PDA
View Full Version : Jet Central Turbines - Artes Jet
Pages : [1] 2 3
  1. Need a Power Pack
  2. Turbine status via Telemetry - SE ECU
  3. Diesel
  4. Jet Central Gear sequencer
  5. Cheetah and fuselage full of fuel after run
  6. Cheetah SP Glow Bad message
  7. Jet Central Mammoth SE Flameout Errors
  8. Jet Central Super Eagle starting problems
  9. Rhino 200 SP/Xicoy Powerpack, Start parameters
  10. I know it's old but Falcon spacing from pipe
  11. Cheetah SE issue
  12. Updated Service request form with Manny's info
  13. No SD CARD error message
  14. ECU Fuel Counter
  15. Rabbit VT90 (first version) ICS max voltage ?
  16. ECU Low Voltage
  17. JetCentral SE Powerpack Receiver / Throttle Input Voltage
  18. Jet Central Mammoth SE 250
  19. SD card for Cheetah 160 SE?
  20. SE power pack mounting position
  21. Is Jose still the rep
  22. Service Request Form Updated Address
  23. Updating old Xicoy to Xicoy V6 or V10 for the Rabbit VT-90
  24. Airborne re-starts
  25. Futaba and SE Telemetry
  26. Mounting Turbine Upside Down
  27. Jet Central rabbit V90
  28. Telemetry adapter setup question
  29. Rabbit sp throttle voltage
  30. Duralite ECU Battery
  31. Jeti Radio setup with Cheetah SE-failsafe/manual cooling
  32. Jeti Radio setup with Cheetah SE-failsafe/manual cooling
  33. Rhino 200 SP PW Numbers?
  34. Weird sound when accelerating past the half throttle (Rabbit VT90)
  35. Warranty transfer for Jet Central
  36. Rabbit VT90 HDT display fading out after a second…
  37. Cheetah starter motor problems.
  38. Cheetah Problems
  39. Cheetah SE "To Idle Error"
  40. Glow element burning when powered up
  41. New Address Change for USA Service
  42. Festo on suction side of pump
  43. Is it ok to use the HDT with telemetry connected ?
  44. Rabbit VT Kero Start
  45. Cheetah glow plug setting with diesel
  46. looking for a good PW
  47. Hot starts on cheetah and flame outs on rhino
  48. 5 blade PC-21 prop with JetCentral Turboprop
  49. 25 hr superbee service
  50. New Service Request Form for Jet Central
  51. JetCentral Super Eagle on Diesel
  52. Jeti Telemetry adapter for 160 Cheetah SE
  53. Cheetah SE Max Fuel Consumption
  54. Bee II KS Warrantee Transfer
  55. Fadec (xicoy) e c u RHINO??
  56. Jet Central Cheetah SE Pipe Gap
  57. problem with super bee 80 N E W
  58. Cheetah un-commanded shutdown?
  59. Mammoth KS Start issue.
  60. Is my cheetah an SP?
  61. Super Bee Help
  62. 3 year old cheetah same as current?
  63. Inflight restart?
  64. Falcon 100 Glow plug issues
  65. Help with Transmitter Setup - Futaba and new PowerPak SE ECU
  66. Professionalism At Its Best
  67. Swapping a Bee and a Rabbit
  68. Additional Fuel Filter needed with PowerPak?
  69. Super slow throttle respound ,super eagle
  70. S-Bus / Power Cables
  71. Rhino ECU battery
  72. pipe to nozzle distance
  73. Jet Central's New Advance ECU and products for 2016
  74. Cheetah power pack vs cheetah sp
  75. Holiday Hours
  76. I.C.S. battery voltage verification for VT-90
  77. Jet Central Holiday Specials
  78. Cheetah pump value
  79. Very important for Jet central owners and Service
  80. Super eagle glow plug and gas settings
  81. Cheetah SP vs non SP Cheetah
  82. Turboprop KS 3 blade prop size?
  83. Mammoth Compressor
  84. Jose Melendez email
  85. Jet Central
  86. Needing contact info for Jet Central .Eric Clapp
  87. Falcon 100 Wot rpm?
  88. Jet Central Will attend Jet Power
  89. Donwloading ECU Data : AU-605
  90. Mounting position for Rabbit 100
  91. Kero Start Rhino unreliable starts
  92. Delayed Start VT-90
  93. Rabbit (VT-90) current draw ?
  94. Fast Idling Rabbit
  95. Old Style ECU on KS Turbine
  96. Jet Central Falcon - High Fuel Consumption
  97. Super Bee start parameters
  98. New warranty option for Jet Central Micro Turbines.
  99. New Jet Central Policies and Changes.
  100. glow bad message on my Cheetah
  101. Rabbit battery replaced.
  102. Voltage input for falcon 100 ECU ?
  103. Jet Central After Sales Service.
  104. Turbine oil for JC falcon 100
  105. Rabbit Top Speed
  106. Engine flame out on take off
  107. Warranty & Service Address info.
  108. Battery Overvoltage
  109. Jet Central Warrantee Question
  110. approved oils
  111. hdt dead
  112. Flames on landing.
  113. Cost of standard 25hr service
  114. ECU Battery Cable to ECU
  115. Quick Fuel question?
  116. Christmas Offers
  117. extra fuel tanks for my jet central falcon
  118. Futaba Telemetry Setup
  119. Cheetah and Diesel
  120. Warranty question
  121. Rabbit V100 ECU problems
  122. Any thrust reports from current users on the new Mammoth series?
  123. Telemetry from the new ECU/Valve/Pump pack?
  124. Fail Safe delay setup
  125. Gas and Fuel Valve ECU Connection
  126. ECU Version
  127. Super Bee Ecu
  128. Excellent service by Eric Clapp
  129. Question about the new power system
  130. On Board Filter
  131. Equipment Installation (Rabbit)
  132. Failsafe settings
  133. Bee II that won't start on Kero
  134. Updated JC ECU- FADEC System - Autostart 10 Battery Votlage
  135. eric ...super eagle
  136. heard from Eric
  137. Leaking SuperBee
  138. Rhino Problem
  139. Bleed air?
  140. Falcon 100. Rumbles off idle
  141. Throttle Curve at Tx
  142. Cheetahs
  143. Converting the Super Bee from 14 pounds to 15.5?
  144. Jet Central Falcon
  145. Rabbit 100 pump and Ecu problem
  146. Falcon and super eagle kero upgrade?
  147. Falcon Shutdown with Thermocouple reading Zero
  148. Cheetahs
  149. No Warranty?
  150. Super Eagle 2 stroke oil?
  151. super bee, no ground control from ecu to fuel or gas valves
  152. JC Experts please reply...
  153. Smoking ECU
  154. Cheetah on gas?
  155. Cheetah on gas?
  156. Help on cheetah start motor
  157. Eric, I need help
  158. HDT
  159. Rabit 100
  160. Falcon Fuel consumption
  161. Eagle temp problem !
  162. Whats coming out next for JC?
  163. Ceramic ignitor question for Eric. (or anyone)
  164. Cheetah problems on starting
  165. Spacing b\w nozzle and tailpipe.
  166. Jet Central turbo prop manual needed
  167. Rabbit problems
  168. Rhino Fault: Gas Valve Overload
  169. Rabbit 100 battery
  170. Rhino Dimensional Outline
  171. Super bee
  172. ECU bad?
  173. Spacing between turbine nozzle and tailpipe?
  174. Rabbit KS Igniter voltage..
  175. SuperBee making backfire
  176. Rhino problems!! WHERE ARE YOU ERIC!!!
  177. Smoke Pump Voltage needed
  178. Jet Central US Service Center
  179. New Rabbit 100 Concern
  180. Thanks
  181. Battery for Jet Central Rabbit
  182. High voltage
  183. needs some advice on my rhino
  184. ICS numbers?
  185. high idle/flame out
  186. RHINO fLAME OUT
  187. Diesel
  188. Thanks, Eric
  189. Flame out /speedlow..HELP!
  190. ecu timer question
  191. Rhino Flame out
  192. Getting a hold of Eric
  193. Jet Central Eagle!!
  194. Can a super eagle be converted?
  195. Throttle learning question
  196. Super Eagle Problem
  197. pump mounting
  198. Thanks again Eric!
  199. Finally I am in..
  200. Rhino inlet ducting
  201. Bee II ks questions
  202. Cheetah Mounting Dim's
  203. Eric's DH-100 Vampire
  204. Falcon Flame
  205. Jet Central and Eric’s Support
  206. Turbine Pics
  207. Falcon sputtering at idle
  208. Best Place for fuel filter
  209. Rhino fuel/oil ratio
  210. spool up time
  211. Super Eagle ICS connections
  212. ECU battery, how many flights do you get out of yours?
  213. JF100 could it be a super eagle?
  214. Super Eagle Mounting Dim's
  215. Super eagle valve question
  216. Fule Ramp Issue on Rhino
  217. Rabbit KS hot start
  218. RPM sensor
  219. Slow Kero start on Cheetah
  220. they grow up so fast......
  221. Issue on Rhino
  222. Eric on vacation?
  223. Jet Central Super Eagle
  224. Deleted Post
  225. warranty
  226. parts please
  227. Rabbit 20 Lb Thrust
  228. Bee II ks
  229. Rabbit Start
  230. Cold-weather starts
  231. Throttle curve settings
  232. Updated Manual for Bee-II Kero
  233. Fuel consumption on a dialed down Cheetah
  234. Super Eagle O Ring Size
  235. Rabbit vs. Cheetah for the C-ARF Flash
  236. Pump Limit Reached
  237. Cheetah to Bell Mouth Distance
  238. Kero back to Propane for Rabbit
  239. Winter Maintenance
  240. Eagle PW range
  241. Rabbit/pipe gap
  242. Diagnose this . . .
  243. New Cheetah in GJC F-15. Great performance
  244. Water in Fuel
  245. Super Bee Burnt Glow plug
  246. Anybody home from JC?
  247. AWESOME service
  248. Is Super Bee upgradeable to new version?
  249. Is my pump bad?
  250. Rabbit kero start problem
