PDA
View Full Version : Questions and Answers
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. OS 62 FS problem! Plz help!
  2. Motor Identification ?????
  3. Carl Goldberg Tiger 2
  4. Mixing rudder to aileron on a Futuba 9c
  5. Demon Cortex Glitching In G.P. .40 Sized Cap232 - Help!
  6. Throttle stick moves Thr servo....Pitch stick moves Throttle servo
  7. Anybody put a 60, on a balsa USA north star
  8. How to grind a flat accurately on a LG shaft
  9. Is heli4me good?
  10. binding ttx650 to txr flyzone models
  11. TNC Tach
  12. ucd sf engine problems
  13. Epoxy Issues:
  14. Battery Charger
  15. Valve Lash
  16. Denver area HS?
  17. Differential wiring with a 6 channel
  18. Telamaster .40
  19. Efte retracts 60-120 Struts??
  20. Traveling to San Francisco
  21. E-flite retract question
  22. Interference Spike
  23. Propeller upgrade?
  24. 4 stroke Engine for a great planes piper .60
  25. Help Please on kit-bash mistake
  26. Who is this little guy
  27. Motor compatability Hobby Horizon
  28. Electric to Glow conversion
  29. Power box problem
  30. Prop size?
  31. Flying in Germany
  32. Fox glow plugs??
  33. Add forums to your home page
  34. Brass Tubing Slicing Silicone Fuel Tubing
  35. Pull pull for rudder
  36. Can nitro make smoke?
  37. Why was this servo recommended?
  38. Model Master Paint
  39. Moki 2.10 running hard
  40. Biplane Aileron Wiring
  41. Ww 1 scale kit..looking for one
  42. CG on an old Piper Cub ?
  43. older rc co.
  44. Giant EX 300 pre-flight questions???
  45. Nitro Engines
  46. B25 props
  47. Can anyone Identify this plane?
  48. How to pair a hobbyzone champ to spectrum dx6?
  49. help needed to find the right electric motor
  50. sullivan starter conversion to lip
  51. New sport/ aerobatic ARF to buy?
  52. Brand New Lipo Battery Swells
  53. Futaba Radio Choke safety setup
  54. gryo using two channels on eleavtors
  55. Glow Engine Cuts in and Out
  56. Retract Springs
  57. Phoenix Giles G-202
  58. how do thin canopy glue 560
  59. gliders
  60. Saito 150 4 stroke
  61. Webra 61 Speed
  62. which paint???
  63. E-flite convergence help help
  64. crflyer16
  65. building my own battery packs
  66. best servos for ucd sf
  67. Power HD 9001 Servo Question
  68. all around best fuel
  69. Mixing servos
  70. 3d printing
  71. What Voltage Meter Are You All Using?
  72. Covering options help.
  73. Aluminum tailwheel bracket
  74. Former RC piloit whos now leaglly blind wants to fly again!
  75. to use a solid Hardwood or Plywood ??? that is the question
  76. Ciano hinges.
  77. What is this plane?
  78. many questions on build?
  79. Questions​ about E-flite's Valient 1.3 bnf
  80. Arthur Bunch's Seahors
  81. power pod on glider
  82. Sonictronics fuel pump question
  83. U can do sf
  84. transmitter battery pscks
  85. G10 Fiberglass sheets
  86. NGH Engines
  87. Super Tiger engines
  88. Painting with dope
  89. nicad battery cycling and capacity question
  90. ACE T-34 maiden flight.
  91. an Un Cure question here
  92. bud nosen cub
  93. DLE Engines Won't Start, Culprits Found
  94. Battery and Ignition Set up for 1.20 Size Plane
  95. MLD 28cc CDI sensor
  96. HELP!...Need advice on Dual Switch Assembly, Ignition Module, and a 72MHz Radio?
  97. pros and cons on 3 blade props
  98. Nitro to gas conversation would a 10cc gasser work in place of a .46 nitro?
  99. Receivers
  100. Dle 30
  101. Storage charge for lipo batteries
  102. Need Help on Throttle on Electric Plane
  103. Fuel tanks
  104. Thrust needs
  105. Bill Evans Future Shock porpoising during take off and landing
  106. Dubro Swivel Ball Links
  107. On board camera.
  108. spektrum ar636 firmware problem
  109. The cost of wood?
  110. Easiest 8 Channel Programmable Radio to learn for beginner....
  111. Dual rudder set up
  112. wing fairings and others
  113. post style control horn set up
  114. Duel servo set up on dx6i
  115. Servo Reversing
  116. Feibao P120 Hawk stab settings
  117. Glow engine parts and availability
  118. Building First Gasser DLE20RA NEED HELP!
  119. NGH and OS Engines?
  120. Micro Servo Question
  121. 1/5 scale de Havilland chipmunk CG point
  122. engine size for particular cessna
  123. Airplane Covering
  124. Value of Saito FA-30GA?
  125. Engine stand offs
  126. red box TF p-40 electric
  127. XG8 My List problem, & Gear Channel question
  128. oil% for evolution 2 stroke engine
  129. Start to Finish, Need your Opinion!!!
  130. giant scale engines
  131. Old Blue Plastic Flightbox ID Please
  132. U can do sf
  133. Servo movement after the fact
  134. Saito 180 Fuel Tank Question
  135. removing stuck gasket on a Glow engine
  136. Hysol 9462, never used it before, your thoughts? will my repair I did below work?
  137. MOKI RADIAL 215cc engine
  138. Building RC aircraft
  139. Setting savings problems with Futaba T8J
  140. Too much engine?
  141. Aeroworks Replacement Parts
  142. Nitro Planes P-47
  143. Does anyone know where to find these plans or even a kit?
  144. Klass Kote clear question
  145. A personal flying field unlike others
  146. Need Silencer Baffle for OS 75/95 AX E4040 Silencer
  147. lazy bee 48" ws
  148. RF 7.5 SLT Dongle Broke
  149. Mentor USA Mentor-G
  150. CG question
  151. Futaba or Spectrum?
  152. Looking for someone with eagle tree gyro experience
  153. There was a ime
  154. DLE 30cc Gas Engine
  155. Engine sizes
  156. What are the effects of oversized landing gear (struts) on a warbird
  157. Giant Scale Spitfire (Thrust to Weight Ratio)
  158. Buy from this seller
  159. Engine for a big stick 40?
  160. Unionville deHavilland Beaver 8'
  161. Rust oleum paint?
  162. Exhaust. Extension
  163. Help with engine info
  164. TF P-40 tip stall
  165. Super cub pictures
  166. Starter charger
  167. Enya 120
  168. General OC oil that mixes with methanol
  169. Cutting G10?
  170. OS GT 15. and a sig kadet sport? I
  171. Antenna
  172. build table
  173. Spirit Aero unit
  174. I need help with a BEC
  175. Great Planes J-3 Cub .40 Size with a .75AX?
  176. os 160 prop?
  177. ST 46 prop
  178. Eng Questiom
  179. Stabilizer
  180. Gaps for Glassing
  181. Cleaning the engine.
  182. rocket power to electric
  183. Dx7 on off switch AR 600 receiver
  184. LADO Retract Strut 6mm Steel Replacement Pins
  185. Engine idle
  186. Paintball gun sound effect?
  187. Servo buzz
  188. Tech aero IBEC what am i doing wrong.
  189. Struggling with my home built hot wire foam cutter
  190. China hobby shop
  191. Covering question
  192. Radio Frequency
  193. Adapting a pushrod to a (Robart) air cylinder
  194. Challenge: Identify this plane!
  195. Seems like JR is done
  196. SIG Kadet Senior wheel questions
  197. What happened to Magnum glow engines?
  198. What batteries to use on my receivers
  199. Glue for planking
  200. Ultra mini stick
  201. Sig kadet senior. Taildragger?
  202. Contact Info for Harris Model Products
  203. Nitro Quad-copter How does it yaw?
  204. Composites for hinges and control horns
  205. Glass Cloth
  206. Evolution nx .52 won't stay running in cold weather.
  207. fm radio gear and e flight and converting my JR388 to 2.4GHz
  208. Robart strut length adjustment
  209. Bolts, Alloy vs Stainless
  210. Plane suggestion
  211. anyone doing CNC, need help
  212. parts swap
  213. Need help identinfying an airplane
  214. hot glue gun problem...
  215. Where do I find this nylon parts????
  216. Ben Buckle Majestic major gas engine
  217. Good but cheaper CA glues????
  218. Center Sprung Throttle Stick on DX9
  219. What is the Factory setting of the Mixture Control Valve?
  220. Great Planes 231EX ARF
  221. Spektrum DX7s and Flaps
  222. Oil mix for OS GT 15?
  223. How to post pictures to seller advertisement.
  224. super cub info
  225. Balsa usa north star
  226. Solartex -Some More Questions for those who know
  227. Coroplast
  228. Pilot Christen Eagle 40/60 Canopy
  229. Discussion regarding 72mhz, hits, cell towers, train tracks and other...
  230. Giant big stick 80 engine
  231. Hubsan H501S stopping props
  232. Upside down engine mountingI
  233. Hitec 3XA and futaba 617 receiver
  234. Best Way ToTransport Large Scale Warbird Fuselages
  235. Aeroworks?
  236. Capacitors and Receivers
  237. Exhaust extension
  238. What is a good plane to start (electric) aerobatics with?
  239. in need of muffler
  240. Please help with art tech reciever/transmitter problems
  241. Hydrographics
  242. help with twin set up for servos...twin motors
  243. Balanced props?
  244. OV-10 ground tracking with slightly off center nose gear
  245. Does anyone make a 40 size delta like the old lanier shrike?
  246. Tarvin model products
  247. Piper Seneca ll cowls
  248. Gyro Mounting
  249. Engine choice help for 1/4 world models air tractor/pawnee
  250. Replacement Carb for NovaRossi R26CR Engine
