PDA
View Full Version : E-Flight Power Sources
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12
  1. Best lipo 12-15C?
  2. Watt meter???
  3. Independent Testing of Lithium Cells
  4. HOW MANY OF YOU HAVE NO BALLANCE TAPS ON YOUR LIPO'S?
  5. batteries
  6. What power supply for Supernova 250s charger
  7. Li Poly swelling on discharge
  8. Discharging Li-Polys
  9. Where can I get lipo cells?
  10. Lipo taking 1/3 capacity during charge
  11. Lipo swelling on discharge
  12. Lipos and higher than rated Mah???
  13. TP-425 Thunder Power Charger...Power Source?
  14. 30A charging current to 800mah LiPo 3cell
  15. Any one using R1EM-WC4 Lipo Charger
  16. Soldering NIMH Cells Help !!!
  17. nimh battery upgrade
  18. Charging Help!!!
  19. Nimh in Paralell???
  20. Battery Info
  21. Did I Ruin My LiPoly Battery Pack?
  22. Leave Lipo's fully charged?
  23. Discharged Li-Po
  24. Electrifly Lipoly4 charger
  25. 12 volt from 120.. who has done it?
  26. Who has the best lipo's?
  27. F27 Stryker Upgrade
  28. Schultze and LiPos
  29. Anybody using Energizer 2500ma Nimhs (At Walmart) For The TX?
  30. Please Help!!! LiPo's For my H-9 Extra 330
  31. RX&TX [SAFE VOLTAGE]
  32. Source for bulk battery connectors...
  33. Piranha Digital Peak Charger Opinions (& Charging Hobbyzone Batteries)
  34. off the shelf AAA NiMH
  35. Qs for those more techie than me...
  36. Soldering Lipolys?
  37. Highest MA Capacity Battery For The Extreme?
  38. LIPO DESTROYED.....OR IS IT....????
  39. What are you using for a 12V power source
  40. AXI MOTORS
  41. Skyvolt System for Lithium Safety and Longevity
  42. marine battery question
  43. voltage cutoff question
  44. I do not know who they are but listen to them.. LIPO FIRE!!
  45. PHX-Link and Phoenix ESCs
  46. li po fire
  47. Li-po (kokam question)
  48. Solderless Power Tubes (SPT)
  49. IS 8.2V MAX NORMAL FOR LITHIUM USING SCHULZE?
  50. 2400mAh Li-Ion 18650 will charge only to 1200mAh
  51. charging Lipos after partial discharge
  52. LiPo: Mishandled or Malfunctioning?
  53. Lipo "Safe Charge" Brands
  54. Lipo Lifespan
  55. WHICH LIPOS AND AXI FOR 15LB HIGHWING PLANE?
  56. Battery for 2 pound plane?
  57. What size battery for ESC
  58. Hitec HAS-03mb receiver and Lipo
  59. Multiplex LN-2010 charger and Lipo
  60. Discharge rates
  61. Eflight 400 and Phoenix 25
  62. AXI 5330/18 vs. Actro 40-4
  63. Finally ready to go Li-Po
  64. which battery pack???
  65. NiCad or NiMH replacement for LiPo???
  66. TP-425Lithium Polymer charger
  67. Flight Duration
  68. HOBBICO MK2 CHARGER..and LIPOS..
  69. Which Battery Pack (superstar ep)
  70. My wife threw the magazine away :(
  71. Which LiPo pack can I use in the Super-D
  72. Lipoly Lifetime
  73. Damaged Battery?
  74. E tec
  75. Lipo Charge Rate
  76. Hobbico Quick Field Charger for Li-po
  77. "Electric power" lipo batteries???
  78. 7 cell 1100 Mah pack -which plane/motor
  79. electric power system for older sailplane
  80. E-flight resources
  81. New to E-flight ... need help!
  82. Batts that will handle high discharge
  83. charging a lipo
  84. Cool Running ESC ?
  85. Tanic Taps balancing???
  86. New to RC, Battery question.
  87. I'm curious about chargers... how long does it usually take to charge a lipo ion battery...?
  88. First charge of Li-Po battery pack
  89. Can this Lipo be saved?
  90. Hacker B50 not producing acceptable thrust
  91. 4S2P Tanic packs ?
  92. Computer connectable watt meter?
  93. which prop w/brushless w/lipo
  94. HIHI
  95. Li-ion and GWS Tiger Moth
  96. storing nimh
  97. Charging 9-cell NiMH with Quick Field Charger
  98. Apache LiPo charger "delays" charging
  99. Lipo voltage drop under load
  100. Can an ESC be 'partially' dead?
  101. Aerobird Challenger battery
  102. Lipo Charger Mod
  103. discharge question?
  104. ElectiCalc Values
  105. lipo question
  106. New to R/C and maybe LiPoly
  107. T-33 and ? # lipo
  108. New Toshiba Lipo recharges 80% capacity in 1 minute!!! Breakthrough
  109. li poly
  110. thunder-power li-po question
  111. How do I save this battery pack?
  112. Slow-v batteries: 7.4v or 11.1v?
  113. new lithium batteries
  114. Stupidy Induced Li-Poly Incident
  115. DO LI PO & LI ION CHARGE THE SAME WAY
  116. Lipo terms help me understand
  117. Programing E-Flite new 20 amp ESC
  118. Park 370 outrunner
  119. Li-Poly Question
  120. Polyquest Lipo question
  121. How long should it take to charge my new LiPos?
  122. 120VAC to 12VDC converter???
  123. AXI 2212x34 w falcon 1100mah lipo?
  124. Best way to blow up a Lipo?
  125. Schulze Warning #7
  126. High Discharge Single Li-Poly Cells
  127. Scorpio DeHavilland Mosquito
  128. Energizer AA/AAA NiMH for Electric Planes?
  129. Understanding "C" ratings and voltage
  130. DO I DISCARD THIS LIPO PACK
  131. Can I charge a 3S1P pack with the apache 2030 charger?
  132. Thuner Power 1320 and Hobbico Elite charger
  133. LiPo charging
  134. Thunder Power batteries
  135. E-Flite Celectra lipo charger, anyone using?
  136. LI-ION discharge question while stored
  137. Charge two packs simo.?
  138. Can you charge lipos below 1C?
  139. Need help with charger.
  140. Flight time on 4cell NiCd 600mah
  141. amp draw
  142. Anyone using this charger?
  143. Use fieldbattery charger to power lipo Field charger?
  144. Eflight 400 Siezed!
  145. how much C does the kokam 1500 mah 11.1 volts batterie have?
  146. batteries in parallel, with diodes?
  147. Has anyone tried dymond LiPos??
  148. Triton or Astro flight Charger
  149. My radio cut out when the motor cut out. What happened?
  150. wanting to ugrade to lipo
  151. Ready to move to LiPo's...
  152. li po battery help
  153. Help With Brushed Motor!!! ASAP
  154. Which Li-Po's would replace my NiCad's?
  155. Charger Question
  156. Battery connector on Skywave
  157. Triton Charger with Hobbico Connectors
  158. Power source suggestions?
  159. Is a 3s2p pack equivalent to a 3s pack?
  160. proper disposal of Lipos
  161. MOVED: AXI Help
  162. Gp 1/3 Pitts arf..what lipo's?
  163. 860mah Charged at 1200mah!?!?
  164. Cheap nimah packs?
  165. super brain 959 charger
  166. What charger for nimh batteries?
  167. The need for speed
  168. Extra small 7.4v Li-Poly Packs
  169. kokam multi charger
  170. Connector weights?
  171. Factory charged ?
  172. battery cycling
  173. 50 mAh nimh cells
  174. Should I charge LiPo 1 cell at a time?
  175. combine lipo packs?
  176. Help with Piranah digital peak charger
  177. Best NIMH for Tigermoth 400?
  178. new power source?
  179. Comments for New DIY Motor Kit
  180. E-flite 370 Brushless, new plane options???
  181. 3D Buddy Edge 540 Power Options
  182. 3D Buddy Edge 540 Power Options
  183. Hot Lipo
  184. 1st li-poly battery
  185. E-flight ascent
  186. Any comment on PolyCharger Lithium-Polymer Charger?
  187. Kokam 15C Cells
  188. Reasonably priced gold 3.5 mm bullet connectors
  189. Wattage PF-12 Peak Charger
  190. Charging LIPO batteries in models
  191. GWS MC2002 Charger question...
  192. Triton setup for LiPo
  193. Cooked Lipos?? HELP!!!
  194. lithium ion protection circuit
  195. What Charge voltage equals 90% capacity for a Li Po
  196. Duralite LIPOs anyone
  197. Quality Lithums
  198. Lipo charger power source
  199. ok to store lipo's fully charge?
  200. Cell balancing- the end of swollen cells of any type
  201. Swollen Lithium pack after winter storage?
  202. Adding an additional lipo battery?
  203. Charging JR transmitter with Triton
  204. Poor show from these cells...
  205. Best Lipo charger for 10+ cell?
  206. Pyramid and Apache 2500
  207. MOVED: Cascade Charger. you can charge as many packs as you have in cascade
  208. Soldering battery tabs
  209. Swollen LiPo?
  210. Shorted Lipo pack??
  211. Did I get the wrong battery?
  212. 7.4 v or 11.1v. which is right 4 me?
  213. Serial charging multiple Li-Po packs?
  214. Apache 2030 Multi-Charger Any Good?
  215. Watt Age RTF to Lipo
  216. WHAT TO DO WITH 11.1V 2200MAH!!
  217. GP3300 vs. Kokam 4th Generation
  218. 4* Forty e-conversion batt suggestions
  219. Best nimh charger
  220. 3-Cell Li-Ion 2350 Mah capacity Charge setting
  221. charging a 8.4v 3300 Nimh battery @ 1.5amps
  222. Battery suggestions?
  223. WM World Fun electric 3D power system
  224. Amondotech SC3300 mh battery packs
  225. MOVED: AMA Rule change for electric flight
  226. 1050 with 1200 ma charge?
  227. Suitable power for Hobby Lobby's 33" P-47
  228. Please help me build a Super Slow Stick!
  229. power recommendations for the Fliton QuiteStorm
  230. Please Help Really Confused..
  231. Electrifly Batteries!!
  232. Zapp batteries
  233. Amusing LiPo close call
  234. Building an intelligent NiMh charger
  235. Best place To Buy Li-poly
  236. help needed with setup
  237. LiPoly Cutoff & Jeti Controllers
  238. Li Po reciver question
  239. Li-Po Charging - Discarge First?
  240. Short term storage of LiPo batteries
  241. Cold Temp and LiPo's
  242. KOKAM SAFETY GAURD
  243. Great Deal on lipos
  244. Building a battery pack...
  245. LiPos lost their power
  246. chharging time for this
  247. looking for 1st lipo PolyQuest or Kokam?
  248. Kokam 15C Packs R 4 Po Pimps
  249. Brushless motor recommendation
  250. SLOW CHARGE QUESTION
