- R6106HFC
- 645s on the s-bus system???
- Futaba 12Z to 18MZ
- MOVED: two batteries one reciever
- Upgrading TX, need suggestions
- 12FGA flight conditions
- 10chg stick centre points
- 12FG instruction manual for dummies?
- Throttle Cutoff for electric with 9C
- 3UCP TX module compatibility
- Software Updates
- Unlink RX from TX??
- T18MZ and timer reset switch
- CGY750 Gyro
- New 18mz with elevator stick travel problem
- Can't get my 8UAF to read ON in Ail. Diff. mode
- Transmitter Case and fit with 8FG- 12FG
- 14MZ wallpaper
- 10 C and flaps
- Programming flaps to elevator
- 6EX with two elevator servos
- Tx Stick Springs
- Futabe FP-8UARF Won't Stop Alarming !!
- 8FGS Want Optical Kill on SC bottom position
- 7C2.4 fasst
- Q: Futaba S9070SB S.Bus servo
- 18MZ snap roll function
- Futaba 18mz
- 14MZ registration change
- R6208SB receiver antennas
- 7c2,4fasst
- Futaba 6ex Problem
- Timer on T18MZ
- 8J questions
- Whats the point of having two sbus ports on one reciever?
- Futaba transmitter and Phoenix Flight Simulator
- SBus extension load ability
- T7C;setting up flap with elevator mix
- 14mz update 1.7.0 question
- 14mz touchscreen
- wrapping rx's
- Using Throttle Delay for other function
- R617FS issues
- 10 CG AILEVATOR Mix question
- 18MZ question
- Futaba Skysport 4YF
- Trim button problems
- 3 different Dual Rate at 2Point Switch
- futaba 6ex 2.4ghz system wont work
- 10C slider
- Futaba 18 MZ
- multi prop control
- 12FG 2.4 Antenna Replacement
- new TM-FH 2.4 module
- speed of signal
- Futaba 12Z Serial number
- Futaba Rep question
- Flaperon operated by 3-way switch 18 Mz
- 18 MZ Telemetry
- MOVED: Quality cost effective RX compatible with Futaba 6EX 2.4GHz
- input needed on charging Futaba TX battery.
- 6106HFC Rec High Speed Mode
- FG8 triple rates
- Gyro
- S3104 servo equivalent
- radio question?
- Futaba 10c & Align 550 3gx setup
- MOVED: One Arm RC Flying
- R617fs reciever voltage
- Need repair part for 7c
- Video 14MZ
- Futaba 10C program mix problem
- trainer setup
- Campac for 9 Z
- R2006GS receiver
- Other Futaba 2.7 volt receivers?
- Futaba 14Z and Thunder Tiger MiniTitan 325 SE
- 12FG: Can I upgrade directly from 1.3 to 3.0?
- Receiver help.
- Outstanding!
- How to transfer models in a 9caps to a 10cg
- Model set up transfer
- Elevon setup in Futaba 10c
- Question/Analog servo use ok?
- Models Vanish from my 12fg
- Futaba T9CAP
- new screen for futaba 14 MZ
- 10CAG RECEIVERS?
- 8UAPS Gear Switch
- receivers
- TM8 Module in 9C
- T8FG updates
- 12ch comparison
- 12FGA Questions
- Futaba 7 cap FM
- Y harness or S.BUS cable ?
- WTR-7 Servos reverse
- T10C Glider mode
- FP-T7UAP programing problems
- Futaba 7C Lipo Question
- dual batteries
- Futaba HV Servo's
- Are software updates on the horizon
- ff9 lipo or life ?
- 8FG Switches
- Futaba S9072SB Servos
- 8fgs fasst modes?
- 10 FHSS module and Tactic 2.4 Gig Radios
- MZ14 manual
- Problem with Ch. 6 not responding to aileron inputs.
- Futaba T6J Transmitter
- rcvr
- SD card
- Binding 2 receivers
- Offset question
- MOVED: 8FG Update 4.1 Question
- Futaba Receivers & Servos for SIG Wonder
- Futaba 10 CAG 2.4 Replacement Antenna
- Small servo for retract air valve?
- 8FG Trainer problem with 4VF student
- 9C display Screen Replacement Advice?
- S.Bus explanation please
- Futaba MPDX-1 and 12FGA Help
- 8U Question
- Can the wrong setup burn a servo out?
- Futaba 8FG trainer cable help
- Futaba T4VF brand new, not working, glitch... what's the problem?
- S9074SB Servo
- TM-FH FHSS transmitter module
- S.BUS question
- SETTING CONDITION 4 AND UP
- 12MZ update
- R614FF RX Problem
- Futaba FG-8 super LiIo 2S 7.4 V/ 2800 mAh
- 12FG
- Old futaba T9-VHP
- Futaba S3152 Disgital servo - okey with 6.6 volts
- Butterfly on futaba T12FG
- Converting a heli throttle to a ratchet type
- S9156
- 9CAP ^ Lipos
- 8FG Super:Trainer function
- Programming 7c 2.4 Gc for flaps
- Futaba 4PKS light bleeds through at side of screen
- 7C Throttle Channel Oscillation
- Futaba S3115
- 12fg radio
- 9C programming recommendation
- trigger a beep with throttle for 12z?
- download software
- 8FG Super
- 14MZ Anomaly?
- left stick problem
- trainerlink jr to futaba
- Futaba BR-3000 checker
- ALT vs NORM what is it
- TM8 / FG8 Super 7c switch
- Receiver voltages
- Which FHSS TX for my RX?
- 12FG travel throttle stick
- Futaba R6008HS 8-Channel 2.4GHz FASST Rx/TM-8 Tx Module
- 10C 2.4 receivers
- Stiffer Springs for 9c and 10c gimbals
- 8FGS VPP Setting
- 12FG Smoke: Part II
- servo slow functions?
- Futaba 7C Mix 2-5 / 4-2 Problems
- 8FG to 7C trainer cord.
- Faulty S3153 servos
- Disabling a channel by Sw on 14MZ
- Programming a 3 position switch for off/on for 12Fg
- 8FG / 9C trainer setup
- 10C and 6J Transmitter question
- How to change throttle sense in a Futaba 6J
- Futaba 10CG LCD
- MOVED: Futaba Receiver
- MOVED: 8FG Super vs 10CG
- 3051 hv
- R6106HFC Antenna Routing
- Futaba 9CAP Flap/Elev mixing
- 12Z with R6106 Rx & Turnigy 55a ESC - not arming
- 3PKS LCD Display where to buy
- Upgrade 9C to 2.4 7C or 8FG
- GY520 Red light or blue light for AVCS?
- Set fixed output on channel 7
- Futaba 10CG LCD replace
- Using trainer just for channels 7 and 8
- GY-401 going bad?
- Futaba T8FG 2.4
- Replacement Switch for 14MZ TX
- 12FG Model Recovery Software - what is it
- Futaba T7C. Size of Coaxial DC charger plug?
- T8FG V4.0/1 software update. Battery alarm clarification please
- Timer set up on FUTABA 10c
- R6106HFC won't link to 8FG
- Futaba R2004GF 2.4GHz FHSS Range
- 7C 2.4 MHz Flap set-up help needed...
- R617FS made in China
- 10C question
- 8fg Throttle cut... solved
- want flaps on 3 pos switch: 10cag radio
- S3306 application guidelines
- T12fg dual rate and expo
- EUROPEAN & US SBUS SYSTEM COMPATIBILITY
- 8SSAP for 2.4GHz?
- y harness on 7c 2.4 for gas plane
- TM-8 Range check question
- 8FG wandering center w/ elevator dual rates
- T12FGA Firmware update to 3.0 has weird problem for Range Check
- Futaba T7C Transmitter Reverse
- Setup Endpoint
- FG8 setup flaperon/dual elevator
- S Bus with Y-lead
- 4 Aileron servos
- 8U with low reading volt meter
- R6008 receiver question
- Using HH only
- Rapid green light blinking on TM-7 module
- replacement t/x case required
- 8FGA Firmware Upgrade for S-FHSS ?
- Trainer control from 6EX-2.4 to 7CAP-72
- Faast: 2 planes, 2 Rx, 1 Tx, same problem
- CIU-2 Help
- Two Aileron servos on a Y-harness
- gy 701 prob
- 12fg software
- Where Are The 10CAG
- MOVED: 14mz Touch Screen Replaced...new pots....
- 8FG Super Question!
- Futaba Trade Up Promotion
- MOVED: 4PKS upgrade
- powerbox or not to powerbox!
- if I use elevator-aileron mix?
- GY520 Gyro
- T9CAP stick broken
- FF T10CG and R6014HS binding problem
- Help regarding T1o CAP
- 8fgs 3 pos switch question
- 5114 rx lost channel
- New 12z user
- Futaba 3010 Servos
- Just bought 10CG & 7C 2.4 FASST systems
- 10c flap/elevator mix
- Futaba 8FG super -servo speed adjustment?
- SETTING UP 7C2.4 FOR 30CC
- Manual of 7C a disaster
- Radio placement with gas engines
- Differential thrust for seaplane, Futaba T7C
- PMix help
