PDA
View Full Version : Questions and Answers
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Piper Seneca ll cowls
  2. Gyro Mounting
  3. Engine choice help for 1/4 world models air tractor/pawnee
  4. Replacement Carb for NovaRossi R26CR Engine
  5. best glue for carbon fiber rods
  6. Compression
  7. Find Appropriate Spinner for Folding Props
  8. Venus fuel tank
  9. Are fuel tank mounting curious ?
  10. Nitro help
  11. Balsa USA Fokker D8 crash
  12. Please ID old plane
  13. 120 Saito Glow to Petrol
  14. Wing tube supplier
  15. Looking for OS Manual
  16. Wanting to upgrade from Hobbyzone Champ
  17. Northrop Special is real?
  18. user guide
  19. Great Planes US .60 help!!!!
  20. Pilot stations
  21. 7 ch spectrum vs the gya gyro
  22. Testing Ultracote
  23. Old Fabric
  24. Transmitter battery packs
  25. ch ignition pickup
  26. battery for MC-20
  27. pacaeromodel starter?
  28. 4 cycle glow plug
  29. A Pound of lead!!
  30. DLE or AGM Carb
  31. Online RC store- - any reviews?
  32. First warbird
  33. is it nose heavy or tail heavy or something else ??
  34. TF P-51 60 ARF Retract Servo Horn Broke While Test Taxing
  35. charging nimh battery packs
  36. Pinout
  37. No electric to HS-81 aileron servos. Is the wiring too thin and/or too long?
  38. Lateral balanceing
  39. Tech Aero IBEC interference with Electric Retracts?
  40. OS 1.20 pumped too small?
  41. Too old?!
  42. Robart Electric Retract Actuator Repair
  43. Lanier canopy?
  44. Os-fs 1.20 four stroke question
  45. Dow hight load 60
  46. ESC use for BEC
  47. Bec with led lights
  48. Threading rod
  49. covering raw balsa wood
  50. Measuring CG on a symmetrical wing.
  51. OS .65 AX break in
  52. WIG Question
  53. OS 25 Trouble
  54. Forula for determining engine size?
  55. Vintage seaplane
  56. What size nut fits this Dubro ball link?
  57. Drilling holes in the leading edge of a wing
  58. need plans for glow variant airplane
  59. Mixing 20% oil FAI fuel
  60. Hi tech HG3XA gyro Help
  61. Hobbico Twin Star Narcelles
  62. receiver and ignition sharing same battery
  63. Rcexl kill switch good or bad idea
  64. low voltage for lipos
  65. saito FG 11 gasser
  66. Fokker DR1 (Neighbors, 1981 film)
  67. Zinger Propellers.......Are They Still Around?
  68. Plane wants a bunch of nose weight
  69. de-bonder for c/a
  70. Rc canopy help
  71. Heat Shield Covering for Tygon Tubing
  72. AS3X Stabilization on EFlite Two Servo Brick
  73. electroinc switch
  74. Looking for a auto pilot (fixed wing)
  75. CG calculation site
  76. Curtiss AT-9
  77. Warbird Flier
  78. paint to work with TF paint
  79. Which is more powerful; Y.S. 1.20 or O.S. Gemini 1.60?
  80. Prolonging life of cyanoacrylate
  81. Engine oil 2 stroke
  82. 9C gyro switch assignment
  83. Radio/Control issues with servo extensions.
  84. Balsa USA Smoothie
  85. Skyarttec cessna 182 motor
  86. Post pics of your flying field, either aerial camera or google maps...
  87. Balancing dynam crop duster
  88. Kraft wheels production rights?
  89. Suggestions On How Can I Convert my Model over to Fixed Landing Gear.
  90. 4 stroke gas vs 2 stroke gas
  91. Mechanical Retracts For Corsair Models?
  92. Styrospray 1000
  93. enya 25 help
  94. Off brand radio equipment
  95. Fuel resistant paint
  96. Visiting East Coast USA
  97. Bridi 4 Seasons 40 CG location
  98. VQ Turbo Porter external tanks
  99. FUTABA TM-FH Module FHSS...Does it worth it to upgrade?
  100. prop hubs and motor mounts
  101. Desert Aircraft
  102. O.S. MAX 40 FP carburetor settings
  103. Flap Mixing
  104. OS 25 FX Running Hot
  105. Vtol build
  106. Ever taken apart an OS 46 ax ?
  107. Odorless thin CA vs regular thin CA setup time
  108. How to switch channels on a transmitter or a reciever
  109. Ground Handling on a Super Stearman
  110. voltmeter
  111. Klass Kote Clear vs. Automotive 2k for hardness
  112. elevator not going back to center?
  113. Have you loved your trailer lately?
  114. Recommend a 20cc plane
  115. JL Power Products Easy Rider Stand
  116. Unknown airplane engine
  117. HELP? What Flying Wing?
  118. Color changing covering?
  119. eflite yak54 loose rudder servo
  120. SPE 40cc question
  121. Spektrum AS3X newbie questions
  122. sale event
  123. H9 8cc p51?
  124. OS .70 Surpass
  125. Motor for Kavan FW 56 Stosser
  126. Rehabilitating Sig Spacewalker
  127. Magnum 52 4 cycle runs on
  128. Mah
  129. Engine differance
  130. Oracover Bordeaux Red
  131. battery and charger question
  132. Heavy oil from muffler
  133. dave brown big lite wheels?
  134. Retract Slop
  135. thunder tiger parts
  136. 6 volt 2500 ma nimh battery packs
  137. bal point or plane ID
  138. 540 edge
  139. Robart Ball-bearing Right Angle Drive
  140. Life battery
  141. Bi-plane CG
  142. receiver padding
  143. Big stik
  144. Magnum 52 4 cycle
  145. Field flight box
  146. CG On Balsa usa EAA Biplane
  147. Last issue of High Flight
  148. Aero Pro G-Shark servo question
  149. Where to get Ultracoat Matching Spraypaint
  150. glo plug for gas
  151. DLE 20 and DLE 20RA Carbs
  152. extending throttle arm outwards?
  153. total loose of the plane - Makes sense?
  154. Swivel Ball Links - How Tight?
  155. step wing
  156. Motor twitches only when propeller is on.
  157. Eagle Tree Guardian: How does 2D mode work in detail
  158. Can I do this to a wing tube and be OK
  159. twisted wire harnesses?
  160. LIPO replacement for NICD transmitter battery pack ??
  161. How old it too old for electronics
  162. Propeller and motor compatibility
  163. Do-Bro low bounce wheels
  164. futaba 9c?
  165. Hangar 9 Katana 50
  166. anchoring antenna
  167. dx7 TX antenna?
  168. Seagull Superdave MX2
  169. battery for gas engine
  170. Purpose of Side Port on AR636 Receiver?
  171. Retrect
  172. Pusher prop set-up help
  173. receiver placement?
  174. Jr futaba control arms
  175. Retracts
  176. hanger 9 2 cycle super plug ???
  177. installing 2.4 RX
  178. V-belt
  179. magnet storage
  180. ok so what 12 volt power set ups do you guya use for at the field charging?
  181. Sealer for nitro exhaust????
  182. Hobby King Covering
  183. Gasoline 1 gal can needed
  184. JR 9505 Programming
  185. retracts
  186. Found good replacement pick and pluck foam for Hobbico double transmitter case
  187. Ohio RC Ultimate
  188. What happen to the screen?
  189. how to set up a 2 airtank retract system
  190. Pitts style muffler
  191. Paint to use for prop balancing.
  192. Need help with a prog-card for motor
  193. Retracts
  194. 300 Glow Twin Question.....
  195. Color Coming off UltraCote
  196. Inexpensive receiver alternative for Futaba 2.4ghz
  197. Glow Plugs
  198. Iron socks
  199. pre-setting servos?
  200. CG changes
  201. 18 X 6-10 propeller questions
  202. I need to know what size prop adapter nut do i need for a evolution 1.0 ?
  203. how do you cover a foammy
  204. fg 14 satioand smoke
  205. FUEL questions
  206. taildragging a Sig Kadet Senior?
  207. Flatten rolled drawings
  208. fuel mixes for nitro engines
  209. Fuel mixes for nitro engines
  210. removing 30 min epoxy
  211. paint spray for depon or foam?
  212. What size engine should I use?
  213. Kissimmee Cloud Dancers a/c ID?
  214. Wanted,sourde for plans or kit of eagle model
  215. Anybody flown a Seniorita with ailerons & full dihedral?
  216. Quality of Control Rods:
  217. What is it........please read on
  218. symetrical wing servo mounting
  219. Need help setup FPV system in Dynam Beaver seaplane
  220. Dual Elevator Setup..Help!
  221. twin cyl. air make up
  222. dx7 question
  223. Is it possible to get telemetry on Apprentice S 15e and keep SAFE?
  224. Eflite Retracts
  225. who makes this yak 54
  226. Thinking of starting a club
  227. balancing a biplane
  228. cutting ARF
  229. DLE 20 RA spark plug
  230. Flying fields around Tampa Florida.
  231. Robart Retracts
  232. O.S. FS-61 Rebuild
  233. correct battery for T9 CAP RADIO?
  234. general question on endurance
  235. looking for parts
  236. Dont know
  237. Magnets & RF Interference
  238. What is this---name and info
  239. DX7 Radio set up
  240. Remove tightened collet from Turnigy D2830-11 1000kv Brushless Motor
  241. 1934 meteor
  242. Magnum xl engines vs Magnum xls engines
  243. Little Dipper plans
  244. airobird xtreme
  245. smoke system adjustable clamp
  246. Where to fly in south eastern Columbus Ohio?
  247. greatplane 300 extra kit
  248. Can someone identify this plane?
  249. FPV 49 flying wing
  250. Props
