PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. .75 engine comparison
  2. Thottle setup
  3. Dummy Engine
  4. Control Line
  5. I need help with a lateral balance problem.
  6. Dual Rx battery question
  7. Good flying sites in LA and Pasadena
  8. Landing questions for tail draggers
  9. Charging of Batteries
  10. Finding foam bodies online (UK)
  11. Circuit board diagram Futaba 9c
  12. Turbo glow plugs....what is the advantage, if any?
  13. Need help identifying retracts
  14. Jr 9303 & Spectrum Module Glitch
  15. could a magnet effect my servo's
  16. 4 stroke propellers
  17. controll surface question
  18. Swallow AC/DC2 error
  19. Flying Field Layout
  20. Rx switches.....why sliding/wiping contact?
  21. What causes this??
  22. Help charging battery
  23. Servo push rod types
  24. Binding question
  25. Charging Jack
  26. More ebay woes..
  27. Please identify this carb
  28. Fastest Charge in the West
  29. Two 2.4 gHz RX in one airplane...how's it work?
  30. .91ax?
  31. Glass-filled LG, paint?
  32. Spinner question
  33. Internal battery JR TX
  34. Great Planes skybolt engine
  35. paint bubbles
  36. Parachute Landing for Airplane
  37. Binding two 2.4 receivers
  38. Toggle Switch
  39. Radio interference
  40. Field Plane Bench Dimensions
  41. Making wmv's into dvd's
  42. supercharger on four stroke glow?
  43. What to do with these planes....
  44. Can I repair my muffler?
  45. Posting Pictures Here
  46. Flat olive drab monokote
  47. can you recommend a rx battery?
  48. Alignment Issue
  49. Sullivan smoke pump question
  50. Expert glow driver
  51. Friend
  52. dynaflight mustang 60 and 120 size plans
  53. bubbles on my fuel line??
  54. How do you cut your canopy
  55. SAITO FA 45
  56. HOW IS THE NEW RCU SEARCH FUNCTION WORKING FOR YOU????
  57. OK guys, another "name that plane"
  58. A loaded question.
  59. Enya 60 IIIB engine parts
  60. Dogfighting
  61. Antennae wire inside or out?
  62. Great Planes Revolver
  63. EC6 Battery Charger - review
  64. No BS servo brand comparison?
  65. What are chemicals that can be sprayed on foam to make harder?
  66. 1/4 scale cub servos?
  67. HobbyLite balsa filler
  68. A.R.D. Enterprises
  69. Astro 109 Charger and Lithium Ions
  70. glue remover
  71. planes turns right
  72. Deep drill thru the ribs & install CF tubes?
  73. is it low temp cover?
  74. Ringed or ABC
  75. what is-A123 battery?
  76. Prop Balancer
  77. aileron differential
  78. info on this old saito
  79. NIMH CHARGING QUESTION
  80. im paiying to much?
  81. Monokote or Solarflex
  82. MI-MH charge
  83. Bubbles in fuel line when using Perry pump
  84. K&S sta-flex fuel lines universal gas or glow
  85. saito FA 100 plumbing
  86. am radio
  87. RC Showcase SV50
  88. Torque Starters Batteries
  89. Servo Jitter with 2.4 Fast
  90. Ultra Sport 40 ARF parts
  91. Saito 100
  92. Glow plugs price?
  93. Is this the Right Motor?
  94. Canopy Tinting
  95. RC in south/east PA, southern NJ
  96. Using dual channels for ailerons/elevators
  97. Very quick LIPO Battery question!
  98. GWS servo arms?
  99. What is in a Name ??
  100. Fuel Tank in a pusher prop Jet
  101. Electrical (Current) Question (it's late, i'm slow!)
  102. TX/RX Binding isues
  103. hangar 9 hellcat 60-fueling system
  104. Pica Corsair kit value?
  105. Heres a techical question for you RC Whizzes
  106. Strength of Pull Pull Cable for a 25% Gasser
  107. How do i check my battery?
  108. balance question
  109. what does a baffle do
  110. Chinese resistor spark plugs...can you tell??
  111. JR600 reciever in a radian foam sailplane?
  112. Slowest Online Order?
  113. esc help motor turnung both ways at same time
  114. How do you give advice to students??
  115. Great Planes Airplane Auction
  116. 4 Stroke engine vs. 2 Stroke
  117. Futaba 9Zap pulse width at neutral
  118. CG for Great Planes PT-19
  119. ,twisting servo wires
  120. 4 Battery Selections
  121. Futaba R6014 FASST receivers disontinued??
  122. pitts muffler / performance question
  123. WD 40 for engines
  124. Magnum 91 RPM Question
  125. Advice please: new battery charger
  126. New 7.4 voltHitec HS-7955TG V2 Hi-Res Ultra-Torque
  127. what do you mean balance the elevator?
  128. Throw meter in percents
  129. can i burn my cmx engine like this?
  130. plane crab to right problem
  131. Standard servo for nosegear retract?
  132. RF interference
  133. os 91 f/s
  134. laser cutting
  135. using expanding foam in built up wings
  136. When are you good enough to teach?
  137. Can a yak54(25size) do 3d whit a 40size engine?
  138. Getting real bad aileron Flutter
  139. Wanted, a manual from Harry Higley on set-up and mixing of JR-8103 radios
  140. Help! I messed up
  141. L/F Canopy for Zlin Z50-120 sized
  142. Is my plane underpowered?
  143. Tiger shark 120 AR engine parts??
  144. Fuel soaked fuseladge
  145. 2 part water based epoxy??
  146. Hobbico Volt Watch2 on board monitor
  147. gluing oil soaked balsa ??
  148. servo placement
  149. Magnum XL-70 idle help needed.
  150. Need the Math
  151. shutdown issue-Magnum 91
  152. Scorpion 3008-32 setup help needed ASAP please
  153. Spacer, Drive Washer
  154. low tank
  155. fz Ys63 engine need help!
  156. OK...last one...I swear. What is it? Cap?
  157. ace micropro 8000
  158. Three Line Fuel Tank Setup
  159. 2.4 myths
  160. Need help identifying a couple more planes
  161. Robart High Point Prop Balancer Paperwork Needed!
  162. big scale j3 cub cmp engine!
  163. Attention modelers near Gilmer, TX!
  164. Balsa USA Excalibur RC Kit (Reference)
  165. Piper cub needs work...
  166. USB cables for tx to use flight sims ?
  167. Anyone have a MDS .68 FS Pro Manual?
  168. What plane is this?
  169. OS 120 & OS 91 FUEL TANK SIZES
  170. What do you do with your brand new 2 stroke engines?
  171. 26 guage servo wire
  172. Need advice on how to recover a plane
  173. What Park Flyer model are you flying?
  174. OS 120 4 Stroke Surpass Pumped
  175. Joss Stick ???
  176. fuel proof paint
  177. Concealed Rudder Control
  178. G38 Help
  179. Lights and Rx
  180. ARF building
  181. New generation of engines
  182. OS MAX .61 SFN R/C Heli Engine be used for RC Airplanes?
  183. How much rudder?
  184. Pressure Line to Muffler
  185. Air Tricks??????????
  186. Mechanical Issues & Mysteries - Calling Expert Opinion!
  187. Gas tank size
  188. False firewall/bulkhead for Skybolt
  189. Saito 65 Gasket Set
  190. NitroModels, think twice
  191. Dual Rates - What's your logic?
  192. World Models carbon pushrods
  193. what % is this extra?
  194. EBAY/PAYPAL !! CAUTION!!
  195. 2 seat spitfire
  196. viper hobbies
  197. Can you identify this airplane?
  198. Help repairing balsa planes
  199. How many versions of Futaba FF7 are there?
  200. Servo extensions
  201. Please help me with these Spektrum problems
  202. Owners of GP Super Skybolt - Please vote
  203. Begginer in 3d
  204. ignition
  205. workbench
  206. Who loves touch and goes ?
  207. Seeking turbine Jet
  208. Lanier Strike
  209. Saito 80 engine bearings?
  210. injury topic forum
  211. MOVED: WW2 RC aircraft engine
  212. Any unique pilot figures out there?
  213. 75 mhz radio with 72 mhz crystals
  214. How to tighten up horizontal stab thats removable
  215. Confused on paints
  216. do you change glow plugs at the begining of each flying season ?
  217. glow engine unknown make to me help!
  218. ok can you identify this plane and its designer
  219. binding
  220. Silicone Exhaust Deflectors and 4 Strokes
  221. Best 4S engine for 13.5" 3-blade prop
  222. Cheap and Easy smoke system
  223. 90 red head engine.
  224. saito 170 R3 bearings
  225. this bubbles are going to turn me crazy
  226. saito 1.25 4 stroke
  227. Trouble with a Pitts muffler question
  228. kyosho 188 agwagon
  229. watco clear lacquer in place of nitrate dope ?
  230. on board camera
  231. OS 120 Twin
  232. Foamie hinges help.
  233. Landing Gear Source
  234. How much gap is too much
  235. AR6100 rx
  236. Washington State RC
  237. 9CAP THrottle trim and cutoff
  238. Four Star 40 trim question
  239. cylinder head reattached leaks air
  240. 4 Stroke Rocker Lubrication?
  241. Central Texas indoor flying site?
  242. amphibian aircraft old- real old
  243. Breaking the sound barrier - possible?
  244. JR 9303 with Li Poli Battery
  245. help with gas engine size
  246. Saito 56 exhaust pressure?
  247. Robart retract problem
  248. bomb bay doors
  249. YS 91AC
  250. kyosho gee bee z
