PDA
View Full Version : E-Flight Power Sources
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12
  1. park 370 eflm1205 on 3 lo pos
  2. what is it a Nimh or Nicad
  3. Watt Meter Connection?
  4. Time to go brushless...
  5. E-Flight outrunner 400vs PJS-3d-550 ?
  6. LiPo Cell Balancer Confusion!
  7. truerc.com 99 amp lipo
  8. Thunder Power Li-Po charger ?
  9. How do you calculate amps drawn?
  10. **New GWS brushless motors**
  11. Thunder Power balancing?
  12. Li-Po voltage charging question?
  13. E-flite ESC/Motor Question
  14. Balancing
  15. Combat models A-10 Warthog
  16. help on lipo battery please.. adapting balancers
  17. Li-Pos
  18. Cell Balancers - How Important?
  19. Very Quick Lipo Question
  20. Lipo for Yak 55 EP 3D ARF by great planes?
  21. Pixie 20P LVC with a 3 cell Li-Po
  22. motor bogs after 3-4 seconds
  23. battery not charging - please help
  24. FEW QUESTIONS...
  25. deleted
  26. charging balanced li-po packs
  27. Announcing MicroPower e-flight recorder - only $69.99!
  28. Thunder Power Li-Po question
  29. This LiPo Safe To Use?
  30. Are ESC,s alike on top end output?
  31. the 60 bl outrunner
  32. Li-Po Battery
  33. Li-Po safety
  34. want to go to Li-Po
  35. Ncmh Battery.....is this a normal thing?
  36. Hyperion LiPo
  37. new Nimh pack Ist cycle
  38. LiPo 3S1P battery for 3DFoamy ??
  39. connector module in series question
  40. Astro geared or not to be geared
  41. Thunder Power Production Dates???
  42. Where do you buy your lipo packs?
  43. Output of TP 3S1P 730mah?????
  44. Ebay 3cell 3500mah lipo? Any comments?
  45. Hobbico Quick Field Charger MkII: Is it REALLY for Lipo's??
  46. new power conectors
  47. thunderpower charger short!
  48. NiMH and NiCd in a same pack
  49. Parallel charging NiMH
  50. Polyquest charge connector?
  51. Which to choose? LiPo battery and charger questions
  52. New Power System
  53. lipo caution???
  54. Polycharge ???
  55. 60amp ESC $50!!!
  56. diversity calc question
  57. Which Charger?
  58. Li-po first use?
  59. Are these two interchangable???
  60. LiPo reduced capacities
  61. What Kind of Ni-Mh Battery?
  62. Custom JR Transmitter Battery Pack?
  63. Charging Li-pos in parellel, Help Needed!
  64. Anyone heard of ABF LiPo's?
  65. Apogee batt connectors ...
  66. MM Magpie + Lipo
  67. need info for batt's and esc
  68. spitfire may need change,motor
  69. Connectors
  70. Very Confused- Lipo questions
  71. noob with a question on motor selection
  72. shouldnt solder Nicads Vrs nimh
  73. Li-Poly Pack construction materials
  74. 370 outrunner problem
  75. Lipo Storage 40% state-of-charge.
  76. battery takes wayyyyy to long to charge
  77. 10 minutes to 90% charge??!!!???
  78. new charger settings need help?
  79. AC powered Li-Po charger?
  80. Newbie question: LiPo - Voltage Cutoff
  81. what battery?
  82. wanna see the inside of a lipo?
  83. battery has 2 connectors
  84. NiMh charger-3 packs at a time?
  85. Art-Tech 3-Cell Li-Poly Wall Charger?
  86. Is Lithium Ion the Same as Lithium Poly?
  87. This is how you treat your business partners???
  88. Thunder Power Service!
  89. voltage drop vs. amp draw
  90. Ni-Mh how to?
  91. Best prices on Lipos, and where?
  92. newbie battery question(s)
  93. Newbie question about new charger..
  94. Time between charges on LiPo batts
  95. please help need info on hobbico feild charger mk11 charger
  96. Lipo Help: 10C 12C, whats the diff?
  97. Li-Po fire;
  98. Where to buy GP2200 ?
  99. charge rate
  100. horizon charger and KAN 650's
  101. light flight info
  102. Are Lipos allowed on airline flights?
  103. ebay esc cut off for li-po's
  104. Good Li-Po battery charger??
  105. Mpx twinstar batteries?
  106. Li-po Swelling??
  107. How warm is safe?
  108. extending wires???
  109. Just need a lipo recommendation
  110. Building an Electric Motor Mount
  111. ESC cut out when flying wider wing, battery discharge 6C...
  112. Lesson learned: Lipo's really ARE dangerous
  113. Flight times 5000 or 3700
  114. Polyquest Lithium Polymer Super Sale
  115. Smaller battery for Park 400 4200kv
  116. voltage boost for 3S
  117. Li-Po Charge Times
  118. truerc batteries
  119. Pro-Peak Prodigy & LIPO
  120. putting packs together?
  121. li-po problem - help
  122. Kokam LiPo's 3mm connector?
  123. "Good, the Bad, and the Ugly" QF article discussion
  124. 20C to 30C Lipos A Reality!
  125. Completely Newb Li-Po Question
  126. Welgrade Li-Po's
  127. Lipo in 2 meter glider?
  128. Dymond Lipos...Great Battery At About Half The Cost!
  129. Astro Flight charger, POOF and PZZZZZZ?
  130. Li-Po below recommended level, anything to do ?
  131. Sun (heat) killed my lipos?????
  132. swallow advance charger
  133. E-power Batteries
  134. nths
  135. Slow stick battery sub q?
  136. 8.4v pack warm after use
  137. Fliton Extra 330L , Axi 4130 16 Battery choice
  138. Higher mAH Battery and slow stick
  139. Balancing Lipo questions
  140. lipo, esc, and motor question, F 27stryker
  141. Battery for my Apache
  142. Lipos : High Rate 1500 mA or... Light 2000 mA ??
  143. Check these cells out
  144. What does this mean?
  145. electrajet
  146. LI-PO Charging Question
  147. Pro-Peak Prodigy II - Charging in 3mins?
  148. Astroflight Question
  149. mrc 969 need help
  150. power source??
  151. too large prop?
  152. Peak battery/weight ratio
  153. Lipo How many Cycles?
  154. Rebuilding LiPo-packs?
  155. sanyo sp scr ,are they like sub c?
  156. The "Black Art" in Battery ID ?? !!
  157. Hacker A30-16M
  158. New to Li-Po's
  159. Motors, ESC's and Batteries, OH MY!
  160. 8.4 NiMh pack weight
  161. kokam 3.2 ah in series. Question.
  162. Lipo charger connectors and wire problems??
  163. Switching from NiMH to LiPo
  164. "electric power" batt. Brand....any good?
  165. How to measure AMP draw for Brushless Setup
  166. Which battery charger to get for lipo?
  167. Thunder Power with Triton question.
  168. charger
  169. charger
  170. Help LI-Poly charging Help!!!!!!!!!!!
  171. running different volt packs in series ???
  172. longer flight times with aerobird challenger?
  173. eflite outrunner an hobbylobby airblaster
  174. Can you overload an ESC with batts in parallel?
  175. amperage ? about new duratrax ice charger
  176. Battery capacity question
  177. LHS says a Kokam is the same as a KAN?
  178. Lipo battery pack construction
  179. What are the specs on this pack?
  180. Battery Connectors
  181. RC Smart Lipo
  182. Electrical current = a river
  183. Is a lithum charger with 1.2a good enough?
  184. Lipo Damaged??? Fire Extinguisher???
  185. Lipo Newbie Question
  186. Lipo Fire
  187. 8.4V Bad 7 Cell Pack Reads Almost 12 Volts?
  188. Astro Flight Super Whatt meter manual
  189. Lipo in a stryker,can stock 460motor handle?
  190. Mountain Models ETANA
  191. LiPo's from Dymond???
  192. AXI Equivalent to PJS 1200
  193. Dymond Turbo Charger and Nimh's
  194. Charging Time on Lithium Polymer Battery
  195. Thunder Power Charger
  196. recommendations for LIPO charging
  197. Making a battery pack
  198. TP Packs in series
  199. 3 cell lipo auto cut off circuit
  200. NiMH Problems...Help
  201. Am I Missing Something?
  202. Think You Have A Bad Cell Or Pack? Try This First!
  203. Battery recomendations??
  204. Li-Po Charging question
  205. Ni-Mh pack drops below 5 volts
  206. Polyquest LiPos
  207. Greatplanes Polycharge amperage?
  208. tp 1320 tripping out
  209. help me has to regulate for charger ultramat 10 of graupner
  210. ce qui ont ce chargeur ultramat 10 de graupner aider moi a le r├ęgler
  211. Lipos get stronger
  212. Charging TX NIMH Pack
  213. BalancePro - 2s Cell Balancing Charger and Battery Packs
  214. Outrunner 2408-21
  215. maxamps good stuff?
  216. HELP! My Lipo's went to sleep and won't wake up!
  217. Powerizer Sub C 3300 Charge Rate?
  218. When is a Lipo Garbage?
  219. hooking up a LiPo battery
  220. Charge rates for LI-Po batteries.
  221. Question about Discharge capability
  222. Can a novice solder his own Lipo or Nimh packs?
  223. Apex lipo batteries, good or bad?
  224. GWS lipo batteries, good or bad?
  225. bad cell removal from 3 cell li poly pk
  226. What, no explosion?
  227. Lipo pack swelling
  228. is a mega 16/15/3 considered low impedance?
  229. swollen pk in 3 cell electrifly
  230. On board temp sensor
  231. battery question
  232. ICE charger?
  233. Voltage drop in Ni-MH
  234. Swollen Lipo - what should I do?
  235. How To Find The Bad Cell In A Pack?
  236. lipo loosing power??
  237. Any way to calculate the C rating of a lipo?
  238. Lipoly charger
  239. Did I fry my new GP3300 battery pack
  240. Li-Po meets H20
  241. End All to Lipo Explosion Worries-Feedback
  242. FIRE...QUESTION
  243. Dynamite vision peak ultra li-po charger
  244. lipo's vs nimh
  245. apache smart charger
  246. Please help with Triton and Lipo
  247. New to Li-po's
  248. eLECTRIC POWER
  249. Calling Mr Adriantan
  250. Still Need A Cheap Source For 3000MA Nimhs (For Extreme)
