PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. RC Fields in Phoenix area?
  2. 18 volt battery for your starter
  3. Futaba Receivers
  4. Film Trim iron - Soldering iron
  5. Determining EP Motor size
  6. Hobbyking HXT 900
  7. I love glow Engines! Where to get a ring for a G90?
  8. ca's
  9. Is banna hobby worthy?
  10. help getting my old os46ax running again
  11. Which Giles 202 is this?
  12. Good 5th-scale skis for a Sig Cub?
  13. Wing Bolts Help
  14. Florida Keys
  15. OS Max 91fx Shutting off above 3/4 throttle, HELP!
  16. JR RD 922 RX Binding problem
  17. Alpha 40 hanger 9 with evolution .45 engine
  18. 00
  19. GEE BEE Y
  20. Canopy Question
  21. 2.4GHz Tx and Rx Question
  22. Golden Skies RC
  23. 4C carb air intake
  24. Giant Scale crop dusters?
  25. Retracts for Corsairs Help!
  26. WTB Kyosho Calmato 40 Sports
  27. Pactra Solar Film
  28. Robart Pin Hinge Question
  29. Sportmaster c of g and other
  30. aileron throw
  31. Engine priming problem
  32. jr radio equitment question
  33. Painting an already painted cowl..
  34. Help ~ How to ship a plane from UK to US?
  35. Are these planes considered parkflyers?
  36. Spektrum DX8 Replacement Battery Help
  37. Old Futaba Radio
  38. What Glue do you like to use to glue in gear boxes on Foamy's?
  39. Painting Question
  40. Saito 100 for this airplane???
  41. prop reamer
  42. What in the world is this model?
  43. O.S. 55AX Engine Floods - PM Tucano
  44. engine modification
  45. Fun Fly Hots
  46. Shipping through Greyhound
  47. All my resin is solid as a rock, never had this happen!!!
  48. RCM March 2004 Virginia Creeper
  49. Unknown OS carb
  50. Pacific Aeromodel Gee Bee Y !.20
  51. Someone from Russia
  52. Parkflyer - Removing Landing Gear Caused the CG to Shift Back?
  53. glue for foam
  54. Canopy that may fit Dave Patrick extra 330
  55. New to Lipo Batteries. Question about Batteries.
  56. Park Flyer Electric Motor Stops At Full Throttle
  57. E-Flite Battery Lead Question
  58. Another OS110 4 stroke question
  59. OS .91 prop drive hub spins
  60. wire safety clips?
  61. A question about servo noise
  62. Laser Design Services for kit cutting?
  63. Modifying Stabilizer Incidence
  64. Two stroke glow
  65. Slowing Retracts
  66. Shipping an RC airplane help!!!
  67. OS 75AX muffler
  68. Li Fe Batteries?
  69. Glow Engine Question - Why does the Propeller threads loosen the same direction the engine runs?
  70. Help me ID this plane please.
  71. Airtronics 94394
  72. Zinger Props
  73. Why buy a kit just to have it?
  74. Dampening Engine Mount
  75. Tower codes
  76. OS-61
  77. Thunder AC 6 / Eflite UMX batteries.
  78. Question about Fiberglass Cowlings
  79. A Question about Hard Landings and Strong Landing Gear
  80. Dubro Hinges
  81. Parts ID ...
  82. Convert transmitter frequency?
  83. Nose gear placement
  84. When you cant find finish resin?
  85. 100KM cross country flight.
  86. enough power?
  87. Joining Fiberglass Cowl Halves
  88. Smoke Fluid - Home Brew
  89. mixture valve on os 61
  90. Centering dual aileron servos?
  91. Futaba 10c. separate elev. servo`s?
  92. Eflite Micro 2 cell battery charging
  93. 61 OS FX DRIVE WASHER
  94. Power equivilant between Glow and Electric
  95. Magnum engines?
  96. need help with airplane lid?
  97. Dubro Hinges
  98. Recovering a plane
  99. OPTO KILL SWITCH ROUTING PROBLEM
  100. match box
  101. Leaking muffler
  102. Minimum power for a 9# plane
  103. Engine to plane set up!!!
  104. Transporting in a pickup
  105. 4.8 vs 6.0 volt setup
  106. Landing gear mains
  107. SONIC RETRACTS
  108. Posting ads???
  109. How do you assemble a hand fuel pump?
  110. Opti-kill stays live when Tx shut off
  111. Are Zap Adhesives Worth the Extra $$$?
  112. Airplane Cradle
  113. Question about wing and stab incidence.
  114. Grumman Goose kit
  115. What is your go-to plane and why?
  116. working on starting an aircraft company
  117. Question about Radio Interference
  118. first 4 stroke motor question
  119. Best water based primer solution.
  120. Foam wing cutter?
  121. Savox SC-0251 Sevos
  122. control horns with ball joints HELP!!!
  123. Quick and easy cowl baffles ? Anyone?
  124. Slowing Pnuematic Landing Gear
  125. Smoke system for nitro engines
  126. taylorcraft old style landing gear
  127. Mintor 38cc carb linkage
  128. top flite taurus canopy
  129. DLE 20 won't stay running
  130. Need help identifying an airplane
  131. Flying Fields in the Newport Beach area
  132. Where can you buy O-Rings Small Enough for Our Engines?
  133. Help Please! Looking for dimensions of Midwest Giles 202 Canopy
  134. WORLDTEX Covering
  135. Finish/Brad Nail Gun
  136. Air Plane Cradle
  137. help with my .61 pro
  138. elevon settings
  139. Glowlite EDR-103 battery question
  140. right hand turn on take off
  141. Throttle servo
  142. Panel lines and rivets
  143. P-51 decals
  144. Ideas for PVC stand?
  145. Adding trim color
  146. What do I paint my glassed warbird with
  147. DLE-55
  148. Landing Gear Fail Safe
  149. Attaching fuel line from tank to engine.
  150. Saito FA-80T Flat Twin
  151. DOES ANYONE KNOW WHERE A HANGAR 9 ULTRA STICK 120 LITE IS AVAILABLE??
  152. Is this a good field box set?
  153. remote needle os engine
  154. Deal of a lifetime???
  155. thinder tiger .61 leaking fuel
  156. Castor Oil
  157. Flap Servo Set Up
  158. ZLIN 50 L
  159. Futaba T8U Transmitter
  160. gas clean up
  161. Programming radio
  162. fubata 6 ex radio
  163. Two O.S. 61 FX Engines Went Bad On The Same Day!
  164. SIG Fazer plastic mould mount
  165. parkzone vs dynam
  166. RCEXL MINI TACHOMETER
  167. WOT?
  168. DLE 55 Break-In Gas/Oil Mix Ratio
  169. Model Airplane or sUAS
  170. 25FX tuning problem?
  171. Debonding Epoxy
  172. superfalcon prop version biuld
  173. If you could only have FIVE airplanes, what would they be?
  174. Proper procedure for cleaning glow engines?
  175. Can I clean a glow plug with water + dish cleaning soap?
  176. Help identifying this bird
  177. Tail Wheel Question
  178. Which way to smoke?
  179. FS 61 Inlet Manifold 45669400
  180. What are the pitfalls using LIFE batteries??
  181. DOPE OVER FABIC COVERINGS
  182. better landing gear
  183. sig kadet sr cg
  184. cheap 4 channel electric trainer?
  185. DX8 lipo charging???
  186. battery charger
  187. atch and cg on flying wing
  188. Base Information for Unknown Center of Gravity
  189. parkzone p51 esc
  190. Am I the only one that noticed this
  191. painting over clear lacquer or lacq primer
  192. What size electric motor to use? Please Help
  193. Wilga by Kmp
  194. evolution 50 cc gas engine troubles
  195. Replacing connecting rod Magnum.61
  196. switch for gasser
  197. Motor, battery, plane dilemma- rant
  198. Model Airplane News 1980
  199. Fly Baby Balance point
  200. tail incidence
  201. rc plane for bf
  202. wing covering
  203. aircraft-stand
  204. Need help with hold down keepers for neumatic air lines
  205. Propeller Sizing for Specific Motors
  206. Wing tube slop
  207. OS LA 40 Carbeurator
  208. motor runs like crap
  209. Range Problems
  210. What plane to get
  211. Kill Switch for a Glo Engine
  212. Need Help with Hinge Repair in Hard to get at Places
  213. Thinning out epoxy with isopopryl alcohol
  214. how to build a three peice wing
  215. Dx8 trainer with Dx5e
  216. flaps
  217. Aileron Advise
  218. sig spacewalker11
  219. CG
  220. Avistar wing
  221. Is my CC Speedie and Dongle Obsolete?
  222. T max 2.5 conversion kits
  223. LiPo charger suggestion for 7.4v UMX Beast
  224. cg on b25
  225. Grayson Hobby
  226. outlaw extreme flight with os 46ax
  227. Hobby King
  228. Inverted OS 91 4 Stroke Surging
  229. A123 and voltwatch
  230. Muffler gasket?
  231. K&B CRANK ID
  232. TGY 26cc
  233. which lie to fuel-up?
  234. OS 110 4 stroke acting funny???
  235. Airtronics 2.4 Ghz non-genuine recievers?
  236. HELP PLEASE! Suggestions on hand-starting petrol engines
  237. Performance of hitec hs81 servos
  238. 'Rothmans' Pitts Special
  239. MyHobbyStore, Retailing, & Giant Shark -Conflict of interest with RCM&E magazine
  240. Radio performance
  241. Spektrum DX7
  242. Retracts UMS Technologies
  243. balance question
  244. DX6I edge 540 aileron issue
  245. GIANT SHARK IN UK -POOR SERVICE
  246. electric fan jet engine reversed
  247. soldering a 4-stroke muffler?
  248. Plans coversion from dwg to pdf
  249. Is anyone else flying in Starkville, MS???
  250. (PILOT PLANS) SKY LOOP 404 ENGINE
