PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 [100] 101 102
  1. Need control surface travel amounts and CG location for a GP Super Sportster 40...
  2. Adding wheel friction
  3. How corrosive is smoke oil?
  4. Guest flying site in Greenville SC
  5. Frisket Paper?
  6. Sig Kadet Sr How to setup wing bolts.
  7. Rec. engine for Dragon Lady 60
  8. Will it work ?
  9. Robart Retracts question
  10. Best Glue for Robart Hinge Points
  11. 10 mph winds with a parkflyer?
  12. EasyTex,SolarTex,GlossTex!!!!!!!!
  13. R/C fields in Omaha NE
  14. Heavy GP Phantom F-4 and Fx-91
  15. Anchorage flyers
  16. Need to find a Mag. 1.08 Spinner Nut!
  17. Used 8Utx, Don't know channel?!?
  18. Monokote Vs. Ultracote. Which is lighter?
  19. covering
  20. retracts
  21. Virus
  23. SIG's Web Site
  24. O.S. .40LA/ Tower Hobbies Fun 51?
  25. Massachusetts hobby shop (heli equipment)??
  26. taurus
  27. engine mounts
  28. Finding CG "article" in Mag
  29. covering wing with 2 colors
  30. stick-on weights?
  31. please close
  32. LT-40 Bolt on wings
  33. RCezine - Online R/C Magazine
  34. What Float Plane is this?
  35. Balsa USA 1/4 scale Edo floats ....any good?
  36. Big Bird Stop - Good or Bad
  37. Engine Size
  38. Fastest RC powered plane????
  39. Looking for Simon
  40. Float Plane Question
  41. C of G for Ultra Sport 1000
  42. Pitts style muffler for Top Flite Corsair 60
  43. Kansas City Hobby Stores/MNC Hobby?
  44. Horn Placement....Is this OK?
  45. Weight removal and prop balancing
  46. rubber in the engine mount
  47. 20 x 6 PROP
  48. Top Flite Elder Biplane opinions?
  49. Looking for CNC aluminium producer
  50. Makin' It Go
  51. What fabric covering material options are out there?
  52. who makes foam floats?
  53. Painting lines on runway, "H" on pad
  54. Whats better!! RC Heli's vs RC Planes
  55. Shell Oil Monocote Scheme
  56. Hovering and Gyros
  57. Cowled Engine Problems & Solutions
  58. Sealing a leaky mufller
  59. Aluminum Plane electric problems?
  60. Home made Carbon Fiber landing gear??
  61. yellow aircaft rep.Who is it?
  62. who sellspainted pilots?????
  63. Foam cutting health risk?
  64. Nylon wing hold down bolts
  65. 4 star 60 bipe
  66. Please help a Spinner Newbie
  67. Sig Kadet LT-40 Wing Kit
  68. Engine Mount Glued in Place
  69. Whats the best way to hang a profile up?
  70. channel scanner check?
  71. Runways
  72. Field Box plans...
  73. Resting plane on its nose
  74. West Systems Epoxy
  75. CG Goldberg Ultimate
  76. For all those trailer owners. Is this worth it?
  77. Exhaust residue on Cya. hinges?
  78. Field Box Equipment
  79. Covering Problem specially with Monokote
  80. Gosh #$%& CA Hinges
  81. Las Vegas flyers
  82. *** Everything Hinges On This ***
  83. solvent disposal
  84. MonoKote SmartStripe
  85. Model Aircraft Composite Kits any good!!
  86. Fiberglass over ABS?
  87. Quick question about Redundant batteries?
  88. battery interference
  89. Aluminum Spinners
  90. Banner tow with model
  91. GP Phantom
  92. Bolt on wing questions
  93. St. Croix LongEZE
  94. Getting fuel stains out of balsa ?
  95. too much weight in nose?
  96. stalling to side
  97. Nose weight?
  98. Sig smith miniplane
  99. *** Ariborne Video ***
  100. Electric Starter help
  101. HANGER 9 PIZAZZ "Can it Take it"
  102. Best nitro resistant flat water based clear
  103. Need PC decal program or
  104. OOPS. used 5 min epoxy instead of 30 min epoxy on wing..PROBLEM??
  105. engines
  106. Why only Sig for Scale Cubs?
  107. Buddy box question
  108. Enlarging Aluminum spinner?
  109. What is Don Incolls new web address?
  110. How do you measure incidence?
  111. Canopy Graphics
  112. what is tapered?
  113. Flying Field in Tenerife Sur
  114. Oleo struts?
  115. Aero Span
  116. GP Cap 232 40
  117. DU-BRO Kwik-Fill Fuel Valve (Glow) *help*
  118. Whats everyone thik about the Co Pilot/
  119. down thrust VRS up thrust
  120. Gas tank sizes
  121. gws zero
  122. World Models Chipmunk
  123. Throttle linkage???
  124. prop with mousse can muffler
  125. Tower Hobbies
  126. Is there a stronger mec. retract out there?
  127. Looking for a field around Mooresville, NC
  128. Ca Hinges
  129. Z-bend
  130. Some questions about flying fields
  131. GP Ryan 120 ARF
  132. Float Flying??
  133. Balancing and Control Throws
  134. Need Info. on Breaking in any Size electric Motor
  135. Tank placement question
  136. gas tanks
  137. anyone knows a good hobby shop in miami ?
  138. Fiberglass Cloth sources?
  139. Rustoleum fuel proofing help!!
  140. Paint
  141. Stuck in africa
  142. Help:Dubro inflatable tires
  143. Air Pump for Robart retracts
  144. What BiPlane?
  145. Silly prop question.
  146. jack of all trades master of none
  147. Cycling a Tx battery that is connected to radio circuitry?
  148. Aerobatic plane?
  149. Ideal Prop Size
  150. I need sound advice
  151. What comes after a Trainer?
  152. Side thrust
  153. TME smoke question
  154. Painting a ABS heli cowl
  155. Pullstart?
  156. Super Skybolt Drawings
  157. Looking for a pilot.
  158. A look into the future, is it going to be an ARF market
  159. How to remove c/a
  160. Where do you keep your RC Planes?
  161. How to route Kevlar cable out of glass fuse?
  162. Gws Tiger Moth Problem
  163. Diablotin Jr63
  164. dremel bits
  165. Help with throws on a flying wing
  166. Where to buy"Wring it out" by D. Patrick
  167. How much does the "turn" of a motor matter?
  168. Wing Stall In A Loop
  169. Hangar 9 fuel pump
  170. Ultracote problem
  171. The New HobbyPoxy Hardener WORKS
  172. Problem with radio hit's
  173. Hobby Paints
  174. Are you a master model builder?
  175. Welcome bpryor
  176. Eureka- HobbyPoxy part B replacement
  177. carbon veil
  178. Conversions of torque ratings
  179. Channels for RX&TX
  180. Capacitors: what are they for?
  181. OS Max .40 FS crank
  182. Jack Stafford models
  183. 4 Blade Prop question
  184. self made spinner
  185. Jack Stafford Models
  186. Broken Wing Dowels
  187. switch harness question
  188. Clubs in Downers Grove, IL.
  189. How to set a Pull-Pull Rudder...?
  190. How can I get a sponsor for R/C Airplane
  191. Canopy Scratch Removal ?
  192. Giles 202
  193. Help!! Transporting planes in shell top truck.
  194. Skyflex, gas powered kit, find the CG.
  195. What trainer is best for arial video.......
  196. Main Landing Gear Flutter ?
  197. fuel soaked wood
  198. Prop size for Sig Astrohog
  199. Cline Regulater
  200. How To Weigh A Model?
  201. Spray system for a crop duster
  202. plans
  203. Model Tech CAP 21 # 3160
  204. Spitfire: Landing Gear Spread?
  205. Who is a good source for carbon fiber?
  206. Pattern
  207. AMA subscription
  208. Center of Gravity
  209. how much up vs down throw in ailerons?
  210. Need help In Mississippi looking for Foam
  211. questions, questions
  212. Engine match and performance on a GP Patriot
  213. Hitec Supreme RX- wrong one?
  214. When do i need to replace bearings
  215. The Times They are a Changin'
  216. where to get replacement Goldberg parts??
  217. Prop reaming???
  218. OS 70 FS w/ Aresti ...Help.
  219. Photography/Bomb Drop Pods.ED Project
  220. "presto" ?
  221. WWII Military font
  222. If you only had one day in San Antonio
  223. Stickers & decals
  224. Highest Flying RC Airplane
  225. Balsa USA Enforcer
  226. Engine angle info. needed
  227. Sig senior CG location
  228. Sig Cap231EX w/OS 1.08???
  229. Where do I get a dummy radial engine
  230. Second Plane Advice Needed
  231. What Bi-Plane??
  232. Which prop.....Master Airscrew or APC?
  233. Static Electricity
  234. Trim? Sub-trim?? No-trim??? Help!
  235. Unstick CA
  236. wing incidence 1/4 GP space walker
  237. High speed touch and gos
  238. Photographs
  239. Contact paper on bottom of wing?
  240. Painting
  241. Any brightstars?
  242. Zagi Question
  243. thrust angle
  244. Ultra Hots Engine Placement.
  245. Plane for o.s. .40
  246. pusher props
  247. Goldberg quitting business???
  248. Those Foam Wheels...
  249. Hobby Poxy/K&B Super Poxy Hardeners?
  250. Small pins size of 6-32 bolt
