PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. PLANE FLOATS
  2. Recommended Reading
  3. Ordering from overseas
  4. Seagull Edge 540 Engine
  5. 1962 Falcon 56
  6. Rc universe feature?
  7. esc switch
  8. Getting back into hobby - Best online suppliers?
  9. (3 1/4
  10. Hobby City Servos,, Need Info
  11. How do most of you shape a leading edge?
  12. Monokote How to best seal the edges from fuel???
  13. whats the value of
  14. Two Hanger 9 P-47 .60 CG questions
  15. Dual battery question
  16. Wing Struts - Necessary or Cosmetic?
  17. Corona 2.4 DSSS v2 use in Old JR Galaxy and Century Radios
  18. DIY servo extensions
  19. rc pilot figure
  20. balence point
  21. Crow setting.
  22. U Can Do Antenna Problems
  23. Panel Line Tapes
  24. Raven 40
  25. Smoke Oil Question
  26. Propeller Selection??
  27. Glow Fuel
  28. Is this "really" Ultracote?
  29. Receiver battery charging question
  30. ?Reverse Running OS61 FSR How-To?
  31. i need nitro engine coupous !
  32. How to build a hot wire foam cutter
  33. Tower Hobbies TS-35mg, are they strong enough?
  34. ARROW - LADDIE MIKULASKO
  35. Auto Cargo Pods for transportation
  36. hinge removal
  37. Warbird Colors vs Nelson Paints
  38. OS Pegasus FF320
  39. Airframe for an older ducted fan engine
  40. JR DS8511 at 6 volt?
  41. Retract/Door Valves - UP or Electronic ?
  42. shoestring canopy
  43. Mounting a Saito 1.20 inverted
  44. Converted weedwacker motor Question
  45. Switching servo signal or power on/off mechanically? OK?
  46. CHA Hobby Shops
  47. Any experience with "Hobby Discount Outlet"????
  48. Opinions wanted information appreciated
  49. miles reed" weeks bi
  50. Long Ez 60 Prop size
  51. 4-Stroke engine size recommendations?
  52. Spliiter for the battery
  53. Control Loss
  54. hinge fixing
  55. 4 stroke v 2 stroke equivalent
  56. lead time for retracts?
  57. What airframe for this 4-stroke?
  58. dymond rc
  59. Glassing Question
  60. 6 volts
  61. Ultimate Bipe C.G. ?
  62. Best Mini Van Bang For The Buck
  63. Plane for an Os 25?
  64. 4-40 linkage setup general question
  65. Smoke system ?
  66. Inverting a 4-Stroke Glow
  67. peakmodels
  68. Help w/ Fliton Extra 330S
  69. help me
  70. How do you organize
  71. table for start the airplanes
  72. m. what type of foam is the best
  73. Need replacement for Sorghum
  74. power system help
  75. Fly when it's snowing
  76. Removing weight from my Stick
  77. parkzones new indoor bi-plane
  78. Latex Paints
  79. McCoy .29 help
  80. Problem when adjusting Thunder Tiger engine. particulary, when adjusting Air Bleed Screw.
  81. Hitec optic 6 trim problems
  82. Replacment 72mh red flag
  83. Midwest AT-6 Texan
  84. Need help wiring
  85. retracts
  86. futaba 4yf transmitter battery voltage
  87. Spektrum DX5e Tx Throttle stick comes out
  88. RC alternator
  89. Fuel tank size question
  90. 6 volt battery spektrum AR 7000 and Gear
  91. Foam cleanner
  92. futaba fasst systems
  93. servos for my CG Ultimate
  94. Servo tray material ?
  95. Zenoa G26
  96. Fuel Proofing Sig field box
  97. Can't find part for GS45 Super Tiger
  98. Is my RX pack ok?
  99. Fuel Tanks
  100. help with spinner size
  101. Futaba 7C 2.4 Question
  102. rigth engine?
  103. zenoah egine
  104. How to prevent / avoid midair collisions?
  105. TowerPro servos
  106. Spray Systems
  107. zenoah 45 ignition upgrade help
  108. What about these?
  109. What are these?
  110. Looking for Santa Monica Hobby shops!
  111. LiFe batteries Lithium iron phosphate ?
  112. Don't know how to do this?
  113. Small butane torches
  114. Quantum Bomb Drop System
  115. McCOY Glow PLug for Webra 36
  116. Oldest Model you own
  117. BATERIES
  118. When Do You Need an OPTO ESC?
  119. PZ Foamy Messerschmitt
  120. Citabria Pro - Balsa USA
  121. Solution to servo play?
  122. bad compression/damage
  123. What kind of glue?
  124. saito 72 4c open or closed
  125. Gas/Nitro fumes in the house?
  126. RX pack duration??
  127. Can you ID this engine?
  128. how to size glow engine?
  129. Great Planes Extra 300S 40 ARF
  130. Find in my grandmothers basement
  131. glow plugs come loose
  132. WWI Prop Hub And Nut - What Company made
  133. Long EZ
  134. Broken Horizontal Stab.
  135. What is a HOW FAST, how does it work
  136. bluebird servos
  137. Santas Gift-new plane
  138. info on electrics i.e. motor size, esc's, etc.
  139. Siato 150 with Slimline Pitts......where does the nipple go
  140. stregth of balsa sheeting on foam wing
  141. Any idea what to do with extra wings?
  142. os 61fx & tuned pipe
  143. LIPO TX
  144. flaps
  145. Need help with biplane ailerons
  146. Should I be concerned?
  147. Gyro for ailerons & elevator
  148. 4 Stroke jam nuts
  149. I just want one more...all are NIB...
  150. how too rate a Hobby store customer service?
  151. Robart air up/spring down retracts won't lock down
  152. Servo size for 143" wing span
  153. Radio Dilemma
  154. Everyone has problems with the wife
  155. Hanging planes
  156. Magnum XL 1.20 queston
  157. 3-Blade prop for OS .46 FX?
  158. ENGINE SIZE
  159. OS .46 LA Blue issue
  160. Futaba 6ex 2.4ghz
  161. Tailwheel Control Rod Options
  162. Quique Yak 72"
  163. Bud Nosen Plans
  164. seagull models yak 54 .60-.90
  165. Saito 100
  166. joining servo wires
  167. Fiberglass cowl for 1/4 scale cub
  168. Dead Battery
  169. Flying Field Activity Level for Decade
  170. Ovel guide wires
  171. Converting Plans
  172. Servo Play
  173. Field Box Battery
  174. HowTo Repair Hole in Balsa Sheeting
  175. Radio issues
  176. How to compare motor sizes.
  177. 2.4 receivers and different brand transmitters
  178. Using Futaba crystal in a GWS 8 ch rx
  179. HELP
  180. Master Airscrew props
  181. Is it broken or not?!?!?
  182. Biplane help
  183. Macs Pumpless Smoke Valve/ System
  184. Does LustreKote match Solartex
  185. Pressure Tap in Sport Muffler Question
  186. Have any one used tiny brite lights 911
  187. K&S Mightly wire bender/coiler
  188. 1980's Scout Low Wing Trainer
  189. COVERING WITH FABRIC
  190. Hobby City?
  191. Hobby King Quattro 4 x 6s Multi Charger
  192. Battery for older TH mini-tach?
  193. scale decals for 1/5 P-51D mustange
  194. Looking to up grade to 2.4GHz
  195. Super Tigre question
  196. Biplane Wing Loading
  197. Anti-JR Cap
  198. 2 blade same as 3 blade?
  199. Super Tigre question
  200. hs 81 good or bad?
  201. Turnigy servos
  202. Sparmann P-1 Drawings
  203. Recovering a plane .... control surfaces.
  204. I think I made a score!
  205. Kraft engine question
  206. fuel tank position and pumps
  207. Clear Labels for decals?
  208. DLE 111 Engine
  209. *EMS Charge Switch Issues*
  210. Tower Pro .46 advice
  211. Enya 15-III model 3303
  212. Buddy Box question
  213. tower hobbies 75
  214. Electric motor/esc timing?
  215. Paintball Dropper Idea
  216. How do you transport your models?
  217. ATLAS BRUSHLESS MOTOR MOUNTS?
  218. Pin Switch
  219. my post locked?
  220. hughesnet ripoff
  221. Balsa USA Smoothie
  222. Royal .28 info needed
  223. 2.4 ?
  224. Nexstar EP power Change
  225. hanger 9 sopwith camel take off
  226. Nicklen Metal Hydride overcharge question
  227. Lipo questions
  228. nitro planes ultimate 40
  229. Want to Change out Wheels on OV 10 Bronco
  230. saito engines
  231. What rate should I be charging these at....?
  232. ESC programming changes. No comprendo
  233. How to Remove Water Transfer Decals from Foam
  234. finding replies
  235. Help what is this?
  236. 100" Big Stik Saito FG36
  237. Painting foam
  238. Servo Compatability ? ? ?
  239. YS 4 stroke fuel
  240. what batterys to use for a 50cc plane
  241. what engine is this
  242. aileron servo wires?
  243. rx antenna wire
  244. Stuck LA 46: …….When anti-freeze does not work
  245. R/C flying in Oman
  246. Aerovate gas engines ??
  247. Weatronic programming problem - delicate
  248. How Do You Loosen Up Robart Hinge Points
  249. muffler temp ???????????
  250. can i trust this RX battery?
