PDA
View Full Version : JetCat Turbine Direct Support
Pages : [1] 2 3 4 5 6 7 8
  1. installation position of kerostart adaptor
  2. RX. Pump burned upPhotos sho
  3. Jetcat Mount direction and strap installation?
  4. ECU V6.0 conneted to Futaba FASST 7014SB
  5. JetCat P-70 Outer Shell Dent and Starter Damage
  6. JETCAT V10 Baro/Temp setting adjustment
  7. Can't get my P-160 to switch to Kero start
  8. SPT5 v3 question regarding turbine splutter.
  9. Finding service history on a P160
  10. JetCat P80se
  11. JetCat P400-PRO only generating 27kgf thrust
  12. P120sx inter.kero start problem
  13. SPT15 Marine conversion
  14. 200rxi ?
  15. Glow plug is turned on by ECU YES ???
  16. Glow plug, false reading??
  17. Bearing oiler & filter on front board
  18. Ecu update
  19. Jet Cat Titan
  20. P70 battery low error
  21. Hot exhaust shooting out sides of turbine
  22. How to R/R P-120 starter motor
  23. JetCat P400-PRO glows red with abnormal temp.
  24. Jetcat RXI-90 won't start
  25. P-80 ecu battery change
  26. P140RX sliding forward in bracket
  27. STP5 (v3) Turbo Prop engine issues.
  28. Unit of measure for "Last Fuel Count"
  29. P-140RXi temperature calibration
  30. V6 ecu
  31. Rx style smoke pump. Need help.
  32. P20-SX questions
  33. Is it normal to burn a ECU ?
  34. Jetcat P60 with flame on startup
  35. P100 rx v10 software
  36. determine size
  37. P-140rx pump error
  38. Jetcat p220-RXi LoRpmPmp (Flame out)
  39. jetcat v6.0 issues, buzzing sound in pump
  40. 140rx ecu
  41. P100 Not running at max RPM
  42. RXI-B version Jetcats
  43. JetCat Service.
  44. jet cat 180
  45. P20 Pump problem
  46. P-180 problem
  47. JetCat SPT-5 turboprop
  48. P90 RXIi help
  49. Another "can't start" thread - Jetcat Titan
  50. 200rx v10 ecu problem
  51. JETCAT V10 ECU latest software version?
  52. Jetcat P120 flame start
  53. P80 to P70 manual change on GSU
  54. Jetcat 160SX puff of white smoke on idle
  55. diesel
  56. Jetcat P80SE - running without receiver
  57. JetCat ECU Battery
  58. Jet Tronic software
  59. JetCat telemetry on Futaba 18MZ
  60. PHT3 over-rpm
  61. Ecu voltage
  62. Jetcat p120 front fan
  63. Could I use 3s lipo for the 140 rx or 140 rxi?
  64. p90 rxi question
  65. P 100 rx V10 ECU
  66. V10 ECU RPM2 Output
  67. P90RXI Help
  68. Old P-120
  69. P-70 code.
  70. V10 ECU throttle lead power
  71. P20 blowing plugs
  72. JetCat P300 Fuel Pump Question
  73. Looking for p400 manual
  74. Looking for p400 manual
  75. Jetcat P160 rc Learing
  76. P20 SE rpm range?
  77. P120SE overtemp
  78. P-120sx Manual
  79. P120 "over-rpm"
  80. 160 sx start problem
  81. SPT10 RX Prop mopunting question
  82. 140 RXI GSU showing wrong pump help
  83. 140 RXI GSU showing wrong pump
  84. Batteries for the V6.0 ECU.
  85. JetCat 180 Rx...losing power.
  86. P90-rxi
  87. Kero start P-120 old style
  88. How to change from propane to kero start jetcat turbine
  89. P140RXi Low voltage error on start
  90. Jetcat 120
  91. P90rxi-B Drawing?
  92. Brand new p140 RX thrust reduction procedure
  93. P-60 won't start
  94. Back to Jetcat !! RX 140 thoughts
  95. JetCat P 80 noise
  96. P60SE on diesel
  97. P20SX start problems
  98. P120SX Flameout Diagnosis - Help with downloaded data
  99. Jetcat p80
  100. Aligning the ECU
  101. Jet Cat Codes
  102. Ecu v6.0 firmware mismatch
  103. Titan won't accelorate shoots flames
  104. P70 Glowing Tailpipe
  105. P-160sx combustion chamber
  106. JC P-100 RX flameout after a few runs
  107. A new Battery question
  108. 90rxi default values
  109. Old P80 kerostart plug keeps coking up
  110. P-180 Glow plug boss
  111. Auto optimize feature?
  112. P200 ECU v5.0 uaccel?
  113. Using Flight works 200C with a jetcat P60
  114. Failed start low rpm
  115. P60 Flames at Idle!?!?!?!
  116. P80 se throttle stick curve
  117. P70 Converted to Kero Start - Flame Thrower
  118. Jetcat p120 compressor stall
  119. 160SX 'bad temp probe or amp'
  120. P200 No Beeps or Starter
  121. 140 rxi
  122. Gsu
  123. 140RX Blades Rubbing After Service
  124. P80se won't spool up after landing
  125. DreamworksRC & JetCatUSA
  126. PHT3-3 Test Run
  127. Jetcat support at MS jets?
  128. New USA Representation for Jetcat Products and Service
  129. P-70 EGT Probe Possible Issues
  130. Sailplane P300 Battery Upgrade
  131. Hydraulic Rotor Brake
  132. Pilot Name Change
  133. Jetcat P-20sx problems
  134. JetCat PHT3-3
  135. Jetcat P160 shooting flames
  136. Jetcat p-120 max r.p.m
  137. New JetCat ECU cable
  138. P140RX smokes on diesel
  139. Jet Cat Mini GSU
  140. Converted P200 issues
  141. old p80 (blue cover)
  142. JetCat: Current Service
  143. P120 Long storage, what's best to do?
  144. Pittot tube speed sensor with SPT-10 turboprop?
  145. About a 60SE burner Kerostrart
  146. P20 SX starting issues
  147. P80-SE-P90 RXi -P100-RX . all silmilar thrusts whats the differences.?
  148. P140rx
  149. Poor throttle response P120sx
  150. Change turbine on ECU incorrectly detecting turbine
  151. P-70 starter weird sound
  152. P100rx problem first start of the day, fail with "low temp"
  153. P90RXI diesel back to Kero
  154. Registration question
  155. JetCat & Oil
  156. ecu v.10
  157. JetCat P-120 Questions
  158. P-60 Max RPM problem
  159. Why does my V6.0 ECU have V4.9 written on in pen?
  160. Any problems with storage in garage?
  161. P-80 won`t throttle properly
  162. P-200 pump running high rpm when switching rc on
  163. P-180RXI LowTemp on startup
  164. P-180 RX flame out
  165. P-80 temp-probe probably gone
  166. ECU thinks fuel pump is smoke pump
  167. 25 uhr total run time. What to do next?
  168. Need help with P-70
  169. ECU On/Off Switch
  170. P140rx fuel pump leaking
  171. Flashing green light
  172. Smoke from ecu P-140rxi
  173. P-60 Oil/fuel problem
  174. P20 help
  175. Smokey P60 on Diesel
  176. Foot Long Flame behind P120 & Fuel Floods
  177. low battery warning
  178. Can a older P200 converted to Kero start run diesel?
  179. Propane Valve not clicking during start sequence
  180. p100rx delayed acceleration
  181. P20 kero start fuel line
  182. error code "LoRpmPmp"
  183. To slow and legging acceleration on p 120
  184. P-70 Starting issues
  185. P160SX Flame-out
  186. 180 rxi not start up
  187. Engine flame out on take off.
  188. Internal pressure question
  189. JetCat Service has been flawless
  190. Any Recommendations
  191. P200 SX at 105500RPM
  192. Temperarure probe for SX 120
  193. O-rings for P-120 internal fuel and propane rails
  194. P120 not reaching full RPM
  195. 18MZ v.2.5.0 JetCat Telemetry
  196. P200 question
  197. Pipe distance
  198. P200 manual
  199. JetCat P200/P240's - How to tell if Positive or Negative ground ??`
  200. GSU for P-60
  201. Error, temp sens cable amp on gsu?
  202. 180RX Popping in start up
  203. P70 on Diesel ?
  204. Slipping O ring on Older P-180
  205. P120 SE Flame Out
  206. P 120 SE research serial # & some questions
  207. P100rx start problems
  208. P-60SE Won't Throttle UP
  209. P80 maximum rpm is 117 not 120 !
  210. P-100 RX fuel line size
  211. What is the correct spacing from the starter to the compressor nut on a P 200SX ?
  212. Im now running Diesel
  213. Question about Buddy BoxThrottle programming for a P70
  214. reversed polarity on ecu ???
  215. RPM on Old P-80
  216. Another O-ring question
  217. P180RX = Flame Thrower
  218. ECU battery
  219. p120 SX RPM question
  220. P90-rxi
  221. JetCat P60SE won't go to full rpm?
  222. P-70 Accel
  223. Spektrum telemetry with v10 ecu
  224. P160 help
  225. How are the p-180RX doing?
  226. Buddies P60 not starting
  227. Need help: New (just out of box) 140rx will not start - low rpm
  228. P160 ecu
  229. Diesel ecu settings for Jet Cat
  230. P-180 rx
  231. what balance board do i need for a LiFe battery for my 140RX?
  232. P60 GAS start problem
  233. Diesel use
  234. P-120 Over/Undershoot RPM
  235. P160 help
  236. p200rx...p220rx ?
  237. Turbine Wheel size p-200sx
  238. P160 help needed
  239. Jetcat turbine p200 help
  240. JetCat
  241. P70 parameters????
  242. New version starter in old P120
  243. New P180RX - are there issues regarding first runs?
  244. p70 ecu thinks a p120 is connected
  245. My old P-80 won't start
  246. P-90RXI Fails to Consistently Start
  247. extra wire on p60 ecu?
  248. P90-RXI fails to start. {Fixed}
  249. History of a crazy p160
  250. p20sx valve block
