PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. hanger 9 twist 60
  2. help with jr 2610 compatable buddy tx
  3. Interference Engines
  4. Running Futaba recievers on 6.6 volts?
  5. ys f-120 (messy?)
  6. Gearbox
  7. 3 rudders = Tri-Harness?, or.....
  8. New kit
  9. 90-1.20 size EXTRA
  10. How do I time magnum 91? I had the info and photos and lose them .
  11. engine shutting down on take off
  12. 4 Bladed Props
  13. Fliton Extra 260 Mini CG help needed.
  14. Sig Mfg
  15. classified ads
  16. Scale p51 owners....
  17. JR MatchBox, Spectrum Dx8, Elevator setup
  18. Saito 120S vs. FA120 ??? Please help!
  19. SPACEWALKER II
  20. Experiencing my first glitch
  21. Where do you buy your airplanes?
  22. Plans for Sig LT 25?
  23. long-ez electric setup
  24. Building Tutorial
  25. supertigre .18 marine
  26. Best Motor for a Telemaster 40
  27. large battery questions FOR A PRO
  28. Hand Protection
  29. Great Planes p-51d
  30. aliaron set up
  31. Throw rate issues with ailerons
  32. 2.4 reciever linking
  33. Alipatic resin suppliers?
  34. RC BEECHCRAFT DUKE B60 PLANE AIRCRAFT Wheels?
  35. Anyone have a CNCShark?
  36. Crating Ideas for shipping airplane
  37. Pilot install
  38. hd camera
  39. Twist 40
  40. Tartin twin 77
  41. short battery time
  42. SPRING AIR PRODUCTS
  43. receiver
  44. Denmark, anyone? Question?
  45. Need help balancing my Funtana
  46. temp gun vs temp gauge
  47. question about inverted engines?
  48. Another RC Product Idea!
  49. 3D airplanes made in the USA, ARFS
  50. Sliverlit Turning Wheels
  51. where do you get better back persure?
  52. Fuel dot vs screw
  53. Add ailerons to SIG Senior?
  54. Wing Area
  55. how do I make tapered ailerons
  56. Receiver location relative to battery
  57. Putty for Fiberglass Cowl
  58. CRASHED plane due to servo chatter!! :>(
  59. Magnum ft160 twin running lean on one side
  60. G Shark mk1 or mk2
  61. Gyro in Airplane?
  62. RX antennae inside carbon fiber fuse
  63. Battery charging
  64. Need some suggestions please...
  65. black magic v2
  66. storing planes question
  67. programing question
  68. snoopy needs a balance point!
  69. busted remote needle valve replacement
  70. Great Planes Prop Ballancer
  71. Receiver compatability
  72. Tetra Bubbleless Tanks
  73. Saito 150
  74. Top 3 RC Magazine Choices
  75. I fly Mode 1 aircraft, should I fly Mode 2 Helicopter?
  76. Floyd Manly Ultimate Bipe and Hots Bipe
  77. Sliding pick up bed
  78. pluming for a OS 120 surpuss
  79. Tail Draggers
  80. good first foamie suggestions please
  81. Can you identify this P-40?
  82. Problems with HiTec Optima 6 Receivers
  83. What scale is this Spitfire?
  84. Prop choice
  85. Engine Vibration
  86. BATTERIES
  87. Going to San Pedro, CA
  88. Perplexing engine trouble
  89. Table top band saw
  90. Freewing SU34 ESC Problem
  91. (ask) Spektrum DX8 Problem
  92. Slimline Showtime Pro Smoke pump
  93. Wher is Lee Davis?
  94. HINGERS POINTS
  95. aileron flutter
  96. fuel tank for 4 stroke
  97. Pulse Jet engine in airplane
  98. muffler question
  99. Ziroli Plans - but different?
  100. flaperon end point set up question please help!
  101. Firewall thickness
  102. Futaba 8U 2.4ghz conversion
  103. Main gear width
  104. RC in louisville
  105. Big Eagle 2
  106. Paint ball gun in pup
  107. Moving the retracts air tank to fuselage
  108. FW Canopy
  109. GP CG Machine ruler?
  110. weighing an airplane
  111. converting Alpha 60
  112. Saito 125 Muffler Adaptor Nut
  113. What plane for an Older OS 40 four stroke
  114. Connecting motor to RC-receiver
  115. Hello
  116. tbm von extra 260 35%
  117. hardware supplier
  118. Mounting onbond video camera to minimize vibration & waves in vedio?
  119. ace charger repairs
  120. Connecting retract air line tips/help
  121. Hobbico Starfire 40 Need A Tailset
  122. Aileron Flutter in a Ultimate, help needed
  123. DUDE!! Can you just shut up??
  124. Great Planes ElectriCub (Piper Cub)
  125. Top Flite Cessna 182 Skylane GP/EP ARF 81
  126. TIght Wing Tube
  127. Looking for RC Club in Westlake TX area
  128. Castor Oil
  129. What the flutter?
  130. ultra sport 40
  131. cool power fuel ?
  132. Plane storage
  133. On-Board glow plug starter
  134. Source for small Drawbar/Return Springs
  135. What retracts to use?
  136. ASP61fs mounted inverted
  137. WANT A GOOD HOBBY SHOP-WHOLESALE TRAINS!!!!!!!!
  138. Best volt meter
  139. 2.4 ghz Radio choice which one?
  140. How to use a smoke system on my dle30??
  141. Charging 12 Volt Battery through Deluxe Panel?
  142. covering on ESM FW-190
  143. Decals
  144. OS FS200 remote exhaust
  145. recover
  146. barn door ailerons
  147. all about Sig mfg
  148. What fuel are you using
  149. Fox .40 needle valve
  150. removing monokote stickers
  151. Monokote?
  152. 120mm fury fans
  153. custom made decals
  154. deleted
  155. RC stuff....buying vs. Selling
  156. SC engine help
  157. Futaba 7c 2.4 rear transmitter cover
  158. World Models Voodoo
  159. Need help identifying a motor
  160. Unknown brand engine?
  161. Iron setting
  162. covering prep.
  163. Iron Sock Problems. How can you clean a dirty sock?
  164. Running engine dry
  165. model fancy box
  166. 2 blade props vs 4 blade props
  167. Spektrum TX and RX compatability
  168. What paint can take 30% nitro
  169. How far
  170. Static 4-blade prop
  171. Need help with Graupner Extra 300
  172. Any Flyers near the Dixon, IL area?
  173. Cowl mounting
  174. Thunder Power TP610C question
  175. RC Product Ideas
  176. Filler Compatible with Fiberglass
  177. Hitec Aurora 9 Lipo
  178. some one to fly with
  179. Want to try Gas, request your opinions
  180. Weather website question
  181. Trim Scheme?
  182. revolver kit
  183. Orange FASST 2.4 rec .from HobbyKing
  184. scratch building
  185. Goldberg Vintage Shoestring question...
  186. Looking for a sim file
  187. Radio & switch hook up
  188. dual elevator servos
  189. quick radio question
  190. CAN SOMEONE ID THIS PLANE FOR ME?
  191. Looking for Flight Stand
  192. JR 11 & Switchglo/smoke programing help
  193. evolution eng. frustration
  194. Rossi 60
  195. tail dragger conversion
  196. How to keep muffler bolts tight?
  197. looking for a 4 blade prop for a 26cc gas engine
  198. On Board Glow that runs off RX Battery
  199. OS 70 Surpass engine.
  200. Saito 100 starting tips
  201. Saito 115, DX8, RPM Sensor
  202. Hyperion 720i net charger questions
  203. "OLD" Super Tiger .40 Problems (again)
  204. Practical wing section for thermal soarer
  205. Paypal ID #5S9785734L657511H)
  206. Electric RC Help
  207. why do i need dsmx?
  208. Starter Problems with Saito 100
  209. HELP - GP P47 clunk doesnt work!
  210. bubbles
  211. Flight times?
  212. CG of YAK 54 from PHOENIX
  213. SHOULD I DOWNGRADE?
  214. Striping Tape
  215. Plane on top of car, good or bad?
  216. soft tube for field box
  217. Will japanese made parts run out
  218. Fiberglass Question
  219. Compatibility of Different Mfrs Retract Servos?
  220. I need all you motor heads
  221. Monokote ARF Camouflage
  222. Where is Fliteline Solutions
  223. Filling Trailing Edge Hinge Slots - Suggestions Needed
  224. Skybolt Torquing Over
  225. Modifying a Robart Piston
  226. Direct sunlight effect on radio & monokote
  227. perry pump
  228. Sig Skybolt, Need CG location
  229. Digital Volt meters
  230. Non delivery after 3 yr wait.
  231. fun 51
  232. Spektrum dx7 question
  233. Servo torque question II
  234. Best Forum to ask about Moki's?
  235. Byron Originals T-34C Bonanza Beechcraft Series
  236. Model AIrplane News Digital
  237. Can I unsubscribe to a thread?
  238. robart air valve
  239. Servo torque question
  240. RC Hobby Shops - Peoria Illinois - where are they?
  241. DLA 56
  242. Help me to identify this plane
  243. turnigy motor and squacking sound help
  244. Futaba T9CP Programing
  245. Carb for Saito FA65
  246. A question on engine rebuilding
  247. Any RC airfield near Johnson City NY ?
  248. *TECHone Mini Malibu*
  249. Edawards 5cyl. Glow engine
  250. How to setup Flaps - DX 7 and Spektrum AR 6210
