PDA
View Full Version : E-Flight Power Sources
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12
  1. lipo's not upto scratch ( or im doing something wrong?)
  2. Battery And Charger Combo I Really Really Need Help
  3. Speed 400 connector problems
  4. GT Power A8 Charger from HK
  5. I tested the Polyquest 45C discharge Lipos
  6. need a charger for Parkzone 8.4 600mah battery
  7. Charging plug issue
  8. C rating with parallel packs
  9. zippy batteries and what kind of charger to use?
  10. F-27C Battery Options ?
  11. New batteries
  12. Hobbyking Replacement for Jeti Phasor 30-3
  13. Need Help Please!! RTF LI-POLY question
  14. Advice for LiPo charger
  15. Battery won't balance?
  16. Voltage cut off?
  17. watt meters
  18. Battery Charging Question
  19. Blade MSR battery connector
  20. 45c thunder power batts!!!
  21. Li-Po puffing Why?
  22. Li-poly short circuit
  23. Digital cell diagnostics ??
  24. Dynamite Passport LiPo 6S Charger
  25. Eflite 60 Amp Brushless esc
  26. GWS FW-190 power
  27. How many volt's in a 11 volt pack?
  28. EC3 connector from Hobbyking
  29. Can I use a 20C battery?
  30. Mixing Used Lipo pack with new pack?
  31. Need equipment to do a formation charge on 12V lead acid batteries
  32. Max Thrust at 40 ampers
  33. charger 4 cycling transmitter batteries
  34. lipo safety question
  35. 4s pak 1 dead cell?
  36. Battery Selection
  37. LiPo Help
  38. Salvaging/Balancing NiMH Pack
  39. E-Flight POWER60
  40. Thunder Power 6 cell battery
  41. New to Lipos!! Need help trying to charge battery pack.
  42. NEW Batteries: SILVER-ZINK; Outstanding !
  43. Turnigy equivalent for a E-Flight Park 480?
  44. standardized BAT connectors?!
  45. charging raido lipo battery
  46. Charger and Bat
  47. Accucel-6 LiPo balance mode error?
  48. MOTORS AND BATTERY
  49. battery for trainer
  50. HobbyKing Lipo Battery for Parkzone Ultra Micro Mustang
  51. Need close up pic of Park 250 outrunner back side
  52. Newbie about batteries.
  53. Battery basic question.
  54. LIPO BATTS AND COLD TEMPS?
  55. Wiring in LiPo's in series to get bigger packs
  56. Capacity vs Voltage curves for lipos
  57. under load drop
  58. 3.7 Li-Poly pack warning!!!
  59. Question on Lipo pack
  60. use automotive charger as power supply?
  61. Deleted
  62. Seperate battery for receiver & Servos
  63. E-flight-A-T6 texan -need battery -
  64. Learning about these batteries
  65. Accu-Cycle Elite for a new ElectriFly Triton2 EQ
  66. Thunder AC6 Smart LiPo Balance Charger
  67. new venom lipos any good ?
  68. Help needed with E- Conversion motor/battery/prop choice
  69. phoenix ice bec
  70. 2 brushless motor wiring?
  71. Lipo 3s minimum voltage
  72. Replacement 64-65mm power unit?
  73. Opening up LiPo packs ?
  74. EFlite Power 110 Problem
  75. Motor quality vs price
  76. Equivalent brushless motors
  77. Turnigy Lipos
  78. Has someone tried Rimfire 300 28-22-1380 on 2S and 8x3.8 apc
  79. Recommend a battery for this motor/esc combo???
  80. Will too much "C" rating fry brushless mtr.
  81. Triton2 overkill?
  82. dead lipo recharge
  83. lipo size for setup
  84. lipo size for electric setup
  85. Turnigy 5000mah 3 cell 25C lipos
  86. Puffed Cell
  87. Li-Po Storage
  88. E-Flite 3S Balancing Li-Po Charger HELP
  89. Parkzone Battery and Charger
  90. Charging NiCD using NiMH Charger
  91. Is this system capable of a reasonable climb rate ?
  92. STOBA - Cure for LIPO Safety Issues?
  93. E motor class ID
  94. XPS Lipos
  95. Whart discharge rate battery?
  96. Need help with watt meter reading
  97. Who sells a good 2100 pack nowadays?
  98. Green Power Lipos from HobbyPartz and a couple of questions
  99. E-Flight Apprentice motor
  100. Any way to tell?
  101. Inside a Lipo
  102. 30 Amp pro ESC
  103. balancing jacks
  104. New problem all power lost
  105. E-Flite ESC Link
  106. hyperion vs thunder power
  107. My First power system fails No clue Help!
  108. LiPo idiosyncracies
  109. Prop for SmoothE?
  110. Turnigy K-Force ESC's - headsup
  111. E-Flite 1-5 Cell Li-Po Charger - Wall charger available?
  112. Prop for Power 46 on 5 cells
  113. Need a new and good Lipo charger
  114. Charging a NiMH battery
  115. Turnigy ESC Issues
  116. which battery
  117. Thunder Power 1010C
  118. E-Flite battery pack... won't charge!
  119. E-Flight Balance Charger plug issue/ Need JST
  120. HobbyKing battery problem????
  121. Lipo Battery dead? or something else?
  122. E-flite Intelligent balancing charger??
  123. E-flite celectra charger & Astro flight blinky
  124. Charging Li-Po Batteries Question
  125. Dumb Dumb DUMB thing I did...
  126. Twin motor sizing
  127. Help, newbie needs Hacker Info .
  128. Lipo bat- 3S vs 3S1P
  129. Looks like Flightpower is OUT OF BUSINESS!!! Or at least heading that way..
  130. SuperStar BL Conversion
  131. hobby king questions
  132. My new power system ?
  133. NI-MH oddness
  134. Getting started in Electric which charger should I buy
  135. after flying confusion with lipo volts
  136. Series connector sparking
  137. Battery and Charger Help
  138. Lipo recharging statistics
  139. Do I have a problem,
  140. E-Flight battery not charging.
  141. Battery plug preferences
  142. How to determine prop size
  143. Leaking LiPO
  144. hyperion 50a...v3.1w
  145. Smoke is bad
  146. Hi ! is my new battery FUBAR?
  147. replacing bad cell
  148. Additional help with brake on 20 amp ESC.
  149. lipo safety-Thunder power 11.12100
  150. 2 Brushless motors for 1 ESC?!?
  151. Right Lipo for a little oomph?
  152. Prop Mount Problem
  153. What do I use for Rx battery?
  154. How puffed is "puffed" ?
  155. What to do with trashed lipos?
  156. Lipo balancer question
  157. Charging Gel batteries in an Ultra E-Box
  158. NEW BATTERY COMPANY
  159. A123cells
  160. Need some new lipos
  161. Charger Behavior Question
  162. LIPO charging question
  163. Qestion about battery and charger
  164. Lipo Batteries From SkysharkRC
  165. 12V charger for 9.6V battery?
  166. ESC, Glitching and Crash
  167. Blinky & Blinky adaptor for Thunder power
  168. 12-VDC 10 A power supply for home use
  169. Discharging Lipo Packs
  170. How manyy amps am I pulling?
  171. UK 12V PSU for Hobbico Quick Field DC Charger MkII
  172. Value hobby G force LiPos
  173. LiPo Battery Sources
  174. Electric newbi questions
  175. ZTS Pulse Load Battery Testing
  176. 6S3P
  177. Balancing Leads
  178. Li Po batteries which are better
  179. E- power lipo question
  180. E- power lipo question
  181. Elite Battery Cells
  182. Looking for cheap 3000mah lipos NOT from Hobbyking
  183. 12v vs 15v 1A vs50MA
  184. Li po's with a Promax brushed motor
  185. mini ultra stick pnp
  186. Parkzone T-28 motor?
  187. need help for a123 battery THANKS
  188. Charging Guide
  189. ZIPPY AND RHINO LIPO's
  190. Over Charged LIPOs?
  191. Impulse Battery Balancing
  192. Yet another parallel lipo question
  193. mrc 969 charger
  194. E-flight 11.1V & Electrifly Equinox adapter?
  195. General question about LiPo charging
  196. 2200mah 11.1 V battery too much for 25amp ESC
  197. Fire box for Lipo's
  198. Charging four separate cells with EK2-0852 and general balanced charging question
  199. ?????
  200. parallel lipo's
  201. What is the best way to attach the battery to a foamie plane?
  202. Linkman Charger
  203. BANTAM or HYPERION help me decide
  204. Largest brushess motors
  205. charging lipos with accucycle elite
  206. Need outrunner equal to a .60-.75 glow
  207. Feasible conversion or Not?
  208. Rebuilding paks
  209. Thunder Power Question
  210. Rhino Lithium Batteries
  211. can I run two chargers off an 18amp power supply?
  212. What effect does running different size ESC have on the motor
  213. old flight power lipo bal lead quest.
  214. HELP !!
  215. Soldering Deans
  216. another parallel lipo question
  217. Electrifly charger!
  218. Question on my charger?
  219. lipo mAh question!
  220. trak power v-balance not working
  221. Proper charge/discharge of cells
  222. need help w/eflight 505 charger
  223. Breaking in lipo's
  224. Hobbycity.com Zippy Lipo Batteries
  225. BATTERIE exceed FOR F-35 Radio Remote
  226. PULSE XT CONVERSION?
  227. 30C Thunder Power Lipoly cells
  228. can i change lipo balancing taps?
  229. Low voltage on LiPloy pack
  230. FMA Cellpro 10S charger
  231. Charging lipo in serial
  232. NIMH Battery Questions
  233. Charging Lipo lower rate.
  234. hobby city battery
  235. sensored motors..
  236. Any experience out there with Neu Energy Packs?
  237. Lipos won't charge
  238. APACHE SM2500 CONNECTORS SOLUTION
  239. S-60 servo issue
  240. TP610 C pack balancing
  241. which charger need help in choosing
  242. Best DC Car Charger for GWS 7.4v 1300 mah lipo?
  243. Step-up transformer for electric power
  244. Looking for 4s 2000-2200mah 15c lipo, Any idea ?
  245. Please help ESC/motor problem
  246. Max Lipo Temps
  247. PLEASE HELP! ac lipo charger connection
  248. ESC Coil
  249. The eternal charger question
  250. Rascal 110 &160 Eflite Power System
