View Full Version : Questions and Answers
- Need the Math
- shutdown issue-Magnum 91
- Scorpion 3008-32 setup help needed ASAP please
- Spacer, Drive Washer
- low tank
- fz Ys63 engine need help!
- OK...last one...I swear. What is it? Cap?
- ace micropro 8000
- Three Line Fuel Tank Setup
- 2.4 myths
- Need help identifying a couple more planes
- Robart High Point Prop Balancer Paperwork Needed!
- big scale j3 cub cmp engine!
- Attention modelers near Gilmer, TX!
- Balsa USA Excalibur RC Kit (Reference)
- Piper cub needs work...
- USB cables for tx to use flight sims ?
- Anyone have a MDS .68 FS Pro Manual?
- What plane is this?
- OS 120 & OS 91 FUEL TANK SIZES
- What do you do with your brand new 2 stroke engines?
- 26 guage servo wire
- Need advice on how to recover a plane
- What Park Flyer model are you flying?
- OS 120 4 Stroke Surpass Pumped
- Joss Stick ???
- fuel proof paint
- Concealed Rudder Control
- G38 Help
- Lights and Rx
- ARF building
- New generation of engines
- OS MAX .61 SFN R/C Heli Engine be used for RC Airplanes?
- How much rudder?
- Pressure Line to Muffler
- Air Tricks??????????
- Mechanical Issues & Mysteries - Calling Expert Opinion!
- Gas tank size
- False firewall/bulkhead for Skybolt
- Saito 65 Gasket Set
- NitroModels, think twice
- Dual Rates - What's your logic?
- World Models carbon pushrods
- what % is this extra?
- EBAY/PAYPAL !! CAUTION!!
- 2 seat spitfire
- viper hobbies
- Can you identify this airplane?
- Help repairing balsa planes
- How many versions of Futaba FF7 are there?
- Servo extensions
- Please help me with these Spektrum problems
- Owners of GP Super Skybolt - Please vote
- Begginer in 3d
- ignition
- workbench
- Who loves touch and goes ?
- Seeking turbine Jet
- Lanier Strike
- Saito 80 engine bearings?
- injury topic forum
- MOVED: WW2 RC aircraft engine
- Any unique pilot figures out there?
- 75 mhz radio with 72 mhz crystals
- How to tighten up horizontal stab thats removable
- Confused on paints
- do you change glow plugs at the begining of each flying season ?
- glow engine unknown make to me help!
- ok can you identify this plane and its designer
- binding
- Silicone Exhaust Deflectors and 4 Strokes
- Best 4S engine for 13.5" 3-blade prop
- Cheap and Easy smoke system
- 90 red head engine.
- saito 170 R3 bearings
- this bubbles are going to turn me crazy
- saito 1.25 4 stroke
- Trouble with a Pitts muffler question
- kyosho 188 agwagon
- watco clear lacquer in place of nitrate dope ?
- on board camera
- OS 120 Twin
- Foamie hinges help.
- Landing Gear Source
- How much gap is too much
- AR6100 rx
- Washington State RC
- 9CAP THrottle trim and cutoff
- Four Star 40 trim question
- cylinder head reattached leaks air
- 4 Stroke Rocker Lubrication?
- Central Texas indoor flying site?
- amphibian aircraft old- real old
- Breaking the sound barrier - possible?
- JR 9303 with Li Poli Battery
- help with gas engine size
- Saito 56 exhaust pressure?
- Robart retract problem
- bomb bay doors
- YS 91AC
- kyosho gee bee z
- anybody? crrc gas engines
- Can you use futaba crystals in a hitec receiver
- What sungalss lens color is best for RC flying
- aileron servos balsa USA citabria 2??
- Custom paint on airplanes
- AR9000???
- Which glo-plug?
- Hiding control horn back plate on aileron
- air compressor ?
- CG for balsa USA citabria pro
- Best Airline Connectors ?
- Degrees into inches to setup controls
- Cycle NIMI battery packs
- vibration with electric powered ultra stick
- Power Box 12 battery Charging
- FUTABA 9ZHP ELEVATOR/AILERON STICK NOT WORKING
- servo black wire
- tail wheel wires
- How he HECK do you use the DX6i in trainer mode/Buddy Box?
- rc airplanes store?
- DOES THE FUTABA 9c has MODEL MACHT?
- SIG Aerokote Temp. ?
- Wedgy plane from AMA magazine
- DX7 - Prog Mix
- My basic trainer wont fly
- Telemaster40 Alternative
- Had to start engine with plane inverted?
- Who is responsible for your plane
- Need help with receiver choice.
- Is it necessary to use after run oil?
- Installing Solar Cells on R/C Electric Aircraft
- gas in glow fuel jugs
- Looking for more pics of this plane F4U Corsair
- foam or balsa?
- Pusher Props for Electrics
- Which Servo do I use>?
- spacewalker
- Dubro Kwik Fill orientation
- Balsa, Spruce, Ply, Hardwood Sources
- best retirement rc locations
- Don't laugh, these radios are all I have!
- Goldberg 60 size Ultimate
- Plans/pattern for a wn sock?
- Question on Great Planes ElectriFly Triton Jr DC Computer Charger
- spacewalker
- Looking for fields around Lakenheath, UK area
- spektrum dx7 and reciver ar500 PROBLEM!
- Any Enya 120 4c parts?
- Bob Dively Liquid Mask
- PICA T-28 ENGINE PROP QUESTION
- Scaled up Ugly Stick for a G-38 Zenoah
- scale size issue
- Big Sun Dancer receiver ??
- Battery hookup question
- Servo to Actuating Valve Connection..
- Anybody here an artist?
- landing problem
- CG on Direct Connection Ultimate KAOS
- Replacement carb.for old Laser 50
- Pulse Jets
- propeller size comparisons
- Best RC hobby store in Chicago area?
- Runway Fabric
- Muffler
- Center of gravity
- Saito 100
- Just simple question!?
- receiver choices
- Easy start for ZG80
- gas & zip ties
- Spraying Clear Dull Coat On Ultracoat
- sunglasses
- AMA Ins. Not Valid?
- 610c thunder power charger
- I have a possessed plane!
- Spinner Size for a 14x6 Propeller
- discharge the batterys good or useless?
- Super Stick .60 advice please
- futaba 9c
- Flying Fields?
- Future of 72Mhz
- Is a 90ASP engine to much
- What's a good plane for windy conditions?
- USING A LIPO PACK FOR RECIBER
- chooseing a prop
- Graupner Vibration Absorbers - How to mount
- How Much Wood
- Futaba 2.4g 6 ch VS 2.4g 7 ch
- Sepktrum buddy box set up
- RX LI-POLY
- JR PCM 10X memory battery replacement
- y harnes and extension any problem?
- klasskoat over nitrate
- tractor prop efficiency vs. pusher prop efficiency?
- Straightening a tail?
- Added Safety
- 120 CMP Cessna Gas to Electric??
- Wheel Pants
- crrc 50 spark plug gap
- Magnum120 4S
- christen eagle 120 arf up wing
- balancing spinners
- I amusing a JR XP7202 radio and a
- charging this LIPO cell ??
- Seagull New Edge 540T 60-90 size
- Full Throttle Delay?
- How to balance a Skybolt??
- Airplane NiCd's, How old is too old?
- Is Testors Dull Coat Fuel Proof?
- Smoke system oil mixed with fuel...is it OK?
- 30% Nitro in planes.
- best drill for balsa
- Spraying Clear Dull Coat On Ultracoat/Monocoat
- Irvine 46 bottom end srew possition
- Satio 150s rpm?
- ANYONE ORDER FROM CALIBER HOBBIES?
- JR Servos compatible with Futaba RX
- Spektrum AR7000 antenna
- pictures of your workshop
- where to buy decals?
- Dubro snow skis
- needle valve extension
- Lipo use for Sarter Battery ?
- After Run Oil - Conflicting Advice????
- Engine mounting tips
- Shorten Antenna length?
- Flaperon vrs spoileron
- coreless dremel
- Carbon fiber LG question
- perry pumps
- corregated control surfaces
- Question about iron-covering?
- Prop spinners
- Where is a good place to buy Resistor Spark Plugs ?
- photos
- Seawind balancing
- Good Fuel Deals?
- Abell RC Servos
- Sig Somethin' Extra ARF 40
- Saito fa30s third nipple??
- Which Retract Servo
- Pneumatic retract air hose size???
- 12X5 Prop on a ST 51?
- cap 232 nitro plane, taild heavy or nose heavy?????
- Fly Cam One Question
- Throttle Servo is getting interference with gas engine?
- sig spacewalker
- Which size air tank for retracts???
