View Full Version : Gas Engines
- saito fg84
- Mintor 22 tune
- Zenoah G62 battery size
- So, what do you think about your EME 55CC V2 Gas Engine with autostart?
- Ghq
- Magnum 400 conversion to petrol
- OS GT15 to Glow question
- best props for zenoah 38cc
- OS GGT15 High Speed Needle Valve Tuning
- Zenoah g62 vs DL 50 which has more power
- Carb leaking fuel bad.....
- Rcexl is always on
- Help what engine????
- side carb DLE 30
- Dle35 ra finish
- FPE 3.4 engine
- Valley View 20cc mounting dimensions
- Reed Valves and Relative Performance
- hand starting
- spark plugs
- RCGF 10cc vs Evolution 10GX2
- Zenoah G26EI spinner Q????
- battery size for gas engine
- zenoah 20 info
- throttlle arm orentation
- carb troubles
- Evo 7260 Radial, what prop for flying?
- Valach 60cc The Beast
- Test Running Gas Engines
- smoke tank
- 2 stroke oils
- dle 20cc cylinder swap
- Evolution 15cc gx Thrust
- Pitts style muffler
- DLE 20 on a profile runs rich flying inverted.
- Is DLE 111 and DA 100 prop drill pattern the same?
- DLE 30 reed petals
- diode voltage regulater
- Dle 20 throtle servo alignment
- Sachs 4.2 Walbro WJ1D carb help needed
- First fuel engine - what do I need?
- low top RPM DA50
- Zenoah G-38 Will not turn up rated power
- EME On Board Starter
- FG 14 satio smoke tank
- HH100T engine parts Needed
- Where are you buying your cranksaft from? G38
- Big stik prop suggestion? DLE 35
- RPM Sensor ? for a DA 60
- Gt33 not working properly
- Help identify an engine?
- dle 35ra
- MLD 35 Carburator butterfly problems
- Fuel tank foams. Any advice? just have a lot of foam or bubbles in rank. Any advice o
- DLE55 ring source
- Experience with DLE 85
- 41 cc US Engine compatible mufflers
- G38 crankshaft work on the ZP38?
- Pulse Port on Walbro Carb
- Saito FG-17 (100) 4-Stroke Gas Engine
- JC EVO 28cc or 30cc cracked prop hub
- DLE35RA GAS:OIL ratio
- Saito Fc 14 Gas Engine
- AGM Engines
- satio fg 14 gas engine kill switch
- Moki 2.1 converted to gas
- Which is the best of these, DLA 32 , EME 35 or the RCGF 32
- Brave Heart engines
- Need iginiton module for DLE 20
- G38 ignition wire?
- Support for Fuji Imvac engines
- DLE 30 four stroke equivalent?
- Older G-38 Carb Kit
- Will a Zenoah G320 cylinder and piston fit a G26 case?
- Carb rebuild…..the extra steps
- Prop drill size & O.S. GT-33 shaft
- G26
- Os 91
- Thoughts on motor mount
- Marine Motor
- What DLE Gasser for 25% Cub J3
- DLE 55 vs DLE 61. Real world difference
- Mintor 38 cc Engine
- 3W's looking for a twin or single 56 or lower
- One piece muffler for NGH GT25
- Saito FG-21: fuel which octane? 90 or 93
- AH 100cc gas Engine
- Help with electrical connections
- MLD 35 - can't strrt!!
- MVVS 80 has Walbro carburator HDA-182 which need repair kit K24-HDA
- Any DL Engines owners out there???
- What size gas engine for airplane?
- First (2) giant scale planes purchased... now which engine should go where??
- JC Engines (Question about)
- 20:1 oil ratio for DA50R
- Amsoil better than Motul?
- DLE 55: Change from side to rear exhust?
- DLE 30 Carb.
- rcgf 20cc problem
- Cheap DLE 30- too good to be true?
- DA engine worth the extra price?
- Zenoah G38 Muffler
- Fuji 43 .... need a couple of parts
- Help needed with DLE 30
- DLE vs DA
- Wich Walbro carb for DLE 55
- problems with dle-30
- spe 26 ignition sensor setting?
- Looking for a Walbro 662A
- Routing a twin exhausts into one cannister
- Hard to start dle35r please help!!!!!!!!
- Loose JTec Snuffler Muffler
- DLE35RA Can I use a 6.6 volt life batt with no regulator?
- Zenoah G62 carb problems, not drawing fuel
- DLE 35 Carb question
- Replacement ignition system for ZDZ 40 RERI
- Looking for info on DLE 55/55RA port mods
- weed whacker motor
- Turnigy 32 Running Rough
- CH Ignition for Moki 150 radial
- every brand has it's problems
- gas engines smoke oil
- Roto 130 FSI 4 stroke inline 3 cyl; Anyone got any experience?
- Rcexl Ignition Issues
- model no# for g23 carb
- G23 carb.......looking
- Frank Bowman's Retirement
- DLE Engines On-Board Digital Tachometer
- 30cc dle not getting fuel
- sachs 4.2 prop hub
- DJ engines from Mile High R/C
- missing useless "sticky"
- Gas to glo plug.
- da 50 ran strong but then?
- Fuji 34 muffler
- Spark plug wire on DLE 20
- Zenoah G-26 Spontaneously Quits.....
- Broken Fuel inlet
- Please Help Identify This Gas Engine!!!
- Precision Eagle 4.2 Glow to Gas
- DLE20 Runs full throttle with both Hi an Lo needles all the way in??
- reed valves
- Mystery Probe
- prop size for dle 35 ra
- Best gas choice in 10cc range
- Fabulous Break in Test stand I got!
- Hobby King 52cc intake
- Header/flexible tubing source?
- Zdz 50
- Righter/ Denny Plane Drone Engine
- New RC Hobby engines
- Help please G62 information
- DLE 20 drops rpm after 10 sec idle
- 4.2 lost compression
- Da 50 carb issues
- DLE20 RA (Rear Exhaust) Throttle Extention
- gas vs glo
- Idle screw and spring
- Can you Make DLE 55 Run Clockwise?
- RCGF 20RE engine
- Da 50 slow to idle down
- Saito 300T Converted to gas med-range problems
- please advice if I'm doing it right or wrong
- DA/DLE Ignition Systems
- Gas powered rc
- Baffling an engine
- RPM's on 14x6 with Evo 15cc Gas Engine?
- DA100L low RPM
- Carburator Question
- Evolution 33 premature wear
- primer for walbro carb
- Da 50 fuel tank
- Sachs Dolmar 4.2 Carburetor Spacer
- Evolution 160 radial
- A few questions about Evolution 10 cc gas
- Converting a Homelite weedeater engine to RC
- Help and opinion with an early model DLE 30
- Zenoah G26 Surging at WOT.
- A and M engine
- JC Engines 51cc or 61cc/dont know which...
- Zenoah Engine REpair
- Tuned exhaust pipe for Honda GX31 engine.
- 42cc US muffler
- MVVS 35cc, large amount of thick black oil residue.
- DLE Problems
- FG 14 C tach not working, help
- dle 20vs zenoah g26
- Help ID this motor??
- Does oil content affect idle?
- Tuned pipe bend radius? how tight is too tight?
- 3W 50i
- Da 50 shielding
- moki 70cc gas engine
- Rcexl sensor problems
- MAN OS GGT10 review, picture captions in what language ?
- Some progress with the GT80, but still a couple of concerns.
- B25-Engines?
- Rcs44b2
- Changing from 20:1 to 32:1 gas to oil ratio
- Adding a 12" ext to the pick up lead??????? DLE 35 RA
- NGH 30cc 4 stroke
- At a complete loss with GT80...........
- Can I use A123s with this G-62 ignition?
- Sticky gas review
- choke dont close
- Six bolt hubs
- OS Muffler on Evolution 15GX2..?
- Bennett muffler repair
- Tuning your Gas Engine made easy....
- Zenoah-62 reduction drive starting
- Brison 52 bearings
- DLE 35ra fuel consumption rate
- gas engine surging
- G-23
- Need larger cup
- SPE 26 Parts
- Zenoah gt80 problems
- DLE 20 muffler question...again; Sheeeh.... let's try it with PICTURES this time.
- Sachs 4.2 engine
- DLE 55 ignition modules
- 1.20 glow versus 30cc gas
- Need strange muffler for DLE 20 in this strange position....
- DLE 120 / 111 bolt pattern
- weigh and size Dle 50 and DLe55
- BCMA 26cc AND BCMA eXL auto advance ignition MANUAL SEARCH
- new to zdz 80 super, hints & tips?
- Is this too rich?
- DLE Carb Rebuild Kits
- Os gt10
- Gas Engine Fuel Line
- Lift Meister - engine for?
- G-45 rpm?
- RC 35cc Gas engine Plane Cooling
- Need help identifying mystery twin?
- Bowman's Rings
- quadra , wont start ?
- G38 On Coleman Fuel
- Plug cap falling off
- Zenoah G62 oil mix question
- HS needle setting for Evolution 15GX2?
- Engine will not fire..15cc
- Gas/oil mix and ring replacement
- Is This Safe for Gas??
- Dle 35 carburator
- ATT. Gas engine Gurus OS Max GGT10 CC or 15 CC
- AGM warranty beware
- Fuji 64 cuts out in midrange
- Valley View Props?
- dle 20ra
- Is it possible to cut the insulator block on the carb of a G 62 for more clearance?
