PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Charging NiMH batteries
  2. Calculating wing weight
  3. RC Airplane I-Phone Apps
  4. SLIMLINE SCAM
  5. SPRAY ADHESIVE
  6. Electric starter won't turn it over os .91
  7. windshield for Super Decathelon
  8. Glow plug for a 4 cycle engine
  9. How difficult is it to replace painted covering?
  10. Motor Mount Question for OS FS30
  11. Input about Sig Aerokote?
  12. Bomb drop system ?
  13. Balancing question.... problem?
  14. Mylar Covering
  15. ASP .61 2 stroke engine stalling problem.
  16. Problem Binding DX7 to AR6200
  17. Triggering lights with DX6i for airplane?
  18. Abu Dhabi
  19. Two questions for gasoline ignition experts
  20. Walbro carb for DLE 30 ?
  21. Hobbico LiFe 6.6v with R617FS
  22. Copyright Issues when re-designing an "discontinued" model?
  23. flight weight
  24. Engine mounting ?
  25. Master Airscrew Props..
  26. OS 90 4 cycle without a choke
  27. Using Sullivan Gold N Rods on a Seniorita
  28. sig senior kadet
  29. Exhaust into retracts
  30. Dubro Vintage Wheel, 5.6" diam. ??
  31. Setting up throttle cut on a DSX9
  32. 10 Year Old Batteries in XP8103
  33. airplane in a tree
  34. Pilot Figurine!!!
  35. ISC ROBINHOOD 80
  36. gp 60 cub
  37. Canopy/fin for Chip Hyde Gee Bee ARF
  38. How to stop wing flexing
  39. IRON BAY STILL IN BUSINESS?
  40. Sig Supercoat shelf life
  41. Bolt Size for 1 Piece Landging Gear
  42. Bolt Size between Engine / Mount / Firewall
  43. Servo question... Specs Futaba/JR sport
  44. Wire question
  45. Spektrum reciever AR6200
  46. Bearing direction in engine
  47. Hi tech eclipse 7 xmitter
  48. RC TV
  49. any answers to finding lost airplanes?
  50. Flap mechanism for models
  51. Red Square Models
  52. Corsair website?
  53. Just going to NiMh batteries. Any pointers?
  54. my engine is eating glow plugs. HELP!
  55. Super Tigre 45 Parts
  56. William's Bros. Giant Scale Wheels?
  57. Evo .61 vs. OS 55
  58. 3 Blade Prop for OS 120ax
  59. os 46 cutting out
  60. dubro insulated engine mounts
  61. Epoxy to alchohol Thinning mix ratio??
  62. Selling Used Fixed and Rotary RC Models
  63. PLANS FOR PIPER SUPER CUB
  64. King gas engine
  65. Flight Box ID
  66. Does anyone know how this plane locator works?
  67. Where to position fuel tank????
  68. servo operates backwards
  69. GP 40 size Revolver question
  70. OS 40 FP PARTS
  71. 2.4 antenna
  72. Icare-RC
  73. When do you normally go the field to fly?
  74. Exotic ESC programm tones
  75. Centering aileron servos
  76. F-27C stryker issues
  77. Great Planes Spacewalker incidence issue?
  78. Electronic ignition
  79. Hobby Shack SST 40 Kit Question
  80. DL 50 or DLE 55 ??
  81. Engine mounting question for my CAP 232 ARF...??? PICS
  82. Cmp Corsair 120 .. NEED WING
  83. Power HD Servos
  84. What size plane for my engines?
  85. EZ CAVALIER 40 ?
  86. Best place to plug in an on board voltmeter?
  87. Magnum 91 four stroke
  88. In cowl engine recomendations
  89. Rear bearing for OS 46 AX
  90. what is the best RC transmiter out there?
  91. Advice on contacting Great Planes
  92. Winter is coming!!
  93. gas engine needs a home
  94. Servo mounting location
  95. ys fz.63s
  96. Solartex
  97. need help cg and motor thrust
  98. smoke fluids????
  99. Single Vs Dual Conversion
  100. Where to find a glow plug of this size.....
  101. G-51 vs 12oz Tank
  102. anyone every buy servos from dymond rc
  103. f-35
  104. Mounting a 4 stroke engine
  105. What is best to remove CA from carbon fiber?
  106. Outrunner motor mounting on Beaver
  107. Slow Stick F motor mount problem
  108. new field help
  109. 1 Servo controlled by two servo channels
  110. Gasser muffler extension
  111. Futaba 8FG question.....?
  112. Anything to do Before I put this plane together? PIC
  113. thunderbird 6 amp 9amp castle creations
  114. Reversing a Enya 2Stroke
  115. bad prop C/G or both?
  116. What Strange things do you do with your R/C Plane or Heli?
  117. p-51d blue nose servos
  118. What is the best cycler to buy Triton or elite ?
  119. Radio setup for Ultra Stick
  120. Kit cutters
  121. Funtana x 100 fuel tank size
  122. ohio superstar tailwheels great service
  123. What is 1:4.7. scale?
  124. Servos
  125. Gas Airplanes / storage and smell
  126. help with landings...
  127. Back Pack UAV WING JOINTS
  128. R6014HS
  129. Dumb servo thingie question.
  130. Sleeve has a yellow spot on it?
  131. asp/magnum 1.80 2 stroke
  132. Voltwatch lights all on????
  133. Getting into Gassers?
  134. Nicest ARF Corsair in the 50" to 60" size
  135. In search of hobbyking reversible esc's
  136. CA HINGE MATERIAL
  137. tx over the shoulder tray?
  138. Texas RC Wholesale ???????
  139. JR receiver binding
  140. Engine Kills Chips?
  141. Disassembling a ST G90
  142. Building Adhesives
  143. Super light Covering Material
  144. Carbon fiber looking Ultracote
  145. landing light picture
  146. Breaking / running in an ASP 52
  147. How many/long to make wing tubes.
  148. Solartex and Poly-Tak
  149. What to use.... Propeller question??
  150. Sbach 30cc All Brands
  151. Moving engine forward changes geom'ery?
  152. HobbyKing US Warehouse
  153. Did you know?: Clarence Johnson
  154. Removing Wrinkles
  155. Best method to splice longerons/spars.
  156. DX7 Binding Problem
  157. EFlite Electric Retracts
  158. props
  159. Where to find 7/8" wing tube and socket?
  160. Where to get rolled paper tubes for CF wing tubes?
  161. Turning Power On and Off to Servos
  162. loss throttle response
  163. CG Setup and fuel level?
  164. Canopy Cleaning
  165. Receiver after a crash
  166. JR transmitter using Futaba receiver
  167. tt .46 Carb Fit?
  168. OS91FX With Macs Tuned Pipe need help
  169. NEW Work bench!!
  170. Multiple Servos/Motors
  171. estimating fuel time?
  172. Anyone that owns a Great Planes Escapade...Question?
  173. Do I have a bad reciever
  174. zdz 80b2rv engine
  175. Another Koverall question
  176. Crazy Prop Vibration
  177. Glowplug burnout
  178. Magnum XLS Engines
  179. magic hand 30% yak 54 cowl
  180. Best float plane and float plane site
  181. fuel dot and charging port?
  182. E-Flite P-51B Mustang 32e Prop Conversion ???
  183. OS .25 low end tune
  184. back pressure question
  185. Maybe a little advise from here??
  186. What Paint matches ultracote??
  187. Field box Plans?
  188. Great Planes Hinge Slotter - what power
  189. ESM P51
  190. exhaust valve for OS fs 70
  191. Boosting power output in this small engine...??
  192. pica p-51
  193. Is Aerial lenght relative to frequency for 72Mh Radios
  194. Pay-pal issues/questions
  195. associated press releise
  196. Robart Hinge Replacement - Getting the old out?
  197. flat spot on tire-plane stand
  198. Pick my next plane..... Nitro first.
  199. Balsa Sheeting Question
  200. E600 glue
  201. Carb for ZDZ 40
  202. fuel efficient engine?
  203. Adding a spring to the throttle gimble stick
  204. Yak 54 with DLE 30
  205. Spectrum DX6I
  206. OS Engines
  207. Flat Tire
  208. Removing Adhesive
  209. servo buss
  210. problem with binding
  211. How to balance an airplane with a pod mounted engine above the wing
  212. Where to inject smoke oil on headered saito
  213. Super Tigre 40 silencer question.
  214. SeaGull SPACEWALKER II .46 Size
  215. servo reversing y-harness
  216. Pictures of Fairchild 24w
  217. Dang Bubbles
  218. os 61 max engine help
  219. Great Planes Spinners and APC Props Not Compatible?
  220. Fliteskin
  221. Why the big price difference??
  222. hopping up OS 1.60
  223. Ni-cd = ni-mh?
  224. storing a new engine
  225. plane size?
  226. Airplane will not complete a loop
  227. New JR ES-539 servo's humming loudly
  228. dx8 spektrum transmitter
  229. Is there any locating devises for when our planes go down in the bush ??
  230. twist clear stickers
  231. gasser line
  232. Turnigy 9X 9C 2.4G (v.2)
  233. P-51 Mustang butchering
  234. O.S. 40LA adjustment question??
  235. convert tif plans to pdf plans format
  236. prop style for Saito .82 FS
  237. Waco YMF 3
  238. Best Muffler For OS120AX
  239. asp engine
  240. Which Field Box
  241. RADIO INTERFERENCE
  242. Digital Servo Setup
  243. TWist 40 covering
  244. binding 2.4 problems
  245. GP Patriot 40
  246. engines
  247. What would you do?
  248. LUCKY!!!!!
  249. Does anyone have a foam cutter and can cut some foam for me??
  250. retirement time
