PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. 11.1 Lipo battery in TX
  2. EP to GP
  3. Fixing a glow fuel soaked fuselage
  4. Eating glow plugs
  5. Need a bulletproof nose gear
  6. Aviomodelli Cessna skymaster
  7. Prop for OS 1.08 2 stroke
  8. TDL MODEL SYSTEMS EXTRA 330L
  9. Need help spraying clear coat on Latex.
  10. New Zealand Aero Products??
  11. What filler for ABS plastic??
  12. Battery help??
  13. 6.0v?4.8?
  14. Do the adaptors come made for American Sockets??
  15. Determine Plane for Known Elec Motor
  16. Help identify planes as need cowls
  17. Setting Up My Idle
  18. RadioFrequencyInterference
  19. Hangar 9 Ultra Stick 40 size
  20. A Question Of Aerodynamics
  21. Cleaning plane
  22. r/c airplane club in Newburgh NY
  23. 91fx
  24. The name for this tx mix?
  25. Ironex
  26. OS 60 FP
  27. 12v Computer Power supply use?
  28. what is needed to charge lipo batteries?
  29. ys DZ170 muffler
  30. Why does my nitro engine not work?!
  31. L-19 flaps
  32. storage
  33. band saw or scroll saw
  34. es100/s3003/ts-53 servo question
  35. small batterie for 9 servos?
  36. Aileron set up
  37. OS 200 for SIG 1/3 Scale SPACEWALKER?
  38. Charging and cycling with regulator
  39. Please Identify this Airplane
  40. A&M Aircraft Eng.
  41. Removing Fabric Covering
  42. Check your Batteries
  43. opinions wanted
  44. Long-term engine storage
  45. Filling balsa?
  46. DX7 dual ailerons and flaps
  47. Backup RX battery question....
  48. zenoah G-26 air
  49. Anyone use the Finer Edge starter adapter?
  50. Has anyone built on glass?
  51. Sport or Pattern Prop?
  52. Prop selection?
  53. 1st place engine sig 1.3 parts
  54. GP Extra 300 SP engine
  55. Charge leads for Spektrum DX7 TX battery.
  56. saito 100
  57. Adding a GYRO to an airplane
  58. RC Battery Clinic
  59. futaba vs jr throttle
  60. Proper way to use CA glue?
  61. CA glue
  62. AFTERMARKET RECEIVER FOR CONQUEST FP-4NL AM 72.590MHZ MODE 2
  63. os 120 fs exhaust
  64. FUTABA 6EX-2.4
  65. HARMONY ROCKET
  66. Rx batterys for electric setup
  67. Sig on TowerHobbies
  68. Question about T10
  69. Whats the Likleyhood?
  70. Thrust to weight Ratio on GeeBee Z
  71. large scale pitts python
  72. Engine/Tank Siphon question
  73. Beaver KMP on floats with evolution 40 cc
  74. OS 46 FXi Muffler
  75. Saito 72 throttle arm position
  76. piper j3 cub
  77. 3 Blade prop question
  78. What aerobatic model this is?
  79. Saito fa 8- prop hub/nut size
  80. Futaba T6XA manual?
  81. 3S LiPo Packs in Transmitters
  82. What is the maximum per cell voltage?
  83. Jigs for making procution rc airplanes
  84. What is this 44cc?
  85. Sebart Katana 30 wing set
  86. ASP Engines/Servos
  87. Battery load
  88. Stuck carb screws
  89. Aileron EPA ?
  90. Telemaster wing
  91. Wood Prop Compression
  92. giles 202 wing tube
  93. OS .46 LA Surging Problems
  94. custom exausts and sounds.
  95. Anti vibration washers
  96. Nylon Wing bolts
  97. Down thrust and CG adjustment
  98. *Epoxy Over CA*
  99. Zenoah G23
  100. Where can I find specs for old ASP .61?
  101. what planes for a .30 four stroke
  102. Ok to Modify a prop??
  103. Cermark SPE43
  104. 2.4 buddy box problem
  105. Sig where are you?
  106. Spektrum DX6i Radio set
  107. need help to set up a gyro
  108. Futaba T4NBL
  109. Pheonix Decathlon Windshield
  110. Would it work?
  111. gyro and a cub
  112. Expensive vs Cheaper Motors
  113. Gluing control horns
  114. Kaos 40 - old timers used what engine
  115. Aerobatics Training (Video, DVD?)
  116. best 9 channel radio?
  117. What's the deal with Ripmax
  118. Scratches on spinner
  119. Special liquid to waterproof your electronics?
  120. question about props, those with half numbers
  121. Hiding Balsa Structure Under Solartex
  122. Can anyone identify this plane?
  123. Saito 180 smoke ?
  124. ASP .61 or the O.S. .65 LA?
  125. Corona 2.4Ghz Futaba Module & Rx (V1 DSSS)
  126. Buying Futaba 10CG from Hong Kong?
  127. Engine noise level questions
  128. OS 7L Carb. Exploded View PLEASE??
  129. Custom Woodcraft Flight Box - Measurements
  130. kyosho spree
  131. OS 46 LA Loose Screws
  132. Dissapointed in OS service
  133. Miss budwiser boat...Please Help
  134. CG Question
  135. Gyro help
  136. Oiler expert for 12 to 15 os and saito engines
  137. Help selecting a prop
  138. Prop help Please
  139. kmp dauntless cg
  140. Tappet Valve Adjustment, Saito 100, how the heck???
  141. Saito 100, what the Hell Happened Here??!
  142. Need Ca kicker
  143. Canopy for Epsilon 60/90
  144. extreme flight 54e parts!
  145. AeroWorks .90-1.20 Yak-54/Engine
  146. why does my picture of display never change?
  147. Hayes Tanks
  148. funjet aileron solution?
  149. MOKI made in Hungary history
  150. JR9303/2.4 throttle trim won't work
  151. swap meets
  152. Good battery for DX6
  153. DIY Push Rods for AR6400
  154. engine stalls after diving
  155. Blue or Red lock tight
  156. AirTractor 502 Question!!!!
  157. Range Problems Futaba
  158. looking for ideas for securing wing struts on Cub
  159. Flying Wing or Low Wing
  160. Built up engine nacels
  161. @What smoke system for RCS 215 radial?
  162. Monokote on metal?
  163. Incidence question: Cessna 120
  164. Why does a stick type model not fly like a trainer?
  165. RC Tool Box
  166. Ducted Fan Question
  167. Where to buy slimline fueler valves?
  168. H9 Angle Pro battery part #?
  169. Help! Landing gear weak!
  170. Fuel for cox motors?
  171. Removing Robart point hinges
  172. Need advice on a battery Charger
  173. wood or fiberglass?
  174. pusher prop ???
  175. Smoke issues
  176. Dual batteries with a Spektrum Rx
  177. Control suface glue
  178. battery question
  179. Muffler Performance???
  180. JR receiver info needed!
  181. Installing a Du-bro semi-scale tailwheel
  182. incidence meter
  183. Electric conversion for Eagle 2 trainer
  184. tail dragger wheel question
  185. 2.4 transmitter
  186. Wing Incidence
  187. How to get smoke oil out of an airframe?
  188. Good deal or not?
  189. Engine Trouble
  190. Need advise what servos, pcm receiver, and batteries I should by for my new CMP Katana S140
  191. FUEL DRIPPING FROM CARB
  192. Anyone Hum ?
  193. Futaba Servos
  194. Solar Energy question?!
  195. gyro on a plane
  196. Primer for Nelsons paint
  197. Koverall Question
  198. Aero Express RC Trailer question
  199. Did Lustrekote ever make a flat olive drab?
  200. Colored Nitrate Dope?
  201. Slowing a rolling plane!!!
  202. Faulty Receiver???
  203. Throws for a .45 size acrobatic Edge 540?
  204. Removing glue on canopy
  205. Warning
  206. 4 stroke muffler ?
  207. Cutting down props
  208. Mounting engine on firewall...HELP PLEASE!
  209. futaba
  210. Fuel tank size?
  211. GP Cub wing struts
  212. Ideal Wing Loading for acrobatic planes?
  213. Prop balancing
  214. Senior Kadet Plans
  215. Props?
  216. lipo batteries
  217. Need advise with engine selection
  218. glassing fuselage question
  219. Engine vs Tank
  220. Virtually new 46ax bad bearings
  221. CG Help Needed Please !!!!!!!!!
  222. want to buy p51 D
  223. Probllem with airplane roling without cause
  224. Spektrum DX7 Travel Adjust-Hi and Lo rate
  225. Looking for an 8 channel 2.4Ghz radio
  226. Rear exaust engines
  227. Smallest Prop for a Saito FA50?
  228. HK Ball bearing Control horns
  229. supertiger G 2300
  230. Used Zenoah G-62 for $100.00???
  231. Graupner MX 16 IFS Transmiter
  232. ignition battery
  233. Magnum 32 parts
  234. Pacer Z-Poxy
  235. Speed Webra 61 Long Stroke
  236. Engine LOT number ??
  237. Inverted 4 strokes as much trouble ?
  238. Trimming for inverted flight.
  239. Sonic Cleaners - who has used them?
  240. What to use for the ceiling in my Trailer
  241. HELP with outrunner problem
  242. how can an 52cc be this cheap?
  243. 120 Saito
  244. If I had known the difference between anecdote and antidote my friend would still be alive!
  245. RX battery cell size?
  246. Can anyone identify this bipe ??
  247. Engine preservation
  248. the wingsmaker products?
  249. What aircraft is this??
  250. strange crashes
