View Full Version : Questions and Answers
- Flying during sunrise and sunset: how to block the Sun glare?
- Gas or Nitro
- Gas or Nitro
- Lipo for a flight battery
- fut 9cap radio issue
- Where Is Correct Balance Point
- help calculating power system
- Is Electric Smoke Possible
- JR 9303 Spoiler Programming Question
- mounting cowls
- 2.4G receivers and batteries
- AMA weight limit for model airplanes
- Castle Receiver/ Hitec Transmitter
- N- numbers
- Y harness, centering, seting travel for each servo........
- Well there goes an $8 glow plug...
- LEDs on rx flashing?
- UCD .60 engine
- dremel small table saw
- How Do I Connect a Charge Switch to the Switch Harness and or TX?
- Futaba 8U programming
- Engine Mount Safe?
- Is it Possible? 2 gas tanks...
- Hobby Shops in San Antonio Texas
- looking for large B29 by guillows
- ulta-stick 120
- Switching to 2.4 questions
- How to clean model windows
- Smoke?????
- High torque metal gear servos
- prop size
- Using incidence meter
- Does age have to do with what airplanes you fly?
- I know nothing about a Cap 232
- Any rc flyers from Guam on here? I'm looking for my instructor.
- Question: Radial knob on Transmitter
- Tower's Kit inventory is getting a little low
- WHERE IS AIRTRONICS NOW???
- Powermaster fuel
- Spektrum Tansmitters and recievers
- Aeroflyte Jupiter plans
- Where to install Perry Pump on Engine?
- Engine keeps flooding before start
- Bad Experience with Hangar 9 RTF - Need Advice
- New Trasnmitter battery for 7 channel CAp
- nitro models cessna 337
- SAITO .72 PROPELLER.
- Glow Plug Selection
- Question about pistol tx throttle position
- Semi-stuck torque rods.......Solution?
- fuelproof clear coat help please ?!?!?!
- Sky Raider Mach I Aileron Trouble
- Rossi 46/Webra Carb
- MVVS 1.44 Twin Engine
- 40 4-stroke engine for Sonic 25 low-wing?
- Venom snakw eye cam
- Forum Subscription Question
- Push Rods
- stinson decals
- Smoke pumps?
- Prop Hole Size - Master Airscrew Props
- Werid Happening
- Requesting Advice: Propeller-Powered Skateboard (Mech. Eng. Undergrad Design Project)
- Powering Nav Lights
- Forgot where to buy an MPI Charge switch!
- Trim repair
- Adhesive Quality
- Old cox airplane
- Du-Bro Lazer Rods in Lanyu Cross 46A (Ugly Stik)
- Nitrate dope?
- hobbyking transmitters
- Balsa USA P-51D Mustang
- gear reduction adapter
- WHERE TO GET HITEC HS-82MG SERVO ARMS????
- FUEL TUBING SIZE FOR OS .95 AX 2 STROKE
- Muffler for OS 108
- Should ailerons move for pitch
- Helicopter Rx-Tx on airplane
- My own private moneycoat nightmare!
- Charging a nickel-metal hydride battery
- How to install propeller alighned with spinner back plate
- DLE-30cc in a Ultra Stick Lite 120??
- Venus 40 rolls when using elevator
- fox 4.2 engine problem
- Starter Brushes ??
- Converting Torqmaster to run on Nimh batteries
- Spektrum 7 channel questions
- O.S. 160 Slimline Smoke Muffler question
- amp draw of servos
- Plane to stay in small car ?
- First gasser, DA 50, help please!!
- Transporting in a pickup bed
- What side is
- Officially frustrated!!
- supertiger .46 g-21
- Zenoah 20ei hard to start
- ZDZ 40 ajustment
- Sig four star 60 engine with O.S. .91fx???
- Check Valve Question
- has top flite changed there monocote?
- R/C plane parade float. Anybody?
- Any tips to make sure i get this landing right?
- Nitro Models gone?
- 2.4 question
- RX battery screwup
- Mechanical retract setup
- HELP!! Problem Mounting Tailwheel Assembly... CUB
- 7 volt servos
- Airframe for ST-2300
- Cleaning Elapor foam?
- Super Tiger or Magnum
- RAM On-Board Glow problems
- tail dragger steering springs?
- Miracle Y ARE THEY OK TO USE ?????
- Plane for a G38
- Super Tigre engine problem
- HobbiCo Top Fueler Mark III
- Unknonw Cap 231 or 232?
- What if....Becomes What is.....
- Optima receiver antenna placement
- U-CAN-DO-3D 46 SIZE WITH AN .61 EVOLUTION?
- plane for 20cc gasser
- engine troubles
- OS engine trouble
- Foam transformer problem
- **Read Poll Question First (In First Post)** then make your selection! SILENT POLL
- Best way to fiberglass, whats your way?
- OS .40 FX Trust Washer
- This is not a question, this is an ORDER
- diregard this post
- How often to charge my DX-7?
- Battery discharge ?
- Super Sporster 90/120
- charger
- Engine Choice!
- Thin Ca Problem
- Solder Gun?
- charlie bauer
- Rust-Oleum....?
- 46 fx or 46 AX
- Weigh in scales
- x-tech
- Best fuel for Moki 2.10
- Hobby King DC Watt Meter Manual / Instructions and Sample Wiring
- Disaster! need help or advice
- Transfer tape for installing decals
- nose art
- transmitter case
- New shaft for Atlas Outrunner?
- how many gallons?
- Sullivan Dynatron wiring question
- Confused about Prop reamer
- HANGAR-9 DENIGHT SPECIAL 50 ARF - REVIEW
- Moki 2.10 what size fuel tank?
- new plane
- transmitter
- foamie hinges
- Has MonoKote formulation been changed?
- Hobby King TR52DV Camera Instructions / Manual Here
- tinting windsheild?
- How much runout is acceptable....
- extra 330s 140 arf
- fuel
- Unregulated Futaba 9252 & 9256 servos?
- Laser 200 83
- cmp extra 300s 140
- How do you CUT a carbon Fiber Spinner out?
- OS .91 4S won't run
- Steering linkage setup w/retracts??
- Saito 56 in my Sig Somethin Extra!!!!
- Just curious....which of the "Big Boy" 2-strokes is king?
- New to Ultracote Covering Questions
- Perry Smoke Pump Use
- ops 30 cc
- Spektrum DX7 range test failed
- Whats the difference ????
- TROLLS?
- Two way Y Valve ...
- Futaba 6EX 2.4ghz radio possible glitch
- Plane Plans
- Buying Spectrum
- pica duellist plans
- Engines for 1/10 scale B-17????
- Ultra Stick 40 Aileron & Flap Setup?
- Spectrum DX7
- onboard glow driver - need help!
- ross engines
- Gas:oil ratio...and I'm confused
- 120 ax plug
- flaps on 10C
- Problems with a dealer
- Hobby Zone Super Cub
- Bummed up aileron torque rod thread on strip aileron.
- Opinions for OS PUMPED engines
- Making pull pull hardware?
- asp .61 carb
- engine mount for a BGX-1
- what am I talkin about
- petrol engine
- Help, Mixed Up Fuel Jugs
- Can't see how to "edit" item I posted to sell?
- What spinner sizes for 12"-15" props?
- Gas Conversion
- BUSA Sopwith Pup and G38
- Batteries
- Standard servos
- custom exhaust
- Aircraft letterings
- Airtronics Servo Arms
- Wrinkled Covering
- are these good for wing tubes?
- Cost of the JR 9303, 2.4 and the Spektrum DX7, 2.4?
- FTL 50cc Engine Problem
- Old AM Radios?
- JR 8103 won't transmit
- building a starter pack
- right or left thrust?
- asp.61 carb problems
- Fuel for bushing engines.
- Help!!!!! please
- Flat Spot on foam wheel
- Looking for a 17x4 prop.
- Liquidation! Everything must go!!
- #11 Knife Handle?
- SOLARTEX COVERING
- World Models 200cc fuel tank - Fix?
- Onboard Glow
- Fuel Pump what wont leak after a few months
- F-117 Stealth
- Why so down on young guns?
- plane balancer
- crash nothing wrong
- Is there any company out there making replacement fiberglass landing gear?
- radio setups
- Magnum 120 4-stroke or Saito 100 in a Seagull Yak?
- build threads
- Am I right?
- Golberg Anniversary Piper Cub, What's my kit worth?
- CS-60's on tiger2 .60 ailerons...
- Fuel Proof Paint????????????
- 70" Revolver Engine Question
- AUSTIN TEXAS
- EXPERT ELECTRONIC,S ONBOARD GLOW
- excessive aileron play
- Engine cooling with cowl aircraft
- How big a problem is to much engine
- Testing Servos - Will I Damage them??
- Engine Cleaning
- vintage os 20 fly wheel
- Boy Scouts: Aviation Merit Badge
