View Full Version : O.S. Engines Support
Pages :
1]
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
- Determining Correct 3-Bladed Propeller For OS 55AX Engine
- 12CV Start Shaft
- How Far Back Can Tank Be From Spray Bar?
- Trying to ID this OS muffler / silencer part
- OS GT 15 gas
- Os GGT 15 crankpin hardening
- Os 120 pumped
- OS GGT 15 repair
- About measures O ring FT 160
- Trying to ID this OS Cylinder Head
- 46FX piston/liner
- black engine coating
- Os max 120 ax
- Bolt Torque Setting
- Cylinder and piston for OS SF 61 ring
- Is 120 f
- OS Max H60F Gold Head Quits On Every Final Approach
- OS 65 AX won't turn over
- OS Max 61 SF problems
- compatibility question
- Which older OS engine is this for ?
- FS-120 MKIII - Leaking on Pressure Regulator
- OS FT160 trouble shoot
- Removing Prop Driver From H60F Engine
- Os Max GT22
- OS FR5-300 Front mounted Exhaust ring
- 61RF-H abc instructions
- I have a OS 21 TM engine specifications
- Size of os max sx engine
- Questions re: GT-15
- 61VR Connecting Rod
- OS GT-15 air bubbles in fuel line
- OS 60 Max fp Needle valve assembly
- Is this too much clearance
- FS 70 Surpass Gaskets?
- pressurizing an OS FS90 fuel system
- Are OS Engines still made in China
- OS GT33 issues
- OS 300 Sirius Radial running only on 4 cylinders
- Zboard motor pulsing in drive
- older OS 120 4 stroke pump screw reset info
- screw size
- Os 95v
- OS FS Surpass II bearing question
- Os ggt 15
- FS-95V Front Bearing Discontinued
- GGT15 Mixture Screw Initial Setting
- OS160 FX Propeller
- Os .21 vz-b vspec
- OS FS-26 Serial Numbers
- OS Max 50 SX Ringed
- exploding rear bearing in OS .65
- Os 25 fx max head torque problem
- OS FS-91SII pump question
- os 46 fx problem
- OS 21 RF-B manual
- 46 sf instruction manual
- O.s 8B Carburetor.
- OS GT15 Engine, looses power
- OS 10 FP questions.
- Older OS engine head and backplate screw sizes
- OS 91f/s
- OS 91 FS w/pump power problem
- Which Hex size for NGK CM-6 plug? (OS GF40 Plug)
- Caburator 20E dust cover from OS-21 RG
- OS FT120 Gemini Mk1
- Need OS Gasket Set PN 6114 For OS 60 Gold Head
- os 91 four stroke
- OS MAX 35 FP Start problems
- OS .60 Black Head
- .46 FX and AX piston and sleeve compatibility
- OS FS-91SII: clunking sound when cab passes the push rod?
- OS 70 surpass head
- OS Pump Question
- OS 61 Four Stroke throttle stuck
- OS Needle Valve question
- pegasus Questions
- carb vs tank level with pressure
- O.S. Engine "Gaskets"
- OS Max 25 sf engine
- Os gf40 4 stroke basic question
- OS .40 LA Operation
- FT-300 Super Gemini Connecting Rods
- os 55ax installation problems
- OS Fr7-420 questions
- OS support
- Os .110
- os 55ax
- 91hz with #61b carb
- Os 15gt
- OS. 21 tm
- O.S. 1.08 FSR carburetor overhaul
- 25 FX Discontinued 2017
- OS 70 SZH question
- O.S. 120 II gemini exhaust extentions
- OS BGX 2.2 Head Gasket question, and Head and Back Plate torque specs please
- O.S. .61sf
- run a four strock using crankcase pressure or no pressure
- Different 1.20??
- 61 FX Bearing Replacement
- O.s. 10 / 15
- why does my Idle Needle need to be set so Lean ??
- trouble with replacing low speed needle
- OS CZ-2 Rebuild
- O.S. .46 SF Max Restorations; HELP!
- looking for a parts soource, OS .91 surpass II
- O.S. 120 FS Surpass (1) ?, Pump....... converting from pump to non pump....
- OS 46 FXi piston/connecting rod oreintation
- Engine quites after 30 seconds of idle
- O S FS 120 engine parts
- OS 91 Surpass II quits when igniter is removed
- OS FS 91II P (with pump)
- Oil content
- OS 15LA Engine Made In China?
- GT60 Backwards Start
- OS made in China?
- Recommended props for engine
- Os bx 1
- Help needed !!
- OS 120 Surpass Pump Timing?
- OS 1.60fx Piston Question
- OS FS91 and FS120 exhaust question
- os carbs
- O.S. .91fsr low RPMs
- engine compression
- os surpass fs 120
- 95 rv piston removel
- 46LA Carburetor Fuel Inlet Nozzle
- OS 91 FX Head on a OS 91 SZ-H Engine
- OS .52 FS Unusual Problem
- ball on hex screwdriver twisted off in socket head
- Torque curve for OS 1.08 FSR or OS .90 FSR ?
- OS .90 fs
- Os 46vd-p
- OS Sirius FR5 300 5 Cylinder lost compression!
- OS 91 FX Piston
- OS 55 ax problems
- OS GF30 adapter nut for Tru-Turn spinner
- OS 91 FX problems - need help
- OS 91 surpass making a strange popping sound.
- OS 91 SII (non-pumped) Idle Mixture Adjustment
- Any issues mounting an OS 110a inverted
- Os 61 sf abc
- 48 Surpass with APC 12x6
- 18x8 propeller for GGT15?
- O.S. 1.20 AX rebuild
- 95AX - Exhaust port on Engine is longer than the Extension?
- Scott J.
- O.S. Four Stroke Alpha engine discontinued
- A Dilemma about Propeller and RPM.
- OS 120III Pumped Cam/Cam follower alignment
- O.S. Walbro GT15 HZ carburetor part
- OS FS-120 Surpass II Rebuild Question
- OS FS-70S II parts question
- OS 91 FSII Pumped leaks from regulator
- OS FS26 valve cover
- OS 91 RZ compression
- Fuel for break-in of OS Four Stroke engines
- OS FL 70 Piston Removal
- GF30 Carb leaks around the rotor at the body is this normal?
- Origin of OS engines?
- OS 90FS and OS91 Surpass in a twin
- Upgrade FS-26 to FS-30?
- os 52fs coverplate
- os fs 200 regulator
- New OS GGT15
- OS FS-48 bearing questions
- Mufflers for older four-cycles
- OS 46AX Muffler question
- Cam timing on old 91 surpass
- 1988 O.S. .21 MAX EXR and O.S. .21 MAX RF Factory Needle Settings HELP?
- OS 61sf with a OS fueler system, carb and muffler
- Pegasus 240 Questions
- Noise?
- OS 91 FX at about mid throttle
- OS GT15 starting issue
- OS carburators
- O.S. FS-120SIII - Regulator System Reassembling - Howto
- Os rf/ sf
- Os 60fp (rn)
- on board glow
- Would camshaft timing one tooth out cause a F/S engine to run hot?
- OS 105HZ-R Engine
- 91 Four Stroke Surpass
- O.S. Max 77 VR DF
- O&S .61 four stroke sleeve removal
- OS .91-P Tricky Tune
- OS six cylinder Pegasus ??
- OS 55AX Piston removal
- OS 1.20 Supercharged Parts
- Bearing shields
- OS FT 300 twin
- OS120 FS Destroyed... PLEASE
- converting 91 FS II pumped to non pumped carb
- GF-30 engine mount
- OS 61 SF - Need Drive Washer
- poor running fs-30s
- OS 110 pumped cracked case
- How Low of Idle should a typical 61 FX Engine get?
- Can't remove muffler screws OS 32 SX
- Idle Screw will not stay set on a 60C Carb.
- O.S. FS .61 carb
- OS .46 FX Carb Replacement
- O.S. FS Series 91 Surpass Weird problem.
- Did os ever come with Perry carbs?
- T-6010 Tuned Silencer for OS 1.40 - using it on a 1.60
- OS 91 Surpass woodruff key
- OS Gemini 120 FT
- OS Parts for a Tower engine?
- GT33 big end bearing replacing
- Os 160 twin fuel set up
- OS55HZ Hyper Break In
- Is max 15cv-x
- Gf-30
- FT 120 GEMINI 1 glow engine twin cylinder
- OS 91 VR-DF square and roud head difference
- 95 AX, "mr. deadstick"
- O.S. 2B carb
- OS 91FX Piston orientation.
- OS FS 200 S, Oil in the crankcase
- OS 4-stroke Valve Sizes
- Os 91 fs
- OS FS-90 rear rocker
- Os 120 Surpass pumped stuck lifter
- OS Mufflers
- FT-160 rod removal help, please
- Help, I need exhast headder for OS .91FS
- OS 91S II Needle Valve
- 0% Nitro fuel on AX engines
- OS 160 Twin Prop extension
- OS FS@-56 fuel leaks at exhaust header pipe
- muffler presure heat
- Need Carburetor nozzle assembly for OS Max 40 fp
- Pressure Fitting O.S. 744 Muffler
- Bax, OS 70 FS Carb Question
- OS FS-120 Surpass Pumped (late '80s?) Trouble Running
- engine power loss
- OS 1.20 FS Poor Performance
- OS carb part...
- Why Do Model Engines Run Backwards Sometimes?
- Throttle Lever Assembly 1.08
- OS 1.40rx Temperature
- O.S. .25 AX
- O.S. 120 Surpass Failing after hot.
- FT-240 Cam/Crankshaft Timing
- MOVED: OS VALVE SPRING WORK IN MAGNUM MOTOR???
- MOVED: Marvel Mystery Oil?
- OS MAX 21 XZB
- os-20fp
