PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 [101] 102
  1. 4-Star -120 flying weight ?
  2. 4*40 throws
  3. Spinner Size??
  4. help - ultracote keeps peeling off
  5. *** Dremel Dilema ***
  6. Building and flying doghouse extreme.
  7. Need Recommendation for Small Bipe
  8. 2 Blade to 3 Blade Conversion?
  9. plans, kits, or both for a mosquito, .40 size
  10. Alitmeter
  11. Diablotin E and Diabolic
  12. Funny Looking Pilots
  13. 4 1/2 inch tire search
  14. prop selection
  15. fiberglassing wings
  16. pattern plane exhaust system
  17. RV-4 wing
  18. Ultracote matching paint
  19. float flying info
  20. Bending Repacement Wires for Retracts
  21. Fiberglass Cowlings
  22. Moorman Aircraft Works
  23. Wheel pants coming loose
  24. Accucycle Plus HELP!!!
  25. dowel pins or gussets
  26. cleaning an engine?
  27. Pull pull
  28. Limiting Robart Cylinder Movement
  29. Flying a twin engine a/c...
  30. Is it ok to mount an angled control horn?
  31. fuel pressure question
  32. Polyurethane ?
  33. P-38
  34. Run time equation?
  35. Tru-Turn Mounting bolt
  36. Thinning Balsarite
  37. Fiberglass
  38. Perry Pumps
  39. can I get a bushing for prop fit??
  40. Were Can I Find Christen Eagle or Beech Staggerwing
  41. Please close thread
  42. Dubro nylot bolts WAY TOO FRAGILE?
  43. OS FSR 61 Prop
  44. Cermark aluminum spinners any good?
  45. Balance Point on a Lanier 232
  46. Neopreme vs Tygon for gassers?
  47. Incidence meters...
  48. Props at high altitudes
  49. gas engine muffler -quieter
  50. 8oz tank clunk doesn't move much. Problem in a long dive?
  51. A-10 Warthog
  52. rc controller for kodak dc25
  53. Flying into the clouds- anyone done it?
  54. tail struts
  55. Please, I need to know
  56. What speed is too fast?
  57. MARUTAKA Kits from Hobby Barn???????
  58. Simple Question about nitro car.
  59. Flaperons
  60. Fuel tank backwards?
  61. What Happened to Balsarite?
  62. 3 Bladed prop
  63. laser incidense meter
  64. which cub should I build GP or Sig
  65. What is Incidence?
  66. Wheel Pants
  67. Looking For Someone Who Builds Planes For Extra Money
  68. Saito 120,tru turn spinner,APC props??
  69. Advice On What Prop To Use!!
  70. Saito 120 with 15x8 prop
  71. How do I make smoke fluid????
  72. How to make a matched set of wind ribs?
  73. anyone know anything about a GMP cobra helicopter?
  74. which prop size
  75. Mufler Fitting
  76. Prop Balancing For Large Wood Props. Does The Hub Need To Be Balanced???
  77. Fuel Dots
  78. Hitec rx antenna
  79. Covering wing?
  80. Shipping a large box?
  81. Using CA On Clear Plastic Windows/Canopies
  82. C/A Accelerater on Covering (adhesive side)
  83. Frequency Scanner... Help!!
  84. Wing Bags
  85. Question on Thrust angles
  86. Converting to Tail Dragger
  87. Tower Hobbies shipping to Europe, crazy!
  88. Rv-4
  89. GP Extra 300
  90. 91 fx
  91. fuel proof paint?
  92. Whats the best way to store a plane
  93. Aerial Photography
  94. Antenna wires?
  95. Proctor Enterprises
  96. Tacky Fiberglass
  97. Glue???
  98. Yellow Aircraft
  99. Prop Question?
  100. Covering Question
  101. Soldering Question????
  102. Traveling to Biloxi, Ms
  103. Building on Glass?
  104. Anyone Know a good BUILDER??
  105. Lightweight primer/filler painting method
  106. Little Help
  107. Anyone know an eazy way to remove old covering?
  108. Frequency Scanner-which one??
  109. What's up with the forum?
  110. help me open a hobby shop
  111. spirit of st louis
  112. Wram Show adhesive?
  113. stab repair
  114. Ultracote on foam?
  115. Poll--Which covering do you use and why?
  116. Bomb Drop
  117. C.g.
  118. CyanoEpoxy
  119. Pre stretching cable/ Prop differences
  120. Propper prop drilling.........
  121. century 21 paint
  122. Nylon vs. Steel Bolts
  123. Lasik, RK, etc + R/C = ?
  124. flag decals
  125. foam cutting&vacuum bagging
  126. PAINT orange peel &fish ye problemI'm finishing a glass fusalage
  127. Camera on plane
  128. Paint
  129. Test Stand
  130. gas engines size guide
  131. Futaba Skysport 4
  132. Cessna 195 Plans
  133. Help a Friend
  134. Setting up Throws Mechanically
  135. Smole systems
  136. Power Panel
  137. aileron diffential question
  138. not a straight loop
  139. transmitter case
  140. Epic R/C...still in business?
  141. Painting over Monokote ?????
  142. Swenson's Specialties
  143. How do you get a PIZAZZ into a hover ?
  144. I'd like to build a transmitter tray
  145. xx
  146. Stan's fiberglass products
  147. Paint On Props
  148. Pull Pull System
  149. Wood glue any good?
  150. Ace Bingo Canopy
  151. hostetler skymaster
  152. D&L Tucano
  153. Going from AM TO FM
  154. CG G.P Tracer
  155. help on a modeltech cap 21
  156. speed controls
  157. Stickers and emblems
  158. Covering material
  159. Using glass to join Monocote
  160. Pilot for Kyosho Cap 232 Breitling Arf
  161. Have a bunch of poly!
  162. CA hinges?
  163. Right Thrust
  164. Top Flite red box kits
  165. Loctite on nylon motor mount
  166. Sukhoi Tip Stalls
  167. prop-jet kits
  168. Asp Engines
  169. Old CAP-21 cowl
  170. Buying a kit from Canada
  171. Getting a level surface by sanding...
  172. CA Smear on Canopy
  173. 21st Century Fabric
  174. Hobby Stores in Dallas Area
  175. Battery Location
  176. rc truck won't run
  177. Covering over paint?
  178. Epoxy won't cure- Now what???
  179. Merits of different coverings
  180. Installing Large Areas Of Trim On Ultracote
  181. Can you rewire Futaba FP-S 148 servos to work with JR radios
  182. RC hobby shops in malaysia?
  183. C.G. for a St. Croiz model 1/5 scale Long-Ez
  184. C. G. for a St. Croix model 1/5 scale Long-Ez
  185. Monokote on Monokote
  186. Need Help on Gear Redution
  187. flaps vs flaperons ???
  188. servo position
  189. Futaba Crimp Tool
  190. Stan's fiberglass cowlings
  191. Wax Crayon Used On CA Hinge Install?
  192. lightweight fabric
  193. Adverse Yaw
  194. Painting latex pilots
  195. Matching paint for metallic Monokote
  196. Need building (repair) assistance
  197. Cheap airbrush
  198. heli engine on airplane
  199. Aeroworks edge 60/90 cg question
  200. monocote question
  201. Going to TOP GUN
  202. Mcdanial spark plug ?
  203. Radio Glove
  204. Where Are They?
  205. Scratch Flight Box
  206. Covering advice
  207. Painting Foam Wings
  208. Hangar 9 J-3
  209. Austin Craft glow plug wrench
  210. What kind of scale do you weigh planes with?
  211. Anybody tried the FMA Direct "Co Pilot?"
  212. co-pilot systems?
  213. preditor
  214. AMA Contest Director Question
  215. Stinson Reliant--Your views
  216. CARBERATOR COVERS
  217. removing JB Weld
  218. Spell Check
  219. questions on melting lead
  220. Long Easy Rc Model ?
  221. How to Laterally Balance a Biplane?
  222. Flaperons on my second plane
  223. Printing on MonoKote
  224. Where and which jig to buy
  225. HeLp!
  226. Elmers Probond question
  227. Can I use Monocote trim over 21st Century Fabric?
  228. Microsoft Word Fonts?
  229. Futaba Aluminum TX Case
  230. Testors paint won't cure
  231. Wipp Aerials
  232. Bulk JST connectors and a Crimper Tool?
  233. aero works edge 540 rtf 1/4 scale
  234. Covering
  235. need a tip on balsa filler
  236. To build or fly?
  237. Flying Feild R.I.P.
  238. TME simple smoke w/ os 160fx???
  239. Homing Beacons
  240. Sig Rascal...40 size??
  241. OS 160 Twin 4S OK For ??
  242. See thru Monokote
  243. I need an IFO instruction booklet
  244. Anybody try Super Phatic glue?
  245. Wet VS Dry
  246. servo muscle
  247. Servo arms?
  248. Foam
  249. Does Balsawood Go Bad
  250. Need retract help
