PDA
View Full Version : E-Flight Power Sources
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12
  1. LiPo Parallel / Serial configurations?
  2. LI-on Square batteries....Calculate Mah????
  3. Sanyo 1HF-C1U 1.2V NiMH
  4. Charging LiPo with a L-ion Charger
  5. Forgot to unplug!
  6. Electronic Speed Control Selection
  7. There is such a thing as a stupid question.
  8. Lipo Fire Incidents by Cause
  9. where to buy single cell li-po
  10. Yes or no, please. I think my brain is too full!
  11. what batteries go with brushless 400
  12. Help with battery sellection
  13. Power pack selection
  14. MRC SuperBrain 969 and LiPos
  15. Is the tradeoff in weight ....
  16. wire resistance
  17. Orbit Microlader or Triton?
  18. 969 vs. triton?
  19. 700AR cells
  20. GWS PT17
  21. Custom batt pack question
  22. LiPo battery pack capacity
  23. Formosa and himax
  24. LiPo for a 7.7:1 GB and S300?
  25. compairing li-poly`s and nimh`s ? help please
  26. LiPo pack assembly question
  27. POWER
  28. Battery repair Help
  29. Lipo's and Triton
  30. KANN cells
  31. RAZOR V2 flight time
  32. Battery for Axi ac1215 extreme brushless
  33. Going brushless
  34. Cobalt 400
  35. Charging basics for an electric Newby
  36. Li-Poly esc
  37. JST/BEC Connector
  38. single cell Kokams
  39. Etec battery Q
  40. Thunder Power 2100mAh Packs, need advice for brushless motor
  41. E-tec li-poly 2s2p packs in series ?
  42. Custom batt pack lead question
  43. Battery Connections???
  44. Prebuilt li-poly packs over 3000 mah?
  45. GWS 400BB-B
  46. Multiplex 480 Twin Jet RC2400 or GP3300
  47. volt regulator/cutoff
  48. Field Charging ???
  49. In need of some help
  50. li-poly help PLEASE!!!!!
  51. battery descriptions
  52. Triton "No battery" error
  53. Astroflight 109 lithium charger
  54. Will a li-ion pack work on my brushless motor?
  55. charging lipos with an astro flight 109
  56. Best all around charger??
  57. Terry battery pack
  58. Question about LiPo 2s2p battery.
  59. New Kokam High-Dischare Rate cells
  60. MkII charge time with lipos
  61. Ripmax Mercury Ex and e-tec joy
  62. Kokam 1500 mah cell
  63. Help on Li-po spec numbers
  64. LiPoly fully charged?
  65. nicad change to alkaline help please
  66. Charging Rates ?????
  67. Maximum BEC Voltage
  68. Can old battries be saved?
  69. Cell phone Li-poly packs
  70. Batteries - rule of thumb?
  71. KILLED 2 LIPO PACKS!!
  72. Wiring Li polys
  73. Power for Sky scooter pro 2
  74. Hobbico Quick Charger Mk II charging Li-Polys
  75. Wattage Stearman Battery Help
  76. Jeti 18-3 for LIPO'S???
  77. LiPo Kokam 1500 vs TP 2100
  78. Li-poly choice
  79. What Rate do I select to charge My Nimh??
  80. Taking the Lipo Plunge
  81. kan 1050
  82. Lithium Polymer batteries: how to determine end of life span
  83. Li-Poly info source
  84. How do I charge a single 40mAh Li-poly cell?
  85. HOW DO I BUILD A LI-POLY PACK
  86. buying nicads
  87. Li-poly question
  88. Kokam 340mah 7.4V with a 20C discharge rate!!!!!!!!!!!????????
  89. LIPO BATT???
  90. Li-Poly Should packs be Series or Parallel
  91. How do you find out how much a li-poly battery can handle?
  92. NEED HELP FAST
  93. How many amps can a thunder power 7.4V 860 pack take?
  94. Triton charging Lipo's =2 hours or more???
  95. ESC for GWS IPSD motor & Lipo Batt?
  96. NiMh packs for GWS Beaver and Slow Stick?
  97. Retimed 350 on a 3cell lipo?
  98. HELP! needed, Nicd Pack Mishap!!
  99. Slow Stick Bpack Suggestions
  100. Possible KAN cell killer.....
  101. Lipoly packs-HOW HOT?
  102. NI-MH shelf life?
  103. Adding Lithium to a NiMh RTF
  104. 5 amps into an 8 cell 2150 mah nicad?
  105. Is there an adapter to plug your hobbico charger into the wall
  106. Will hitec male fit into futaba female (for charging)
  107. Speed control with cutoff for lithium
  108. Which Lipos for GP Headwind B
  109. HOW TO BULILD LIPOLY PACKS
  110. PF-12 wattage peak charger question
  111. Charger Question
  112. how many years will take to charge
  113. Apache 1500 Charger
  114. LiPo Question.....
  115. Weher can I get the cheap chargers?
  116. Batteries for Brushless
  117. NiMh Charging question
  118. Ericson T28 lipos
  119. Winter Flying with Lithium Packs
  120. Sky Scooter Pro 2 battery
  121. Best charger for LiPo 14.8 Volt packs?
  122. quick motor/battery question
  123. car packs in airplanes
  124. 12 Volt Power Supply
  125. Anyone try these yet?
  126. 50Amp - Any Li-Po can support?
  127. Battery or charger problem!!!!!
  128. SuperBrain969, how to charge new NiMH?
  129. Which Lipos for New GP DC-3?
  130. Radio Shack1-C3 NiMh
  131. Laptop batteries
  132. Best Lipo Choice
  133. Nicad info
  134. plug for my 8.4V battery to charger?
  135. pro peak mecury ex
  136. Help! Is there something wrong with my battery?
  137. another newbies battery/charger question.
  138. Is my charger the problem?
  139. prices for nimh 3300 packs
  140. Esc for lithium ion battery???
  141. What Li-Polys do I need?
  142. hobbico mkII and li-poly?
  143. What charger do you suggest?
  144. MRC 959 Charge AA?
  145. best batteries for increasing flight duration on superstar ep
  146. Etec 1200mah 3s charging
  147. BEST LI POLY SETUP FOR 3D PLANE
  148. What to do?
  149. Live Wire..what lipo's?
  150. GWS ME109 BATTERY RECCOMENDATION?
  151. Johnson Motors
  152. how do I set my TRITON to charge a 11.1v 700mah lipo?
  153. Can I use this for nihm cells?
  154. what do I need
  155. Excellent Service Story !
  156. Laptop batteries
  157. best charger for the $$
  158. lithium charging question.
  159. Li_po's what do I need to get started?
  160. Battery Question
  161. new elect. guy question
  162. FMA any good
  163. MOVED: Brushless slow stick???
  164. 7cell 8.4v nicad peak question
  165. yet another li-poly question
  166. Static Thrust on AXI 2212/26
  167. Poly vs. Nimhs in 6 lb plane
  168. Charging New Nicds- overnight?
  169. 2P pack
  170. Lipo Question #6,248
  171. 4 motors,1 speed control ?possible?
  172. Will this combo work?
  173. Triton, Super Brain 969 for Li-Poly
  174. Speed control cut out question.
  175. Other sources of Lithium
  176. NiMH Battery problem
  177. High Voltage Hot Rodding
  178. Kokams from your local hobby shop!
  179. Li po and amprage
  180. What kind of power source to use for peak charger?
  181. Triron charger
  182. LiPo charger
  183. LiPo Question with Aveox Setup
  184. LiPo for Cobalt 400
  185. Another li-poly question
  186. Best 6 cell 7.2V for Sky Surfer
  187. simple lipo question
  188. Lipo's for new Pigi plane?
  189. charge rates
  190. GWS Formosa..What size Lithium Battery??
  191. New Nimh Battery Pack
  192. Simple 6/7-cell field charger?
  193. battery compatability
  194. Li poly Question
  195. MRC 959 Superbrain
  196. Astro Flight Model 109
  197. Batteries ....Please Help
  198. The MAGIC BATTERY
  199. 6000 mah 3 cell lipoly
  200. is there one charger that will do it all???
  201. Twin wiring
  202. pico-stick battery pack alternative
  203. lipo for 12 amps?
  204. GWS E-Starter Power Upgrade?
  205. battery pack for pico stick
  206. Charge Shelf Life
  207. Li-Poly safe?
  208. How many cells are best for 7.2v
  209. GWS Battery Packs and Charging
  210. etec 2cell 1200 enough for a 300 with d drive
  211. Lithium Memory?
  212. Hobbico Mk 11 charger on Li Po
  213. Help with Triton Charger and 110mAh NiCd
  214. Which Hacker?
  215. Which Li-polys for T3D II Wild Beast?
  216. Li-poly/ Li-ion
  217. Confused
  218. Is my Nicad charger going to work
  219. wattage cobalt motors vs speed 400
  220. 3s LiPo with EDF-55 twin?
  221. Li-ion Camera Battery
  222. which Li-Poly pack to replace 16 cell Sub C
  223. HRSC2600 vs GP3300 vs 2400 SCR
  224. Buying Lipoly
  225. Building Battery Packs
  226. Kokam "Safety Guard" Battery Safety Unit
  227. Battery Recommendation for T-33
  228. PRODUCT HAZARD ALERT
  229. Building a Kokam "Super Pack"
  230. 7.2 volt charger
  231. Li Poly Recommendation
  232. LiPo Cell Bursts into Flames on Video
  233. Li-Po Max
  234. New AstroFlight LiPoly Charger
  235. Got Kokams?
  236. Li-Poly charger
  237. mismatching cell capacities
  238. Charging Li-Poly pcks in parallel
  239. Lithium Polymer History Brief
  240. since i can't find a razor...what do i get?
  241. Solar Power
  242. Battery Pack for the Cox J3 Spectra
  243. Charging Lithopoly on the super brain 969
  244. NiMh first charge
  245. Independent LiPoly measurements
  246. Temp. of pack after flight
  247. connection
  248. LI-PO - Brushless Configuration?
  249. Battery Recommendation for Cap 232?
  250. i need info strong sail plane batteries
