PDA
View Full Version : E-Flight Power Sources
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12
  1. nimh voltage
  2. storing li-poly's??
  3. Wire size on GWS LiPo pack
  4. How long to recharge Lipo's?
  5. AT-6 Electric-- need batteries and chargers
  6. Here is a good source for Lipo packs
  7. Charging over 1C???
  8. Got my first swollen LiPo today...
  9. recovering lipos
  10. Lipo Cutoff Voltage and slow charging?
  11. balancer
  12. Newbie to Lipos. How do I use a Polycharge w/balancing Lipo?
  13. Integy 2500mah battery
  14. Battery pack testing
  15. help locating a nimh battery pack
  16. HELP!!!!!!!!!
  17. 29.6V--11000 mAh Paintball Bomber using a E-flite 60
  18. Guillows 16" F6F
  19. what the heck is going on....
  20. Is there a limit to how fast a lipo can be charged?
  21. questions about charging NiMH
  22. LiPo replacement balancer leads
  23. Lipoly or NiMH
  24. Slight over-discharge - Beeping charger! help
  25. 1800 mah NiMH troubles
  26. Need help wiring power supply
  27. New Lipo
  28. Balancing without a balancer
  29. E-FLIte LI-POS =THUNDER POWER PACKS????
  30. Lithium Chargers question. Not usual questions
  31. LiPO conversions
  32. A123 Systems batteries
  33. Astroflight Wattmeter
  34. My crashed plane and battery
  35. Draganfly, anybody buy from them?
  36. How do I cut this open?
  37. Tiger Power 3s 1500mah
  38. Battery Run Time?
  39. Lipo's current/question
  40. Fast Lipos
  41. What nimh is = to a 3s 3200 mah lipo?
  42. NiMH Cell Size
  43. 12 Volt Power Source (battery) for My Celectra LiPo Charger
  44. Hitec Neon Charger
  45. Charging LiPO's with Charge Protection Circuitry built-in
  46. Lower price on Thunder Power parallel packs
  47. AWESOME- Found Source for NEW a123 Lipo Nano Chemistry Batteries
  48. Triton charger
  49. Charge & Discharge leads
  50. Charging NiMH packs with wal wart?
  51. Dont make my MISTAKE!
  52. AWESOME -Src for New A123 Lipo found
  53. Lipo Sacks safer way to charge your lipo's
  54. Batteries/power
  55. what LiPo is best
  56. LiPo solder tabs breaking
  57. 12.21v max from new 910mah normal?
  58. Anyone make a 3s 1800mah 4oz lipo?
  59. Lipo Do's and Don'ts
  60. Charging a Lipo..
  61. Newbie needs some help:-))))
  62. Is balancing really necessary?
  63. Nimh Maintenance
  64. Cell imbalance on new pack
  65. Lipo Saftey - Reminder
  66. New to Li-Pos..quick question.
  67. Which setting to charge a lipo at?
  68. Thunder power charger and deans connector problem
  69. Outrunner motor comparisons ID's
  70. MY BALANCE PRO PROBLEMS
  71. Weight issues???
  72. PQ 2s-4s PCM Guard
  73. Thunder Power batteries in Europe
  74. Lipo short cut, useable?
  75. 540 brushed to brushless
  76. HECells any comments
  77. Good Lipo Charger Plz!
  78. Faulty Lipo's?
  79. Free Freight on Thunder Power/Poly Rc and more
  80. Supernova 250 Charging 3300 NiMH
  81. triton charger on sale at tower hobbies
  82. how to wire batteries in series or parallel?
  83. Ebay LI-PO's
  84. 7 Cell NIMH to LiPoly
  85. E-Moli Li-Ion Batteries IMR26700
  86. Noob question about cut out problem?
  87. Running 9 21003s/20c packs in "3p3s"? Heard it cannot/should not be done?
  88. Help for a newbie wanting to modify
  89. Sig Kadet EP
  90. lipo awg leads for Blade CP
  91. ACE2521 Super Digipulse programming
  92. NiMH battery pack & speed 700 motor
  93. balancer??
  94. Kokam and FMA?
  95. Questions from Lipo Newbee
  96. GP ElectiFly Lipos and Charger Problem?
  97. advise or hooking up batteries in series
  98. What power supply for celectra charger
  99. Major flight time problems
  100. Li-Po life span
  101. Li-Po with 280 Brushed Motor??
  102. 900 mah too much?
  103. What capacities do you favor?
  104. Apache 2020 and Electrifly Safe Charge pack.
  105. Help with cycling
  106. 12 volt charge?
  107. Funtana 90 Lipo failure
  108. LiPo charge wires
  109. battery charge error - any advice?
  110. Best balancer charger?
  111. what 's safe to do..lipo?
  112. Li-po balancing adapter wires
  113. Multiplex Magister Power combo question
  114. Lowest volt per cell lipo?
  115. triton won't charge
  116. What do you think of this charger
  117. Milwaukee Li-Po Packs
  118. Is it the motor, esc, or batts?
  119. Adding A Balancing Plug To A 3 Cell Lipo
  120. Using The AstroFlight "Blinky" To Balance Packs, Common Sense Lipos, etc.
  121. Apex Lipoly batteries superior?
  122. Typhoon 3d Li Po connection
  123. Old cell phone batteries?
  124. E-flight 370 outrunner problem.
  125. Battery Issue or Plane? - Aerobird Challenger
  126. esc, charger,battery recommendation
  127. Li-poly waterlogged
  128. lipo qeustion
  129. Li-Poly 3S or 4S poll?
  130. Which Li-Poly Brand????
  131. Who is FMA
  132. FIELD BATTERY QUESTION
  133. charger question
  134. lipo discharge cable?
  135. Programming an ESC for Lipos
  136. Connectors on the Multiplex BL-480/4G?
  137. using balancer when charging
  138. speed control Question
  139. 7.2 or 11.1 whats better
  140. Poly Quest Lipos...Any good?
  141. Maximum mAH on BP-21
  142. How long will it fly??
  143. POWER SUPPLYS
  144. Stupid question, I'm sure.
  145. why the flux rings
  146. When Good outrunners Go BAD! PLEASE HEPL!
  147. When Good outrunners Go BAD! PLEASE HEPL!
  148. How many chargers on a car battery?
  149. CBM A-10
  150. Will this destroy an esc or just the battery
  151. Parkzone Typhoon Li-Po and ESC Question
  152. storing lipos?
  153. did i kill it?
  154. NiMH/NiCd to LiPo/LiIon charger adaptor
  155. Which Battery to Use?
  156. Charging NiMh xmitter battery
  157. Parelling lipo pack
  158. Pure Hobby Combo Price on TP-1010C & Balancer
  159. wire connectors/wire size
  160. Outrunner v. Inrunner Motor
  161. Watt's Up Meter before or after ESC?
  162. Duplcate
  163. Aveox ESC/LiPos
  164. The Perfect Charger
  165. What battery speed controller do I need ?
  166. Li Po charging HELP!
  167. Anyone able to convert a 3S1P to a 2S1P?
  168. new battery technology
  169. Disposing of lipos?
  170. Battery Help please
  171. can i use this for measuring the amp draw?
  172. Hot LiPo, hot Brushed motor?
  173. lipo dead????
  174. Lipo size ...
  175. Possible to run 11.1v Lipo on speed 480?? (7.4)
  176. Do people just not know how to use LiPos?
  177. lipos with brushed motors
  178. My battery, is it NiCad or NiMH?
  179. Balancer, How important??
  180. CHARGERS???
  181. Cheap lipo's
  182. Battery for a Cobalt 40 Geared Motor
  183. 3S, 1500 Lipos on Sale FMA Direct
  184. Wrong setting- not enought power
  185. Li poly tests
  186. 7.4v LiPo discharged to 2 volts. What Next?
  187. X-peak 3 problem?
  188. lipo charging/discharging??
  189. Questions in charging Li-Poly battery and setup?
  190. TP 1320 Leak
  191. 8C,10C,15C...which do I choose
  192. TP Pro lite 4S2BP, 64 amp discharge?
  193. Power Conversions -- Motor to Battery
  194. Charging Advice needed for various cell types.
  195. Different out puts for AC-dc chargers
  196. Help - Need info on charge rate NiCds
  197. 8 cell pack, charger only charging for 7
  198. eflight park 400 brushless motor rotor replacement help please
  199. TP li-po ?
  200. How many charger's on one 12V Battery?
  201. reciver battery...
  202. Need advice -- Jeti 15/4 with Extreme Flight Extra 300?
  203. Charging a Lipo Twice?
  204. Field "boosting" a charged battery.
  205. Charging and set up question for park flier!
  206. Question about parallel Lipo packs, and charging
  207. My new lipo, and my new esc, did it cause damage??
  208. LVC on a pico round 480 esc
  209. Hobby Lobby series module
  210. TP 2100mah and SuperBrain 977...
  211. Lipo Charger Suggestions?
  212. What Batteries?
  213. LIPO power dilema
  214. PolyQuest Lipo blowout
  215. Dead LiPo?
  216. LiPo question
  217. Falcon batteries and balancing
  218. whats a better power source for field use
  219. TP 3C 1320mah discontinued?
  220. thunder power 2100
  221. lipos getting fat!
  222. Charging Cellpro packs?
  223. IMPULSE-ive Marketing
  224. Damn lipos
  225. peak chargers ,whats going on
  226. HELP
  227. new li-poly charger/balancer on the market ?
  228. power loss in lipo
  229. Lipos with Axi 2808/20 Castle Phoenix 35 ESC
  230. Charging Li-Poly’s safely
  231. Charging lipos at 500 or 750 mah?
  232. e-flight 450 bl
  233. Lipos, what to do?
  234. Need charger recommendation
  235. Should Nimh batteries be stored charged or discharged ?
  236. Lipos
  237. Is this a good power supply for charging at home?
  238. JR 700Mah 4.8v Receiver battery
  239. New lipos
  240. Horsefly Help
  241. need advice
  242. hobby-lobby power supply unit
  243. Lipo Shorted out
  244. Typhoon 6 3D
  245. Motor speeds up and slows down with 1 particular Batt
  246. Thunder Power TP-205 Balancer
  247. 5volts to 3 volts: need resistor?
  248. LiPo Charger help
  249. Help
  250. Power Supply For Charging At Home??
