PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. could somebody tell me what kind of plane this is
  2. The right biwing for my research...
  3. Byron/Iron Bay AT-6 Texan
  4. Anyone else having problems with Sig?
  5. FPV real time video
  6. I need help to link dual rudder servos
  7. Servos for GP Sportster 60
  8. Servo
  9. fuel
  10. unsolved crashes
  11. Can I swing this?
  12. Kit Identification HELP
  13. WW l planes
  14. Chinese Super Tigre reports
  15. dry saito
  16. RC radio and servos question
  17. OS engines factory webpage?
  18. Vintage OS 60 Gold head
  19. Parkzone F4U Corsair Receiver Problem
  20. Transmitter metal case... where to find?
  21. Motor for Herr Little Extra?
  22. DX7 Mixing Ailerons and Elevators Together
  23. How much power?
  24. Runway Length and Width Minimums
  25. yo yo effect
  26. Installing control horns
  27. Engine incidences for a chipmunk
  28. How Long Do Servos Last?
  29. Two batter system question
  30. Plastic Prop Spinners - Keep from Scratching
  31. I need a header but don't know where to get one...Help!
  32. REAL radio chatter for airplanes??? help please
  33. RC field in North Las Vegas
  34. Increasing pull weight of engine?
  35. Whats the price?
  36. FM PPM Receiver for Gas Eng Plane
  37. Saito - Enya 90 4 C exhaust question
  38. JR 11X?
  39. My rx melted!
  40. Stick engine mounting question
  41. Vendor "Spring Air"
  42. Battery Connector Help
  43. hobby shop problems
  44. Bonding Koverall to Monokote or Ultracoat
  45. parkzone f4u corsair and accessories
  46. Elevator mixing
  47. 2.4Ghz Rcvr placement
  48. Flight Box Fule Pumps ???Problems /Fix???
  49. best charging jack mount
  50. Creator of Radio Control
  51. CL Forums?
  52. Weed eater
  53. Best linkage??
  54. Obsolete O.S. parts
  55. OS FS-30 four stroke questions
  56. WHERE DID I GET THESE SANDING FILES????
  57. Futaba Radio
  58. Jittery Control Surfaces
  59. Help identifying airplanes...
  60. o.s. 75ax
  61. my Futaba 8UAPS transmiter fails, help meĀ”
  62. LRP zenit 370 motor
  63. Designing a plane just for the wind
  64. Where to find 2.4GHz Pitts RTF
  65. Need to Repair horizontal Stab.
  66. troybuiltmodels
  67. Scaling info needed
  68. Military Channel's top ten fighter aircraft of all time
  69. Corsair scale guysneed your help!
  70. Spektrum Repairs
  71. Gorilla Glue
  72. New Engine Select
  73. ground clearance
  74. Trailer size?
  75. CG for a Yellow Aircraft Sukhoi SU-31 - 1.08
  76. Painting Super Coverite
  77. nitro engine problem
  78. goldmine!
  79. Engine mounting bolts
  80. Classic Goldberg Cub Kit
  81. dual servos?
  82. Fliton Inspire 60 engine question, real quick
  83. Is GMS engines shutting down?
  84. JR Quattro trainer
  85. Using a .55 when a .46 is recomended
  86. GREAT TOWER HOBBIES SERVICE-I'VE FOUND THE SECRET
  87. Receiver interferance
  88. Gasoline vent/overflow outlet
  89. .40 sized engine for Hyperion P51?
  90. I need help with GMS 47
  91. JR XP 8103
  92. Iron Bay regulator
  93. Trojan Virus
  94. PICTURES-How do i repair a broken fiberglass fuse on a hotliner?
  95. JR RS70 won't bind to a certain freq
  96. CG for a Yellow Aircraft Sukhoi SU-31 - 1.08
  97. Jato Transmission
  98. airplane anomoly
  99. Cordless drill for engine starter
  100. Ex glow guy looking to get back into flying, going electric
  101. Tuned Pipe
  102. Need Battery Information
  103. Eye in the Sky
  104. Fuel proof surface for work table (MDF)
  105. seagull yak cg question
  106. Any one knows of a good 2.4 Spectrum Analyzer Program for the PC?
  107. Happy Fathers Day!!!!
  108. NEED HELP FINDING TAILWHEEL ASSEMBLY??????
  109. Any CL Forums in RCU?
  110. What engine for a Das Box Fly Bipe?
  111. Superiger 51 needle valve gasket
  112. What should I buy?
  113. NI-MH Cycle
  114. Getting back in the sport, Need some help
  115. Mechanical Retract Hangs low on one side.
  116. Dead Receiver
  117. landing gear ???s
  118. Is this normal?
  119. 6v system, Y together servo's?
  120. amp loads of glow/eprops
  121. Engine toast
  122. k&b.61
  123. great planes 50cc reactor and DLE 55
  124. Is this plane any good
  125. 15 minute countdown sounder/beeper
  126. futaba hi band/low band rx question
  127. Best method for cleaning gunge off glow engines?
  128. Evolution Engine Carb low end restraint
  129. Shipping a model to South Africa?
  130. Phoenix Decathlon flying problems
  131. White Plastic Spinner
  132. HOW DO I GET E-MAIL NOTICES FOR A SEARCH WORD??
  133. Carburetor problems
  134. nv setting for os 15 max
  135. exceed-rc brushless speed 400? any thoughts
  136. Thread lock ?
  137. lazy ace cg
  138. COOL POWER FUEL QUESTION
  139. Maiden take-off? Behind or Besides?
  140. Power boxes
  141. New battery question
  142. Quivering servo
  143. New radio & no receiver's ?
  144. flap setting dx6i
  145. Futaba FASST using a JR retract servo
  146. Bungee launcher for .40 Kaos (w/o landing gear)?
  147. eletric retract question
  148. Dynaflite PT-19 wing filet
  149. LiPo battery in Futaba 9CH
  150. Flying during sunrise and sunset: how to block the Sun glare?
  151. Gas or Nitro
  152. Gas or Nitro
  153. Lipo for a flight battery
  154. fut 9cap radio issue
  155. Where Is Correct Balance Point
  156. help calculating power system
  157. Is Electric Smoke Possible
  158. JR 9303 Spoiler Programming Question
  159. mounting cowls
  160. 2.4G receivers and batteries
  161. AMA weight limit for model airplanes
  162. Castle Receiver/ Hitec Transmitter
  163. N- numbers
  164. Y harness, centering, seting travel for each servo........
  165. Well there goes an $8 glow plug...
  166. LEDs on rx flashing?
  167. UCD .60 engine
  168. dremel small table saw
  169. How Do I Connect a Charge Switch to the Switch Harness and or TX?
  170. Futaba 8U programming
  171. Engine Mount Safe?
  172. Is it Possible? 2 gas tanks...
  173. Hobby Shops in San Antonio Texas
  174. looking for large B29 by guillows
  175. ulta-stick 120
  176. Switching to 2.4 questions
  177. How to clean model windows
  178. Smoke?????
  179. High torque metal gear servos
  180. prop size
  181. Using incidence meter
  182. Does age have to do with what airplanes you fly?
  183. I know nothing about a Cap 232
  184. Any rc flyers from Guam on here? I'm looking for my instructor.
  185. Question: Radial knob on Transmitter
  186. Tower's Kit inventory is getting a little low
  187. WHERE IS AIRTRONICS NOW???
  188. Powermaster fuel
  189. Spektrum Tansmitters and recievers
  190. Aeroflyte Jupiter plans
  191. Where to install Perry Pump on Engine?
  192. Engine keeps flooding before start
  193. Bad Experience with Hangar 9 RTF - Need Advice
  194. New Trasnmitter battery for 7 channel CAp
  195. nitro models cessna 337
  196. SAITO .72 PROPELLER.
  197. Glow Plug Selection
  198. Question about pistol tx throttle position
  199. Semi-stuck torque rods.......Solution?
  200. fuelproof clear coat help please ?!?!?!
  201. Sky Raider Mach I Aileron Trouble
  202. Rossi 46/Webra Carb
  203. MVVS 1.44 Twin Engine
  204. 40 4-stroke engine for Sonic 25 low-wing?
  205. Venom snakw eye cam
  206. Forum Subscription Question
  207. Push Rods
  208. stinson decals
  209. Smoke pumps?
  210. Prop Hole Size - Master Airscrew Props
  211. Werid Happening
  212. Requesting Advice: Propeller-Powered Skateboard (Mech. Eng. Undergrad Design Project)
  213. Powering Nav Lights
  214. Forgot where to buy an MPI Charge switch!
  215. Trim repair
  216. Adhesive Quality
  217. Old cox airplane
  218. Du-Bro Lazer Rods in Lanyu Cross 46A (Ugly Stik)
  219. Nitrate dope?
  220. hobbyking transmitters
  221. Balsa USA P-51D Mustang
  222. gear reduction adapter
  223. WHERE TO GET HITEC HS-82MG SERVO ARMS????
  224. FUEL TUBING SIZE FOR OS .95 AX 2 STROKE
  225. Muffler for OS 108
  226. Should ailerons move for pitch
  227. Helicopter Rx-Tx on airplane
  228. My own private moneycoat nightmare!
  229. Charging a nickel-metal hydride battery
  230. How to install propeller alighned with spinner back plate
  231. DLE-30cc in a Ultra Stick Lite 120??
  232. Venus 40 rolls when using elevator
  233. fox 4.2 engine problem
  234. Starter Brushes ??
  235. Converting Torqmaster to run on Nimh batteries
  236. Spektrum 7 channel questions
  237. O.S. 160 Slimline Smoke Muffler question
  238. amp draw of servos
  239. Plane to stay in small car ?
  240. First gasser, DA 50, help please!!
  241. Transporting in a pickup bed
  242. What side is
  243. Officially frustrated!!
  244. supertiger .46 g-21
  245. Zenoah 20ei hard to start
  246. ZDZ 40 ajustment
  247. Sig four star 60 engine with O.S. .91fx???
  248. Check Valve Question
  249. has top flite changed there monocote?
  250. R/C plane parade float. Anybody?
