PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Any tips to make sure i get this landing right?
  2. Nitro Models gone?
  3. 2.4 question
  4. RX battery screwup
  5. Mechanical retract setup
  6. HELP!! Problem Mounting Tailwheel Assembly... CUB
  7. 7 volt servos
  8. Airframe for ST-2300
  9. Cleaning Elapor foam?
  10. Super Tiger or Magnum
  11. RAM On-Board Glow problems
  12. tail dragger steering springs?
  13. Miracle Y ARE THEY OK TO USE ?????
  14. Plane for a G38
  15. Super Tigre engine problem
  16. HobbiCo Top Fueler Mark III
  17. Unknonw Cap 231 or 232?
  18. What if....Becomes What is.....
  19. Optima receiver antenna placement
  20. U-CAN-DO-3D 46 SIZE WITH AN .61 EVOLUTION?
  21. plane for 20cc gasser
  22. engine troubles
  23. OS engine trouble
  24. Foam transformer problem
  25. **Read Poll Question First (In First Post)** then make your selection! SILENT POLL
  26. Best way to fiberglass, whats your way?
  27. OS .40 FX Trust Washer
  28. This is not a question, this is an ORDER
  29. diregard this post
  30. How often to charge my DX-7?
  31. Battery discharge ?
  32. Super Sporster 90/120
  33. charger
  34. Engine Choice!
  35. Thin Ca Problem
  36. Solder Gun?
  37. charlie bauer
  38. Rust-Oleum....?
  39. 46 fx or 46 AX
  40. Weigh in scales
  41. x-tech
  42. Best fuel for Moki 2.10
  43. Hobby King DC Watt Meter Manual / Instructions and Sample Wiring
  44. Disaster! need help or advice
  45. Transfer tape for installing decals
  46. nose art
  47. transmitter case
  48. New shaft for Atlas Outrunner?
  49. how many gallons?
  50. Sullivan Dynatron wiring question
  51. Confused about Prop reamer
  52. HANGAR-9 DENIGHT SPECIAL 50 ARF - REVIEW
  53. Moki 2.10 what size fuel tank?
  54. new plane
  55. transmitter
  56. foamie hinges
  57. Has MonoKote formulation been changed?
  58. Hobby King TR52DV Camera Instructions / Manual Here
  59. tinting windsheild?
  60. How much runout is acceptable....
  61. extra 330s 140 arf
  62. fuel
  63. Unregulated Futaba 9252 & 9256 servos?
  64. Laser 200 83
  65. cmp extra 300s 140
  66. How do you CUT a carbon Fiber Spinner out?
  67. OS .91 4S won't run
  68. Steering linkage setup w/retracts??
  69. Saito 56 in my Sig Somethin Extra!!!!
  70. Just curious....which of the "Big Boy" 2-strokes is king?
  71. New to Ultracote Covering Questions
  72. Perry Smoke Pump Use
  73. ops 30 cc
  74. Spektrum DX7 range test failed
  75. Whats the difference ????
  76. TROLLS?
  77. Two way Y Valve ...
  78. Futaba 6EX 2.4ghz radio possible glitch
  79. Plane Plans
  80. Buying Spectrum
  81. pica duellist plans
  82. Engines for 1/10 scale B-17????
  83. Ultra Stick 40 Aileron & Flap Setup?
  84. Spectrum DX7
  85. onboard glow driver - need help!
  86. ross engines
  87. Gas:oil ratio...and I'm confused
  88. 120 ax plug
  89. flaps on 10C
  90. Problems with a dealer
  91. Hobby Zone Super Cub
  92. Bummed up aileron torque rod thread on strip aileron.
  93. Opinions for OS PUMPED engines
  94. Making pull pull hardware?
  95. asp .61 carb
  96. engine mount for a BGX-1
  97. what am I talkin about
  98. petrol engine
  99. Help, Mixed Up Fuel Jugs
  100. Can't see how to "edit" item I posted to sell?
  101. What spinner sizes for 12"-15" props?
  102. Gas Conversion
  103. BUSA Sopwith Pup and G38
  104. Batteries
  105. Standard servos
  106. custom exhaust
  107. Aircraft letterings
  108. Airtronics Servo Arms
  109. Wrinkled Covering
  110. are these good for wing tubes?
  111. Cost of the JR 9303, 2.4 and the Spektrum DX7, 2.4?
  112. FTL 50cc Engine Problem
  113. Old AM Radios?
  114. JR 8103 won't transmit
  115. building a starter pack
  116. right or left thrust?
  117. asp.61 carb problems
  118. Fuel for bushing engines.
  119. Help!!!!! please
  120. Flat Spot on foam wheel
  121. Looking for a 17x4 prop.
  122. Liquidation! Everything must go!!
  123. #11 Knife Handle?
  124. SOLARTEX COVERING
  125. World Models 200cc fuel tank - Fix?
  126. Onboard Glow
  127. Fuel Pump what wont leak after a few months
  128. F-117 Stealth
  129. Why so down on young guns?
  130. plane balancer
  131. crash nothing wrong
  132. Is there any company out there making replacement fiberglass landing gear?
  133. radio setups
  134. Magnum 120 4-stroke or Saito 100 in a Seagull Yak?
  135. build threads
  136. Am I right?
  137. Golberg Anniversary Piper Cub, What's my kit worth?
  138. CS-60's on tiger2 .60 ailerons...
  139. Fuel Proof Paint????????????
  140. 70" Revolver Engine Question
  141. AUSTIN TEXAS
  142. EXPERT ELECTRONIC,S ONBOARD GLOW
  143. excessive aileron play
  144. Engine cooling with cowl aircraft
  145. How big a problem is to much engine
  146. Testing Servos - Will I Damage them??
  147. Engine Cleaning
  148. vintage os 20 fly wheel
  149. Boy Scouts: Aviation Merit Badge
  150. Ultracote question
  151. engine/fuel question
  152. Battery Charger Help!
  153. saito 115 and 125 fuel tank sizes
  154. My Thunder Tiger F-91 ate the cam....
  155. Flew the maiden on my hog bipe!! wrong engine!!!
  156. Telemaster Electro throttle problems
  157. R/C Flight Simulator for Macintosh
  158. adding to elevator width??
  159. Starter Batteries
  160. Securing the Muffler
  161. Safer EZ-Connectors
  162. Which flys better?
  163. OS 91FSR
  164. Servo has no strength in ONE direction?!
  165. Properly Setting up a Pull Pull rudder?????
  166. Hotels or RC Farms
  167. asp .61
  168. Optic 6 Sport - 2.4GHz - Feedback
  169. Question about old engines
  170. Micro Receiver
  171. A couple questions.
  172. smoke switch
  173. WHAT ENGINE TO USE
  174. 2-part wheel pant assembly
  175. Futaba 2.4GHz Question
  176. 2 strokes vs. 4 strokes for cessna .46
  177. O.S. .91II props
  178. Stuck Prop nut
  179. help with engine and plane?!
  180. Evolution .46 Muffler Issue
  181. I need a fuelproof clearcoat... Help...
  182. any info on 1/3 scale tri pacer
  183. German Fighter?
  184. Batwing Question
  185. Saito 150S Always Backfires
  186. Robart Mnfg. Crappy Service
  187. silencing a Futaba 7c.
  188. Pitts Special, 1/3 scale questions? Need Help!
  189. Noobie needs a little engine advise
  190. Smoke system on Magnum 91 4 stroke
  191. What is the proper way to Iron Ultracote on top of Ultracote?
  192. toledo
  193. engine size
  194. New to Gas engine question
  195. After Run Oil???
  196. Theory about likeage and radio setup.
  197. Question for you Enya Guru's
  198. Top Flite 1/7 P-51 Arf retract problem
  199. Locktite CA Question
  200. Shoestring Racer
  201. Please recommend a plane
  202. I don't know this one..
  203. Armoral in fuel?
  204. Wind to your back Landings.
  205. Airplane starter amps.
  206. Need to know
  207. nose art
  208. transmitter stand
  209. Thunder tiger windstar ep help
  210. Rx backup battery as onboard glow driver.
  211. My next radio - what do you recommend?
  212. Does the DLE 55 have more power than a zenoah g62?
  213. zenoah g62 4 blade prop
  214. Do you have a use for a machinist?
  215. cap 232
  216. ST3200 NEEDLE VALVE EXTENSION
  217. inverted Saito 100
  218. Pushrod of 1mm Diameter... Where can I find it?
  219. Pirate models 42%g202
  220. Almost crashed 1/4 Scale CUB Floatplane yesterday...
  221. J&K 92 inchTR 260+ manual
  222. SPECTRUM RADIO
  223. JR PCM9X II & Hitec - Dual Channel Problem
  224. What is the deal with Futaba 3305 servos?
  225. Epoxy Mixing Ratios.....
  226. Nylon insert blind nuts
  227. V-tail setup
  228. How to Test servos
  229. Have you noticed two recent facts in RCU?
  230. My Cub flies way too fast!
  231. PowerMaster no more
  232. Am I Braking Any Laws ???
  233. High voltage servos
  234. Building First Kit Airplane
  235. VQ Models concerns?
  236. UFO foamie
  237. Broken RX Antenna
  238. Evolution GX26 Choke Question - Help!
  239. Turnigy Plush ESC instructions needed.
  240. Paint Colours FS#
  241. E-flite power 25 pulsating
  242. Aircraft weight range for zenoah g62
  243. Replacement Parts For Goldberg Ultimate
  244. Great Planes Landing Gear Super Chipmunk ARF
  245. Throttle reversing
  246. Art-tech Yak 54 propellers
  247. O S 91 BRAKE IN ??
  248. Lancair-Legacy CG
  249. Metal Throttle Arms & Linkages
  250. Yet Another CG Post ...
