PDA
View Full Version : O.S. Engines Support
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18
  1. New OS 120AX back plate rubbing
  2. OS46SF Counter Rotation Crankshaft
  3. OS FS 91 Surpass I Valve springs.
  4. Surpass 1.20 III pumped idle problems
  5. Slimline compact pitts on a 55AX
  6. 40 Fx Needle Valve
  7. OS55AX
  8. OS 91 FX
  9. Max55AX quit in Torque Roll
  10. OS 46 AX main bearing removal
  11. OS 1.60
  12. 120AX deadsticks
  13. OS 120 Surpass 111
  14. O.S FS-120S-E Four Stroke Q's
  15. MOVED: OS .46 FX vs AX
  16. OS Max III 35
  17. BAX, A FOLLOW UP OS 120 QUESTION???
  18. OS ft-120 FUEL TANK LOCATION
  19. OS 120 III front and rear bearings
  20. 91 Surpass
  21. os 160 FX Piston Ring Replacement
  22. Removing cylinderhead on FS91II
  23. deleted
  24. OS 56 FS
  25. Parts for a FS-40.
  26. OS FS-120 pre Surpass
  27. 40FP fuel inlet adjustment
  28. .35 AX - Needle Valve adjustment doen't make any difference
  29. Flex Pipe Application for FS-120S-E
  30. OS 21 tm (Revo) question
  31. os .21 vg
  32. OS 46 fx-h
  33. tight TZ.12
  34. OS 65 VR-DF
  35. OS .81 FS a valve clearance
  36. Adding After run without a crank vent
  37. OS rz max restart problem
  38. OS200FS, any updates?
  39. Extra needle with 1.20 surpass ? why ?
  40. OS 21 V Spec Discontinued?
  41. OS .91FX 2 stroke
  42. OSFS91S
  43. Older TH .46 engine
  44. v spec .21 world edition fuel leak
  45. OS 61FX Needle - Bax need your help
  46. OS 108 break-in prop. size
  47. 1st Gen. FT-120 Twin
  48. 1.20 Surpass III 60n or 70n carb
  49. OS 65LA Fluctuating RPM
  50. problem_os200_pump
  51. Max-65LA how & what
  52. Two Stroke Rear Bearings
  53. OS1.60FX not drawing fuel
  54. pumping a old 91 four stroke
  55. OS 61 RF w/pump
  56. MOVED: os 200 4 stroke
  57. OS 46AX Bearing Whine
  58. OS Max 90 2 stroke problems
  59. MOVED: OS 1.60 with smoke anyone tried it?
  60. Help ! Os200-P Low RPM
  61. Help ! Os200-P Low RPM
  62. OS 52 HEADGASKET?
  63. 46 ax deadstick
  64. o.s. max rz restart
  65. OS 19 Prop Nut Help
  66. Different .55AX Mufflers (E-3020 & E-3070)
  67. 18TZ - Can't get it running properly
  68. Set Screw on OS 2060 Pipe
  69. O.S. P8 Glow Plugs (conical)?
  70. O.S. 1.60 FX pump needed?
  71. tuning a 11k carb
  72. OS FS30 spring valve broken 3 times
  73. OS 120III pumped rebuild
  74. 50 sx Throttle stop screw
  75. OS 91SII and Onboard Glow, needed or not?
  76. os 18 cv-r break in
  77. Gummed up/stuck fourstroke engines
  78. Need plug recommendation please
  79. OS 15CV-R - New P/S kit?
  80. FS-91S-II-P Fuel Pressure Regulator
  81. After Run oil in New 4 strokes
  82. O.S 50SX P/S Question.
  83. O.S 4stroke fuel
  84. Need 7D carb.
  85. OS 140 RX With muffler
  86. OS 300 Broken Crankshaft
  87. OS FS-120 Surpass loose muffler
  88. OS 18TM Issue
  89. 30VG rotostart problems
  90. 70 FS
  91. OS 91 Vrdf exhaust manifold availability..
  92. So Max 61 FSR ABC Drive Washer
  93. Hot!! OS 30VG
  94. O.S. 160 FX on a Macchi MC 202
  95. Remove piston OS 120
  96. OS FS 20
  97. Stuck wrist pin on OS fs 70
  98. O.S Max .32 SX-H
  99. engine size and type selection
  100. O.S. 91fx Inverted tips
  101. O.S. Max FX 91 won't pop...need help
  102. OS 91 Surpass II w/pump
  103. Os 46 SF ABC
  104. O.S 90 Surpass valve timing
  105. OS 12TR(P)-T Idleing problems
  106. OS FS 91 Surpass 1
  107. abnormal engine swap plane/car
  108. OS 61 FSR timing
  109. 55AX rebuild help
  110. os fs 30 problems
  111. FS 91 SII FI HELP!!!! anyone who knows
  112. Old O.S. 60SR Parts
  113. O.S. 55AX vs. 61FX?
  114. BGX
  115. OS FS200S P
  116. Cold weather break-in of 55AX
  117. clutch bell retaining screw
  118. ft300 connecting rods
  119. os 35 ax header pipe
  120. Tamiya/OS FS-18SR problems
  121. OS Max H 80 engine
  122. OS 18cvr / exhaust
  123. Old OS 90 2-stroke
  124. os160 problem
  125. FS200 Exhust thread size
  126. OS 91 heli engine
  127. O.S. 120 FS pumped
  128. OS 120 FS w/o pump initial Idle setting
  129. OS 21TM Glow Plug question
  130. 46AX
  131. 18TZ Breakin and tuning help
  132. OS .30 Motor Problems
  133. Starts up and then cuts off
  134. OS 21 V Spec pipe?
  135. OS DF question
  136. does os make a ez start engine?
  137. OS fs-40 - really old!
  138. OS 61VR-M Engine
  139. OS 200 Muffler/pipe options?
  140. O.S. 120 AX
  141. os 70 surpass parts
  142. OS FS91 Surpass II pump issue
  143. Carb secure screw question
  144. MOVED: OS 200fs Cline or Perry?
  145. 70 4 stroke
  146. FSa Lineup
  147. FX 1.60 annoying problem
  148. OS 91 FXGlow plug
  149. FX and AX ...
  150. 55 AX carb disassembly
  151. APC 13-4W to big for 55AX?
  152. OS 7L carb reassembly?
  153. OS 120FS II pumped
  154. Letters on bottom of mounting flange
  155. Another AX46 Question
  156. OS 46 AX
  157. O.S. 61 RF
  158. O.S. ft160 twin Crankcase slime routing/burning?
  159. OS61SF carburettor problem
  160. How do I take my carb off?
  161. 18tz(P) crank into a 18tm
  162. Need OS Max 40 SR Muffler
  163. MOVED: 160fx max and smoke?
  164. OS 61 SF ABC
  165. Stock OS 160 muffler in Yak
  166. os200-p fuel tube connection ?
  167. OS 120 Surpass III losing power
  168. OS 61 Max Fp Fuel Issue
  169. O.S. 120 fs rebuild
  170. os bgx 3500 break in?????
  171. FS-120 Series II Pumped surging
  172. Fuel for Os .21 RF-B
  173. OS FS 91 SURPASS
  174. Will a new 91 w/pump bolt up where a 91 Surpass w/o pump was?
  175. vspec .21 problem
  176. OS21TM Question.
  177. OS 160 AX?
  178. .91 FX straight pipe??
  179. os 300 enought power?
  180. S.O.S. OS FS-40 Surpass camshaft questions. Help needed!!!
  181. engine mount specs
  182. OS 18 TZ
  183. OS 2.00 Lackluster performance
  184. Obsolete OS Engine Information
  185. OS 61VF ABC GS A-1
  186. OS .61 4 stroke
  187. 18TZ Can't go past 1/2 throttle
  188. OS FS-70S needles bottoming out
  189. .91 FX Leaks Fuel at Drive Hub
  190. FS61 Silencer
  191. OS-46SF "Reversed"?
  192. OS IL-300 4 Cylinder - Fuel Setup
  193. OS .46AX running too rich
  194. Max distance between OS91FX and tank
  195. OS 55AX engine & plug life?
  196. FS-26 AND FS-30
  197. Stock 91FX muffler Q
  198. Break in?
  199. OS200-P getting 6500rpm ONLY....
  200. Os 55 Ax dying
  201. OS 3500 BGX-1 problem
  202. 91 Surpass metallic engine knock at half throttle?
  203. v-spec issues
  204. PD-04 Diaphragm Fuel Pump
  205. FS 40 Stuck valves
  206. OS 1.20 4-Stroke Questions
  207. .55ax noise
  208. OS MAx .10 ?
  209. OS FS 91 w/pump peak RPM
  210. os91fx and os61fx
  211. OS 25 FX
  212. will there be any new OS engine soon?
  213. os .18
  214. Figured it out..... Not worth reading
  215. OS FT-160 leaking fuel
  216. MOVED: Cline vs. Perry vs. Iron Bay
  217. 91 FX backplate ?
  218. Best replacement for OS .46 AX
  219. 30vg warranty
  220. OS 120 AX, No response to needle valve adjustments
  221. os 91 fx rebuild
  222. Spin start adapter for OS .21 V-spec
  223. MOVED: Good .12 engine
  224. exhaust on 55ax
  225. Letters code below mounting lugs
  226. OS 91 RUNNING GOOFY
  227. what is a os cz hirobo
  228. Ideal .55ax rpm range
  229. O.S. CV-R bump start conversion
  230. delete
  231. 1.60 prop sizes
  232. OS .52 & .56 exhaust thread pitch.
  233. os 120ax + remote tank = :(
  234. os 120ax
  235. exaust 4 stroke
  236. O.S. 61 F/S Touchy high speed needle
  237. Old but new OS 91 surpass with choke valve
  238. The Amazing 120AX
  239. Need upgrade carb on OS-FL70
  240. Os FS30 muffler and needle valve extensions
  241. 91 surpass prop size
  242. torque specs
  243. FS-200s and FS-200u; what's the difference?
  244. OS Surpass ii idle problem
  245. MOVED: O.S. FS 120
  246. MOVED: OS 200 for Pattern?
  247. OS FS-48 Replacement Head
  248. *OS 120AX & Nitro Content*
  249. Inverted OS FL 70 won't lean out.
  250. O.S. FS-120 III Surpass 4-Stroke with pump "NEED HELP"
