PDA
View Full Version : Q-500 Racing
Pages : 1 2 [3] 4 5 6 7 8 9
  1. 424 servos
  2. "Sheeting the Sheeting" with fiberglass
  3. Looking for a good last generation SS Nelson Q-500
  4. Q500 entry-level Q's
  5. No Nelson
  6. 66-012
  7. Nelson SS-Q500 wanted
  8. actual Size of JETT/Nelson mounts
  9. Which crank is what?
  10. Rules Q500 AMA 424
  11. AMA 424 Race Bloomington, IL June 20 & 21
  12. Hodges Hobbies Race 5/30/09
  13. Viper Repair
  14. Custom Backplates
  15. AMA 424 Race - Wichita Kansas
  16. The Smasher - Building the Wood V-Tail
  17. Lowes RC website
  18. Whats This
  19. 2.4 g in viper
  20. Using different wings on the same fuselage?
  21. The Boomer by Bill Vargas
  22. Composite Tails and Molds for Sale
  23. AMA 424 Sport Quickie on a 2 pole course
  24. Conspirator by Arch Adamisin
  25. New Viper 500 RTC
  26. Viper Dog
  27. VIPER TRIM ISSUE:
  28. Better late than never - RC Barnstormers Spring Race
  29. NEPRO 424 Q500 RACE 5/3/09 HADLEY MA
  30. Merlin Glow Plugs
  31. Finally raced the Smasher
  32. Old Julian Airport Racing Results and Pictures!!
  33. Q500 Times
  34. Inolab Servos Great units
  35. North Carolina's Old Julian Airport Races Role Call!!
  36. Compete For The Lead Goose Trophy
  37. Airtronics FHSS radio in Q500?
  38. Practice Day At Old Julian Airport Race Course With Video
  39. Field Bench
  40. The Venom Strikes Back
  41. Let me put it this way....
  42. What's legal??
  43. What G loads do Q-500's pull?
  44. Viper Composite Wing
  45. Predator II Airfoil?
  46. The Wood Smasher
  47. Hodges Hobbies race 4/4/09
  48. Funny Q500-40
  49. KCRC 424 Pylon Race – April 25th
  50. New Backplate Motor Mounts for Thunder Tiger 40 Pro engines
  51. Get your NINJA Q500 Now!!!
  52. OS .25 FX Turning 22,500 RPM
  53. Dominator 500 CG
  54. Smaller versionQ500
  55. Q 500 Vortex
  56. Intimidator q-500 kit
  57. best glow plug for TT pro 40
  58. Q-500 Intimidator plans?
  59. HINGES
  60. Q500 IN VENEZUELA
  61. Rubber Duck Antenna for Futaba 9C Trans:
  62. Why Do They Call It Quickie 500?
  63. V-Tail Layup Schedule
  64. Building a better Viper wing
  65. Building the Smasher for 424
  66. New Spanish Q-500 model (VeraMar-V)
  67. SMASHER 424 RACER
  68. Q-500 Sheeted wings and foam cores for sale
  69. Q-25 Pylon Racing
  70. ANOTHER WARNING
  71. Racing Helmets:
  72. Piston and liner fit and performance
  73. My Latest BuckShot Quickie 25 Racer
  74. Vacuum Bag that 424 Wing
  75. FORA 40 q500
  76. MOVED: CG Hangar9 P47 150
  77. The Katz Meow
  78. PYLON RACES IN MARACAIBO VENEZUELA
  79. New Quickie in progress..
  80. Wing Skins
  81. lipo battery for starter
  82. Help with 428 Q-500
  83. Low cost vacuum bagging setup
  84. NEPRO PYLON SCHEDULE FOR 2009
  85. BuckShot Quickie 25 Build
  86. Engine Weight data?
  87. Dominator 500 plans or kit
  88. New AMA class racer Indoor pylon
  89. Spickler Quickie 500 Laser Kit
  90. The Seeker Composite Tail
  91. Intake Timing .46 Pro TT
  92. Reintroduction of the Smasher
  93. PYLON RACES IN SOUTH CAROLINA
  94. Quickie500.com
  95. Mr Quickie
  96. 66-012 airfoil
  97. Hodges Hobbies pylon race February 21
  98. Out of the ashes of WinterFest
  99. Wings for 424?
  100. O.S. 25FX Backplate Mount
  101. Winterfest
  102. NEPRO Winter Metting 1/24/09
  103. Old Julian Airport Air Races in NC
  104. Setbacks
  105. Lanier Predator - is it OK???
  106. scat cat dihedral question
  107. Tangerine Roll Call
  108. Profi Engine?
  109. Sheeting Foam wings
  110. VIPER 500
  111. LSQ500
  112. Q500 VENEZUELA
  113. Joe Bridi Gyro build
  114. Next Q-500 Plane after a Viper, Is there one?
  115. RC Power -Duck Antenna
  116. uk budget class's
  117. Bridi Gyro
  118. Vortex Q500 Kit
  119. Old School Q500 building
  120. PROPS
  121. XCITER
  122. T-tail Quickie
  123. WTB
  124. Great Planes Wing Viper 500 air foil
  125. Pit Bull Construction
  126. Installs...
  127. Viper Blows wing!
  128. JR 2.4GHz for pylon RX's
  129. MY FIRST Q500 MACHINE
  130. Differential
  131. SONIC 500
  132. Servos - anyone used the Airtronics 94761Z?
  133. SERVOS
  134. Day Go CG.
  135. build thread on Scat cat
  136. MOTOR FOR SCAT CAT
  137. Nelson q500 throttle linkage
  138. NEW VIPER FIRST FLIGHT IMPRESSIONS
  139. Viper Fuselage Width
  140. SpeedWorld Race
  141. 1/64 Plywood Wing Skins Any Good?
  142. OS 46 AX Remote Needle Mounting?
  143. RACING IN MARACAIBO VENEZUELA
  144. New Italian Q500
  145. Nelson Q500 manual / instructions
  146. scat cat replacement?
  147. HiTec HS5245 digital suitable for Q500?
  148. NACA Codes
  149. KCRC race October 4th
  150. prop?
  151. New Spektrum 5ch RX
  152. Glow plug for TT 40 Pro
  153. New VIPER Rips.
  154. jett ls Q 500
  155. Nelson SS Q500 props
  156. Chicago Area 424 Pylon Race
  157. HELP
  158. Me and my Vipers
  159. Viper aileron torque rod problem?
  160. Fuels
  161. Q-500 WING CONSTRUCTION ?
  162. Cleaning brunt oil off head fins
  163. TT GP 42 Engine Leaking and compression decline
  164. Q-500 ENGINE CLASSES
  165. Thuder Tiger Pro .40
  166. Nelson Q500 .40SS Performance
  167. 2 pole 424 race - CANCELED!!!
  168. Yes, another Viper question...
  169. KCRC 424 Fall Classic Race, October 4th
  170. Low End Rich Needle Trick:
  171. OS46ax NEEDLE VALVE [ VIPER ]
  172. Flight Trimming Issue:
  173. q-500 plans
  174. how fast am i flying/grudge racing aug23,2008 houston,tx scobee field
  175. Nelson LS Best Set up
  176. sam-rai for 424
  177. Need an engine
  178. RC Barnstormers Fall Race 2008
  179. Daven at the Nats
  180. Q 500 Race
  181. 2008 Nats
  182. Best engine
  183. Engine back plate mount
  184. F-1 And Super Tigre
  185. 424, Quickie 25 and Club 40 racing at Lowes Motor Speedway
  186. Viper! Near krasch!
  187. DX-6i elv trim malfunction
  188. Viper Q500 with K&B engine
  189. 424 Summer Workshop and Testing
  190. DX-6i beware of drum roller break down
  191. There is a catch with the DX-6i!
  192. Q500 aileron torque rods
  193. NINJA Q-500, Ready To Ship, Tip and Techniques
  194. New Ninja for sale
  195. TT Pro40 Muffler?
  196. Viper Q500 tips and techniques
  197. Digital Servos
  198. Engine tuning
  199. Q500 racing in san diego?
  200. Nelson LS and SS throttle linkage location
  201. Servos
  202. 428 in Cincinnati June 7th
  203. Question for the JR guys
  204. Where to get Q500 airplanes???
  205. New Saetta V4 building Thread
  206. Viper 500 plane issues
  207. New Racer/New Pilot
  208. Viper Thottle Servo Placement
  209. Composites
  210. Are there any Vipers Anywhere?
  211. Hodges Race
  212. Summer Pylon Series at Lowes Motor Speedway
  213. 428 NCPL RACE - 1 week to go!
  214. Q500 landing gear question
  215. where to find q-500 airplanes.
  216. Moving up to 428
  217. Flying Characteristics: Viper Q-500 Pulling up in Turn Number 1:
  218. Happy 424!
  219. Vortex Plans
  220. North Central Pylon League Race
  221. Q500 Racers!
  222. 428 pylon and foam wings
  223. Incidence Questions
  224. 424 Race in Kansas City - RC Barnstormers
  225. Alternative to a bladder tank?
  226. Any Cheap Q500 ARF'S
  227. Carbon landing gear
  228. Carb coming lose
  229. Viper 500 - Best Configurations?
  230. HurriKane Sheeted Wing Strong enough for 428?
  231. Matney Models Mad Dog Finishing
  232. wings
  233. Help for a returning pylon racer
  234. Ninja 500
  235. Newbie Quickie Question
  236. Prop for Vipper
  237. APC prop
  238. Lowes speedway demo 424
  239. Different kind of plug?
  240. Viper 500 - where from?
  241. This the plugs for my new Q/500
  242. Futaba Servos
  243. APRIL 13 RACIN IN VENEZUELA
  244. Battery Dilemma: For Q-500 - 424
  245. I may be wrong
  246. 424 Race in Kansas City, April 26th
  247. Testing a Tettras Fuel Tank:
  248. Tettras Tank Set up: Confused need some hlep
  249. TT Pro needle valve
  250. HOW TO BUILD A "HAULER" Part 1
