PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Radio choice
  2. Help with dual battery system
  3. Push rod wire
  4. charge switch compatability
  5. Sheeting the Leading Edge of a Wing
  6. Plane noses up for no reason
  7. Charger and Lipo batteries
  8. DX8 Question's
  9. Prop size?
  10. Foam Wing - Multiple Sheets for Thickness
  11. BigStik
  12. Noise traps
  13. Parkzone Typhoon problems right out of the box.
  14. Saito vibration
  15. High pitch props
  16. HOW FAR WILL YOU DRIVE?
  17. Wing to Stab alignment How To?
  18. YS 140 no compression
  19. Gee Bee R3 Gas 30cc 1850mm (ARF)
  20. Robart retract worth?
  21. Best way to power video transmitter?
  22. Finding for product
  23. Glow Fuel Line "plumbing" Question
  24. Polish for canopy
  25. HELP! DX7 program question
  26. saito 125 or dle 20
  27. Equivalent Gas Engine Size to Glow Engines
  28. What size of 3-blade prop?
  29. Hobby king customer service
  30. vk navajo
  31. Airtruk plans
  32. Soldering steel landing gear
  33. How to fly different 3D maneuvers with a RC-Plane
  34. Front Gear
  35. Coverite or Solartex
  36. Brushed to brushless motor conversion
  37. Dennis Bryant Fiesler Storch Jury Struts Problem
  38. E-FLITE RETRACTS
  39. Exhaust deflector for OS .61
  40. safty clip for receiver
  41. Is RCU having server issues?
  42. rc workbenches ..show me your work tables.
  43. Is this aircraft stand still being made?
  44. Futuba 10c needs a new battery
  45. RCG 15cc?
  46. Engine Temps
  47. 1
  48. CG on P-39
  49. Weston Magnum
  50. CAN'T GET PROP TO BALANCE
  51. What 3 blade prop for ZDZ 80
  52. OS FS 70 Ultimate
  53. old foam midwest plane
  54. Custom landing gear engineering question
  55. Goldberg Cub Windows and cowling
  56. OS 110 4 stroke full throttle sputtering
  57. Can I use these servos in a 50cc class Yak?
  58. blinking leds on Bipe
  59. Any instructions on how to build a radio control system from scratch?
  60. Any RC Pilots In Southdakota???
  61. Decaks Airliner *pcm lockheed 1011* Help
  62. What the heck is wrong with the marketplace?
  63. Hobby Authority.com?
  64. Are ASP Engine Good Engine??
  65. Problems with Tower Hobbies Brand Epoxy
  66. Seagull Edge 540 60
  67. "NIB" Full Scale WWII Spitfires found in Burma
  68. Electrical connectors
  69. Glued the wings but forgot wing tube
  70. Fox 36 X
  71. The use of fast links
  72. weight and balance pulse 125
  73. Baffles in a cowl
  74. Fuel proof paint?
  75. prop shaft thread
  76. Programming FS-TH9X Transmitter
  77. C.G. Eaglet 50 Question?
  78. Inverted 4 Stroke
  79. CA Glues
  80. Which battery size is best?
  81. Servo jitters Help please!!!
  82. HiTech radio problems
  83. A123 idle time
  84. glow fuel
  85. Super Tiger Exhaust Setting?
  86. Bad News...
  87. Trexler tire question
  88. Hobbico power panel leads melted
  89. Futaba servo - Receiver gang connector
  90. OS Max-S 35 muffler options
  91. Fixing a Futaba FP-T8SGA-P Transmitter
  92. Fixing a Futaba FP-T8SGA-P Transmitter
  93. zenoah g38
  94. Need a .25 glow ARF
  95. Adf.ly needs to go. Admins, will you look into this?
  96. Wing Tube Fastening
  97. How can I test receiver batterys
  98. Atkins' F8 Crusader
  99. DLE 20 - tuning
  100. YARGGGGGGG..... battery chargers !
  101. 26cc Gas Engines!
  102. Spektrum DX18
  103. muffler for Thunder Tiger .61
  104. Easy Washout Solution
  105. Brushless motor alternator?
  106. what size props for OS 61 FSR
  107. USPS, Service with a smile. The Sequel
  108. Parkzone Extra 300: Performance too high for my skill level
  109. Extended length Nose Spinners RedBULL style
  110. Engine size help.
  111. Mosquito CG
  112. Waking up an old engine
  113. Run up table plans
  114. rachet throttle stick
  115. DX8 programing help
  116. Been out of the hobby. Catch me up on Radios?
  117. staling wingtips
  118. Is this a Bud Nosen Gere Sport ??????
  119. NGH Gasser
  120. need help! os 1.20 surpass
  121. FY 30A, or FY20A, stabilization system?
  122. yak 54 seagull help 63"
  123. JR Radio programming
  124. Bonding Aluminum - JB Weld or Aeropoxy ?
  125. Sig Kadet Sr. CG point
  126. How to Upload PDF's
  127. Why not use an oversized tank?
  128. Servo suddenly died - any idea why?
  129. Alpha 60 prop "over reving" my Fox .74 engine?
  130. kadet sr landing gear Q
  131. weight saving technique for fiber glassing planes?
  132. Angry with saito 100!
  133. New RC Facebook Covers
  134. Removeing old airplane covering
  135. MOKI 2.1 fuel useage.
  136. horsepower rating on a evolution .61 nx.
  137. Ordering from hobbyking for FPV Gear how are they?
  138. Landing Gear Issue
  139. Covering a Plane with Ultracote
  140. soldering
  141. KeyChain cameras?
  142. help Identify the MFG this Spinner
  143. FINALLY got engine to start- cant get it to work right for anything
  144. Gimbal tension springs for JR 9303
  145. Fandango
  146. Easy Star Removing Servo
  147. Direction problems on my Champ.
  148. Servo reverser
  149. Servo flutter
  150. looking for a Very small vid cam for plane
  151. What is the best way to add an aluminum frame to a polyethylene windscreen?
  152. What happened to the Parkzone T-28D Trojan?
  153. Mini Magic Extra
  154. DLE-30
  155. cant find a manual
  156. What the heck is Ad Fly?
  157. Model Tech Magic CG
  158. Removing CA between stab and elevator
  159. Tank height vs. thrust line
  160. stripped head bolt
  161. What engine?
  162. Aliphatic resin glue(Titebond original and Titebond II), are they fuelproof???
  163. R/C Grave Marker
  164. Eclipse 7 Tx problem HELP!!
  165. Ibis 40 Trainer
  166. b25
  167. HK CS question about JR 10X conversion to 2.4
  168. Futaba FASST Radio problems..
  169. Need help w / 20+ yr old Goldberg Piper Cub
  170. What is this?
  171. Rant/Question lol
  172. YS 61-S Long Stroke
  173. E-Flight 25-46 Electric Retracts
  174. DX8 Question
  175. AVRO ????
  176. pc servo controller
  177. Converting from glow to electric help!
  178. An Un-ending glitch
  179. FINALLY! Aluminum CIRCLE servo arms
  180. Super Tigre .61 not drawing fuel, HELP ?
  181. Weight Placement vs Amount of Weight
  182. sealing gaps
  183. Spektrum DX 8 battery upgrade
  184. Got Wood?
  185. portable pilot stations
  186. Help with Enya 46-4c exhaust
  187. Rudder hinge broke...?
  188. rustoleum epoxy appliance paint
  189. Anylink with Hitec Aurora 9
  190. Anti-collision light
  191. Gas fuel tank setup
  192. carbon fiber push rods
  193. Skin covering
  194. Engines dying randomly?
  195. LG conversion
  196. Need ideas for next airplane!
  197. Holy Spektrum FAIL?!
  198. Did I SMOKE my .75ax?
  199. ROBART RETRACTS
  200. Futaba Synth module
  201. Redundant Receivers?
  202. AT-6
  203. Hangar Nine Electronic Incidence Meter
  204. Tuning a saito 56?
  205. fuel
  206. Cox Black Widow
  207. CA Hinges question
  208. Want a LiFE battery tester
  209. Motor Life
  210. Question on location
  211. Sharing Info About Ultracote & Easycote
  212. How to adjust high and low speed needle valve on Evolution .46?
  213. I can't get this new engine to start for anything
  214. Active Powersports?
  215. Century 7 Radio won't charge after getting new battery.
  216. upside down
  217. TT 46 Pro maximum 8500RPM
  218. How do I power this? Sullivan Hi-tork starter 12V
  219. OS AX 46 Nitro
  220. Nitro to Gas ?
  221. Why is rcuniverse.com website sometimes not opening up and instead an error message comes up????
  222. S&W Fuel
  223. CA Question
  224. 2.4 Binding?
  225. Wing Bags Help
  226. 1/4 Scale Clipped Wing Cub: Two Piece Wing
  227. Warsaw Aeromodelers Contact Info
  228. wheres the best place to buy spektrum rec,s
  229. ARF covering vs. removing and glassing
  230. Globe Swift plans
  231. Cleaner
  232. Anylink and Futaba 4YF
  233. Wing spar shim
  234. Mono-Kote Questions
  235. Slimline mufflers
  236. optix 6 72mhz
  237. Toysonics XB-70
  238. 4 stroke trainer
  239. Can You Help me ID this Plane?
  240. Can I narrow up a carbon fiber gear by making it two piece?
  241. Question for K&B 61 experts
  242. Unseizing nitro engine
  243. Help identifying this plane
  244. Looking for a light weight no mess fuel connector
  245. Looking for a light weight no mess fuel connector
  246. Birdi AT-6 Kit
  247. EZ-LONG 160
  248. setting a decal
  249. Magnum .25 remote needle valve?
  250. How to cut wing ribs
