PDA
View Full Version : O.S. Engines Support
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19
  1. Opertaing temp for O.S. FS-91 II Surpass
  2. OS.90FSR DatŠ° & Manual
  3. MOVED: OS .30VG
  4. Problem with os 18tm in revo
  5. I Stripped My Head's Plug Threads.
  6. 2nd gen. wankel question
  7. OS120 pump Surpass I
  8. OS 91 FX Needle Valve Question
  9. Dose a pumped OS 91 get after run oil
  10. OS FS-91 SII-P
  11. OS Max .15 III Prop Shaft Thread
  12. os 55ax manual
  13. 70 Ultimate "original" vs "new"
  14. OS 30VG (P) ES
  15. os 120 pump parts
  16. Old OS Max .50 bearing size?
  17. OS FS-70 Ultimate W/Pump
  18. AX 46 Muffler
  19. 12 or 15 for JATO
  20. Carb for 61SF-ABC-P
  21. OS .28 xz engine
  22. A Question for Bax...F versus FSR
  23. os .21 vg break in
  24. Bax.
  25. FX 1.60 with 18x6 wood. What RPM?
  26. 91 Surpass I backfire on throtle down
  27. Questions about my new O.S. .18 CV-RX
  28. os 18 cv rx
  29. For Bax
  30. O.S. 30vg break-in
  31. OS FS40 4 Stroke
  32. MOVED: OS FS 91 engines
  33. OS.46FX
  34. O.S. .75AX
  35. Bill Baxter
  36. os 50 weak?
  37. O.S. 40 LA loosing rpms
  38. FS-120 Surpass Version 1 fuel line size
  39. BILL BAXTER ROCKS !!!
  40. OS 120 SE Largest Prop?
  41. OA 120fs S3/pump vs 160 Twin's Power..
  42. OS 120 Surpass II Pump spitting fuel
  43. Recommended Air Filter OS 18 TM
  44. OS 160 trouble
  45. .12 TZ 5 port
  46. Original OS FS-120 short shaft
  47. os .12cv-r
  48. OS .049?
  49. Engine Mounts
  50. OS 50 Hyper
  51. 120 ax prop
  52. best pipe for os 18 cvrx (side) on a ntc3
  53. 120 ax
  54. FS 91 Surpass III pumped tank vent line
  55. OS SF .61
  56. 55ax and Bisson Pitts muffler problem
  57. Ideal rpm for OS 52 Surpass and OS 70 Surpass
  58. OS 55 AX mid range problem
  59. Lost my muffler threads
  60. #7L Carb parts
  61. new os 18 cvrx on ntc3 wont shift..pls help
  62. FS-120 Surpass II HS won't adjust
  63. OS 70 ultimate Help Needed!
  64. .21 VG
  65. os 200 fi
  66. V-Spec
  67. 160FX-FI brake in?
  68. OS 55AX carb
  69. OS FS-91 Surpass smoking at low rpm
  70. Need help !! os140RX engine just won run
  71. HELP !!!!!!!! OS 91SII 4 STROKE PROPLEM
  72. 40la
  73. OS 50 SX carburettor exchange
  74. two cover 120 timing
  75. OS 50 SX fuel bubbles
  76. OS .50 heli ask: (after a galon )
  77. 50 Hyper Warranty Question
  78. Can not start .46 LA
  79. what is the best tuned pipe set?
  80. Twin Cyl. Temp. Difference
  81. Flow Direction? OS Check Valve
  82. Spare parts for OS 91VR-DF
  83. Very short glow plug life....
  84. OS Engines .21 VG
  85. OS 18TZ Head Temperature
  86. OS 70 Ultimate Owners Manual
  87. OS 18TZ T in RC 10 GT
  88. onboard glow plug ingniter
  89. OS .46 FX plating problem?
  90. 46 fx
  91. head shims on .18TM
  92. 46 AX carb issue
  93. Need exhaust part. max.21rf-b
  94. Glow plug question
  95. roller bearing (one-way bearing) problem
  96. what glow plug/fuel combo for v-spec
  97. 55AX and prop
  98. OS 50 sx flaming out
  99. .70 Surpass Prop and RPM
  100. GBX tuned muffler?
  101. os 18tz eb modified
  102. os 120 surpass hs-needle
  103. inconsistent RPMs
  104. O.S. 12TZ-T Rotary Carb?
  105. OS 50SX-H Nitro Question
  106. OS .55 Muffler Extension - Tower .46 Muff
  107. os 70 surpass vs os 61 fx fuel consumption
  108. la65 help
  109. OS 70 Surpass Removing conrod
  110. OS Max .40 fp
  111. Ft300 timing
  112. O.S. 1.20FS Engine Question
  113. GP kit spinners bad for our OS engines?
  114. OS 46 AX mid range stumble
  115. v-spec
  116. OS 46 SF abc - P
  117. os 91 fs surpass pumped
  118. Magnum #2 in OS 160 FX
  119. OS .21 VG ShimmingThank
  120. Leaky Carb in OS 18 TZ?
  121. .21 V-Spec Dust Cover ripped, dirt present. Best way to clean?
  122. OS .46SF pump carb
  123. OS 1.20 FS Surpass
  124. 91 FSR Carb Linkage
  125. OS .91 surpass II w/Pumps leaks at regulator
  126. Need a prop for OS 25FX
  127. Rear bearing wont stay in place
  128. Os Fsa-56
  129. 91 non pumped 4 stroke
  130. os 91 fs surpass pumped
  131. Os 18tm
  132. 91 fs power output
  133. OS FS-91 SII-P
  134. OS .55AX problem
  135. New O.S. Surpass III Pumped questions.
  136. OS 91FX High Speed Needle Valve
  137. O.S. 1.20AX Dead stick problems
  138. New to RC - Need help with FXi 46 Mixture Control Valve
  139. OS91FX Trouble shutting down
  140. Can I Install a Pull-Start on an O.S. .18-CV-R???
  141. Muffler Compatibility - 25FP vs 25LA
  142. OS46VXDF
  143. I saw the OS .75 AX ringed engine
  144. OS Surpass II with a Pump
  145. Connecting rod
  146. model weight for 91FX
  147. FP40 feels strange when crank turned
  148. MOVED: New OS FSa-56 4 stroke
  149. OS 300 Twin
  150. Are O.S. Engine parts made in China?
  151. 91 surpass needle settings needed
  152. Os fs 40cx car
  153. os 120 ax prop and fuel recommendations
  154. dtx 18 and os 15 cv
  155. OS55 prop reccomendations
  156. O.S. 70 Surpass valve adjustment??
  157. How about a Factory Support Forum for GMS engines?
  158. OS 46 AX...Runs with needle valve closed !
  159. OS 50 Hyper Help?????
  160. os fs 52s
  161. New OS 61fx and MACs Tuned pipe
  162. .21 Vspec break in.. No, first time starting...?
  163. what glow plug on .18 ostm?? is os# 8 ok?
  164. Tuned Pipe for the O.S. 18TZ
  165. OS FS 70 ll surpass...black guey stuff
  166. .15 cv-r
  167. os 120 surpass aluminum motor mount
  168. OS FS 48 Surpass
  169. Idle trouble on my OS 12TR w/10J carb.
  170. OS .60 fgr questions
  171. OS 120 Surpass III
  172. OS FS 70 Surpass 11
  173. OS 30VG Compression ?
  174. Header and Pipe Combo
  175. OS 30 run in
  176. O.S. 18TZ-TX versus O.S. .18 CVR-M
  177. COOLPOWER SUPER T FUEL
  178. RECOMMENDED TEMPERATURES OS46 AX
  179. os 12 cv-r settings
  180. What's the best fuel for my OS 160FX?
  181. OS91FX mixture setting
  182. .52 muffler woes
  183. muffler swap
  184. Was told to repost this here in case someone can help. OS AX .46
  185. Hobby Services
  186. os 91 fs pumped is muffler needed ?
  187. Carb sticking at about 1/2 throttle
  188. OS 120 AX
  189. os 120fs header fit??
  190. will it fit A JATO
  191. VZB Vspec 21
  192. DTX .18
  193. OS 120 Am After Market Pitss
  194. SZ91H-PS head shim question
  195. OS Wankel Overheating
  196. OS 30vg and 30%
  197. OS .46fxi seems tight after setting
  198. OS .18 question
  199. OS 1.08 FSR 1.08
  200. 60L vs 60B
  201. os 35 question
  202. OS VR DF 91 with tuned pipe and prop option
  203. OS fs 40 four stroke
  204. dtx .18
  205. Traxxas "ez start" spinning on my os 18
  206. .46 and .55AX Help
  207. OS120AX
  208. fs 70 surpass
  209. BGX Start problem upside-dow
  210. Need new crankshaft for 160FX - taken care of
  211. OS Engines .21 VG
  212. OS .91FX
  213. OS46V Rear Exhaust
  214. OS FX 91 sputters on high end
  215. FS120 III Exhaust
  216. OS 300 Twin
  217. problem: 4 stroke mounting
  218. Heat cycle break-in???
  219. Quits at idle after removing glow charger - OS 70 Surpass II
  220. Running In an OS37SZ-H
  221. OS VSpec Pipe designations
  222. 30% Heli fuel in OS 46FX?
  223. OS 91 DF ?? what fuel????
  224. OS .55AX needle valve.
  225. FS 120 III Surpass - False firewall
  226. FS = OS is Tamiya FS an OS
  227. OS 91 Pumped problems
  228. .18 TZ question I'm a little confused...
  229. excesive fuel
  230. Idle bar plug
  231. new OS Wankel
  232. Getting an OS10FP head
  233. FS-120 Surpass III Engine w/Pump - tank location and plumbing
  234. Excessive fuel from crankcase vent
  235. OS Timing FS 61 Surpass
  236. Need Help... Stressed out...
  237. MOVED: Fuji43EI RF Interference
  238. Piston color
  239. 120AX & 160FX Noise Levels?
  240. MOVED: O.S. 91 Surpass prop and Sig Hog Bipe
  241. ENGINE TROUBLES
  242. OS FS 120 in a Giant Big Stik?
  243. 1.60 twin pressure taps help??
  244. O.S. 18 TZ-TX problems
  245. Needle valve for O.S. FS-120S-E Surpass
  246. O.S. 1.20 AX muffler
  247. need advice for 1.60 gemini twin exhaust ext
  248. OS FP .40
  249. OS .50 SX Break-in
  250. Header and Tuned Pipe
