PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. mechanically R/C'ing a joy stick
  2. Bought a box of goodies..... Is this worth selling? Pics..
  3. new Saito125a ready for run in and fly
  4. Futaba 14MZ support
  5. Top Flite Smart Stripe
  6. FUTABA6EXA
  7. CRRC 26R Spark Plug Alternatives.
  8. A wiring question
  9. 1/8" shank router bit
  10. A Flying Four Stroke in Winter
  11. Saito 100 Rebuild or toss buyer be ware of used engine's and planes.
  12. Smoke Muffler or regular pitts?
  13. retracts or fixed?
  14. ASP 91 manual
  15. Breaking in - OS FS 1.20 E Surpass Engine
  16. 6.0v Nimh battery
  17. Do I need to use CA with carbon fiber strip?
  18. Zenoah 20 ei ignition problem ?
  19. Whats your favorite field box, especially non-field box field boxes.
  20. Robart Hinges
  21. Fuel line size????
  22. Moving to Colorado, Help please.
  23. Binding problem/Questions?
  24. Model Tech - SuperCub 1/5 RTF 81",
  25. 6v or 4.8v reciever battery?
  26. SUPER TIGER
  27. Sarpuls P 51
  28. seagull decathlon 120
  29. Hanging your planes....?
  30. Center of Gravity contraption
  31. cosmo 61?
  32. Photos
  33. TwinStar Engines?? TT vs ST
  34. Delta Wing C of G calculator
  35. Engine / fuel problem
  36. battery cycles
  37. Great Planes Floats ?
  38. 12V Gel Batteries
  39. Homeade muffler?
  40. Swap Meet Tri Pacer Sterling 135 Find
  41. anyone know what plane this is
  42. nylon hinges
  43. futaba dsc
  44. Saito muffler connection reliability
  45. ARF manufacturers afraid of??
  46. rc tractor pulling
  47. Carbon Fiber Tubes
  48. New plane is here!! Question on engine cover?
  49. Balsa to Foam glueing???
  50. Throttle flutter with motor running, radio on
  51. Wing Bolt Solutions
  52. Who Makes the best 40 Profile
  53. Why Have 72 mhz Radios Not Come Down In Price?
  54. Anyone using G Mail?
  55. dual elevator set up
  56. quadra q52 sparkplug gap
  57. local hobby shops RIP
  58. Kalt g23 0r 22
  59. Aeroworks steerman
  60. Spring Air Retract Identification
  61. fuel tank at balance point/center of gravity
  62. Please help me diagnose my engine problem!
  63. CA Hinges vs Nylon Hinges
  64. Basswood Spar Warped!
  65. CG Problem
  66. Dual receiver battery?
  67. AirField Sky Trainer 400 Prop Shaft
  68. Prop Balancing Question
  69. What Shipper Is Best?
  70. fuel proof products?
  71. Attaching control horns ?
  72. J-3 Scale Decals
  73. Calibrate throttle-stick Futaba 14MZ and FX40
  74. ground check airplane
  75. JR Propo dealer
  76. Remote Glow grounding help
  77. Wing Bags
  78. Best way to cold bend landing gear
  79. New Retracts from E-Flite for 60 size
  80. ESC and batteries
  81. Replacement for lost EasyGlider + FlyCam
  82. parkzone wild cat
  83. Crashing - a part of the hobby?
  84. Where to fly near Disneyland?
  85. watt meter
  86. Airtronics Radio
  87. Proper mid-air attempted ribbon cutting crash etiquette
  88. Smoking Fuel?
  89. ??Lustre Kote Problem??
  90. Mehcanical Aileron Differential
  91. Servo Strength's
  92. aeropro laser 200
  93. 1st attempt at gas, MAYBE!!
  94. Spend my money.... Transmitter??
  95. Clearcoat over Basecoat - Question
  96. Ordered new plane.... How to change this?
  97. Satio 180 Question
  98. Does anybody pay attention to the classifieds anymore!!
  99. ARF for salvaged OS 25LA
  100. Airplane Storage Method Pros and Cons
  101. Customized Components
  102. Rudder flutter problem...
  103. nose up test
  104. Prop Nut: Is there such thing as TOO tight?
  105. HD video
  106. Can You Identify This One?
  107. MyAtomic.com Opinions? Just asking
  108. Caution Ebay seller 2pch101
  109. Stained Vinyl Covering Help.
  110. Morris Hobbies?
  111. Remote Glow Starter queston
  112. Slimline Boxxer Fuel Pump
  113. seagull AT-6 74" 91-120 Please help with C of G
  114. 25cc Homelite 3occ Ryobi worth??
  115. Redwingrc
  116. New to 2.4 buying on R/C
  117. Monocote patch over Ultra coat
  118. Need help with terrible flying airplane
  119. Sound on Graupner MX-16
  120. battery cycling
  121. what kind of plane is it??
  122. Different battery voltage when using 2 batteries for retracts/receiver
  123. Glow plug head stripped
  124. Fuel tubing
  125. How Much is this Worth?
  126. DASH 8 INFO PLANS , ARF OR KIT
  127. AMSOIL
  128. New Turnegy 9X V2 2.4 radio
  129. Align STQ100 starter
  130. engine tuning
  131. Balancing
  132. Great planes extra 300 .60 size prop
  133. Trailer Buying Help Needed
  134. Help Identifying make of Mustang and cub
  135. 9C Prgramming: Flaps/Elevator
  136. ASP 46 - where is the low speed mix needle?
  137. four stroke help
  138. JR wit Hitec Optic 6 sport as a trainer radio
  139. Lipo Charger
  140. Blade Source for Stripper
  141. Can you mix Micro-balloons with canopy glue?
  142. texas hurricane
  143. Saito 125a setup help needed!!
  144. Was this overspeed or mech failure?
  145. Vector flight Extra 300
  146. Shipping
  147. "Spring Air Retracts" Won't Retract
  148. esc
  149. help with plane manufaturer-brand?
  150. Prop Suggestions for a brushed 370 motor
  151. Weston UK 36 setting
  152. anything wrong with carpenters glue for joining wings?
  153. Sig Kommander
  154. What oil to use for Saito storage
  155. Starting inverted Moki 2.10
  156. Best fuel for inverted engines
  157. Spring Air Retracts
  158. Mustangs
  159. kyosho flip 3D cowl
  160. Am I on the right track
  161. My mini glider wont fly. why?
  162. glow 4 stroke versus gas
  163. Anyone know how to make a scale dummy engine pinwheel?
  164. Replace the Cylinder or just the ring on a Saito rebuild?
  165. os .91 FS
  166. Rapier L2HP motor
  167. OS Max 60 FP Not Running
  168. DX7 Binding issues with eletric plane
  169. LT-40 Wing Inciddence
  170. Combining glow fuels
  171. ASP Engines any good or no
  172. OS91FS loose front bearing
  173. x9303 programing
  174. foam
  175. jersey modeler fuel can fittikngs
  176. YS 120 ???
  177. 15% nitro fuel
  178. K&B .61 Tuning and Break in... a little help plz
  179. fuel tank
  180. Parkzone Decathalon wing same as super Decathlon?
  181. What size is a Rossi 11.40 engine?
  182. Slimline muffler installation
  183. Funtana x100
  184. 2.4GHz radio/receiver compatibility
  185. ASP 46 same as MAGNUM 46?
  186. Sea Breeze
  187. Servo question...
  188. Team Polo
  189. OS91pumped fs
  190. Best Firewall Sealer
  191. Sig Engine Mount Alternatives
  192. Mystery Plane - Identification
  193. magnum 4 stroke muffler loose
  194. Dual Elevator Servos programming and DX6i
  195. Loose FS muffler
  196. Exponential setting on TX?
  197. Fox 60 no fuel
  198. Glow plug
  199. How to sell a design?
  200. Fox .60
  201. Plan needed for portable foldable field stand
  202. Help Please ! Ace Digipace 3 Adapter Missing
  203. Macs Bolt-Through Muffler
  204. Ni-Cad Battery "Memory"
  205. Is it really necessary to pin nylon or CA hinges?
  206. Nylon Clevises
  207. Andrews Aeromaster CG???
  208. Engine setback on a ultra stick 60??
  209. Aspect Ratio?
  210. carl goldberg epoxy
  211. Reinforcing a "used" glass cowl
  212. OK, MODERATORS, WHAT'S THIS??
  213. setting up pull-pull on a rudder
  214. rascal 110 wings
  215. Discontinued OS Engine Parts ?
  216. Prop Recommendation for Funtana w/FA-50
  217. painting sig koverall
  218. Need help with dual aileron set up
  219. Futaba 4YF 2.4GHZ FHSS Radio
  220. ARG! Control Surface Horns - Help
  221. Glow Fuel
  222. JR Max 6 Radio
  223. Right Flyer 40T manual and CG
  224. What engine is this?
  225. 4 cycle lubrication
  226. Which battery to use...
  227. Is there a way to hide a small tear in Mono?
  228. What prop to start testing with on a 95AX
  229. sig mayham 3d
  230. Tuning/Break-in OS .91 FS II P
  231. One pitfall of hanging it by the tail wheel
  232. What size bolts are required to mount a Super Tigre GS-45?
  233. Fox 29x Needle Bearing Special
  234. picked up some stuff, need to know what its worth.
  235. Any Suggestions for Covering Fiberglass?
  236. Cutting perfect 1/2" circles in covering
  237. Sonic 25 CG
  238. Please Identify
  239. Li-ion Batteries
  240. Futaba T6EXAP Transmitter Reliability
  241. old engine revitalizing
  242. Great Planes Space Walker Parts - Cowl
  243. Sportster 60 power
  244. Radio glitch on new model...
  245. wolf predator parts
  246. Power Box / Futaba
  247. could somebody tell me what kind of plane this is
  248. The right biwing for my research...
  249. Byron/Iron Bay AT-6 Texan
  250. Anyone else having problems with Sig?
