PDA
View Full Version : E-Flight Power Sources
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12
  1. Recharging LiPo battery
  2. Megapower charger won't charge.
  3. THE BEST BATTERY CHARGER
  4. Walkera HM 5#10 3.7V 1000ma Lipo Charge
  5. E-flite rtf stock charger..question!
  6. Extending Battery Life
  7. Would you risk it with this li-po?
  8. Disposing of damaged lipo batteries
  9. pack without balance tab, can i install one?
  10. Brushless Help
  11. 2 cell Vs 3 cell
  12. COLD STORAGE OF LIPO BATTERIES ??
  13. NI-MH BATTERY SIZE? WHAT CAN I RUN
  14. My LiPos don't preform like new?
  15. prodigy 2 charger with equinox
  16. Lipo charging question flightpower
  17. Equinox Lipo Cell Balancer
  18. Need 3.7 V Single Cell LiPo Now
  19. The magic 3v
  20. Charger Adapter Cable
  21. input charge voltage for 2 cell
  22. ZIPPY battery balance Question
  23. E-Flite Power 110/CC Phonix HV-85
  24. GP Reactor Bipe power setup question?
  25. Have I got it right?
  26. Park Zone...A Products Liability Case in the Making?
  27. Damaged Deans Plugs Lower Performance?
  28. 2cell Li-pi question and BC-6 charger
  29. Need advice on buying charger
  30. Has ayone recently purchased a Hyperion 0606i charger?
  31. Alright, this whole lipo thing confuses me...help!
  32. Need info on elect power for sundowner in USRA
  33. Re-soldering balance leads onto lipos
  34. Is my ThunderPower 1350mah dead?
  35. thread size for Rimfire prop adaptor
  36. hyperion balance charger/dynam lipo's balance leads????
  37. Battery Recall
  38. Calculating Flight Times??
  39. lipo packs & prop selection
  40. Totally corn-fused
  41. Where to get batteries?
  42. 1500mAh LiPo for CX-2
  43. LiPo Balanced Question
  44. Stupid battery question's
  45. Thanks to Parkzone!!!
  46. Power Switch
  47. best way to balance lipos
  48. Balance tolerance
  49. What should Cell voltage be???
  50. li-po newbie, how do i charge this thing?
  51. E-flite EFLC505 Intelligent Lithium Balancing Charger Problem.
  52. SuperBrain 977 Charger and 8+ NiMH?
  53. Batteries in series
  54. Lipo Charging Problem Question
  55. broken balancing wire on 3s lipo
  56. Is My Battery Pack Toast ????
  57. How Do You Check MAH On A Lipo ?
  58. Lots of questions
  59. new hyperion 6060i charger i am scared!!
  60. Question about battery and ESC matching
  61. keep lipos in???????
  62. Charge adapter for WOW-RC charger/Thunder Power LiPo
  63. ????astro blinky????
  64. PKZ 1800 MaH Puffy.
  65. lipo discharge ?
  66. HELP! Best Lipo charger for about $100.00
  67. ThunderPower 3S2P 11.1v 4000 mah question
  68. Where can I find a technical article on RC LiPos?
  69. Ideas for providing charging power at the field?
  70. Charger Question
  71. Lipo Battery Question????????
  72. Help with IMAX B5!
  73. Lipo Charger
  74. Turnigy 35-30C....
  75. what amps to charge at
  76. puffy li-ion packs
  77. Charging and using my lipo
  78. Smashed li-po
  79. will this setup work?
  80. Charge and Discharge rates
  81. Hyperion EOS 0610i Net opinions
  82. triton jr charger nicad li pol
  83. VSport Brushless Motors
  84. Quick Cooling Li-Po's
  85. Too many motors!
  86. Tower Pro 20A ESC problem
  87. Twin motors and one ESC?
  88. ESC and battery question for the wise
  89. A quicklipo Question
  90. Chargers that plug in wall outlet for LiPo & NiMH, NiCD
  91. Am I hitting Low Voltage Cutoff? Why?
  92. Hyperion LBA6
  93. Great Planes ElectriCub AXI Motor?
  94. Which LiPo and which charger?
  95. Anybody Using These New LiPo Battery Packs Yet?
  96. Brand new 25A pro brushless catches fire?
  97. BM2408-21 and Slow Stick
  98. Exceed RC Fusion Power Series Experience/Data?
  99. LiPo noob question
  100. park 450 vs 480 for Gp Yak 10 size
  101. new battery type?
  102. Thunder Power Balance Plug
  103. Charge through discharge
  104. Max Amps or Thunder Power Question
  105. Lipo storage container - ammo box?
  106. connecting lipos
  107. Help! Li-Po Balance Plug Wiring
  108. Connecting lithium polymer cells in parallel
  109. Wire size ?
  110. ultra noob question-dont laugh
  111. Lipo SAFTY _WHAT ARE THE KEY POINTS
  112. Set Up Help
  113. lipo charger
  114. Stupid Question
  115. SJ Propo Brushless Motors
  116. E-Flite 25 amp esc, Park 450 outrunner & JR610UL reciever problemsin>
  117. Problem selecting a Motor
  118. New Thunder Power battery
  119. Why do I keep burning ECS???
  120. Do I have a bad charger??
  121. Rebuild a pack?
  122. How do you compare motors??
  123. Thunder Power balancing tabs
  124. A123 Racing $15.00 and 15% discounts on Batteries and Chargers
  125. Hyperion Lipos?
  126. Electric Newbie - Need Help PLEASE
  127. ESC to Rimfire adapters
  128. 3 or 4 cell ?
  129. How To Solder Aluminum
  130. How Many Times Do You Condition Cycle Your New Expensive LiPo?
  131. Package setup for 3d profile plane.
  132. NiMH Charge ?
  133. Can I use a 4S1P in my NexStar EP?
  134. Motor sizing high KV rating set for low rpm or low KV run at higher rpm setting
  135. Overheating battery
  136. Charer question
  137. How not to treat a customer
  138. FlightPower Evo Lite 2500mah 11.1 v
  139. DEWALT now $166 or $ 144 from DEWALT ?
  140. Glo to electric question
  141. Searching hard.... charger to batt connection
  142. Need some advice on a Lipo
  143. I need to built a lipo batery pack
  144. LiPo Pack for E-Flite At-6 Texan w/Power 32 Motor
  145. LiPo Battery for High Performance E-Flite AT-6 Texan?
  146. Battery charger on car battery
  147. Motor for 40oz 3D plane?
  148. Do I need to balance
  149. charger option?
  150. lipo charge question
  151. Does Size Matter ?
  152. Charger Problems and battery type help please
  153. 11.1 thunder cat lipoLipo
  154. Another Lipo question.....
  155. nimh equivalent to lipo
  156. sfe to change leads on lipo?
  157. Lipo and fire? Should I quit already?
  158. FlightPower EVO 25 1800 3S 11.1v 25-40C
  159. Custom Low Battery Alarm
  160. need to know input
  161. lipo for reciever and servos
  162. On a budget need a lipo balancer / charger
  163. 8.4 7 cell 2600 mah AA humpack
  164. electric plane Questions
  165. Blade CPP battery question...
  166. LiPo, Charger, Balancer...please help
  167. HELP!!! Can I get some feedback on a LiPo given to me?
  168. ElectrifiedTrying to find planes
  169. Thunder Power converter to JST-XH ?
  170. FRESH START
  171. parkzone 8.4 battery problem ? or is it ?
  172. Charger Reccomendation
  173. Building Lipo Packs
  174. keeping lipos safe
  175. E-Flite Power System...Motor Sputter Prob.
  176. Help..... Do TP packs have the same mAh regardless of the rate you discharge?
  177. esc to motor connectors
  178. Pulling my hair out
  179. tenergy?
  180. lipo success report
  181. bloated lipo
  182. a lot of experimenting
  183. best brands of li po batteries
  184. battery weight?
  185. use blade cx2 charger for other batts?
  186. (Frustrated with ESC or AXI motor
  187. Need Help with Multiplex charger
  188. Pieces needed to complete a conversion
  189. battery chargers with balancers
  190. Cant figure out the C thing
  191. What is the smallest LiPo battery pack available?
  192. Settings for LiPo Battery on an Accu-Cycle Elite?
  193. Conversion to electric with E-Flite
  194. Goofy questions
  195. Help! - Need IC part number for Handy 2 charger
  196. Some basic new lipo questions
  197. how to choose lipo vs. NiMH
  198. EFlight Extra 260 Help
  199. battery maintenance question?
  200. Ordering LiPo's
  201. Lithium Magnum Batteries
  202. 12volt dc car battery charging at field
  203. How good is this battery?
  204. E-Flite 400BL, 20ESC & 20C Lipo Is It OK?
  205. Cellpro 4s to hexTronik Lipo
  206. Hobbico Electric Motor
  207. Fromeco Ion Cube Help
  208. Great source for Li-po and Ni-Cad Batteries!
  209. EMAN EX-RCLP208 Charger
  210. SPEKTRUM DX7--HELP!!!
  211. lipo with great planes mini slinger
  212. Cell Pro 4-S Charger --- I Need Help !!!!
  213. Charger Anyone?
  214. How to breakin a new battery pack?
  215. Lipo storage question
  216. NiMH battery care - Aerobird Challenger charger
  217. Make my own lipo packs?
  218. GP Lancair EP Brushless??
  219. Charger Question ?
  220. need an all-in-one charger-recommendations?
  221. Discussion - Forget the graphs - Best "value" lipos poll!
  222. T-601 is most equivalent to which inrunner BL motor?
  223. Continuous and burst current draw specification
  224. Evo packs 29-31 charges gone bad ?
  225. balancing adapter
  226. New E flier needs Lipo and charger advice
  227. miniature nicad for 12" foam J3 Cub
  228. Current draw of 550 size motor???
  229. Can you turn a 3 cell TP into a 2 cell?
  230. MiniMag with Himex HC2815-2000 motor question
  231. Can I use this battery?
  232. Motrolfly USA POWER PACKAGES
  233. Connecting in Parallel and Series questions
  234. Eflite Power 160 motor
  235. adding balance connectors
  236. Using Eflight charger on larger battery?
  237. HIMH and Nicad same size
  238. What are they talking about: connector?
  239. A123 charges, motors and ESC?
  240. 3e Lipos any good?
  241. NIMH chargables store type
  242. LiPo Balancing Terminal Pin Spacing- Question
  243. Lipo 10c battery question
  244. eflite 10 motor
  245. electrifly balanced li pos?
  246. Can a Trinton 2 charger ballence lipos
  247. Brush motor as a generator?
  248. Battery for Trex 600
  249. LiFePo123
  250. bc-6 or the hyperion EOS1210I
