PDA
View Full Version : RC Helicopter General Discussions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52
  1. Need heli flying field in Los Angeles
  2. interest in turbine power for Heli
  3. A couple videos.. Crashes, night flying over fire......
  4. OS 61 WC in Raptor 60?
  5. Sceadu 50
  6. IRCHA Jamboree picts
  7. What do you think?
  8. Clutch Runout
  9. New Raptor 30 V2
  10. Caliber 30
  11. GY401 question
  12. From Interest to New
  13. GY401 or the GY502 ?
  14. Heli Book
  15. GV-1 and 8103
  16. help stop my rotopod from vibrating
  17. Ergo60 Question
  18. Invert Switch?
  19. Venture header tank alternative
  20. JK & TB will have YS .91's at IRCHA!!!
  21. Rough Running 61wc at hover
  22. Venture header tank location?
  23. Voyager 50 Pics
  24. OS70 Manual
  25. Safe way to check "head speed" ?
  26. Going inverted with 8103 on the sim.???
  27. Are we there yet?
  28. JR X-378 radio
  29. Thunder Tiger 680 mm carbon blades??
  30. Skid protectors/asphault flying
  31. Poop, Fiddle-Sticks, Golly !!! I Crashed
  32. Good News for Kalt Fans
  33. Scale Helis?
  34. G2 vs. Real Flying
  35. If you ever go to fly your Raptor, and realize you forgot your starter...
  36. How would you like to fly this???
  37. Rapor 30
  38. Pitch / Throttle Curve How-To?
  39. Rap50 flip rate?
  40. What's a good 50 size helio?
  41. I want to get a heli
  42. Broke my OS 50
  43. Kyosho Caliber 30 + JR 8103H Setup
  44. O Ring & Shim Q 99SE?
  45. Main & Pinion Gear Mesh 99SE?
  46. Fury Clutch tool tip
  47. Webra .35 engine in Raptor
  48. Installing Extreme Mast/Bearing in Fury60
  49. Heli Lubricants
  50. Emergency Landing....=Much Luck!
  51. Ski Sport Fusalage Question
  52. Cyberheli will soon have the YS 91
  53. os 61 sxh wc needle settings
  54. Fury - Bearing Failure!!!
  55. Venture questions for a new guy
  56. YEEEEHHAAAAAA! I Flew my Sceadu for the first time today!
  57. JR sport digital servos 811's
  58. Right turns and Left turns....
  59. Newly built Sceadu 50
  60. os 91 hydro lock
  61. Turbines to beat glow in FAI and F3C
  62. Venture and 8uafs setting?
  63. Futaba GV-1 Governor setup HELP!!!!!
  64. Fury 50 expert to 60 expert.
  65. Woof & Poof
  66. 7008 Flash fuselage kit ?
  67. Volkul you copy Cat
  68. Look at this.
  69. Servo Problem
  70. What and how
  71. radio glitch with old metal helis
  72. Excell 60 CT
  73. I want your HELICOPTER VIDEOS.......
  74. Venture/Rotopod Question
  75. EuroCopter EC120 Colibri or EC130
  76. Radio or Copter!!
  77. Koll Rotor Pro Balancer
  78. New Miniature Aircraft Parts for Fury
  79. looking to get a 60 size heli (Fury vs R60)
  80. Advice on a 30 Sized CCPM Heli
  81. New Heli
  82. Larks Fall Fest Heli Funfly Nov.1,2,3,
  83. Fuel...
  84. Hirobo Scadeu 30/50
  85. Is it too late to run? (Long ramble)
  86. Please advise current gasser helicopter model
  87. Venture Assembly Suggestions
  88. photos...any comments...
  89. hatori muffler for Raptor 60
  90. A Heli For a New Guy
  91. I Can't set the Mixture on my tt36
  92. With the nasty summer
  93. Raptor 50 RX antenna?
  94. Ergo 60 to Vigor canopy?
  95. What do you guy's think
  96. Check this heli out
  97. What could make this happen?
  98. Aerodynamics & Engineering
  99. Loctite removal and clutch liner ?'s
  100. Whats a good 50 size ?
  101. Idling with hums(OS61WC)
  102. Saw a REAL UGLY field mishap toady
  103. has anyone ever seen this heli?
  104. Voyager 50
  105. Thank you G2!
  106. New Pilot Locator
  107. Reciever Glitching
  108. Raptor .30 blade recovering??
  109. Cyclic Wobble
  110. Starter for YS80 help !
  111. Electric Heli. ???
  112. coloring glass baldes
  113. I just didn't know
  114. Futaba 401 gyro and JR 8103- basic gyro settings
  115. IF money was no object....
  116. What Plug For the OS 50 SX-H
  117. How Come????
  118. Raptor ?
  119. Raptor tail servo location?
  120. Raptor 60 rudder servo...
  121. which Heli Do I Purchase?
  122. throttle notch?
  123. Raptor 60 owners
  124. Inverted: switched or switchless
  125. Voyager 50 Manual
  126. Persistence Pays off!!
  127. anyone have a micro heli with a scale fuse????
  128. Rig #2 takes flight
  129. Which X-Cell 60?
  130. When to try for the first time?????
  131. fma copilot
  132. Which links and balls for Raptor 30
  133. The Best Helicopter Radio
  134. 6 Pounds of dynamite in a 3 pound box!!
  135. Where to get a Weston muffler for TT36?
  136. Helecopters
  137. os 32 questions
  138. 3-D masters Videos
  139. Morley Carbon F-1
  140. Helimax governor
  141. Am I Nutz?
  142. Gem 2000 ?
  143. How do you do a pirouetting loop ?
  144. recievers??? all the same?
  145. Help with setting up a Rappy and 6xas
  146. Why ?
  147. Pittsburgh PA, Fun Fly - This Saturday the 3rd
  148. Paddle Upgrade
  149. Idle up 1 setup?
  150. JR Venture 30 - Help me put together the "Perfect Trainer"
  151. Does this guy look like he's having fun?????
  152. Need Howto help on flips & rolls
  153. What paddles do you use?
  154. RPM for a .30 heli
  155. tail rotor upgrade
  156. R.P.M. for a .30 heli
  157. Question is my engine the problem? rappy 30 OS32
  158. 3-D question
  159. How long is it supposed to auto?
  160. Police interest at our field!
  161. X-cell 60 SE - main rotor play ...
  162. How many tanks does it take to
  163. Futaba 6XHs & CCPM
  164. Raptor 50, OS50 heat problems
  165. Floats for flying off water?
  166. Question about 4ch Air Radio on Heli...
  167. Need help with used Lite Machines 110 heli
  168. heli bobbing ?
  169. Futaba vs JR radios
  170. Helicopter lube
  171. Needing manual for Concept 60 SR
  172. Telebee gyro instructions.
  173. HELP!!! ccpm problems, 8uhfs on CP hornet
  174. Custom painted canopy
  175. Attn Jr Venture owners, fuel tank problem!!!
  176. Weston 60 experiences
  177. Scale fun fly and contest
  178. Field Gear ?'s...read meeeee
  179. Caliber 30
  180. It's a Boy!!!!
  181. Gyro
  182. To put servos/Gyro in the Rappy 30 or Ergo 60?
  183. Anyone using??
  184. Anywhere to Fly in West Los Angeles?
  185. R/C service TECH ?
  186. r50 engine
  187. New to Heli's, New to Raptor
  188. Servo eater
  189. Can't get motor started
  190. Muffler Screw
  191. Whats This Jr Xf622 Radio Worth?
  192. Power probleme with the webra P5
  193. Hey Jeff any info on the new Mini Lama?
  194. Heli fun fly this weekend in Ohio
  195. Need Manuals (JR NEJ-1000a Gyro & X-Cell Pro)
  196. Book help
  197. What carb for TT 36?
  198. Will a Nexus autorotate?
  199. new user with a question :)
  200. Hovering and breezy conditions
  201. Ys 61 ,Upgrade from a 50 to a 60..
  202. Fury Is a 60 now.
  203. Raptor 50 and Ordering
  204. New Heli has the shakes
  205. Carbon Blades Advice
  206. hirobo engine
  207. It's broke, PLEASE HELP ME!!!
  208. Futaba 9252 replacement gear set
  209. Need Help!
  210. cooling head stripped
  211. header tank
  212. Which has more power YS80 or OS70?
  213. Lite Machines 117
  214. "Improvements"
  215. fly bar
  216. Check out this paint job.
  217. concept 60
  218. Parts Need to adapt SE99 for YS80 or OS90?
  219. Mavrikk 600mm woods
  220. gv 1 help
  221. My new Freya 80 is done, 1st flight Today
  222. hornet questions
  223. pics of my newly painted canopy
  224. rap30 clutch problem!
  225. Do you use a governor?
  226. *****Advice in this forum******
  227. ? for Gary Wright
  228. Prop washer for OS-50sx-h
  229. New Heli section added to website.
  230. Heliproz ?
  231. Raptor 50 building question
  232. Sloppy Venture
  233. Where to get nexus parts?
  234. Trying to set up a 401 gyro
  235. futaba GV 1 and 9C set -up
  236. newbie!!!!!!!!!kyosho schweizer 300 need help 4 set up!!!!!!!!!
  237. Link
  238. LINK
  239. Welcome
  240. Hirobo RC Heli Direct Support Forum Open!
  241. Goodbye Hoola-Hoop!
  242. Grease raptor 30 drive gear?
  243. two small nicks on my OS 50 piston head!!
  244. FMA co-pilot
  245. Canopy work...
  246. Nexus clutch liner question
  247. How well would this work?
  248. Post your ?? for LMH
  249. Great deal on Campack style Memory
