PDA
View Full Version : E-Flight Power Sources
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12
  1. LiPo Question...another newbie to E-flight here...
  2. Battery alternative...
  3. need brushless motor set up help
  4. TP2100 3S balloons after only one flight: throw away $80?
  5. E-Tech 11.1v 1200_HOT!
  6. Which Li-Po brand is the best choice?
  7. Printed instructions for Apache 2500 here
  8. 1550 mah battery but charger's settings are 1200mah or 1700mah
  9. LiPoly's Versus LiIon's - What's the Story
  10. Hooking up a psu to a DC Charger?
  11. "C" Ratings for Kokam...
  12. Estes has hydrogen powered rocket. How far off can hydrogen use for eflight power be?
  13. charging 6 volt Rx battery
  14. LI-PO Newbie questions
  15. WHEN LI-POLYS GO BAD??
  16. New NiMh Pack Questions
  17. Need Help
  18. Li-Polys..What's the max discharge rate now?
  19. best of two bad choices?
  20. lipo`s and esc.
  21. lipo charger
  22. Batteries w/ soldering tabs question
  23. kokam 20C batteries
  24. Batteries and charger for Slow Stick Stock Engine
  25. Lithium Fire video footage?
  26. Connectors
  27. lipos are hot!??
  28. Nicad-nimh capacity
  29. HELP!!!!!!!!!!!!!!
  30. WHERE TO GET STUFF FOR MY AXI 2820/10 in th UK
  31. Kokam High Discharge Packs
  32. OK to solder different plug onto charger ?
  33. E-TOC videos
  34. Correct charging procedure for Lipo with a Triton
  35. Flight Time ?
  36. Switching from Ni-CD to Li-Po.
  37. Lipo dead and wont charge after 2 uses HELP PLZ
  38. Kokam Safety Guard/Lipo question
  39. li-po question?
  40. Charging Kokam 340 mAh Lithium Poly cells
  41. LiPo DAMAGE-Lil' Help?:)
  42. Lithium ion? Lithium Polymer?
  43. Increasing Battery Voltage
  44. Best Site to purchase batteries
  45. Help with Firebird Commander to Piper J-3 Cub conversion???
  46. NiMH to Li-poly question
  47. need help on charging batteries!!
  48. duration
  49. firebird commander charger
  50. MOVED: 6 meter receiver
  51. Calibration screens for Prodigy & Swallow chargers
  52. Triton Help "battery T too low" on NIMH
  53. Check the battery voltage
  54. Gotta give a vendor props
  55. Li-polys spontaneously combust?
  56. MRC 969 and LiPo
  57. adding a cell to a lipo pack
  58. lipo pack seperation
  59. Need advice on choosing LiPo
  60. Kokam LiPo Connector
  61. delete this !moved to another forum...
  62. choosing a li-po ???
  63. Thunder Power 2100 7.4v pack FS: ----
  64. Great Planes Triton Top Off Help?
  65. AMPS, SMAMPS!?
  66. Sizing a Li Po battery
  67. Lithium Polymer Battery in a SuperStar ep select ?
  68. How to tell if the battery is fully charged?
  69. GP Triton Help ! open circuit error !!
  70. Where to buy batteries online??
  71. Thunder Power getting HOt!!!
  72. lipo help please
  73. charging sub-c battery packs
  74. Type of ESC needed for Li-Po and GWS TM
  75. Charging NiMH 300Mah battery ?
  76. Big NiCad question
  77. Rx Voltage tester
  78. Is there a plain simple answer Li-Poly
  79. Great Planes LiPo with SafeCharge: Do you need a LiPo charger?
  80. Switchin' to Lipo Mathematics
  81. Lipo Question PLEASE HELP!!!!
  82. Slow Stick Pack HELP
  83. AC Lithium Charger Found, Maybe?
  84. Noob Li battery question
  85. Hitec CG-335 Pro Charger
  86. New cells type,high power.
  87. Mounting Aux Car Battery
  88. NiMH Baterry Cycling Question
  89. LiPo Cell balancing
  90. anybody know about this Lipo charger?LPC-400 Lithium Polymer Li-Po Smart Charger
  91. Newbie
  92. Triton VS Astro 109
  93. Help! Do I need a voltage regulator?
  94. Dymond Super Turbo charger
  95. Sorry, but another newb question.....
  96. AC Lithium Chargers?
  97. Batt pack charging temp and cooling
  98. thunder power bad lipo
  99. Li-Po lack of info.
  100. TP 1900 Li-po trouble (need advice)
  101. Questions about connectors
  102. Changing battery connector
  103. Li Poly charger question
  104. Li Po Charging Questions
  105. Going Lipo - How to choose
  106. Charger Polarity
  107. soldering Lipol packs
  108. Leave overnight on charger?
  109. Mega Motor
  110. Has anyone tried this pack out yet?
  111. Repair of an Ultramat 25 charger ?
  112. They're Finally Here!
  113. Li-ion with GWS park flyers
  114. LiPo Low Voltage Warning Device
  115. Pushing Thunder Power new cells
  116. Battery Question - Speed 400
  117. lithium / cobalt motor setup ?
  118. Q? Graupner "ULTRA DUO PLUS 30" charger
  119. Kokam 1500 Dying?
  120. Fuel cells. 10x the power of Li-Ion. The future of eflight?
  121. best battery-lithium???
  122. ESC and Li Poly
  123. What C to charge kans at
  124. MOVED: ms-001 brushless
  125. Geared Astro cobalt 05 lipo??
  126. Lipo Swelling
  127. Do More Voltage and Cells = More Power and Flight Time?
  128. Lithium-ion & Apache 2500
  129. How long can I leave a charged Battery ?
  130. Making a E flight Field support -what Battery?
  131. Reference source for battery packs, etc.
  132. Battery Specs
  133. putting packs in parallel
  134. Battery tabs
  135. SC on XE2?
  136. LiPo voltage under load....
  137. Is the MRC 969 superbrain a good charger?
  138. E-Flight Battery Evolution - Zagi Style
  139. First time charging of li-poly
  140. New to Li-poly, very confused
  141. E-tech Litho on Slow Stick
  142. heat shrink tubing.
  143. Nimh failure modes
  144. onboard temp. cut off switch
  145. Dumb move of the day (week, month, year?)
  146. What lipo battery package to get for my new 60-90 pattern ship?
  147. Can new nimh AA 2100ma cells be used?
  148. 13.4v or 12v???
  149. Charger NiMH
  150. tp340 parallel charging
  151. Thunder Power 1900 10C or Irate 1800 10C
  152. 1900 Sanyos NiMh
  153. X-PEAK 3 or PRO-PEAK Prodigy available in US?
  154. AR BATTERY
  155. Battery cycling
  156. LiPo safety
  157. Combat Wings XE2 setup
  158. Cobalt 400 power??
  159. LI-POLY POWER - I THINK I FIGURED IT OUT!!
  160. Super Digipulse II or Triton? And config of planes ok?
  161. cell phone batteries for flight?
  162. How to balance with Lipo's
  163. LiPo disaster x 2
  164. Thunder Power 10 C 1900 3s
  165. 180 motor on 7.4v LiPo vs 9.6v NiMH???
  166. how fast can a lipoly charge
  167. Average flight time?
  168. Can HS-55 servos be used with 8.4 volt pack?
  169. Unknown battery capacity and Supernova
  170. 4/5 sub C 2000mha nimh batteries
  171. ESC-MOTOR-BATTERY
  172. any help on this power supply?
  173. Are these batteries any good?
  174. HELP - Newbie ?: Rx & Motor - same power?
  175. Hobbico Field charger
  176. Li-Poly shelf / cycle life
  177. gws defective
  178. Help with jump to Lipo
  179. batteriesamerica lipoly packs for reciever?
  180. li-poly charging problems
  181. How to identify a JR/FUT GWS ESC ?
  182. LiPoly wiring best practices
  183. What LiPo for Yard Stick
  184. Trouble with Esprit Model T.P. Battery Order
  185. Pigi 3D Power system questions
  186. Triton problems
  187. What ESC to use with Li-Polys
  188. li-poly with gws system?
  189. Which lipo for IFO?
  190. Charger Recommendations
  191. Triton Power Source?
  192. Slow Stick Large Battery
  193. GWS Mustang and Himax 2015
  194. 2x 480s, batterys?
  195. Motor is Cutting Out
  196. GWS Tiger Moth Battery
  197. Triton Charger
  198. Sanyo AAA Packs
  199. Pick a LiPoly
  200. Charging amps for Lipo - Triton
  201. li poly discharge ??
  202. kokam 203 charger power source
  203. nimh charging
  204. Nimh....what to do
  205. Micro flyers... Li-Ion... packs.. please look
  206. what brand of batteries to get for 400 applications?
  207. Kokam Raises the Bar - again!
  208. Hobbico Quick Field Charger MKII
  209. 500 mah lipo'a when available?
  210. Help with battery selection
  211. Great Planes "ElectriFly" Lithium Packs
  212. li-poly batts
  213. Does more MaH equal longer flight duration
  214. Identification of Li-Polys
  215. etech 2 cel li-poly & piccoboard.......
  216. Volt meter with Hobbico MKII
  217. NiMH batts. getting HOT!
  218. Triton undercharges everything
  219. Electrifly C10 & 3S Lipo
  220. 2S or 3S for Brushed Motor?
  221. 4s4p versus 4s3p for a Hacker B50-13S
  222. where to buy li-poly for less?
  223. Li-Poly for Hobby Lobby (JR) P-38
  224. Need Li-Poly Cell Resistance & Weight Data
  225. New kokam lithium battery
  226. Lipo of about 500 Mah capacity?
  227. li-po for e-starter with stock motor
  228. Lipos for Wattage Turbo Hawk
  229. why can lipo's be wired in parallel but nicad's cannot
  230. Lipo's used with SlowStick
  231. Lithium Buffs
  232. Li-po's and controlling discharge
  233. Charge rates
  234. is anyone 100% sure if NI-MH...
  235. Power source for charger?
  236. zaggi xt converting to brushless
  237. Lithium Ion and Polymer cells
  238. dual IPS drive on my Tiger Moth
  239. Great Planes DC-3 Li-Poly Conversion
  240. 3S3P + 2S3P OK?
  241. AstroFlight 109 Charger help
  242. 7.4 Li-poly need a voltage regulator?
  243. Slow Stick Battery
  244. What lipo's for AXI 2808/24
  245. Laptop Li-Ion battery discharge rate
  246. nimh question?????????
  247. how low can a lipo go?
  248. Lithium Ion cells ex Notebook Computers
  249. Battery/Charger Basics
  250. Li-poly Storage Help, Please!
