PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. A123's and Futaba FASST Receivers
  2. Futaba 7C, old vs new
  3. Old Sanwa Receiver
  4. Painting Props
  5. Sportster 40 - Which Engine - OS 40FP or OS LA 46?
  6. OmniModels
  7. I really loved RCR BUT
  8. Travel Plans
  9. favorite magazine?
  10. Battery Upgrade for Futaba 12FGA
  11. pilatus
  12. GMS motors
  13. disassembly of glue joints
  14. Problems with Fedon Aircraft
  15. OS 48 Surpass
  16. ultrastick setup
  17. Slodering wheel collars
  18. CA on canopy
  19. Great Planes Super Skybolt Power Question
  20. Sheeting Wings with Titebond or White Glue
  21. Epoxy vs CA+ for tail feathers
  22. G-10 FIBERGLASS
  23. Futaba 7C 2.4GHz Air Radio System
  24. Kits sitting in the box...
  25. Kyosho dc3 fuslage
  26. Hobby Shop Simulators
  27. Hobbico Servos & Hitech
  28. Bed Slide
  29. green spinner
  30. Enamel paint thinner question
  31. Spektrum AR6300 problem?!?
  32. power redundincy question. plz help!!
  33. Name that Plane!
  34. What's the best way to make Panel lines on a ARF?
  35. Lateral balance Extra 260 .90
  36. Balancing a Towerhobbies uproar
  37. Flying in Saudi
  38. wings n things hobby store in gladesville
  39. stinger 60 arf
  40. Need new ideas for something fun
  41. New here with question Futaba FP-77uaps PCM 1024 Radio
  42. different engine mount location
  43. JR radio pricing
  44. retractable tail wheel set up question
  45. Easy Sport 40 as a taildragger
  46. Great Planes Skybolt
  47. What maintaince should be done to get plane ready for 2009 flying season
  48. Pressure Fitting/Bisson Muffler
  49. How to keep trim attahed?
  50. counter rotaring
  51. video
  52. Uh Oh!!!!!!!!!!!!!!
  53. Evolution .46NX Will it work?
  54. Anyone else have 2.4gzh spektrum glitches and issues?
  55. Epoxy & micro balloons, how too??
  56. Radio Setup on a Vtail Predator B UAV
  57. 3DAIRPLANE
  58. charging my futaba batt. packs with tekin charger
  59. cross wind landing
  60. OS .20 4 stroke muffler question?
  61. Repainting oil soaked balsa/ply.
  62. Decalage?
  63. What camera to mount on an airplane?
  64. HOW TO GET BOW/WARP OUT OF COVERED AILERON
  65. do you listen to music while building.
  66. charging batteries
  67. NiCad and NiMh battery packs where to buy
  68. 72 hz convert to 2.4Ghz
  69. JR Tx battery and diode
  70. Contacting 3dx Hobbies??????
  71. Does it hurt to cut a prop down
  72. Harry Higley's "Bipes" book
  73. Where to buy wing bags?
  74. vertical stabilizer repair
  75. hobbycity.com
  76. Are these two RF modules interchangable?
  77. Engine Question
  78. Trying to remember what a plane was called?
  79. Powering a TF GS P-47
  80. Bugatti RC Airplane
  81. HXT 12K SERVOS.... ARE GOOD?
  82. seagull ultimate biplane
  83. Plastic to metal glue
  84. P-51 kits
  85. New Ultra Stick 60 factory mods.
  86. Do you usually have to share the sky?
  87. How many guys to you fly with?
  88. Dummy Engine Installation
  89. Got a question about fitting a cowl.
  90. RCU Video Reviews
  91. dauphin Island al
  92. First Gas
  93. Art Tech Wing Tiger
  94. OS Max 35 H carb needed
  95. RCR going belly up?
  96. stand-offs
  97. circuit board
  98. vibration
  99. A.M. Or FM.Whats the big diff?
  100. can i use an airbrush kit to paint rc models?
  101. In Flight Video Setup
  102. Lithium Rx Battery help
  103. WHAT ARE THE CG'S
  104. what size prop for os 91
  105. Getting scratches out of MONOKOTE ??
  106. How "fuel proof" is butyrate dope?
  107. Photo post help needed please
  108. 2.4 receiver question
  109. Foam Glider to RC Conversion
  110. Seeking help about Whip Aerial
  111. Brushless motor
  112. 40 or 60
  113. Wanting something different
  114. Stab installation on my new ARF....
  115. F-16 bryon
  116. painting aluminum
  117. switching recievers
  118. Futaba Super 7 help
  119. Thrust Angle???
  120. What RC plane do you recommend?
  121. Engines
  122. Custom fees in Canada
  123. Ailerons on a Kadet Sr.
  124. What is the deal pop ups on RCU
  125. Don't ya just love it when - -
  126. PROPS??? 1, 2, or 3 blades????
  127. where to buy discontinued funtana x100
  128. Retract landing for 108" PBY,
  129. OS Gemini 160 FT: Tank Pressurizing
  130. Warbird Decals
  131. FUTABA GYROS - GY401 VS GYA 350,351,GYA352
  132. Futaba Rx
  133. Lost Airplane Locator
  134. Matching paint for Ultrcote
  135. GEE BEE Y TAILWHEEL WHEELPANT
  136. Can't get CG right?????????
  137. engine maintenance after extended storage
  138. What is this plane
  139. what is the cg for a dave patrick 40 bi plane
  140. futaba receivers
  141. What type of glue for Dubro flat plastic hinges?
  142. First Gas Airplane
  143. OS 40 MAX FP
  144. GP Ultra Sport ARF, would you buy it?
  145. Can CA be thinnned (with debonder) ?????????
  146. PROP PITCH SPEED AND THRUST
  147. Servo extension cords
  148. Epoxy dries brittle
  149. SkyRaider preformance
  150. Spectrum Module Upgrade Question
  151. OS MAX .46 SF
  152. Hangar 9 Guts PNP Models and major price hike!
  153. what airplane is this?
  154. Need info on two older/vintage kits
  155. What is it Need CG
  156. F4U Corsair Parts ?
  157. Midwest Aerogloss
  158. best price on spektrum recievers??
  159. Question on mufflers for ST S-75
  160. Deflection Meter Design
  161. tightening up covering
  162. Autogyro Flight Simulator
  163. Approximent Scale help?!
  164. 4* 40
  165. Flight Packs
  166. What size prop. would be good for GMS 76.
  167. composite fuse.
  168. engine on f-22 raptor pts
  169. control line conversion to rc
  170. OS 40 MAX-H problem
  171. Large scale rc setup
  172. os.91fx (RINGED) what prop?
  173. Four Star side thrust
  174. Two batteries in one plane Question
  175. JR wiring
  176. 2-56 and 4-40 threaded rods
  177. Question about receiver crystals
  178. HELP/ Centering Engine on Firewall
  179. Futaba radio giving trouble??
  180. battery position
  181. Radio Question
  182. Hanging RC Plane from Ceiling Advice
  183. Radio trouble?
  184. Recovering over exsisting cover
  185. Sig Rascal 40
  186. Zenoah G-26 Muffler
  187. best transmitter battery?
  188. Soldering Question
  189. Goldberg Decathalon Windscreen?
  190. 2.4
  191. A/C Power for Receiver
  192. modelflight cyclone 90 rc plane manual
  193. Pin on drive washer , os .90 2-stroke
  194. OKC Hobby Shop
  195. 4.8volts or 6volt Rx
  196. Header Tanks
  197. Do You Know The Name Of This Plane?
  198. aligning aileron with wing
  199. SCREENSAVERS? I AM LOOKING FOR SOME RC SCREENSAVERS
  200. K/B prop driver
  201. Ideas Needed for Travel With RC Equipment on Comercial Ariline
  202. electric retracts for bob cat size 50
  203. 60E Pitts Python from hobbycity.com
  204. Rubber-band aircraft design
  205. Maybe not the right forum but.............
  206. Covering Films???
  207. AMA numbers on aircraft
  208. push rod set up's
  209. O.S. 61 SF what prop?
  210. KMP Beaver cockpit kit
  211. Hobbico 180 starter
  212. Servo specs?
  213. 9C programming for air retracts
  214. Workbench Height
  215. MVVS .26 engine setup
  216. HELP Balancing Pac Aero Gee Bee 120 y
  217. Byron originals pitts
  218. covering
  219. O.S. FX 46
  220. Robart Retracts
  221. When do you use a 2 or 4 stroke
  222. balancing props
  223. wood props help !
  224. Conversion to gas
  225. CLUB FUEL PURCHASES
  226. Spektrum DSP60 Servo Shudder/Jitter
  227. Gas prop on an elecric plane?
  228. DECALS DECALS
  229. Help with ski mount.
  230. Epoxy didn't hardenYuk
  231. How are the hobby shops doing
  232. Matchbox Problem
  233. I bought a new plane.
  234. JR Reciever Compatibility
  235. How can I extend my throttle arm?
  236. Shipping an Airplane?
  237. Car gas vs. plane?
  238. Transfer letter
  239. Need a plane for OS 32 SX engine
  240. Hand Crafted 1-of-a-Kind RC Planes
  241. Anyone have a Funtana 90 Cowl?
  242. Engine block repair
  243. Please help out one arm club member
  244. painting covering film monokote ?
  245. Plans anyone? Electric
  246. Zenoah G-26 Prop Hub
  247. Looking for prop.
  248. prop nut [ alloy ]
  249. real time application
  250. tube bender
