PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. anybody? crrc gas engines
  2. Can you use futaba crystals in a hitec receiver
  3. What sungalss lens color is best for RC flying
  4. aileron servos balsa USA citabria 2??
  5. Custom paint on airplanes
  6. AR9000???
  7. Which glo-plug?
  8. Hiding control horn back plate on aileron
  9. air compressor ?
  10. CG for balsa USA citabria pro
  11. Best Airline Connectors ?
  12. Degrees into inches to setup controls
  13. Cycle NIMI battery packs
  14. vibration with electric powered ultra stick
  15. Power Box 12 battery Charging
  16. What plane is this?
  17. FUTABA 9ZHP ELEVATOR/AILERON STICK NOT WORKING
  18. servo black wire
  19. tail wheel wires
  20. How he HECK do you use the DX6i in trainer mode/Buddy Box?
  21. rc airplanes store?
  22. DOES THE FUTABA 9c has MODEL MACHT?
  23. SIG Aerokote Temp. ?
  24. Wedgy plane from AMA magazine
  25. DX7 - Prog Mix
  26. My basic trainer wont fly
  27. Telemaster40 Alternative
  28. Had to start engine with plane inverted?
  29. Who is responsible for your plane
  30. Need help with receiver choice.
  31. Is it necessary to use after run oil?
  32. Installing Solar Cells on R/C Electric Aircraft
  33. gas in glow fuel jugs
  34. Looking for more pics of this plane F4U Corsair
  35. foam or balsa?
  36. Pusher Props for Electrics
  37. Which Servo do I use>?
  38. spacewalker
  39. Dubro Kwik Fill orientation
  40. Balsa, Spruce, Ply, Hardwood Sources
  41. best retirement rc locations
  42. Don't laugh, these radios are all I have!
  43. Goldberg 60 size Ultimate
  44. Plans/pattern for a wn sock?
  45. Question on Great Planes ElectriFly Triton Jr DC Computer Charger
  46. spacewalker
  47. Looking for fields around Lakenheath, UK area
  48. spektrum dx7 and reciver ar500 PROBLEM!
  49. Any Enya 120 4c parts?
  50. Bob Dively Liquid Mask
  51. PICA T-28 ENGINE PROP QUESTION
  52. Scaled up Ugly Stick for a G-38 Zenoah
  53. scale size issue
  54. Big Sun Dancer receiver ??
  55. Battery hookup question
  56. Servo to Actuating Valve Connection..
  57. Anybody here an artist?
  58. landing problem
  59. CG on Direct Connection Ultimate KAOS
  60. Replacement carb.for old Laser 50
  61. Pulse Jets
  62. propeller size comparisons
  63. Best RC hobby store in Chicago area?
  64. Runway Fabric
  65. Muffler
  66. Center of gravity
  67. Saito 100
  68. Just simple question!?
  69. receiver choices
  70. Easy start for ZG80
  71. gas & zip ties
  72. Spraying Clear Dull Coat On Ultracoat
  73. sunglasses
  74. AMA Ins. Not Valid?
  75. 610c thunder power charger
  76. I have a possessed plane!
  77. Spinner Size for a 14x6 Propeller
  78. discharge the batterys good or useless?
  79. Super Stick .60 advice please
  80. futaba 9c
  81. Flying Fields?
  82. Future of 72Mhz
  83. Is a 90ASP engine to much
  84. What's a good plane for windy conditions?
  85. USING A LIPO PACK FOR RECIBER
  86. chooseing a prop
  87. Graupner Vibration Absorbers - How to mount
  88. How Much Wood
  89. Futaba 2.4g 6 ch VS 2.4g 7 ch
  90. Sepktrum buddy box set up
  91. RX LI-POLY
  92. JR PCM 10X memory battery replacement
  93. y harnes and extension any problem?
  94. klasskoat over nitrate
  95. tractor prop efficiency vs. pusher prop efficiency?
  96. Straightening a tail?
  97. Added Safety
  98. 120 CMP Cessna Gas to Electric??
  99. Wheel Pants
  100. crrc 50 spark plug gap
  101. Magnum120 4S
  102. christen eagle 120 arf up wing
  103. balancing spinners
  104. I amusing a JR XP7202 radio and a
  105. charging this LIPO cell ??
  106. Seagull New Edge 540T 60-90 size
  107. Full Throttle Delay?
  108. How to balance a Skybolt??
  109. Airplane NiCd's, How old is too old?
  110. Is Testors Dull Coat Fuel Proof?
  111. Smoke system oil mixed with fuel...is it OK?
  112. 30% Nitro in planes.
  113. best drill for balsa
  114. Spraying Clear Dull Coat On Ultracoat/Monocoat
  115. Irvine 46 bottom end srew possition
  116. Satio 150s rpm?
  117. ANYONE ORDER FROM CALIBER HOBBIES?
  118. JR Servos compatible with Futaba RX
  119. Spektrum AR7000 antenna
  120. pictures of your workshop
  121. where to buy decals?
  122. Dubro snow skis
  123. needle valve extension
  124. Lipo use for Sarter Battery ?
  125. After Run Oil - Conflicting Advice????
  126. Engine mounting tips
  127. Shorten Antenna length?
  128. Flaperon vrs spoileron
  129. coreless dremel
  130. Carbon fiber LG question
  131. perry pumps
  132. corregated control surfaces
  133. Question about iron-covering?
  134. Prop spinners
  135. Where is a good place to buy Resistor Spark Plugs ?
  136. photos
  137. Seawind balancing
  138. Good Fuel Deals?
  139. Abell RC Servos
  140. Sig Somethin' Extra ARF 40
  141. Saito fa30s third nipple??
  142. Which Retract Servo
  143. Pneumatic retract air hose size???
  144. 12X5 Prop on a ST 51?
  145. cap 232 nitro plane, taild heavy or nose heavy?????
  146. Fly Cam One Question
  147. Throttle Servo is getting interference with gas engine?
  148. sig spacewalker
  149. Which size air tank for retracts???
  150. Using a Saito 56 right angle adapter.
  151. Help me find out what kind of plane this is
  152. Jr XP783 screen problems
  153. Why a Larger Size Plane?
  154. Tru turn adapter for saito 91
  155. Convertible plane
  156. Spring Air Nose Gear
  157. Monokote fix
  158. How to delete one of your own posts?
  159. Traxxas 4-tec 3.3 trade for Team Losi Truggy
  160. A maths question
  161. Nitro
  162. Is my RX Battery still good
  163. Substitute for Zip-Ties
  164. Where do i get a Macchi 205 arf or kit?
  165. Bishop, Ca.
  166. H9 cub with o.s. 52 fs???
  167. OS FT-160 twin cyl in GP Skybolt - Questions
  168. smoke system
  169. Whos is responsible?
  170. Garage sales - do they work??
  171. satio 100 prop
  172. Thunder tiger 91 FS rpm
  173. "OLD" Transmitter platform
  174. foam coating
  175. RF interference
  176. Irvine 61
  177. What to do with old transmitters.
  178. RCU Twilight Zone
  179. Lusterkote clear over Coverite Fabric
  180. Does Hobby City (Hobby King ) have a postal address ?
  181. I am Baffled, Don't have a Clue!
  182. Glow Plug - polarity matter?
  183. kit cutters
  184. Handling Field Maintenance
  185. Assan X8u 2.4Ghz Module for any PPM radio
  186. F-22 Jetlegend
  187. Spectrum Receiver type usage
  188. Fixed Landing Gear tips
  189. airplane suggestion
  190. Flight mode changes throttle control input?
  191. Plane ID
  192. Has any one heard of akro pro 180 ?need cowl
  193. Are there grants available to RC clubs
  194. FlyCamOne2 questions.....anyone have one?
  195. How to make a canopy
  196. Club Meetings
  197. 6v Rec Batteries
  198. Fail safe & W-Fly radio compatibility
  199. Eagle 63 gc location
  200. Help with cowling
  201. new to the plane forum's with ??
  202. But....but...but HONEY!
  203. fuel-where to buy online
  204. Magnum 4 Strokes
  205. gorrilla glue on CA hinges?
  206. A123's and futaba receiver with hitec 5645mg servos
  207. saito 80 info size to a 60 2 stroke
  208. Chord Question??????
  209. servo lead chokes, are they useful
  210. Morris Hobbies Balsa Nova CG?
  211. Question - Aeolianmotor 2825- KV5200 brushless motor
  212. plane weight to engine sizing chart.
  213. TRAINER CORD ( jr and futaba) they work together?
  214. Building a new workshop need list
  215. Paypal payment problems
  216. PAINT QUESTION
  217. Looking 4 PDF manual 4 Sig Astro-hog
  218. cermark 5:1 reduction gear startere
  219. RX, Retract & OnBoard Glow Batteries
  220. Older Sr. Falcon Engine Choice
  221. DX7-Throttle cut?
  222. Old School Field Box
  223. Redline racing oils 100% ester based oil....good for our glow engines???
  224. blHow do you get a prop PERFECTLY balanced?
  225. What servo should I use on my OS160 throttle?
  226. Cordless plane starter
  227. Nose heavy Ultra Stick 60
  228. looking for RC shops in HK
  229. Concealing Battery Switches
  230. Hytec Syn Receiver
  231. Kraft Gyro
  232. What is the smallest Nieuport kit for a Zenoah G20?
  233. Old Glow Fuel
  234. decathlon
  235. Standard nitro tank work for gas?
  236. Reciever battery good after winter!?
  237. Mystery Plane "Sweepy 40"
  238. Spektrum Dx6e not working right all sudden!!!?
  239. O.S engine question
  240. Changing Radio Frequencies - Tower Hobbie Support says no
  241. p.v.a. or c.a.
  242. Help with Painting Koverall
  243. Arc Modelfly Beaver
  244. Do people actually buy these?
  245. My NEW Lipo Sparks !!!!!!!!!!!!
  246. CA & Accelerator Storage
  247. Runtime with a Saito 125 and a 14oz tank? Anyone Know?
  248. SMC KQ2H23-04 *r KQ2H01-03
  249. spacewalker
  250. Long wires on servos
