- Futaba T16IZ Super connect to RealFlight
- Futaba T16IZ servo speed changes
- Futaba Receiver R324SBS and Futaba Sensors 8.4V compatible ??
- R7208SB in dual redundancy rx mode
- bill
- R7108SB and R7208SB capable of SBus & SBus2?
- GYA Gyro question.
- Quality of Potentiometers in the 16IZ Super
- Does futaba still answer questions on here???
- Futaba 18MZ - Two Sitches to operate Jet wheel Brakes.
- Charging isue
- New T18SZ Firmware Released?
- 16sz
- 16IZ 18-Channel FASSTest Transmitter With R7108SB Receiver: Air
- 32MZ Telemetry log - missing log files
- Discontinued futaba servo
- TM-8 FAAST module config and binding
- futaba rx
- Backup battery in the T18SZH Transmitter
- Futaba GYA 440 gyro hookup
- Where to find parts??
- Futaba CIU2 or CIU3 Code 39 message when loading drivers
- Transmitter Firmware updates to Support DD Motors with more Poles?
- Futaba T8J radio
- We need a Flybarless GPS Controller from FUTABA
- SBUS2 Telemetry with R3008SB Receiver.....
- question about futaba recievers
- receiver swap
- T14SG will not show telemetry from R70008SB
- Futaba T9CHP with TP-FSM 72 Mhz and FP-R127DF
- Trying to get DG1 and DG2 to work
- 18MZ and learn RC for turbine problem
- T16iz ailerons stick problem
- Futaba 16iz with CGY760R & BL-100 ESC Telemetry
- Replacement for the R617FS???
- 16SZ Help Please
- T14SG as instructor and the T10CAG as student
- Futaba T4PM Castle link
- Bi-Plane setup
- Futaba 18MZ Camber elevator Mix speed adjustment
- Skysport 4 testing info and data
- Bent Antenna
- t12k trim switches not working
- BLS671SV use in jet airplane
- Duel elevator servos w/9C ??
- Futaba 10 TAC Throttle trim Microswitch not working
- Futaba 18MZ - power adapter/battery charger dead - Amazon adapter good
- Transmitter 2.4ghz & 920mhz
- 12z info please
- T12K dual rate switch assigning problem
- 16SZ. Biplane butterfly
- Futaba 7C Mode 1 flaperon/airbrake assign to a 2 pos switch b,d or g
- 10V receiver For a T4PL transmitter
- 16iz Micro SD Card not working
- Charging Time for 16iz battery
- why more discontinued receivers?
- How do you program a Futaba T16IZ with Flapperons
- Futaba 4pk receiver
- Futaba flyers club
- Question on sensor registration in Tx
- 12fg assign a switch to disable throttle possible?
- Futaba R404SBS maximum operating temperature
- Futaba a500 Servo Settings
- Proud owner of 72mhz Futaba radios, but......
- Converting to 2.4 system
- 14SG Retract Switch Operation
- FP-R127DF receiver tuning?
- Help please..
- Help me please ..
- Futaba T7CAP- servo control issues
- fuaba transmitter
- MZ 18 Flap elevator mixing on a 3 position switch
- Futaba 10J change microsecond range to 1000, 1500, 2000?
- Futaba 14SG - S-FHSS?/Corrupt Model Memory? (I am Confused)
- Futaba PCM FM Radio Battery
- futaba 2006GS receiver compatible w/ T19 CAP ?
- Futaba R7003SB EXT-VOL connected without power to receiver
- Futaba 18MZ and 10 CAP compatibility
- Programming the digital servos
- R3008SB telemetry not working
- Futaba FP-8SSA-P Schematic
- 16SZ Buddy box issues
- T16 IZ, europea, incorporar sistema FasstMulti y Fasst7
- Futaba 3pv radio gear weak break
- Linking problem
- 14SG battery fried
- T14SG Version 9 update has 4 versions?
- 3D Jet Mixing with Futaba T18MZ
- MOTOR question on main thread
- Futaba R7014SB + 16SZ - Failsafe Keeps Occuring
- Futaba S3004 Gears
- 14SG PMix Problem
- T6K - transferring multiple model setting to another T^K
- futaba RG2006GS S-FHSS reciever range
- Does receiver model matter with FASSTest and S.Bus?
- 14SG Butterfly Issue - Stumped
- binding
- Futaba T12FG idle trim
- Receiver link switch
- transfering models from 14sg to 16iz?
- T-FHSS receivers applications
- Player Function on 18MZ
- Ratchet to smooth throttle on 16IZ
- Extend antenna of R7108SB
- T16iz compatible futaba receivers.
- Futaba 18mz front cover
- 18SZ and Telemetry questions...
- Slider tension
- 18MZ - Dual rate on Jet Nosewheel problem
- can CA fumes damage Transmitters, servo's?
- 32mz plastic defect at edges of gimbal area
- Connector "Extra Voltage" Futaba
- Looking for 72MHz dual conversion channel 34 Rx crystals
- Copying 16SZ Model Data to 32MZ
- FP-T7FG/K FM 72 Mhz. Need Compatible Rx
- futaba 7px transmitter antena
- 18MZ - 2015 radio - FASSTEST 18 channel - sbus2
- Futaba RX Antenna Differences
- 4PM Dual Rate Switch
- Futaba HS 6014
- 16IZ conditions/dual rates
- Removing/deleting password on MZ 18
- 16/18sz Throttle Kill on multiple engine planes
- T6K versus T16SZ throttle/motor cut
- futaba T-14SG setting a smoke pump
- Conditions - 18MZ
- Copying 16IZ Model Data to 16SZ
- S-Bus questions
- 8j program flaps
- 18 SZ and SBS-01G
- Help trainer mode Futaba T12K
- Futaba T8J not binding with R2008SB
- SZ16 problem
- 16iz charging
- 18SZ - Speech Volume - crank it up
- 16IZ with 7008SB and7108SB
- SD card
- R7014sb & 12z?
- Questions on S-FHSS and T-FHSS
- R7108SB versus R7008SB
- External charger for 32mz battery
- GYA 553 Gyro
- 16SZ shutoff
- Futaba 16 IZ
- 7006 Rx
- 16SZ Telemetry Alarms
- Reciever battery
- Futaba 10J and changing values 10 1000µs to 2000µs
- 14SG question
- A700 vs AA700
- Orange and green sbus hubs
- Buddy box compatibility
- Futaba 14sg lockout
- 12 FGA "Conditions"
- T18SZ RF Off
- Futaba Tech and Customer service request
- Not Able to Register for Repair Work
- Receiver futaba
- New and old tech combined
- 16IZ copy bug
- R6014HS DG1 and DG2
- Spoiler Elevator mixing
- help with futaba t14sg
- 32MZ wont update
- Rutabaga 18sz throttle elevator mix
- Updates available - 6/2/2021
- Converting 14mz files
- T16IZ - Text to Speech Functionality ?
- Futaba T12FGA G3 Frequency
- T18SZ and T-FHSS Telemetry
- Futaba T6K (Minimum voltage) ?
- 16IZ program an on/off ignition switch
- Old Futaba Magnum Jr problems
- Transfer model data from T12FGA to T12KA transmitters
- T32MZ to T18MZ trainer lead question
- T4px on axial Ryft 2 speed set up
- T12K Telemetry
- trainer cord linking T14SG and FG8 Super
- Bass
- T4YF-2.4G Linking Problems
- FutabaUSA Update Page
- Unable to activate DUAL RATE on slave channel..??!!
- Futaba Area Code
- R2008SB and R3008SB Which One To Use ?
- Slave channel has no trim function..??!!
- Futaba 16SZ Throttle
- T14SG Flaparon Programming
- 12FG Question
- FUTABA T10J output fail
- help on futuba t9chp radio
- R3008SB HV receiver output voltage
- 16IZ Reciever Linking
- 16IZ Antenna Orientation
- Futaba attack-4 radio charging question
- Futaba 12FG Limited Elevator Travel
- CIRRUS vs FUTABA
- Setting via Futaba 14SG
- Can’t find the SWT controls on FP-9ZAP
- Futaba 14 MZ help
- Futaba 16SZ vs 16IZ
- Futaba 16sz Rx compatibility
- 12 fg gear door sequencing
- Futaba 16IZ facilities
- Plug Battery into S.BUS2port
- Range Checking
- Futaba 10cag receiver availability
- Futaba 12Z throttle travel programming ???
- Compatibility of new 16IZ with18SZ/16SZ
- T14SG switch repair
- 12FG triple rates switching
- Radio Terminology
- Futaba 16sz dual rates
- 4PL issue
- R7008SB Channel Modes
- Inhibiting a switch or surface when another switch is in a certain position? (18SZ)
- Futaba Air RX with ground TX binding?
- 16/18sz Flaperon Programming
- Futaba 10CG
- Futaba SBus2 Auto Pilot Interface?
- 32mz inspection
- 16SZ Program Mix
- Futaba 18 SZ to power box professional
- Futaba 16sz
- 32MZ Inspection Notice
- R6014FS Recivers &n RCexceell kill switch
- Futaba Receiver Battery Redundancy
- Username on Futaba 18MZ
- Futaba T2PH one servo not working
- Fasst and Fasstest
- Futaba T16SZ Channel Crosstalk
- LiFe Battery for T7C Transmiter
- FASST receiver with 8J or 10J tx
- 18MZ slow boot
- Futaba T12FGA 72mhz module
- Futaba 12FG to 16SZ memory transfer question
- T6K tx telemetry issue
- Elevator trim for airbrakes
- Futaba 12z module issues
- T7C Transmitter will not link or bind to R617FS Receiver
- 16Sz/18Sz 3.9 Upgrade
- Robbe/Futaba F1712 Vario and 18sz
- futaba 4pk
- Help troubleshooting
- Sbus hub - green or orange connector?
- Model ID for 18MZ
- Futaba Receivers and Carbon Structures
- T18SZ SD Card Problem
- Receiver compatibility with 12FG
- T6J with Trainer Cable
- 32MZ and flaps
