PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. How could I identify Ultracote from Monokote?
  2. H9 P47D 150
  3. Seagull Models Spacewalker I
  4. Right Thrust Needed?
  5. Replace batteries or the whole radio
  6. BATTERY SET UP
  7. mixing paint products
  8. Strengthening internal structures
  9. getting the right size photos
  10. R-600 receiver problem
  11. OS FP .15 Quits in Air
  12. Horizon Pricing Drop!!
  13. 3W 157qs
  14. Who builds high quality ARFs
  15. Things to ponder
  16. Airborne models ?
  17. Monokote / Ultracote Pantone PMS Codes
  18. Black Widow Video
  19. Charging and cycling questions
  20. How do I know when a plane is level?
  21. engine power
  22. Manufactures Section
  23. Looking for Non Tapering Engine Mount
  24. Pulse XT 125
  25. Primer for Nelson Hobbies' paint?
  26. Motor problems OS FS 120 on 1/4 cub
  27. SERVO CONNECTOR KEEPER/LOCK
  28. Biplane N strut attachment
  29. GOLDBERG SUKHOI /SAITO 180
  30. Seagull Extra 300 S Cowl
  31. JR X-347 Battery Problem
  32. Super Tigre G 60 Bluehead damaged
  33. JR 9X II question
  34. SERVO OUTPUT ARMS
  35. Saito Radial Engines
  36. Any tips on getting new control surfaces to move easily?
  37. 2 Pushrods to 1 Control Horn
  38. Futaba connections
  39. Older Hobbico charger?????
  40. Air Retract Question...
  41. Evolution 60NX help
  42. Card V Fuel Tank Location
  43. Low end setting on Tower 61
  44. OS 26 FS vs. OS 30 FS
  45. Electric to Glow Conversion Forum????
  46. Why aren't there more ARCs in the market?
  47. Fuel tank location problem
  48. plans
  49. Problem of RPM's on Saito solved
  50. spektrum module for futaba 14mz
  51. What’s up with Tower?
  52. AIRPLANE/TAIL HOLD DOWN-NEED HELP???
  53. Futaba FASST rx R6014FS vs R6014HS
  54. How far is your field from your home?
  55. JR8103 Dual Elevator Servos with AR6200
  56. Prop spinner
  57. *Hobbico Digital Voltmeter MkIII*
  58. where to buy
  59. seagull extra 260 180sized
  60. Clancy Aviation Stagger Bee plans
  61. GP electrostik on floats ?
  62. CA or Epoxy
  63. heavy hub propnut
  64. goldberg jungmann
  65. making checkerboard patterns
  66. RCM Trainer control surface throws?
  67. A few questions concerning my first build
  68. NEED HELP PROGRAMING FLAPERONS
  69. os 61 fx fuel delivery problems
  70. SC52FS MkII (How to tell from MkI ?)
  71. Will a muffler melt a nylon engine mount?
  72. idle needle on os 25
  73. ASP engines
  74. Cutting Shapes in Monokote
  75. Easy question 4.0v and 6.0v how low?
  76. GP Christen Eagle Fuel Tank Options
  77. JR XP9303
  78. Pictures of a twin cylinder 2-stroke engine crankcase and crank?
  79. Supertiger engine in a cowl
  80. Smoke System for Midstar 40
  81. 3rd Line on Tetra Bubbless Tanks
  82. Scale question
  83. Suitable model weight for OS 200 FS
  84. Raven pattern scheme
  85. chartpak tape size for panel lines
  86. range of Futaba R6101hfc 2.4 rvcr
  87. gms .32 engine problems
  88. gms .32 engine problems
  89. What engine to get
  90. Evolution 58 Power ?
  91. Thinning Out The Hangar, Etc
  92. Any good ideas
  93. HELP!!! Receiver or trasmitter problems? I need advice please!!!!
  94. Need help!!! how to convert 14mz 72 to 2.4ghz
  95. Zenoah G-20 Won't Idle
  96. Servos
  97. great planes extra 300 .40 size question (pre-build)
  98. do you own a car just to transport your planes?
  99. Odd Question
  100. Shelf live for model gass?
  101. Fabricating, hardening and tempering wire landing gear
  102. Bumpy Landings
  103. TAMia COLOR spray paint, is it glow fuel froof?
  104. Flying Weight to Wing Area
  105. Insane picture size
  106. brushless upgrade question
  107. Fiberglass cowls
  108. Bendable muffler tubing
  109. ANTENNA BOBBIN
  110. Magnum xl 70 spitting fuel
  111. Need help with elevator only glitch while engine is running.
  112. How do you hang/store ur planes?
  113. Painting roundels question
  114. SAITO 56 INVERTED
  115. Stuck aileron
  116. devarnishing glow engines ???????
  117. Looking for 4" Spinner
  118. Tank setup issue...What are my options??
  119. Gas-proof flat clear for protecting acrylic paintwork?
  120. Solder issue.
  121. Do You Guys Think This Is Real???
  122. Best Way To Measure Engine Temperature
  123. super tiger .60 help
  124. Pusher Prop New, but 30 mins later & ovaled out? *Help* What did that?
  125. Yak Gasser
  126. best first gasser?
  127. p-51 mustang
  128. OS FS 61 4 four stroke specs???
  129. identify foam rc plane please
  130. possible a bad reciever
  131. recovering
  132. what engine?
  133. COMPUTER RADIO MIXES
  134. *How To Remove Epoxy*
  135. FL70 OS?
  136. Hardening Balsa
  137. Rudder Diving
  138. 2nd plane thoughts?
  139. I need more power! Muahhahahaha!
  140. LED lights for planes from hobby city
  141. Identify this Plane
  142. Escapade vs. Pulse XT
  143. Super Tigre Muffler question..
  144. optic 6 sport
  145. I lost my RCU tool bar. Where can I get it?
  146. Will an OS40LA need valve assm. fit a OS46AX?
  147. Denny JR airplane kit
  148. How does one determine the control horn location?
  149. Best Fuel Line
  150. Source for large wire wheels?
  151. Can anybody recognize this model?
  152. Heli Engine in an Airplane ?
  153. 3 blade prop for OS 52 FS
  154. Old pictures to share. Can you ID these?
  155. 100 inch Big Stik
  156. Hanger 9 cub with OS 70.
  157. SAITO ENGINES
  158. Fliton store USA problems
  159. Sealing a fuel tank fitting
  160. MDS 2.18 Engine
  161. 14 Pound P51 mustang
  162. RETRACT QUESTION ....
  163. RPM's on four stroke?
  164. OS 120 III 4 stroke W/pump
  165. saito prices
  166. os 70 fs camshaft delaminating
  167. Sureflite P39 Foam finishing?
  168. crankshaft end play
  169. cessna 150
  170. This is weird...
  171. O.S. 91FX Ringed Adjustment, Not sure Please Help
  172. I need your help - GV V2 Series Cobra 1/10
  173. 2.4 model memory
  174. battery info
  175. Should I buy a case of castor fuel for 30 bucks. need advise on useing castor nitro in a .46 2cycle
  176. How to trim a retract servo ?
  177. Mechanical Retracts
  178. Sheet metal and MDF
  179. On Board Glo Igniters
  180. Removing Wrinkles from Flat Sprayed UltraKote
  181. Horizontal stab removal after its been ca'ed
  182. How many have flown a GeeBee, and not nosed it over
  183. YS FZ91 Bearings
  184. Rotary tools.
  185. ready to but how?
  186. manually control speed
  187. flycamone question
  188. Saito 182 twin ignition problems
  189. Lucy Speedy 2 meter sailplane
  190. What spray paint to use on Koverall
  191. looking for certain nosegear
  192. Twin Electric Motors
  193. Lipo RX battery pack
  194. Batteries?
  195. Fill Valve for Spring Air's
  196. Saito 130TD Twin
  197. student
  198. Sukhoi parts help
  199. Looking for a trainer
  200. Nitro Planes
  201. help choosing hi tec servos
  202. EMS Jomar Digital Airspeed Indicator help
  203. clear coating
  204. Engine RPM perfmance data?
  205. Wing loading?
  206. Circle Cutters for MonoKote/UltraKote
  207. Saito 100
  208. Spektrum AR6110 Parkflyer Rx
  209. on board glow/backup rx battery?
  210. Question about gas to oil mixture........
  211. Radio memory?
  212. Great Planes Christen Eagle set up help?
  213. JR Propo 2.4 GHZ Control
  214. Futaba 12 fg
  215. Solar Battery Chargers
  216. Magnum .91 4-stroke starting problems
  217. CG Calculation for Mystery Plane
  218. OSHKOSH 2010
  219. Foam core wing sheeting
  220. Highly visible lights?
  221. Older Evo 100 question
  222. Limited servo movement on new Aerobird 3 with video.
  223. OS 61fsr abc problem
  224. Expert Electronics Servos
  225. 62 Saito with smoke???
  226. Help ID these engines please!
  227. Vintage planes in boxes
  228. JR 2.4 9303 Internal Noise (Sound) Within...
  229. Looking fo lanier Mariner
  230. OS Wankel Info?
  231. Where to buy Airtronics 2.4 Rx?
  232. Plane Identification Assistance
  233. Gas engine problem
  234. servo synchronizer question
  235. fried esc or motors? help!
  236. Question about JR 2.4 in Europe
  237. For Sale???
  238. Night Flying
  239. CA glue on cloth
  240. oc engine problem
  241. Aeromaster Sp/Bipe 48"
  242. Irvine Manual
  243. Seagull 260 rolls to the right.... Help
  244. MATCHING MISSILE RED MONOKOTE TO ULTRACOTE
  245. Which paint for trim work on a nitro model?
  246. Transmitter and receiver help!
  247. evolution engine wont stop running
  248. 11.1 Lipo battery in TX
  249. EP to GP
  250. Fixing a glow fuel soaked fuselage
