PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Ultracote On Ultracote - Correct Temp
  2. Funny phrases at airflield
  3. Can someone ID this Extra?
  4. What size car battery
  5. Picture upload
  6. wing/fuse rack ceiling mounted
  7. Please help!! with Futaba T9cap radio
  8. looking for Pusher props?
  9. Biplane Aircraft Identification
  10. Aluminum A/C skin
  11. .46 Engine Prop combo for best torque?
  12. Hard to Check Control Surfaces
  13. Airtronics Transmitter
  14. sending pics to forum?
  15. foam cutter
  16. Olr super tigre high end needle valve
  17. Posting with an iPad
  18. What RX?
  19. high or low band
  20. Craziest thing you have done in this hobby
  21. aurora 9 problems?
  22. Fuel Proofing The firewall?
  23. Power 32
  24. Electric Retracts?
  25. Air Retract Question!
  26. wing/fuselage sizes EAGLE SCRATCHY
  27. Storing Super Z RC 56 Canopy Glue
  28. Saito Engines Inverted
  29. Which 3D plane do we recommend?
  30. Hitec/RCD Supreme Xtals
  31. How to make flaps deploy slowly on JR 9303?
  32. Dave Brown Products
  33. Gas Engine rubber mount ?
  34. Servo, What model Hitec
  35. engine starts backwards
  36. Pitts muffler
  37. Jack Devine Models
  38. How to disengage flap movements from airelons?
  39. What Scale Pilot for 1/6th Scale Plane?
  40. Metal for Magnetic Building Table
  41. Noisy Pitts Muffler
  42. HERE WE GO AGAIN,CAN SOMEBODY CORRECT THIS?
  43. question please about TOP FLITE CESSNA 182 GOLD EDITION KIT.
  44. Pinning pined hinges?
  45. Modelcraft Pro-Tech Charger model 701
  46. YS | 61R LONG STROKE | PHOTOS | VIDS
  47. os engine
  48. Nitro models bobcat
  49. Baby Cyclone fuel tank
  50. What do I have here?
  51. Can a built up wood cowl be hardened b4 covering?
  52. Sub Trim ?
  53. RotoFlow clunkless fuel tank
  54. SAITO 100 PROBLEM
  55. Fly at AMA field
  56. Prop ballance tool
  57. kit or scratch forums?
  58. Paint question?
  59. Chucks Hobbies????
  60. Satio 65 problem
  61. Will glow fuel deteriorate fiberglass
  62. RC Hobby shops in New York....
  63. new plane ideas?
  64. Adding Flaps to the Escapade 40?
  65. Receiver ?
  66. rc equi[p
  67. Sky Fly 1st Gen
  68. Ultimate bipe
  69. Transmitter stick question
  70. Good ARF for a 75?
  71. Can't freeze LiFe???
  72. Another Battery Question
  73. Question about Retracts (Corsair Gold Edition Kit)
  74. Ross .60 twin
  75. Super Hots- thrust angles
  76. What mixture do you use to clean your plane ?
  77. lanier planes
  78. Prop Hub
  79. Iron Bay Models
  80. Longest Torque Rod? Available?
  81. Ross .60 twin
  82. CA hinges full length and gap sealing
  83. Wake up Futaba
  84. Prop size 55ax
  85. Das Little Stik Plans
  86. OS Crankcase vents & After run oil
  87. whats the name of this airplane
  88. futaba jr training cord
  89. Prop size and thrust comparison
  90. Where to find a retailor for ......
  91. battery question
  92. What should I bring?
  93. Lithium Battery Hysteria!!!....
  94. RCU Marketplace issues
  95. Help save our local flying field...
  96. Installing retracts on a custom plane
  97. Torque rods in metal bearing sleeves?
  98. Motor off set
  99. Electric motor off set
  100. Futaba 6EX how to set up exponential with elevons?
  101. Carb Problems
  102. Anyone traveling North to NY from the New Port Richey, Fl area?
  103. JR telemetry ??
  104. Great Planes Retracts
  105. OS-75 fuel problem
  106. low speed needle setting
  107. Who repairs Saito Engines?
  108. OS 75 AX On Going Issue
  109. help SPEKTRUM DX7
  110. plans for the stinger
  111. Futaba 10C Help
  112. Tires and Wheels
  113. Digital servo batteries and charger?
  114. Evolution 40GX..my attempt at a review
  115. BAttery conversion of my Torqmaster 90 starter FAIL :(
  116. saito 1.80 overtemp
  117. Help with CG
  118. 2.4 receiver question
  119. Brazing vs Silver soldering
  120. who makes landing gear
  121. OS 2 cycle problem question
  122. dx8 transmiter
  123. can anyone identify this model
  124. balance point for biplane
  125. futaba 6 ex trainer box
  126. servo gears
  127. Tail Wheel Wheel Pants
  128. tail heavy plane
  129. Looking for Scott Anderson
  130. Cessna 182 Skylane GP/EP Gold Edition ARF 81"
  131. Range Check
  132. Glowbee Intellitech Tach problem
  133. How about a thread about Pilots in the Cockpits of RC planes
  134. Solartex Question
  135. os 40FP carb problem
  136. New Plane Suggestons
  137. Haunted RX stops receiving signal after sitting on haunted table untouched for 4 hours
  138. du-bro hinges
  139. Go engines
  140. Dynatron starter switch
  141. 126 aj slick
  142. Stuka acessories
  143. help on what prop
  144. Duel battery hook up
  145. OS 46 fx bearings
  146. consealed flap and aileron hinges
  147. .40 Thunder Tiger
  148. Quick Question.
  149. Hangar9 Piper J-3 Cub engine mount too small...
  150. ESC failure?
  151. Easytiger Model Customer service
  152. Looking for black canopy for Large Sundancer
  153. Torpedo .32
  154. Binding the Double Horse Volitation to DX6i...
  155. Ignition and Choke Switch on TX
  156. Moki 1.80 piston ring
  157. laniser stinger
  158. BP Hobbies AT-40L Trainer ARF
  159. HAVE YOU SEEN THIS STRUT?
  160. Gas Engines & plastic clevises
  161. Can You Identify This Profile 3D Plane??
  162. Bullet Holes
  163. Question about servos?
  164. anyone know this
  165. need a 10 c expert
  166. Where to fly??
  167. Lipo batt and ESC problem
  168. Irvine 40 with red head
  169. Power HD 9150 Servos Holding Up?
  170. Thrust line question(s)
  171. hobby shops
  172. Saito FA 90T twin cylinder engine question
  173. Foamys ? What is a good model to start out with?
  174. Question About Inverted Engine (Oil and Starting Problems)
  175. I got real lucky
  176. Prop Suggestion for OS .46 AX on an Extra 300S
  177. Evo Engine Plug Problem - HELP !
  178. What is the best way to remove Oil from Oil Soaked Wood?
  179. Lost A Wheel in Mid air. How Do you Land?
  180. Gas engine and prop combo
  181. Hitech X4 Charger
  182. Hobbico Flyzone SkyFly Max - battery adapter
  183. Replacement Battery for Beast and Sbach Ultra Micro
  184. how to link Futaba R608 FS to T6EX
  185. how to link Futaba R608 FS to T6EX
  186. Venus 2 has sudden down elevator occuren
  187. Time to up the ante.
  188. muffler gasket?
  189. Inverted Satio won't run right, help needed
  190. Spinner size?
  191. Original dates for several aircraft kits?
  192. Need Help ID this BL motor
  193. Moved Topic
  194. Boxing Up Planes for Transport?
  195. How do you stop Fiberglass from Cracking?
  196. Choosing best airfoil?
  197. Lite-Ply Grades?
  198. help with new os 75 2 stroke does not run right
  199. YS 120 fz engine problems
  200. Any RC Aircraft Writers
  201. Source for Fiberglass Wheel Pants
  202. MOVED: Don Muddiman Flying Machine
  203. Norvel .074 Problems
  204. Do you solder servo extensions?
  205. Fly in
  206. Spektrum DSM2 Futaba SPMMSFUT9?
  207. Evolution .46NX Glow Engine
  208. Heli Guy Lookin' for a Plank
  209. GP Stick 40 question?
  210. LiFe Batteries
  211. Overcharged DX7 NiMh battery?
  212. .40 size plane at 5500ft.
  213. prop
  214. High thrust for 70mm EDF HELP !
  215. Hobbico Accu-Cycle dis charge rate?
  216. Need help identifying this biplane - Part 2
  217. Best 2.4 transmitter
  218. What Is The Best Smoke Oil
  219. Need help identifying this biplane
  220. Magnum XL 91
  221. Wing building question
  222. Question about propeller noise.
  223. C G on Bi-Plane
  224. needle valve for Torpedo .32
  225. needle valves
  226. RC Hobby Shops - Peoria IL & Vacinity
  227. Dope retarder
  228. looking for longer gimbal control sticks..
  229. Swapping buddy box for mixing
  230. Futaba 10c programming question
  231. setting up throttle servo
  232. Flutter in servos
  233. Orange futaba compatible receiver
  234. EDF Question, R/C Warbirds
  235. DA50R Engine
  236. R/C Airplane Movie
  237. APC 13x4 on a saito 56??
  238. What Ever Became of Morris Hobbies?
  239. Binding
  240. Whats this part in a pull-pull?
  241. Need new or used part for Hangar9 P-51
  242. DLE 30 and prop
  243. what thrainer is this?
  244. Quadplay Q6 Battery Charger
  245. Progamming the Futaba 7c - "digital" rudder
  246. saito vs os ys 91
  247. Battery Cycler/Charger
  248. Ultracote Cold Application
  249. Retract Servo Separate Battery pack ground question
  250. Jets, no nitro DF?
