PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. How Do You Loosen Up Robart Hinge Points
  2. muffler temp ???????????
  3. can i trust this RX battery?
  4. RC Home Owners Ins.
  5. Want a new 2.4 transmitter...Help me decide!!
  6. converting glow to gas
  7. Engine for GP reactor biplane
  8. 2 stroke glow engines by david gierke and Power beyond the basics volume 2
  9. What the heck does a Hott look like????
  10. Flycamone2 battery?
  11. TF P-40 Spinner/Propeller
  12. motorglider for .30
  13. WHICH RADIO TO BUY????
  14. prop measurement
  15. Zip ties on fuel lines?
  16. Wiring and electronics questions...
  17. Reactor Prop choice
  18. Matching ESC with motor size
  19. Flair Puppeteer
  20. Proper Use of Great Planes Slot Machine
  21. Is there a real need for a power system in a 30%?
  22. On-board Starter
  23. Are there elevator pull-pull systems?
  24. This is my last question
  25. Thread Direction (LH or RH) on Ball Links ?
  26. Name that plane!
  27. Hotter muffler for better smoke?
  28. gee bee r2
  29. Servos for 87" yak
  30. Lipo Receiver Batt, Spektrum Receiver and Servos?
  31. Saito 220A vs OS 200 FS
  32. radios
  33. Hanger 9 Funtana 125
  34. flaps and flaperons
  35. Advice Please
  36. BEC or no?
  37. Plane for onboard remote starter and floats
  38. Pilot needs painting/what colours?
  39. Dual Receiver Switches
  40. Mounting kit for Alpha 250 ??
  41. Can I drill a TRU TURN backplate???
  42. dumb question...
  43. Nitro or Gas?
  44. clear domes and engine cowls
  45. How to set up dual elevator with AR6200?
  46. Glued WHAT together ???
  47. Saito valve setting help
  48. What Biplane is this?
  49. Another Radio Question...
  50. I'm looking for a Goldberg Staudacher canopy
  51. Balsarite Fabric
  52. BUD NOSEN MR MULLIGAN & AERONCA 60
  53. Inverted mounting of Saito FA-82a
  54. using incident meter
  55. matt chapman eagle 580 , good motor for 3d?
  56. EXTRA 300
  57. Can you heat and bend Carbon Fiber gear????
  58. Electric Airplanes for Dummies
  59. Trouble starting an OS 70 4stroke Surpass
  60. beginer elecrtic setup ???s
  61. Old Monocote type covering removal
  62. Spinner backplate adaptors
  63. What Servos should I use in 71" YAK???
  64. Threw a prop and now.........
  65. What's the benefit of 2.4ghz over 72mhz?
  66. negitives to running just castor/methanol?
  67. external glow plug setup
  68. How to, stiffen wire pushrods without adding too much weight.
  69. Coverite vs Solartex
  70. DuBro Tank
  71. os fs-91s
  72. Flying field size?
  73. 12 volt air pump for retacts
  74. nitro car engine on Stryker?
  75. Futaba question
  76. Buffing/sanding Nelson's clear
  77. Calling South Missouri Flyers
  78. Clearing Enamels ???
  79. *Portable Starter For Gas Engines*
  80. messerschmitt 109g battery life
  81. help track down who bought flair
  82. Chmodel?
  83. trimming airplane in flight
  84. receiver antenna
  85. parkzone me 109 parts
  86. Pactra Formula U Paint
  87. Gas engine for Top Flite Cessna 182 ARF?
  88. Magnum 70 RFS 4 stroke engine
  89. landing inverted
  90. Dual Airlerons
  91. e-flight esc fix
  92. Radio Problems
  93. Radial Engine Questions
  94. Prop Change
  95. Question about engine location
  96. Brushless motors
  97. Beginner plane kits
  98. gee bee cowl
  99. KARBONITE GEARS
  100. oops, 75mhz
  101. Any diagrams?
  102. How Many Gallons of Glow Fuel Do you Burn Up in a Year?
  103. Thunder Tiger GP .07 ABC
  104. Problems with saito 56 4 stroke
  105. Acceptable wingloading
  106. Balsa grain direction
  107. Great Planes Sequence F3A gas conversion
  108. Secure payment by Paypal, think again!
  109. Rhom air retract leaks
  110. fixing prop
  111. Can I spray PVA glue?
  112. 55AX quits
  113. Radial Engine Glow Driver ?
  114. Need suggestions for a plane
  115. Any decent .46 size Biplanes?
  116. Engine for a Goldberg Wild-stik 120
  117. Linkage
  118. O.S. 26 FS Surpass
  119. HiTech Aurora 9 info/opinions
  120. whats my flying style??
  121. Heat Shrink Fabric?
  122. Tower Hobbies
  123. U-Can-Do 3D, fuel foaming issue.
  124. Need to find C.G. on a Midwest Giles 202
  125. Motivation
  126. redundant receiver batteries, question
  127. Balance Lanier P47???????
  128. 3s Balance lead on a 2s Pack?
  129. Knox Hobbies?
  130. Need help choosing correct engine
  131. RC Field Box identity
  132. Muffler bolts
  133. preparing part for mold
  134. Weight of cured glue
  135. Bill Effinger Aeronca C3 plans
  136. seidel st-996 radial engine
  137. Radio Question
  138. Beside Tower Hobbies
  139. Convert a 50Mhz Radio \ RX to 72Mhz??
  140. finding the cg of a bplane
  141. charging new radio
  142. Transmiter info
  143. Glow to Gas
  144. Giant shop cradle
  145. Monokote over the Solartex
  146. Mystery problems?
  147. Wings or no wings!!
  148. thunder tiger 54 4 stroke
  149. Where to buy methanol for custom fuel mix?
  150. Tracking a Tower Hobbies order via an airway bill number?
  151. batts
  152. ARF and kit builders poll
  153. CMP Corsair 1.20
  154. G-mark .30 5cylinder radial glow engine
  155. Need servo reverse -y-Harness no amplfier
  156. boxer motors
  157. Knocked tip off 9303 antenna, can I still fly??
  158. Smoke system for electric power aircraft
  159. Retracts and CO2
  160. Can a fuel tank be mounted on it's side?
  161. JR Channel Expander Battery
  162. Using auto parts washer to clean engines?
  163. Hitec Micro 05S in a nitro plane?
  164. Under carriage replacement
  165. What brand of engine is this?
  166. LHS Have no stock
  167. Pull Pull servo placement
  168. 83" AT-6 pilot bust size
  169. Indoor flying club
  170. futaba 2.4ghz radio users
  171. Pnuematic Retract Oil/Lubricant
  172. flycamone2
  173. RADIO!!??
  174. Airtronics Stylus 2.4GHz conversion
  175. Tail Wheel Recommendation
  176. does anyone else make a fuel regulator?
  177. Help me figure out this mechanical advantage in the servos
  178. How do UP2/UP3 Air Valves Work?
  179. Light-Weight Paint Over Nitrate Dope
  180. Life of Unopened/stored CA
  181. Robarts, with an extra helping of dirt
  182. Full Scale Aircraft wing loading??
  183. magnum xl52 4-stroke
  184. OS 120 III 4 st. W/Pump Exhaust adapter
  185. Test Stand
  186. Trim solvent on canopy ...
  187. Field Strength Meter
  188. Colors?
  189. Caution about importing from China
  190. Which brushless motor/speedcontroller will work with a plane AND a car?
  191. Flying rc planes in Muscat(Oman)
  192. Can It Be Fixed
  193. Where to find rudder covers and elvator and prop covers for reasonable price
  194. hatch pin
  195. Transmitter
  196. 18 oz tank
  197. CF Wing & Stab. Tubes
  198. Spinners for 3 blades props
  199. Pushrods
  200. low bounce wheels
  201. Help with prop sizes
  202. Plane power system for engineering project
  203. SUPERTIGRE 3250 NEED HELP
  204. Center of Gravity
  205. engines...bringing them back from the dead?
  206. Top flite LustreKote Missile red
  207. Fuel Tank Question
  208. Two Stroke Question
  209. Linking Futaba 2.4 to new receiver
  210. Do people ever ask if they can try your airplane?
  211. Building Stealth UAV
  212. GOOD SOURCE FOR 12V POWER SUPPLY
  213. fuel tubing size
  214. Ultimate 90 to Gas
  215. Grpro engines
  216. Airborne battery for Spectrum radios
  217. How much to charge for designing new plane kit
  218. Airspace warning alarm for model aircraft.
  219. sticky epoxy
  220. revovering a profile. Please help
  221. Landing with Crow
  222. Super Tigre G21-46
  223. Model Tech Magic Extra ARF - 40
  224. Motor to use?
  225. RX Channel Sharing with RX Battery
  226. Jr, Futaba, Hitec WHAT!!???
  227. Transporting a plane in a Car
  228. UP-3 Gear/Door Sequencer
  229. Servo Travel with UP-3 Retract Valve
  230. O.S. 1.60FX Hard to turnover when cold
  231. Black Horse Katana
  232. gas eng looking
  233. Help with illusions - micro telemaster
  234. Anything like a Norvel 25 out there?
  235. Painting ARF - Surfaces with Clear Coat
  236. Stuck Carbs
  237. Any disadvantages to engines without cylinder liners?
  238. ca hinge with epoxy?
  239. Bonanza Beachcraft info
  240. Paint masking doesn't work out.
  241. Mounting tuned pipe. On Little Toni ??????
  242. FPV Problems
  243. Supertigre G2000
  244. General question about prop pitch and diameter.
  245. Storing a Plane in a Garage - Northern (Think Winter)
  246. full scale?
  247. storing a rc plane in a gargage
  248. Question regarding dies
  249. An OS 120 Exhaust question
  250. Saito carb
