PDA
View Full Version : Jet Central Turbines - Artes Jet
Pages : 1 [2] 3
  1. Rabbit kero start problem
  2. Pump Limit Setting
  3. Jet Central Super Eagle on F22
  4. Eagle Start Issuee
  5. Turbo Prop
  6. Rhino shutting down, Lowspeed????
  7. Chinese ceramic bearings
  8. Falcon 100 Gas %
  9. Super Bee hesitation when going from idle to full throttle.
  10. SuperEagle A123 slower response
  11. Gas Start, Where????
  12. What readily available Fuel/Oil can I use with super bee?
  13. Replaced Super Bee Starter motor
  14. Killer Rabbit
  15. 12x failsafe
  16. Failsafe
  17. Super Bee exhaust gap
  18. MAMMOTH DELEVRY?!!
  19. JC Rabbit KS problems
  20. spool time eagle and rhino???
  21. Super Eagle fuel use vs. rabbit question
  22. New Rabbit FOD screen
  23. Ceramic Igniter and ECU battery
  24. gas filter+restrictor
  25. Rhino spontaneous idle increasing
  26. Glow plugs
  27. falcon won't reach max power
  28. bee with 5%
  29. Compatible parts between turbines?
  30. JG-100 What is the Jetcentral Equivalent ?
  31. Rhino flame out - need assistance
  32. maintenance fees
  33. bee shutdown in midair
  34. Rabbit Power!
  35. Maintenance
  36. Rabbet pipe diameter
  37. Couldn't get bee to start
  38. HELLO
  39. Trying to contact Felipe Nieto
  40. Rabbit Temps
  41. ? re fuel solenoid
  42. Ceramic igniter
  43. Rabbit can I run 5% turbine oil????
  44. Can the Rhino and the LPSS be converted to kero start yet?
  45. satisfied jet central owner
  46. Can I use Mobil 254 in my Super Bee?
  47. what glow plug for a Falcon?
  48. Rabbit Dimensional Drawing
  49. What causes the "popping" or "burping"sound?
  50. Rabbit/Merlin 90
  51. What glow plug for Super Bee?
  52. Fuel in the can..
  53. Rabbit using 2T synthetic oozes oil tail cone
  54. thanks to eric
  55. Rabbit starter???
  56. Switching to 2C oil?
  57. rabbit glow plug
  58. Recommended idle RPM
  59. Super Bee bearing
  60. A123 9.9 patch?
  61. 5% oil for Falcon?
  62. Which glow plug for Super Bee and Question regarding plug connector
  63. Falcon - issue resolved
  64. Turboprop - Slow acceleration
  65. super bee flameouts
  66. Air bubbles
  67. Super Bee noisy.
  68. Excellent service!
  69. Rpm increase for Super Eagle?
  70. Switching from Jet A to Kerosene
  71. Festo connector on JetCentral Engine
  72. Falcon- sputtering & high idle (All is good now)!!!
  73. JC Eagle
  74. Starter motor/engine lock up during cool down
  75. Rabbit
  76. Thank You Eric
  77. 2.4 and fail safe
  78. Eric Clapp at Jet Central Does it AGAIN!! PERFECT!!
  79. Looking for eagle turbine
  80. My Falcon wont light either
  81. 40k idle on falcon
  82. warrenty info
  83. smoke flame out?
  84. Propeller RPM's in the Turboprop
  85. Rabbit "slow" accelleration
  86. just a happy customer
  87. Glow Cable to short on Falcon
  88. Take a moment to smell the Roses....
  89. Artes JF 100
  90. Electronic Fuel Valve Body
  91. Kero start ???
  92. Run Time
  93. Rabbit first run
  94. Air gap between nozzle and pipe
  95. Rabbit EGT probe
  96. Inconsistant start up on Rabbit
  97. Question for Eric
  98. whats wrong with my Setup.....
  99. 5% oil ok for Rabbit?
  100. Filling an on board gas tank
  101. Charging Li Ion supplied with Rhino
  102. Turbine Oil Mixture
  103. Jet Central Carlos
  104. Recommended Oils
  105. Eric Clapp
  106. Jet-Central Rabbit VT-90...first impressions.
  107. powermax or butane
  108. Falcon and Rabbit spool times?
  109. Eagle ECU question
  110. Artes Falcon locked up, PLEASE HELP
  111. Mammoth
  112. Disconnecting ICS
  113. JF 100 Falcon glow plug & pump
  114. Super Eagle Help
  115. No cooldown
  116. NOISE
  117. gas restrictor
  118. gas restrictor
  119. √Ānybody seen some Rabbits?
  120. FOD screen for Jet Central Turbine
  121. rabbit reviews
  122. Falcon pipe size
  123. rabbit wont light up
  124. Artes Falcon downunder
  125. Where to source glow plug pos lead connector Artes Falcon 100
  126. Artes Falcon 100 downunder,,
  127. Falcon 100 gas won't light????
  128. Falcon - slow starter speed?
  129. Bee upgrade
  130. Eagle Orientation
  131. Mysterious Shutdown
  132. Super Bee gas restrictor question
  133. Fixed: Flaming Falcon Shutdown
  134. FUEL MIXTURE QUESTION
  135. Combustion chamber compatibility for ArtesJet 3000 Eagle
  136. "Rhino" and 2.4GHz***PROBLEM SOLVED***
  137. Super Bee Turning Red Hot
  138. JF-120 Glow Plug
  139. Super Eagle turning RED HOT???
  140. Data from ECU
  141. A123 Batteries
  142. Upgrad for ecu of JF 120 Eagle?
  143. Fuel Consumption - Eagle 30#
  144. Super Bee Accel. Time
  145. Jet Central "Rhino" in Australia
  146. shutdown ques.
  147. new engine
  148. warranty
  149. oil content in Jet central engines
  150. ARTES SUPER BEE
  151. KJ66 Bearing Preload
  152. Your thoughts?
  153. Artes In europe ?
  154. Rhino throttle curves
  155. Who is running JetCentral USA?
  156. Falcon Shut Down Issues
  157. Rhino wont start - NOW STARTS BEAUTIFULLY
  158. Falcon gap
  159. Water in fuel!
  160. Rhino ECU code
  161. Lifetime Warranty TRANSFER?
  162. Stuck Starter?
  163. RE: Rhino Repairs
  164. KJ66 Turbine Disc
  165. Jet Central Prices
  166. Question of FADEC USB DATACABLE
  167. Ver 5.50 ECU build in throttle curve question
  168. Rhino Jet Engine Time of acceleration/deceleration
  169. Artes Service
  170. Strange Charatcers on Data Terminal?
  171. 45 Pounds Rhino
  172. Thermocouple Calibration
  173. Mobil DTE Light
  174. Super Eagle ECU problem
  175. Rhino flames out of tailpipe
  176. Starter Overload
  177. Falcon starting question, SOLVED!!!!
  178. the "prudent" way to propane start?
  179. My Eagle runs but:
  180. Super Bee gas setting.
  181. Glow Plug NOT shorting!!
  182. Quick question about Rhino!
  183. Falcon "popping" at idle
  184. Lifetime warranty
  185. Kj 66 to JG 100 upgrade
  186. Exhaust Gap
  187. Where to find lifetime warranty details?
  188. lifetime warranty
  189. Voltage for ICU - Super Eagle
  190. Rhino flame out
  191. Bad Glow Plug?
  192. Eric are you there?
  193. SuperBee running GREAT!
  194. rpm,egt extentions
  195. Rhino Test Run
  196. super bee bad glow
  197. Super Bee Surging
  198. Not reaching max RPM
  199. Jet tester
  200. KJ-66 build
  201. Artes JF-100
  202. Engine Orientation
  203. Problem in starting Jf-120
  204. RPM problem of twin engines
  205. Falcon FOD screen
  206. Jersey Jug
  207. Service question
  208. Running aT limited RPM?
  209. Filter, valve installation
  210. Rhino Service
  211. Follow Up on amount of oil
  212. Lake Whales Jet Event
  213. pitottube
  214. Diesel on Super Eagle?
  215. Li-Po battery use
  216. artes jets "flea"
  217. Rhino Max RPM
  218. Bee Upgrade?
  219. Super Bee set-up
  220. Falcon
  221. this doesn't look good
  222. Rhino RPM & flameout issues!!
  223. Rhino flaming at throttle back
  224. i need to help Diy jet engine Grinding the turbine bladeFD3/64
  225. Rhino Fuel Priming
  226. Hello Artes???
  227. Test run on my new Rhino
  228. Falcon issues
  229. turbine power 6.lb plane witch jet engine
  230. Question on using the Duralite 4000 mah, 4 cell, 7.4 volt pack with the Bee
  231. Kerosene start?
  232. Charging Jack for Artes Falcon
  233. Jet programing
  234. Question about The Rhino's maximum thrust ??
  235. artes bee or pst600
  236. Contacting Jesus.
  237. Falcon Users Manual online?
  238. Clogged gas reducer
  239. PROPANE PROBLEM?
  240. I.C.S PLUG?
  241. Mexico distributor?
  242. trouble starting
  243. amount of oil
  244. Running problem Artes JF 120 super eagle
  245. Trouble starting Bee with Jr 10sx
  246. Problems with JF 50 Bee and PCM Receiver
  247. Turbines at 8000 Ft
  248. kj66
  249. MOVED: Dynamax fan stator vanes
  250. New Contact number
