18MZ + 6014FS initialization pending for stick movement!?
- New FASTest Transmitters from Futaba...when???
- Linking 18MZA with R7008SB
- Crosstalk and interference problems on fp-t4nbf Tx
- 12FG vs 10CG decision
- 12fg ailevator trims
- 8fg super differential motor control
- 6EXP battery question
- Changing the switch direction on a FG12?
- T8J, R2008SB Startup.
- GY701, R7008SB and 18MZ with S-bus challenge
- trimming butterfly in a futaba 12z
- Please help with 18MZ tx stick issue
- 14MZ LST and LS
- CAMBER MIX USED TO WORK WITH 14MZ DOES NOT WITH THE 18 (IS IT A BUG)?
- Transferring Models from 10c to 9c
- FASST rx and failsafe
- 18MZ program transfer
- 18MZ System Timer- Model/Total time
- Converting a 10cap to a 10ch
- Futaba 7CAP
- R7008
- good service from Futaba
- Master slave issue
- Rx R6004FF
- Glitch in PPM but not PCM? Futaba 8UAPS
- Change aileron differential slave channel?
- New 18MZ
- Crow braking on electric sailplane
- 12FG tx issue.
- 18MZ is controlling 2 7008SB in single channel mode
- Please forward to futaba japan
- Damaged TM14
- 14MZ and GY401?
- 14mz FORUM registration change AGAIN!!!!!!!!
- Futaba BLS154 Pot Part No
- 18MZ and GY701 Gyro
- S1957 Servo Problems
- Futaba 14MZ low PPM Voltage for TSLRS
- Futaba 8FG using a retract servo with a 3 position switch
- Remove 18MZ throttle stick limits
- MOVED: 8FG Super receivers
- CGY750 in airplane?
- MOVED: hobby king orange receivers
- Futaba 12FG Heli CCPM configuration problems
- Where to find how to program flaps
- Flight modes on 10cg
- 14 Mz Telemetry
- can 6008 receiver drive all of those servos?
- servo slow in Futaba 10CAG for flaps
- Backlight for 12Z
- 12Z and S-Bus
- Update for Receiver Compatibility Chart?
- FHSS Support on 12FG, 12Z, 14MZ?
- Set up Flaps to not deploy above throttle setting
- Trainer inhibit switch
- Throttle curve for 12FG
- 14MZ and Align Trex 450
- Futaba 12z Great planes Pitts 1/3 Scale
- 18MZ battery charging
- T6EX 2.4
- 6 CH Receiver using 10C Tx
- 9CAP Flapperons
- Offset mix for gear doors
- 9ZAP gimbal pot price
- TRAY FOR 12FG
- 6EX 2.4 TX
- Futaba stick change
- Does the 18MZ support the MPDX-1?
- MOVED: Looking for red anodized stick extensions for my Futaba 12Z can some one help me?.
- S9201 Servos and R6008HS Receiver
- 4PL Tx Radio
- S-bus and Opto Kill switch - how to connect
- 14mz AFR aileron split
- t6xas problem
- Can I use regular leads between hubs on Sbus
- 18 MZ Asian version
- Futaba 18MZ - mixing elevator with flaps - Please help.
- AnyLink with Futaba 12FG?
- 18MZ Warning Set
- 12FG Questions
- 8FG Trainer Port voltages
