PDA
View Full Version : Polks Hobby
  1. Mini DIN plug to a Futab DIN plug wire adapter.Tech drawing of Polks Trainer plug pin
  2. Polk Hobby closing
  3. Polks Seeker II Reciever antenna broke off
  4. Tracker III RF output.
  5. PowerBox™ Competition SRS
  6. seeker 6
  7. Done with my Tracker 3
  8. Tracker III and buddy box/cord
  9. Tracker III programing
  10. can I adjust EPA in flight?
  11. Li-Po 11.1V for the TIII
  12. Tracker 3 & AFPD
  13. Tracker 111,Hi rate doesn't function on aileron gimbal!
  14. Has anyone talked to Polk's lately?
  15. Does Polks Support Reply
  16. Elevator control for Polk Hobby CHARLOTTE ARF GLIDER
  17. Whats the latest up date on TrackerIII?
  18. Set-up twin!
  19. New Tracker III's coming.
  20. lipos for rx power
  21. aileron reversing
  22. Elevon reversing on a tracker III
  23. Tracker 11 service?
  24. TRACKER III on 2.4
  25. Seeker RX Problems?
  26. Dianostic mode
  27. Set up twin engines,tracker 111
  28. Stuck on Chann. 30
  29. Tracker III Programming Sheet
  30. Ace rc servos
  31. Aileron-rudder mix
  32. elevons with a 4 ch RX
  33. Tracker III Programing
  34. How to Program Tracker III for Beginner
  35. TS Charger
  36. Tracker TX problem
  37. FMA Receiver
  38. Lack of response by Polk?
  39. Polks reply to the new spectrum??
  40. weight
  41. Latest Tracker III software?
  42. Rudder (ch4 inop)
  43. controlling of Blue bird BMS660MG+HS Rcservomotor
  44. dual elevators
  45. TX Quick Battery Chargers
  46. polks customer service is poor
  47. Seeker II Uncommanded Movement
  48. Beginner needs help
  49. The Valiant Tracker
  50. Tracker III and RealFlight G3
  51. seeker 8 locked
  52. Flicker and mixing
  53. 1-4 MIX
  54. Polk standard servo
  55. Tracker 111 Rudder Glitching!
  56. Set-up twin on Tracker111
  57. Scanner distance
  58. Seeker 6 receiver: acceptable uses
  59. More trainer cord information needed.
  60. is ver 1.0 need upgraded? on tracker 111
  61. Tracker 111 Scanner problem!
  62. tracker 3
  63. Getting new radio?
  64. Distance vs.Control?
  65. I really don't get it !
  66. P-Mix's with Elevon help!!
  67. Tracker III updates
  68. Seeker 6 woes on 5-cell pack
  69. Programming
  70. Tracker 3 Availability?
  71. tracker111, nextar
  72. I am so disgusted at this moment.
  73. Seeker 6 jitters
  74. Help with this Valient Tracker system!!!
  75. Elevon set up on a seeker 6 w/ tracker II
  76. Seeker 6 rcvr
  77. Help needed
  78. seeker 8 antenna replacement
  79. Tracker 2000/15 with Pet Tracker for Sale
  80. FMA Direct and Polks-T200 transmitter
  81. Mix question for the gurus
  82. tracker question
  83. Polk/PCM
  84. Tracker11 Seprate throttle controls??
  85. New question!Whats a Valient Tracker?
  86. Tracker II Manual -lost
  87. dual rates
  88. JR Receiver use
  89. Pretty impressive
  90. antenna glitching?
  91. Help with tracker set up
  92. solution for the trainer switch location problem
  93. new tx
  94. Tracker 3 throttle/rudder glitch??
  95. range problem tracker 3
  96. tracker 3
  97. elevators
  98. Help, Please with Model Selection in TIII
  99. which simulator cord for Tracker III?
  100. Tracker III first night good and bad
  101. Poor Range with Seeker 8ch Receiver.
  102. Replacement Antenna
  103. I am not sure what is wrong !
  104. Tracker III now obsolete?
  105. voltages for the seeker receivers
  106. PCM on T3?
  107. Setting spreadsheet for T3
  108. Seeker 8 -VS- Vision TX
  109. Buddy box
  110. TRACKER11 HELP!I'm forgetting something here!
  111. Tracker 3- what's on the display?
  112. TRACKER III SETUP QUESTIONS
  113. seeker problem
  114. Tracker III Voltage Display Error !
  115. rubber ducky antenna and Tracker TX
  116. When are the rest of us getting our Tracker IIIs?
  117. TrackerIII mini-review
  118. I have a Tracker III
  119. Tracker II Instruction Manual
  120. Tracker III & Quad Flaps
  121. JR 9303 and seeker
  122. tracker 2
  123. Seeker II - Jitter
  124. Tracker II software upgrade
  125. Seeker 6 Channel 1 problem
  126. Tracker III Preliminary Manual now on line
  127. 36MHz Rx
  128. Trim Rate Settings
  129. Tracker Question
  130. Latest Tracker III info
  131. Trim problem
  132. Gliders
  133. Seeker 6 and Hitec Spectra Module
  134. Tracker II support?
  135. Tracker III - Request for information
  136. Tracker III pre-orders
  137. TrackerIII trade-in price?
  138. Knife edge on polk tracker II
  139. Tracker III Wish List
  140. New! The Tracker III
  141. Tracker II Scanner
  142. crash due to radio
  143. Current firmware software revision
  144. Time Over?
  145. Tracker II - Tx Case
  146. Tracker II
  147. Help!!With my Tracker!!
  148. Re Polks 60 A ESC
  149. scanner issue with 75 mhz version
  150. Aileron trim changing with duel rates?
  151. Re: Tracker II on 36Mhz ?
  152. Great Service
  153. Version 1.35
  154. "Rubber Duck" antenna?
  155. New Micro Seeker?
  156. Range Limit
  157. tracker for heli`s
  158. tracker version upgrade
  159. Tracker features???
  160. TIMER ACTIVATION ON TRACKER
  161. Scanner sensitivity
  162. stick mode
  163. Toledo
  164. Trim Fidelity
  165. Switch Combinations?
  166. New 1/2 oz Seeker RX - When?
  167. Is Tracker II PCM?
  168. New Radio?
  169. airtronics PCM
  170. Power output on Polk radios
  171. What is the new update 1-32 I believe.
  172. Channel # in Memory with Model #
  173. Couple Questions on Tracker and Seeker??
  174. It was right Under my nose and I didnt smell it !
  175. hitec 555 and trackerII
  176. Micro Seeker 72 Rx
  177. Old Airtronics vs New Airtronics.
  178. Couple of questions.
  179. outstanding features
  180. Transmitter specifications
  181. tracker landing switch
  182. Can it?
  183. Tracker Throttle kill?
  184. What is happening?
  185. What is purpose of this sub-forum?
  186. making a simple receiver
  187. Rudder -> Elevator mix for knife edge?
  188. A minor point....
  189. PPM control system info needed
  190. 3 position switch
  191. Several Tracker II Issues
  192. Trim Control on the Tracker II
  193. TRACKER II
  194. Flaperons with 5 channel rx
  195. range ckn
  196. Tracker II Battery pack re: charging
  197. onboard glow driver
  198. Seeker II - single conversion?
  199. Tracker II throttle stick not set correctly
  200. just got my tracker II
  201. Got mine today!
  202. Tracker II Tx sold seperately?
  203. Tracker II Pictures?
  204. 1024
  205. Memory
  206. Trim and dual rate on slave channel
  207. Known Issues
  208. Tracker Charger
  209. Radio Configurations Question
  210. Flaperons
  211. Tracker II engine idle down programing
  212. Tracker Manual
  213. Software update question
  214. Seeker Receivers
