PDA
View Full Version : O.S. Engines Support
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19
  1. os max 90 four stroke
  2. OS FS-120S-E Won't Run
  3. Low RPM out of OS Max FP .25
  4. O.S. .61 MAX FSR Engine help
  5. O.S 1.20FSIIIP+mount
  6. OS 91FX remote needle
  7. OS .46 carb problem
  8. NEED Regulator Cover of #70C carb body
  9. O.S 502 pipe system...
  10. O.S. 70 Ultimate Problem - Fuel leak
  11. os fs.70s surpass II prop
  12. OS 120 FT
  13. O.S. FS-120 manual
  14. OS 50 SX quitting
  15. OS 120 FSIII power down
  16. Headers for OS 120 III pumped
  17. OS 1.08 need a new ring and liner
  18. OS Cylinder Peeling
  19. Info On OS 52 FS
  20. OS 70 Ultimate RPM Figures
  21. How to remove cylinder lining in OS ABC-engine?
  22. OS 160 FT outline drawing and dimensions ?
  23. OS .46 Fx sleeve problems
  24. 0S FS 120 SURPASS PUMP DIAPHRAM
  25. OS 1.40 'popping' at idle
  26. OS 70 Ultimate problems
  27. OS Max .21 VZ-B (P) rear exhaust engine
  28. One way bearing prob
  29. will it fit?????????? plz hlp
  30. OS make Chrome sleeve?
  31. which muffler??
  32. os 91 vr df
  33. Carb Parts for 91 4 stroke.
  34. OS 70Surpass - starting problem
  35. OS 1.40 eating glow plugs
  36. OS 120 FT
  37. OS Engine Comparison
  38. OS 45 FSR Part
  39. Reassembly procedure. OS Gemini 120 & 160
  40. Glow Plugs for OS .25 FX
  41. os 50 sx max rpm 11000
  42. Where to find needle valve assembly for older FS 70 Surpass
  43. os91 engine
  44. 1.40 cold starting?
  45. OS 91 FX break in and props?
  46. OS50SX...Very Strange problem!!!
  47. OS .12 TR (P) needle settings?
  48. os 91fs cuts out during flight
  49. OS 70 crank shaft
  50. crank-50sx vs 50sxh
  51. OS 91 FX which prop for slow flight/torque?
  52. Size for carb screws
  53. O.S. FT-160 Twin
  54. Suggestion for OS 2-stroke muffler improvement
  55. OS 50 SX and OS 50SXH Problem?
  56. Replace conrod and piston pin os21 VF-BR
  57. Propeller Shaft - O.S. 70 Surpass
  58. Where to buy new needle for 46 FX
  59. OS 50SX Carb problem, need help.
  60. Ring for OS 50
  61. OS .65 marine engines
  62. 1.60 overheating ?
  63. prop size and rpm
  64. loose muffler
  65. Loose manifold
  66. OS70 SurpassII Carby
  67. 140 FI. How do I reset EC1
  68. no NV response on OS46FA
  69. Gemini Question
  70. 91FX rpm
  71. 120 SURPASS DOWN ON POWER?
  72. 91 fx break in
  73. FX 61
  74. older 61 fourstroke
  75. OS .91 SX-H
  76. BGX-1 3500 wont run vertical help
  77. OS 70 Ultimate
  78. 61 FX idle adjustment keeps changing
  79. FT-300
  80. OS .40 Surpass 4-stroke problem
  81. OS 91 Surpass II Max RPM and Tach Setting?
  82. O.S. .91 Surpass I carb settings and beginners questions.
  83. .46 ax sllimline muffler
  84. OS Max .10 orientation
  85. OS 91 Surpass Idle Problem
  86. thread size on .52 4s
  87. OS7D Carb Setting
  88. OS .91 FSR
  89. OS120 SIII RPM
  90. Practical rpm vs Rated Power
  91. OS 91 FX exhaust pipe
  92. Tuned pipe for 50 SX
  93. New 91 4-stroke crankcase vent strategy?
  94. OS 15 CL conversion?
  95. Break in FS-91 SII
  96. FX91 mixture problem
  97. Prop for 0s50 sx
  98. what causes this
  99. OS FS-91 Idle settings problem
  100. OS #743 muffler
  101. Need some help Bax!!!
  102. Breaking in a .61 FX
  103. OS 61 RFP ABC
  104. os .26 and .40 4 stroke car engines q's
  105. OS 46 C/L venturi diameter
  106. os fs90 fourstroke
  107. OS 91 FS engine quits
  108. OS 61FX Air Filter?
  109. OS 70 Ultimate
  110. OS BGX
  111. os 1.08 breakin
  112. Needle valve location OS 160
  113. O.S 1.60
  114. 30% CoolPower us in 4-strokes
  115. Electronic copy of instructions for O.S. 60 four-stroke engine
  116. OS FS 120 WITH INCLINED ROCKERS INSTRUCTIONS
  117. OS 32H Question
  118. OS 91 Surpass Exhaust header breaks
  119. Is there a .25 AX on the way?
  120. OS 46FX muffler screw
  121. OS 1.60 bearings
  122. Help, was this my fault or OS's?
  123. Muffler back pressure
  124. propeller for OS 30
  125. 90FS Ring Gap
  126. 15 CVA cover plate
  127. LA65 Header pipe
  128. OS .32 Fabc
  129. 61RF-P ABC prop questions
  130. OS FT 300
  131. Cowled OS 91 FX
  132. Problem with OS 26 FS
  133. FS-91 Surpass II - Black residue on the inside-top of fuel tank after running in
  134. OS 61 MAX SF Pumped
  135. OS 90 needle valve and o ring
  136. tank pressure
  137. fuel?
  138. Rumors of an .18
  139. Varnish or Rust?
  140. 61FX pitts muffler
  141. OS 1.08
  142. vz-rz interchange?
  143. MOVED: Need an O.S. FS61 Marine engine
  144. OS .21VZ-B Premature Wear Problems - Please Advise
  145. OS .60 FP RN
  146. Beginner: Cannot Start O.S. .46 LA
  147. OS300 4stroke twin
  148. O.S. Max FP 40
  149. Proper Break-In for an O.S. 25 fx
  150. Prop for OS 300 4stroke twin
  151. OS 50SHX-H
  152. Installing valves in cylinder head
  153. Rumor on the .46 FX
  154. OS FX 91 problems
  155. Hard to tune
  156. owners and parts manual, o s 61 sf
  157. 91 FX knocking
  158. .91 4-stroke exhaust pipe size
  159. OS FS 48 Surpass
  160. O.S. Carburetor #6B .61 SFN-H
  161. OS 61 FSR Carb question/replacement
  162. Bearings
  163. O.S. 46 FS
  164. OS FS-91 Removing the bearings
  165. Question about the Hanno Specials
  166. OS 120 FS SURPASS W/PUMP PLUMBING?
  167. Replacement Piston Ring
  168. OS 120 FSIII w/pump
  169. OS 300 4 stroke twin
  170. OS 160 FX Crank Case Tap?
  171. 140RX throttle linearity
  172. Great Service
  173. Tuning 120 fs surpass
  174. 3 View Outline ??
  175. Timing on O.S. .91SF Surpass
  176. .15FP CL vs RC question
  177. OS 108, Remote needle?
  178. OS .46 LA
  179. OS 108
  180. the 46ax
  181. OS 1.60FX Fuel choices
  182. OS FP/LA interchangability
  183. having problems with OS 91FX
  184. Help for parts for a 90 FSR?
  185. OS 61 SF Burning Plugs
  186. Os 140 rx
  187. OS 140RX
  188. OS 60 FR Muffler??
  189. Bax - Hobby Services inability to repair older OS engines??
  190. OS 160 Cant Get It Rich
  191. OS parts
  192. Parts for discontinued engine
  193. 91FX and a Bisson Pitts Muffler
  194. OS 48FS choke valve interchangability
  195. Hanno Special Header Length
  196. OS Max H
  197. OS 1.60 FX SPINNER ADAPTOR ?????
  198. Is my 46fx liner peeling?
  199. OS-32SX-H question
  200. Hanno Special Plug?
  201. 50 sx-h ring
  202. FX91-What fuel tubing size?
  203. o.s. 50 sx air bubbles
  204. having problems with tuning of O.S .61FX
  205. Setting up an O.S. 160FX
  206. Screw Size 46 LA
  207. i need to know what do i need to turn my os .12 cv into a pull start
  208. 2 questions about my os 40 la
  209. OSMax 12 CZ-Z problem
  210. Temperature of engines?
  211. OS 40Max-H My first engine teardown-help!
  212. OS 46LA...only as powerful as a 40?
  213. OS .46 FX Issue
  214. .91 FSR Parts Sources...
  215. OS 91 FS II pump
  216. OS91 - Dry rear bearing
  217. Problems with MAX 61FX
  218. OS FX .46 Getting Tired?
  219. OS 90FS FOUR STROKE ENGINE IDLE SETTING
  220. Info on FS120S II
  221. parts exchangeability
  222. HELP!! MY OS 50SX ISN'T RUNNING PROPERLY!
  223. Storage of OS 120FS with pump
  224. OS 46 FX Problem
  225. .61SF-P pump nipple broken
  226. OS #743 muffler replacement that fits?
  227. pre detonating OS 1.6
  228. OS 50 w/ 60 Carburetor
  229. OS 61RF-P
  230. OS 40 LA Airbleed setting
  231. OS Rotary engine
  232. O.S. 50 SX air bubbles
  233. os 48 compression loss
  234. OS 120 FS Question
  235. Question about service turn around time
  236. FS 70 Ultimate Availability
  237. OS 91 getting richer on idle
  238. OS 160 Fuel ?
  239. OS LA40 Carb Repair
  240. O.S. .91 FX
  241. OS FS-52 Throbbing
  242. 91 FX idle
  243. OS 70 S II Question
  244. Rusted stuff
  245. os 70 heli engine piston explodes
  246. OS 40 LA Power
  247. OS 91 Surpass question
  248. 52 4/C won't draw fuel
  249. LA 0.40 RPM's running away from me.
  250. OS MAX RZ compression
