PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. PLEASE COMMENT...
  2. Testing transmitter and flight batteries
  3. Old engines in need of repair
  4. Pitts muffler
  5. Twin Stick
  6. fly cam one ?
  7. Plane id
  8. Ultracote and top flite paint
  9. Does anyone know??
  10. SeaGull Superstar CG
  11. Need help converting Senior Kadet to electric
  12. Senior Frontier 80" WS
  13. need your help rcu
  14. CRCC GF 26i engine?
  15. Where can I buy replacement glow engine bushings?
  16. cub bear decals
  17. What elelc motor for .40 trainer?
  18. Painting Spinners
  19. Flaperon Wing on Spektrum DX7
  20. Help with switch
  21. Hitec 5955 servo feedback
  22. is it possible to have too many airplanes?
  23. Spectrum Helio Transmitter
  24. Please help, Evo .60nx runs like a winey little girl
  25. Servo "Chatter"
  26. Hitec HS645MG ?????
  27. JR RX 2.4 921 issue
  28. Crankshaft Sizes
  29. Great Planes F4 Phantom
  30. Balance problems (falls to tail or nose)
  31. Palm Springs CA airfields/hobbyshop?
  32. killer bee failsafe problems
  33. Ultracote Question
  34. Correct rate for charging a lead acid battery?
  35. Ideas for making this plane more visable
  36. Horizon doesn't want my opinion anymore
  37. Is a magnum .91 4 stroke big enough for this?
  38. SWB Servo Arms
  39. Bearings for old 45 supertigre
  40. Orange rx
  41. Futaba receiver without regulator
  42. model airplanes and Airlines can I ship as luggage
  43. spinner for a saito 100
  44. Monokote - Super Monokote ?
  45. Shipping
  46. Tachometer for smart phones
  47. Hobbypartz Products
  48. Transmitter/ Receiver Compatibility
  49. Futaba 6ex ch 6 expo?
  50. Crook it engine mount “help”
  51. thrust in firewall?
  52. What does your club do to promote itself!
  53. Eflite sukhoi
  54. Fight for what is right or fix it, forget it, move on?
  55. canopy for tiger 60
  56. Futaba Fasst Orange/Rx receivers on Hobbyking?
  57. Electric Motor Size
  58. bought this at a club auction...what engine?
  59. Senior Telemaster Ailerons
  60. Pitts 2Sb MAN X03951 Help
  61. A123 Batteries and On/Off Switches
  62. Help I.D. This Mystery Plane
  63. proctor eindecker kit
  64. .60 size p51
  65. Xoar prop problem
  66. Clear coating water base airbrush art.
  67. Repost.. Landing gear and strut construction
  68. Epoxy applied to Foam Planes
  69. how to fix foam wing
  70. I NEED SOME HELP...
  71. current tower coupons
  72. Cleaning mono type covering
  73. RCM Back issues
  74. Dual elevator servos with slight latency.
  75. JR 2.4 tx compatible with hitec 2.4 rx?
  76. Clubs In The US
  77. Storm Launcher New Won't Turn On Again
  78. slope gliders going over 40 mph
  79. Aluminum landing gear
  80. air retracts
  81. New auction plane question
  82. Top Flite giant Scale P-51 Spinner
  83. receiver question
  84. Smoke System
  85. Shipping Time
  86. Spektrum receiver exchange
  87. fowler flap hinge control hookup
  88. Customcutgrafix MIA?
  89. Flying Clubs in Ormond Beach area
  90. Programming new radio
  91. Wing struts?
  92. Next plane
  93. Futaba 7C MIX question
  94. buy and sell
  95. kerosine heaters???
  96. Dubro Steel Turnbuckle 1/4 Scale
  97. Trouble with Spectrum AR 6110e Receiver
  98. dle 20 gasser in 60 p-51 arf?
  99. is it necessary to remove battery pack out of transmitter??
  100. Best channel
  101. Prop
  102. Homelite 25cc engine specs
  103. Ace 4-60 Bipe instruction booklet
  104. balsanova arf 40
  105. 46ax or 55ax
  106. wot 4 petrol plane info please
  107. Alternatives for 2-part epoxy when glassing
  108. Ebay Futaba 1000 mah nicad receiver batteries
  109. kadet senior
  110. Saito 82 engine mounts
  111. Which is the Smallest Carburated Glow engine?
  112. Diamond Airfoil Planes
  113. Can't balance this prop
  114. does this sound normal?
  115. Aluminum or CF Landing Gear for CG Ultimate Biplane
  116. SIG Kadet LT-40
  117. i need help on DUBRO SNOW BIRD SKIIS
  118. PROGAMING FUTABA FG8
  119. paint
  120. O.S. .90 surpass
  121. Minwax Fast Drying Polyurethane
  122. oomodel?
  123. Who sells giant scale starters?
  124. RC model in Sohar Oman
  125. DOUBLE SIDED HORNS?
  126. Old Engines information please
  127. Pluming from tank to engine
  128. B&B Specialties
  129. Futaba or Spectrum
  130. drilling plastics
  131. lazyace 62"
  132. DLE-30
  133. OS 46 FX
  134. Kota Kinabalu Hobby Shops?????
  135. Painting aluminum?
  136. AP .09 Hornet
  137. OS .50 locked up carb.
  138. looking for a 60 size low wing trainer ARF
  139. Dual drive servos
  140. JR tansmitters
  141. radio crystal ???
  142. Bass wood
  143. Yagi?Patch?
  144. Buying on RC Universe
  145. Opinion needed, 4 stroke crankcase
  146. Engine fuel pump
  147. Gluing
  148. Funtana 90 wing tube
  149. How to remove scratches from canopies?
  150. How Much Titebond Glue Is Enough?
  151. First 4-stroke, question...
  152. FA3 fuel
  153. RV,Trailer,5Wheel,ClassC RC Storage and Transport
  154. Quick CG Question
  155. Made in the U.S.A
  156. #11 Xacto blade handle???
  157. gas tank positioning in a 30% yak (55cc)
  158. COOL POWER OR OMEGA
  159. SD10G transmitter question
  160. voltmeter problems
  161. Possible wood filler?
  162. aerotech models int p-38
  163. Instrument Housings
  164. Inverted OS .46 FX
  165. Graphic file
  166. ENGINE FOR 1.20 SIZE LASER
  167. Landing gear wire help
  168. What size is my GILES?
  169. Posting Photos
  170. Byron info
  171. How To Ship Airplanes
  172. need some help with these planes
  173. Looking for M. Novak
  174. Morris (R)ssi) Powerhouse 45
  175. latex over nelson hobbies paint?
  176. Prop fwd vs aft side ????
  177. Hobby King support?
  178. How do you know what servo arm,and hole to use?
  179. Servo reversing
  180. Help with electric motors
  181. Quiet motor/esc
  182. Inexpensive Home made wing bags ?
  183. Noise Wheel Snow Ski
  184. how do you make a gas fueler set up for you plane?
  185. What plane would you get?
  186. Non-Servo carb to Servo controled one
  187. Does Wood Glue go bad with Age?
  188. Kyosho P-51 Betty Lee(.40)..need a wing
  189. need help
  190. What is a good plane for beach flying?
  191. applying latex paint
  192. I can't stand not having a rudder!
  193. 46 OS LA on 60 size trainer
  194. Futaba 7C: servo question
  195. Cub ground handling secrets??????
  196. Painting Koverall
  197. So, what did I do wrong?
  198. Alternate Use For RC Controls
  199. JR XF622 setup with dual wing servos
  200. Nelson Hobby
  201. Stiffening a Fiberglass Cowl
  202. radios/mixing and Y's
  203. OS 46 AX
  204. Clubs near Williamtown RAAF?
  205. Exposed Servo,,Airflow Question.
  206. Value Hobby
  207. Electric motor help
  208. ASP engines
  209. Best time to call Hobby King?
  210. need help locating offset hinges
  211. Classifides correct?
  212. Dollar RC Parts
  213. WHAT HAPPENED TO 12 MINUTE EPOXY????
  214. Having trouble fitting motor in my plane
  215. Who has experience with the Thunder Tiger 130 4-stroke?
  216. Christen Eagle engine size??
  217. Airplane choices??
  218. mini dv cams
  219. Propeller puller
  220. What size lipo to use
  221. I am looking for a straight exhaust extension
  222. need info on this plane?
  223. first nitro
  224. How do you transport your planes to and from the flying field?
  225. 2 stroke to 4 stroke conversion
  226. Broken props
  227. Expanded Scale V Meter circuit
  228. Retact servo w/ servo slow issues?
  229. Lipo battery
  230. DAVE PATRICK EDGE 540 27%
  231. Saito FA-125 on Pulse XT 60
  232. Plans - what's up with suppliers?
  233. spinner size 15 magnum engine
  234. Servo Extensions
  235. another garage storage question
  236. OS 60 MAX FP
  237. GP Slot Machine tool - Tips?
  238. muffler os max 48 fs replace
  239. ar6200 rx battery digital servos
  240. Aliphatic Resin - course or smooth surface
  241. Warped alieron
  242. engine
  243. Spectrum DX8, Love it? Hate it? What?
  244. Seagull Spacewalker 11 Engine
  245. Van hauler ideas
  246. RC stores trusting question
  247. Propeller conversion chart
  248. Windy day plane
  249. Steering servo question
  250. Spacewalker
